Thanks for the inputs.
Sometimes standing too close to the model can cause twitching, walk away (about 10 yds) with everything switched on and see if that stops the twitching.
I did sort of try that - but only the other side of the room.
Have you 'earthed' the motor cans to the propshafts ?
Not yet, but the shafts are not in the tubes anyway - the test was with free motors.
You should never switch your Tx off with the motors still running as they will go into failsafe, if it's set up wrong it may go to full power instead of to stop,
I was deliberately checking to see what happens if the tx goes off.
have you also tried servo reversing to stop the twitching ?
Not sure how that can help as things would end up backwards.
keeping boats in a cold damp shed
It's all new stuff being assembled in a warm, dry spare room.
The T4U is cheap, but works well. Cheap, however, means no quality control, and I have had T4Us with quite poor soldering on the wires to the pots. If the connections in the Tx are iffy, this could cause your problem.
Yes, I am aware of this and before using the tx/rx I took them apart and remade a number of iffy looking joints (all on the tx in fact). But that's not to say I haven't missed some. (In fact there are a couple of small stickers on the tx board with hand written arrows that appear to point at joints that look remade, so I think there may actually be some testing and remedial action done somewhere.)
Have you used the T4U with other servos and found it to be solid?
I only have the one servo. I got a decent spec Hitec unit, rather than a 'bargain' unit, in the hope that it would be reliable.
Having said all that I have made progress, though it is a very strange tale, to me anyway.
I decided to put the mixer/esc into 'tank' mode, which effectively changes it to a pair of unmixed escs, so I could better see what was going on.  This meant using another r/c channel and also removing the the rudder servo lead from the mixer/esc unit and putting it direct into the rx. Much to my surprise all the twitching stopped!
However, I then found that when 'stopped' the port motor (only) was continuously 'stepping' about twice a second until enough forward/reverse was applied for it to run continuously. Starboard was fine. This didn't seem to be an erratic, interferency thing - it seemed fairly regular, though not clockwork.
To find out if this was being caused by the rx or the esc I swapped the port and stbd r/c leads in the rx module.  Everything then behaved perfectly - no twitching, no stepping of either motor (just the motors were now the wrong way round).  Swapping the rx plugs back again results in the port motor stepping again when it should be stopped. WTF?
As a final test I physically swapped the motor wires so the port esc was powering the starboard motor and vice-versa, just in case it was something about the motor that was causing it.  The stepping remained on the port esc (making the stbd motor move).
All of this suggests to me that the stepping is some subtle interaction between the rx and mixer/esc, and that the twitching was perhaps also caused by it - maybe some sort of feedback loop - but that is beyond my knowledge of these things.
I also did another test by powering off the escs, so I was running the rudder alone as I did a couple of weeks ago. Seems fairly OK - just a tiny bit of jitter, but nothing like the twitching I was getting earlier. I am wondering now if that is what I had two weeks ago - memory can be a terrible liar.
I bounced all this off Dave at ACTion, but the only other suggestion he had was to try a different means of powering the rx module in case it was a volts stability issue. I did that but with no change in symptoms.
I then put everything back into mixer mode, with the rudder servo on the mixer/esc, and the serious twitching returned as before.
Having played on the bench with the mixer control I must confess to being not very convinced - not that the principle of mixing isn't OK, but I just don't like the lack of control over each 'engine'. So using tank mode instead seems attractive and also works around this twitch problem.
To get around the stepping problem I've taken the pragmatic option and reversed the P&S plugs in the rx to get rid of the stepping and then swapped the in and out connections of the esc modules to keep the external fuses and LEDs matching the port and starboard drives. As the miser/esc unit is mounted on it's side anyway the 'wrong way roundness' of these connections is not obvious.
It all seems to work OK now and the final job this evening was to mash up a centreing arm and spring for the 4th tx direction, so both sticks self-centre vertical and horizontal. Oh, I had to reverse one of the channels on the tx as well.
I also retested the tx fail with this setup and now only the port motor goes to full chat; the stbd stops. Not ideal, but only half as bad as both going flat out :)
