Author Topic: cirrus receivers  (Read 2835 times)
brianc
cirrus receivers
« on: April 11, 2010, 07:28:54 pm »
Hi Gents.
Got one for all you knowlegable guys out there.
I bought one of those cheap 40 meg Cirrus receivers for an small yacht I`m building,checked the connections and theres nowt for battery pack connection.
Designed for a Becc system I think,question is,can I input a battery pack in any way?
Remember,your talking to a complete R/C moron here,so be gentle guys %)
gingyer
Re: cirrus receivers
« Reply #1 on: April 11, 2010, 07:32:09 pm »
brian,
 I am sure if you put the battery into the
servo ports it will work fine. :-))
Failing that and smoke come out I am wrong {-)
brianc
« Reply #2 on: April 11, 2010, 07:34:51 pm »
Thanks big guy,
Remind me not to ask you for advice in anything life threatening %% {-)
By the way...I here your going to Dortmund %)
gingyer
« Reply #3 on: April 11, 2010, 07:43:17 pm »
did you hear I was going to dortmund
I wonder who could of told you  %)
 :D :D
« Reply #4 on: April 11, 2010, 07:50:54 pm »
hi Big Bry and Ging
What happened at the South Shields show?  I didnt see the faces ... anyway, the Cirrus RX - normally I use a Y lead plugged into Channel 4 (one side of the Y lead battery - the other side number 4 servo).
If you have a look at the end of the Cirrus receiver, where the servo plugs fit - you will see there is notch down the left hand side which takes the Futaba plug.
Black outside pin - negative
Middle pin - red - positive
outside pin - white - for owt ya like  :-)) sometimes we use it as a signal.
Hope this helps,  did the border guards keep you both away from the North East  %) %)
brianc
« Reply #5 on: April 11, 2010, 08:05:50 pm »
Thanks Bluebird,Appreciate the help mate  :-))
I`m afraid I could`nt make it down,the missus told me I had more important things to do(more important than a show?????? silly wench >:-o)
I know Ging is saving his groats for the Dortmund show next week(If they let him in the country that is %%)
I`ll be going to most of the remaing shows this year,so we`ll hopefuly meet up at one of them mate :-))
brianc
« Reply #6 on: April 11, 2010, 08:17:39 pm »
A BIG thank you to both of you :-)) :-)) :-))
Success first time,one very happy chappy O0
« Reply #7 on: April 11, 2010, 08:30:01 pm »
Big Bry - hi there
Cirrus RX are a good little receiver.  I have 2-3 of them...and you can get a good range out of them.  Over 100 miles...make that yars or even yards... %% %% tired after the show  :o
The only downside with them is that you sometimes split the case when inserting the servo plugs - they are sometimes tight (the plugs fitting into the case that is) and it parts the case - but a bit of lecky tape around the casing solves this no bother.
aye
john e
bluebird
brianc
« Reply #8 on: April 11, 2010, 08:40:57 pm »
Thanks for the tip John.
It`s all gone together with no problems mate and will be left in the yacht permanently :-))
A great Forum this,problems solved in a few minutes..what more could you ask for ;)
