Author Topic: continuously moving servos  (Read 3402 times)
manx venture
« on: January 11, 2012, 11:31:11 am »
can you get a steering servo to work so if u hold the handle hard over it continues to turn until you release the handle, same going the other way? thinking of ideas to make a working r/c winch, instead of a rudder attatched to the servo, attatch a drum n string so when you push the lever left or right it will wind in or out
Watchleader
Re: continuously moving servos
« Reply #1 on: January 11, 2012, 12:46:34 pm »
The answer to your question is yes !!   O0  O0
You can use a modified standard servo but it's a pain to modify,  >>:-(  >>:-(  but they are available from Ebay and pretty reasonable cost about a fiver each.
Item No 270771434050 (for 2)
I used these to operate the lee boards on Lady Daphne - see build blog.
« Reply #2 on: January 11, 2012, 01:04:37 pm »
I've moved your post here because this an interesting subject.  Detailed info has been printed but it's buried below.
I'm in need of this info to enable me to automate some features on my Gry Maritha. (opening doors and Hatches etc.)
Ken
manx venture
« Reply #3 on: January 11, 2012, 01:44:21 pm »
thanks men! thats great news, will order some of them and get on with making my winch!
wartsilaone
« Reply #4 on: January 11, 2012, 02:27:37 pm »
I found this. It might be of use.
Ali
Corposant
« Reply #5 on: January 11, 2012, 02:33:24 pm »
Hi Manx Venture
It looks as if they are just what you are looking for. There is no mention of the deadband in the spec. but as they are designed for the job, it should be reasonably wide. (When I was planning to do the same as you for my Puffer, I tried modifying servos but because the deadband was very narrow, it was virtually impossible to get them to stop completely!)
I ended up taking the circuitry out of the servos, just using the motors and controlling them with ACTion Electronics P44 units. In other words I didn't need the servos at all! (I only stayed with them because I had already mounted them under the winch)
« Reply #6 on: January 11, 2012, 03:30:16 pm »
Ali
Have you lost it after you found it Ali ?
wartsilaone
« Reply #7 on: January 11, 2012, 05:37:41 pm »
Sorry, That's what happens when you rush.
http://www.seattlerobotics.org/guide/servohack.html
Ali.
« Reply #8 on: January 11, 2012, 09:36:50 pm »
Have a look on http://www.modelboatmayhem.co.uk/forum/index.php?topic=16349.250  reply 269, about half way down page 6.
« Reply #9 on: January 12, 2012, 12:48:30 pm »
Ali.
Thank you Ali.  Wonderful details. I've printed them off and will be having a go.   :-)) :-))
Page created in 3.313 seconds with 22 queries.
