Author Topic: Topaz rudder servo linkage  (Read 3261 times)
logoman
« on: August 07, 2011, 02:08:19 pm »
I had a some problems with the rudder/servo linkage on the Topaz.
I needed to cut the decking that is above the rudder to get access.
Is it usual not to have access to the tiller?
JJS
Re: Topaz rudder servo linkage
« Reply #1 on: August 07, 2011, 07:01:49 pm »
According to building instruction , der Seekadett has the same problem, no access to ruddertiller. I forsee a hatch in the aft deck to have access to the rudder
JJS
« Reply #2 on: August 07, 2011, 10:46:44 pm »
I really dislike any design that insists that servicing/repair should not be possible, since that is one thing that separates toys from models.  On some of my smaller ones, where an internal linkage was not going to be advisable, I have gone above deck, and painted the bits bright red.  This invariably renders them invisible, something to do with the fact that something so blatantly inappropriate really must be on the real thing.  If the top of the rudder tube would be above the waterline with the tiller below deck, a hatch is the way to go, either disguised into invisibility, or made so obvious that it "must have been there" on the real thing.  If it is anticipated that access is going to be very occasional, and that part of the deck is liable to get wet, then a hatch, possibly of a sacrificial nature, sealed down with water resistant, but easily frangible adhesive, will do the job.
« Reply #3 on: August 07, 2011, 10:54:49 pm »
The basic rule should be that if it goes in you should be able to get it out regardless of what manufacturers might seem to suggest.
« Reply #4 on: August 07, 2011, 11:02:09 pm »
..and that having got it out, it should be possible to get it in again %)
It should be possible to re-phrase that.
« Reply #5 on: August 07, 2011, 11:06:48 pm »
I think that is implicit....
Page created in 0.014 seconds with 22 queries.
