Oh dear.....I responded back to a different website
...try Google Ian..........a few details will be available & photographs of the kit are there..............Derek...[in a senior moment]
Hi PD's....very strange.......I just read a posting from Kiwi...about an eBay win..........Warrier MKII A frame steam engine.........went to respond but it has disappeared
___________________________________________________________________________________________________________________________________________________________________
Designer: J P Bertinat
Star Rating:
A modified and improved version of Edgar T Westburys twin cylinder double-acting steam engine (M7) with 3/4in bore cylinders and 3/4in stroke. (Vols.146-147).
Sheet 1 General arrangement on non-reversing engine.
Sheet 2 Cylinder and end covers; piston, piston rods and crossheads; valve chest and covers, slide valves and valve rods, cylinder standard.
Sheet 3 Baseplate, crankshaft and bearings, connecting rod, eccentric rod, strap and sleeve, flywheel.
Sheet 4 Boiler feed pump assembly and details.
Sheet 5 Steam inlet manifold, inlet connector, exhaust manifold, exhaust tee, union and nipple.
Sheet 6 Arrangement and assembly of reversing gear.
Sheet 7 Reversing gear details, special components for single cylinder engine.
Complete set of 7 sheets.
