Oiler mentioned G-scale loco engineers exploding gas tanks by heating them with hot water. He may be referring to my experience. I've never seen another like it, at least on the active US G-gauge live steamer forum. I posted the details over on mylargescale.com, this was several years ago:
http://www.mylargescale.com/forum/topic.asp?TOPIC_ID=35013What Happened, and the Solution:
1) the loco's tank did not explode, it bulged and split a seam. There was just a hissing, no explosion or flame, etc.
2) the tank was filled with propane/butane mix sold for campstoves (the tank was designed for butane only, though this mix is used by many US steamers in cold climates, and even indoors at the famous annual Diamond Head steamup in Louisanna).
3) the calculated tank pressure (given the measured temperature of the hot water + gas pressure tables) was at all times less than the tank's test pressure certificate,...so why the problem?
4) answer - the problem was not excessive *Gas* pressure, but excessive *Hydraulic* pressure. The tank had been filled plum full of the liquid mixture before I closed the valve (and then added hot water to the loco tender to keep the tank warm; I run in freezing temps here in Montana). The tender was made, by the manufacturer, watertight just for this purpose, namely warming the tender mounted butane tank. But, and this is the problem, if you warm liquid it expands, generating hydraulic pressures in the 1000+psi range (my farm tractor for instance, runs it's hydraulic system at 2000psi). No model tank can withstand 1000psi, so naturally my tank bulged and split a seam.
5) the solution - don't fill tanks plum full of liquid. Propane dealers say you should not fill an outdoor propane tank (home heating) more than 80% full. Always leave a space in the tank for the gas phase. If the gas phase is present, then pressure can never exceed the pressures found in gas/temp tables (which are what the tanks are designed to bear). But if the gas phase is eliminated by filling the entire tank, then pressures rise precipitously with heat, and no tank can sustain them.
6)after the incident, I examined my other loco's butane tanks. Even though I never heated them, a couple mounted on the footplate near the boiler (by the manufacturer) had bulges. It is common to mount loco butane tanks near the boiler so that they stay warm enough to maintain butane gas pressure. For small locos with small tanks it is common to fill them plum full. And apparently, the residual boiler temperature during refueling servicing was enough to make these tanks experience hydraulic-level pressures w/o my realizing it (and w/o causing a leak).
After the incident, I switched to pure propane firing of my locos. I could run in freezing temperatures with no problem, the tank entirely unheated (it rode in a gondola car, no where near the heat of the boiler). The only time I ever had a problem was when the propane gas regulator froze due to frozen condensed moisture from the air, the symptom was lack of gas regulation, leading to the fire going out. Normally Montana winters are so dry this is not a problem, but this particular, high relative humidity, sub-freezing temp day was anomolous. If you shift to propane firing, you will never have a butane sag in your fire. You can't use your original butane tank for propane (propane produces 3x the pressure of butane), so the system must be re-engineered. I can give details if desired.
