Author Topic: I am looking for information on Rowing boats mechanisms  (Read 16664 times)
HS93 (RIP)
  • I cannot spell , tough
« on: January 28, 2007, 09:21:55 am »
I am looking for information on Rowing boats mechanisms. I've got the modelboat plans for "Rowey" but it is very basic, any help would be appreciated.   Peter
White Ensign
  • Limits must be limited!
Re: I am looking for information on Rowing boats mechanisms
« Reply #1 on: January 29, 2007, 09:52:39 am »
Peter, on one of the biggest shows in Germany there was a modeler group who had built some canoes with Indians sitting inside, doing the rowing. If you want to I will have a look and be back to you, to find out some informations....
Jörg
When God created planet earth, he made it with 75% of water. Bet he had the modelboaters on his mind!
tobyker
« Reply #2 on: January 29, 2007, 06:24:25 pm »
I remember some plans for a rower - they were fine if you were, like the builder, a VTR repairer, since almost all the bearings and joints he used were from junked VCRs. Very frustrating. I must build a trireme, one of these days, or maybe a penteconter if I don't feel strong enough. Actually, what I really want to do is a steam trireme.
maninthestreet
« Reply #3 on: February 01, 2007, 06:42:08 pm »
rowlocks?  ;D
chugbug
« Reply #4 on: February 01, 2007, 07:53:49 pm »
Hi Peter, there is  an article in Marine Modelling International dated January 2005 entitled Two Men in a boat written by Chris Chambers,he used clutch and gearbox from an RC tank. Hope this helps,
Dave.
EXBoat
« Reply #5 on: February 05, 2007, 04:39:38 pm »
Have a look at this web site www.crabfu.com lookfor steam powered row boat, good pictures of mechanisms
HS93 (RIP)
« Reply #6 on: February 05, 2007, 05:40:10 pm »
Thanks for the infomathion, a couple of years ago I saw a Pirate in a rowing boat at one of the cheddar steam events. it was quite complicated but that is the type of mechanism I'm looking for .all I can remember is that it had two clutches..
Peter
tobyker
« Reply #7 on: February 05, 2007, 10:41:22 pm »
It's all very well to drive the oars from a totally circular motion, as in the crabfu rowing mechanism, but for realism the horizontal movement should be more than the vertical movement. This of course causes problems in the model if it rolls - really you need a feedback mechanism on the end of each oar to keep it a constant height above the water on the back stroke. When I was at school this was called an oarsman.
HS93 (RIP)
« Reply #8 on: February 06, 2007, 12:02:23 am »
yep that was what the rower on the one I saw did and what I want to build  Peter
tobyker
« Reply #9 on: February 06, 2007, 10:22:46 am »
In that case I reckon you've got to separate the "lift and drop" from the "pull and push" actions. This would not be too difficult inside a trireme, where you can have one oar frame to connect all the looms to, and could probably be done with bellcranks, but is more difficult in a wee man. You can always cheat and use perspex pushrods. If I had'nt got a complete rebuild of the fleet on (and I've just found the sails for a wishbone schooner project in the garage), I'd have a go myself. I've always found solving problems more fun than perfect scale, but that's probably because I can't be bothered with detailing. Each to his own.
johno 52-11
    • lifeboat Models
« Reply #10 on: February 06, 2007, 05:35:03 pm »
I have been doing some design work for a project to build a 10 oared pulling Lifeboat. Part of this has been around turning a rotation from a motor into a rowing stroke. As I will have 5 Ora's each side I will be running them as two sets from independent motors. All the Ora's on each side will be connected together. What I have come up with so far is a rotating disk under the deck with a rod that goes through a pivot in the deck and the end of the rod connected to the Ora with more of the rod above the pivot you get a oval motion as in the diagram below. If you want to try and keep the Ora out of the water on its back stroke you could look at gimbling the mechanism along the fore aft line this would allow the boat to rock and the Ora's to stay level.
cbr900
  • Mayhem is the Only Forum!
    • Roys Hompage
« Reply #11 on: February 07, 2007, 03:05:27 am »
Are yu looking for something like this..........
Roy
HS93 (RIP)
« Reply #12 on: February 07, 2007, 08:24:09 am »
Thanks Roy. It may well be ,what I'm after is one that mimics full size ,and that one may do have you got any info on the mechanism
  Thanks Peter
cbr900
    • Roys Hompage
« Reply #13 on: February 08, 2007, 10:45:23 am »
Peter,
At this time I only have a few photos, but I intend to get the plans from the builder as soon as he returns to the country, as he is in the States at this moment......
Roy
alan colson
  • I Just Dabble In Model Boats
« Reply #14 on: February 14, 2007, 08:44:02 pm »
have a look at the shows catagory alfold 2005 photos by john bass, also dabblers model show photos by guy bagley, there are some great rowing boats built by mike sheppard from south wales.
mike is booked in for this years charity show at alfold on 2nd/3rd june, come along and meet him, i know he wil spend a lot of time showing you how it all works
alan colson
« Reply #15 on: February 17, 2007, 09:24:55 pm »
I have been to brighton model world today 17/2/07, mike sheppard is there and has 7 models on display all operated by various rowing devices if you are able to get there he is displaying again 18/2/07.
If you cannot make it I have an email address for his son.
HS93 (RIP)
« Reply #16 on: February 17, 2007, 10:33:27 pm »
Thanks Alan for the help, Unfortunately I live on Merseyaide so its a bit far for tomorrow , thanks for the offer I will be in touch. And thanks to all the other people who have helped .Peter
Ps. Alan can I ask if you wold edit your post and remove your e-mail address I would not like to feel responsable for you getting any unwanted mail
HS93 (RIP)
« Reply #17 on: February 24, 2007, 03:47:11 am »
Does anybody know who this boat belongs to or has any pictures of the mechanism  or can get any , I took these a few years ago at cheddar , worked very very nice
alan colson
« Reply #18 on: February 24, 2007, 05:40:35 am »
hi peter, it's alan again, i'm not certain but there was a pirate in a rowing boat which may have been the one in the photos, i believe it was a member of the eastbourne club, again many miles from home in your case
rathikrishna
« Reply #19 on: January 15, 2011, 02:35:04 pm »
Ohh great topic...
hmsantrim
« Reply #20 on: February 26, 2011, 02:38:49 pm »
Hi peter.
               I have the plans for the Graupner TINA rowing boat.  It shows the rowing mechanisms.  I have put up a couple of pix to give
                 you an idea of what is there and to see if a copy of some sort may be required later.
                                                  cheers Frank.
sb_maharana
« Reply #21 on: June 29, 2013, 08:23:00 am »
This is a nice topic and helped me a lot building a rc rowing boat. Complete the mechanism part....... here is the video.
http://www.youtube.com/watch?v=BXe-I-c0L7A
« Reply #22 on: June 29, 2013, 10:58:09 am »
Well done.
Keep us posted on further developments. I know I will be interested in this as I'm sure, will others.
ken
Big Ada
« Reply #23 on: June 29, 2013, 05:12:16 pm »
This is an own design by a clever Member of my Club.
http://www.youtube.com/watch?v=ETQhQmWvIr0
Len.
Page created in 0.148 seconds with 21 queries.
