Here's Moday's build only a few pieces near the stern  just four parts which took over 2 hrs this afternoon,I make sure the pieces are all smooth and I give them a dry fit to make sure they fit
100% I make sure they are numbered to put in the right place then glue one at a time remove all waste glue onto the next one and so on press and hold into place then out come the clips etc as you can see I use alot on everything one on have a good look making sure everyone is set and level upright and all areas across then its time to tidy up and sit back and have a good look, and look at the next stage to do ,just two parts to put on at the ends both sides have to bend into shape so they are into warm water  will shape them later then leave to dry overnight  time now is 14.35pm  cuppa then 40 winks back tomorrow.
