Bloobs, to answer your question regarding those stringers, the original plan calls for just the ones that you see in the above photos. But now that you mention it, I reckon it's not such a bad idea to maybe add one more between each side of the keel and outer chines - especially now that each bulkead is placed farther apart. The hull will be skinned with 1.5mm ply so adding the extra stringers makes perfect sense. Thanks for the heads-up.
I'm not sure how best to notch the grooves for the added stringers at this juncture. I have one of those Dremel-type Proxxon drills with came included with several cutting disc. Maybe I could use that to gently make those notches where needed (unless you have a better solution, of course).
Although, just for the record, the hull is already surprisingly strong with just the deck edge stringers and chines in place. Nevertheless, I shall seriously consider your suggestion - even if it's only to allow the outer skin to come into contact with more surface area/stringer material (if you get my drift).
Regarding your other questions, I found a nifty pin drill on the Cornwall Models site. Also, I did after all manage to find the appropriate rudder/rudder post from the same place. I ordered the drill/rudder at the same time as the mini palm planer.
Unfortunately, the link that you PM'ed me regarding the props were for M4 threads, which is a bit of a bummer because I need M5 size. Hence I'm still looking for a source of plastic ones.
Thanks once again for your help and advice.
By the by... Workroom photos were not Photoshopped. Just bog-standard 38mm kitchen countertops and cheapo kitchen cupboards. The one nice luxury is the insulation material behind the wall/floor/ceiling panels. Peter HS93 recommended "Superquilt" insultion from Screwfix. A tad more expensive, but well worth every penny.
Besides, what's so bad about your own workroom anyhow? From where I'm sitting it looks nice and snug in there. Some nice quality works emanates from that shop of yours - makes most of us dead jealous.
Mave:
Ref Verso: See?... I told you it was the battery didn't I?
A? A?
And yes - I'm hearing you regarding beginning with a 12v supply.
