Author Topic: Anton gas tank  (Read 1205 times)
pipercub1772
Anton gas tank
« on: February 02, 2021, 03:38:43 pm »
Hi i have a Anton small gas tank  2"dia x 2"vertical, Can anyone help with the nut and cone and pipe size for the Anton gas valve my usual  3/16" is to large and also anyone in the uk that could supply nut and cones and pipe to fit or any type of reducer to get around the problem Kind regards Allan.
DBS88
Re: Anton gas tank
« Reply #1 on: February 02, 2021, 04:39:24 pm »
Allan you could try Jerry at Clevedon Steam, I have found him to be both very knowledgable and helpful about different manufacturers threads and fittings and he will even make up a special fitting for you if need be.
KBIO
Re: Anton gas tank
« Reply #2 on: February 02, 2021, 06:35:44 pm »
Hello!
Below is the type of fitting that you need to connect an Anton gas tank.
The pipe supply is a 2mm one. Brass or copper do the job.
Note: never use an 0'ring on the burner itself. Generally it is a 5x50 mm or 6x75 mm type with a metallic cone => Metal against metal on the burner.
They are very easy to machine down if a friend can do it for you. ok2
Put a pic of your tank, it will help !
Good luck! :-))
Regards.
pipercub1772
Re: Anton gas tank
« Reply #3 on: February 02, 2021, 08:52:08 pm »
Thanks for both replies  being 76 I'm not good at all with uploading pictures and thanks for the diagram ill try and obtain something of that size,
Kind regards Allan.
Page created in 0.132 seconds with 17 queries.
