Author Topic: Sealer  (Read 2319 times)
3838Derrick
Sealer
« on: April 03, 2017, 07:08:54 pm »
Is there a sealer that you guys use when screwing fittings into a boiler?
Re: Sealer
« Reply #2 on: April 04, 2017, 06:37:17 am »
3838Derrick...............
Model boilers appear to range from 1.5 Bar to 5 Bar working pressure
A boiler with a relief valve setting of 3 Bar will produce steam at ~~135 degrees C on your boiler steam discharge valve
The Technical Data sheets for these Loctite type products  are limited to ~~120 degrees C, however to remove a fitting.....heating to ~~160 degrees C may be required
Long before these Loctite products were developed and marketed, copper shimmed washers were used for sealing boiler valving.......
If an ill-fitting height occurred with the alignment of a steam valve fitting ........some times that RED Stag    >>:-(jointing compound was used
This would however never be recommended in a model valving seating.....
KNO3
Re: Sealer
« Reply #3 on: April 07, 2017, 10:05:39 pm »
I recommend Teflon tape. Much easier to use, remove if necessary and clean up than Loctite, for boiler fittings.
rhavrane
  • Steam passionate collector
Re: Sealer
« Reply #4 on: April 08, 2017, 09:23:08 am »
Bonjour,
Personally, I use a combination of Loctite 577 and Teflon, specially when screw threads or viroles are thin because I already broke several of them screwed too hard (and hard very relative). It is not obvious at all to stop a leak, and going on screwing is not the best solution an example here at 1'00 : https://www.youtube.com/watch?v=t-EI3i1Bhcc .
The worst leak is not the steam one, but the gas one, gas is the fluidest product we manipulate and the most dangerous one  !
Raphaël
Waz
Re: Sealer
« Reply #5 on: April 08, 2017, 11:11:43 am »
Normally I use Teflon tape and a copper washer, however if the fitting needs to be in a certain orientation then I use a copper compression washer. Where the faces are really bad you can use Loctite 574 but be warned this does take 24-48 hours to cure so don't expect to be able to put it on screw the fitting in and then go back an hour later and steam.
tonyH
Re: Sealer
« Reply #6 on: April 08, 2017, 01:59:41 pm »
Loctite 272 works well and has a service range of up to 200 degrees C but needs heating up to remove it.
Tony
Page created in 0.036 seconds with 21 queries.
