had to repair one stripped bung on the top of the boiler. And the bung was damaged as well and I did not feel comfortable threading up a size. This required the big propane torch to keep the boiler body hot and the little oxy-map torch to do the fine work. New sight glass and a few fittings. Came out well and holds 190 psi with no leaks that I could detect. 200 psi gauge, hard to see in the flash. No rupture either! When you buy stuff off ebay, there is always the chance that it is a not a good unit, but this one worked out well. The original work was done very nicely. Two internal water tubes and water jacket down to the bottom mud ring. Just have to lag it and build a base. Holds about 850 ml.
