Author Topic: Model Boat from Paper Mache  (Read 5773 times)
CERES
  • Proud to be a part of the Model Boat Mayhem Forum.
« on: June 15, 2010, 10:09:02 am »
 :-)I have made a balsa plug of a rowing boat and I now want to create the actual boat from paper Mache.
Having tried using torn newspaper and flower/water paste, when fully dried it does not come away from the plug without tearing.
Anyone got any suggestions or do you think a plug could be formed from Plasticine.
Many thanks,
Ceres.
Nige52
Re: Model Boat from Paper Mache
« Reply #1 on: June 15, 2010, 10:22:29 am »
Make sure your plug is highly polished on top of the 2 pack gloss paint you should be using, then give the plug a mist spraying of Trex or another sprayable cooking oil.  ok2
As you're making paper hulls and not fibreglass, the plug surface doesn't need to be like a mirror, but it helps.
Nige
dreadnought72
« Reply #2 on: June 15, 2010, 10:34:04 am »
Another option: wrap the plug with clingfilm.
« Reply #3 on: June 15, 2010, 11:24:54 am »
.... or a wax.
Drkomen86
« Reply #4 on: June 15, 2010, 11:55:11 am »
Vasaline always works for me  :-))
« Reply #5 on: June 15, 2010, 01:12:44 pm »
Any of the above should work, but remember that flour/water paste was what was used pre-polycell to fasten wallpaper to walls, so a layer of something is needed.
andrewh
« Reply #6 on: June 15, 2010, 05:23:20 pm »
All the release ideas are excellent :} It is Mayhem after all!
Suggestion for glue:  use diluted emulsion paint - its an acrylic and when hard is waterproof thereafter
and with a gold-coloured* coat
*my style advisor buys matchpots - I get to use them up
Came out very well, but I confess that I used a layer of epoxy/finishing cloth for the final  (outside) layer
In fact you can use any glue, so long as you waterproof well enough
andrew
CERES
« Reply #7 on: June 15, 2010, 07:13:24 pm »
 :-)) :-))Just as I thought. If you want an answer to a question on models, Non better than members of Mayhem Forum. Thanks a lot Guys.
Ceres.
dave301bounty
« Reply #8 on: June 15, 2010, 08:00:41 pm »
That looks great ,very well done .
Page created in 0.126 seconds with 22 queries.
