Author Topic: tigershark ep  (Read 1862 times)
noodlz
tigershark ep
« on: July 10, 2012, 03:42:58 pm »
hi all,i have a tiger shark ep an my son has diconnected the 3 wiring clips from the receiver in the boat can any one help as to which way they go back,one is red with two wires in it an the other two are black with each having 3 wires
Re: tigershark ep
« Reply #1 on: July 10, 2012, 06:21:30 pm »
Sound like the servo wires have been pulled out.
When they go back in they must be the correct way around. Any chance of a picture please before you guess !!!
XV Pilot
Re: tigershark ep
« Reply #2 on: July 10, 2012, 08:41:48 pm »
Does this help?
The red plug with the two wires is the battery lead - the pic shows where it goes.
The two black plugs with three wires each are for the servos. Most receivers have the centre socket for the steering servo and the end one for the throttle servo, so identify the wire that leads to the rudder servo, plug it in the middle socket, and see if the rudder responds the way it should. If it does, plug the last remaining lead in the last remaining socket, and you are good to go.
However if the rudder moves when you move the throttle control on the transmitter, move the rudder servo lead to the last socket, and plug the throttle servo into the middle one.
noodlz
Re: tigershark ep
« Reply #3 on: July 11, 2012, 11:35:46 am »
thanks for the help,all fixed now,dont suppose you could suggest a direct replacement motor for this model could you,this one is under powered and so many different motors available
Page created in 0.02 seconds with 21 queries.
