Exactly as boat captain says, I have a scoop behind the port prop on my Trent, this pushes water around the escs when under way, in my case it then exits back through the keel, I also have a solenoid valve plumbed into the cooling system which is controlled by a float switch, this taps off cooling water to fill the vaporiser tank as and when it is needed.
Alex
