Pages: 1 2 3 4 [5]   Go Down
Author Topic: bait boat help please  (Read 42773 times)
eddieneil22
  • Model Boat Mayhem great site
Re: bait boat help please
« Reply #100 on: July 03, 2014, 04:42:15 pm »
2
still learning more and more
eddieneil22
« Reply #101 on: July 28, 2014, 04:24:50 pm »
hello again
just finishing the boxing out of the inside of my bait boat,still to rub down and resin it,
then the bit iam not looking forward too,the electrics.
                          neil
« Reply #102 on: July 28, 2014, 04:38:01 pm »
Nice to see you haven't given up .
Answers to electrical problems
will be furnished by experts on the
forum if accompanied with a bottle
of malt whisky  :} :} :D
eddieneil22
« Reply #103 on: July 28, 2014, 04:49:12 pm »
small bottle ned,
ive brought all the workings of my boat,my main question would be,what thickness of wire do i use to wire up the electrics.
         neil
« Reply #104 on: July 28, 2014, 05:05:45 pm »
I always use the thickest silicon covered wire that
will fit the connectors.
It is very flexible and easy to use.
If you put your motor type, ESC and battery
up someone will have the answer.
eddieneil22
« Reply #105 on: July 28, 2014, 05:51:55 pm »
hello ned,
i have two viper marine 15 plug n play,battery are two 12v2,3 ah,the motors are two mabuchi 555,i am working a rudder from my servo,and the tipping of my bait box on channel five switch on my planet t5 transmitter.
             neil
« Reply #106 on: July 28, 2014, 06:00:02 pm »
Same size as the ESC main wires
Should be OK
eddieneil22
« Reply #107 on: July 28, 2014, 06:06:43 pm »
thank you ned,
         neil
« Reply #108 on: July 28, 2014, 09:13:52 pm »
Just remeber to DISSCONNECT one red wire on the ESC wires otherwise you will cook the esc just use a small screwdriver to get the pin out of the plug and simply tape it up....reasopn for this is simple,each esc supplies a 6v power to the reciever
eddieneil22
« Reply #109 on: July 29, 2014, 11:44:03 am »
thank you dave,
i will make sure i remove one red wire,.
           neil
eddieneil22
« Reply #110 on: August 10, 2014, 04:01:24 pm »
hello,
would this setup be ok,i would be adding a y lead to both receiver plugs and removing one red wire from one of the receiver plugs
                      neil
« Reply #111 on: August 10, 2014, 04:28:34 pm »
If you are going to steer it on the motors then a y lead wont be needed.
Just plug your Rx leads into the channels for the two up and down sticks
(having disconnected one red from esc}
eddieneil22
« Reply #112 on: August 10, 2014, 05:17:40 pm »
hello ned,
iam now having a rudder,and useing the motors as power just to run.
« Reply #113 on: August 11, 2014, 08:21:02 pm »
Adding a Y lead would do the job especially as y9ou are using a rudder....PERSONALLY I wouldnt use that make of esc's at all but I WOULD use a ACTion P94 combined ESC/Mixer ...
WHY...................No Need to use a rudder
.........................You can turn the boat round on it's axis
.........................Defo more reliable then the ESC's you are using.
WHY do I say this ...........well it's simple really ......Having Built  and repaired more bait boats than I care to rember where reliability is needed there is only one compny's product I would use......just rebuilt a bait Boat last week that had cost the owner in excess of £500 and it was a so called British built boat that was full of inferior electronics.........filled it with ACTion stuff and now I got a further 3 to do
eddieneil22
« Reply #114 on: August 12, 2014, 02:19:31 pm »
thanks dave,
i havent much money to buy anything st the moment,i try this setup and maybe in the future upgrade,as this is my first build.
                    neil :-)
Pages: 1 2 3 4 [5]   Go Up
