Author Topic: Motor mount?  (Read 11384 times)
Motor mount?
« on: June 02, 2008, 07:45:44 pm »
I need some ideas for a motor mount for my springer.
I'm replacing the shaft and prop tube but now it doesn't line up with the motor.
Ideas please?
catengineman
Re: Motor mount?
« Reply #1 on: June 02, 2008, 07:50:11 pm »
You say that your motor will not line up with the new shaft assembly you have fitted,
can you not use a double  U J set-up this will give you a greater scope of where the motor can be mounted, and this in turn opens up for even more ways to mount said motor .
R,
boatmadman
Re: Motor mount?
« Reply #2 on: June 02, 2008, 08:35:46 pm »
motor mount on my fire springer:
An alternative is to use a piece of aluminium plate, bend to right angle and drill for motor mount and drive holes, and holes for holding down screws.
Ian
barryfoote
Re: Motor mount?
« Reply #3 on: June 02, 2008, 08:39:52 pm »
Martin....wrap motor in cling film.....Big dollop of P38 or similar in bottom of springer. Put motor to coupling and prop shaft and gently squeeze the motor into the P38. Perfect alignment....When dry, remove cling film...Done.
toesupwa
  • USA'd ex Brit
Re: Motor mount?
« Reply #4 on: June 02, 2008, 10:27:56 pm »
Try this thread for some ideas on mounts..  O0
http://www.modelboatmayhem.co.uk/forum/index.php?topic=8322.0
Re: Motor mount?
« Reply #5 on: June 02, 2008, 10:31:41 pm »
I think the P38 is easiest....
Has anyone used one of these or know where I can buy something like these?
HS93 (RIP)
  • I cannot spell , tough
Re: Motor mount?
« Reply #6 on: June 02, 2008, 10:40:18 pm »
I think you may find you need the matching prop shaft as they are not 8mm standard , but astek do an ally one if you want one let me know
peter
Re: Motor mount?
« Reply #7 on: June 02, 2008, 10:44:30 pm »
PropShop sell these motors directly mounted on the shaft too.
HS93 (RIP)
Re: Motor mount?
« Reply #8 on: June 03, 2008, 12:13:03 am »
SHG also sell them .
HS93
Re: Motor mount?
« Reply #9 on: June 03, 2008, 02:28:39 pm »
I've been doing a bit of searching on the old interweb, found a couple of ideas...
I like the way it's adjustable even after installing it.
http://www.offshoreelectrics.com/proddetail.php?prod=adj-540-mount
I could file a couple of slots for the screw holes to make this one adjustable...
http://www.pandanmodelboats.co.uk/acatalog/Motor_Mounts.html
But I think this is the easiest way to ensure good motor / prop shaft alignment. - Who sells them?
HS93 (RIP)
Re: Motor mount?
« Reply #10 on: June 03, 2008, 02:32:15 pm »
Re: Motor mount?
« Reply #11 on: June 03, 2008, 02:54:10 pm »
HS93 (RIP)
Re: Motor mount?
« Reply #12 on: June 03, 2008, 03:06:58 pm »
I thought they where one of your sponsor's they may give you to do a quick build for the next Mayhem meet next year :embarrassed:
I think you still have to put a motor mount bracket to hold the weight  plus you will have to change tubes
Hs93
Re: Motor mount?
« Reply #13 on: June 03, 2008, 03:08:05 pm »
If you use one of the coupler housings Martin you really need to fix it to some sort of bulkhead otherwise you will get twisting of the prop shaft with the torque of the motor.
HS93 (RIP)
Re: Motor mount?
« Reply #14 on: June 03, 2008, 03:11:03 pm »
snap
Re: Motor mount?
« Reply #15 on: June 03, 2008, 03:35:52 pm »
HS93 (RIP)
Re: Motor mount?
« Reply #16 on: June 03, 2008, 03:39:41 pm »
I was editing mine to include it when you posted so you would not have seen it/
HS93
Re: Motor mount?
« Reply #17 on: June 03, 2008, 03:48:12 pm »
Support the motor is easy enough,  it's the alignment that crucial.
Many is the time I've asked someone at the lake;
 "What sound system is that?"
  "What sound sytem? It doesn't have one!"
   "What's that noise then?"
     "The coupling."
      "................Oh!"
HS93 (RIP)
Re: Motor mount?
« Reply #18 on: June 03, 2008, 04:03:32 pm »
use a double coupling
 Graupner Couplings
Graupner Double Coupling
 or a Deans one
Re: Motor mount?
« Reply #19 on: June 03, 2008, 04:11:57 pm »
Hs93
I wonder is I could solder one up out of brass....... :)
Re: Motor mount?
« Reply #20 on: June 03, 2008, 04:13:50 pm »
That's defeatist talk!  ::)
Re: Motor mount?
« Reply #21 on: June 03, 2008, 04:35:24 pm »
     "The coupling."
There are one or two cures for that noise:
1. Stand further away  {-)
2. Wear ear plugs.    ;)
Re: Motor mount?
« Reply #22 on: June 03, 2008, 04:40:24 pm »
     "The coupling."
If you use the Graupner coupler housing and the ordinary Graupner coupling WHATS YOUR PROBLEM !  :-\
