Author Topic: Desco shrimp trawler  (Read 8113 times)
B.B
  • B.B
« on: January 16, 2025, 08:30:28 am »
Latest model on the go (actually 1 of 2)started both of them during October 24 , this one is of an American Desco shrimper design  just  52 x 16 x4.75 inch's . The keel ,deadwood , stem areas are of  Colonial teak, the frames from an old pine bed base, the stringers 12 x 3.5 mm  ,ribs 6 x4 mm & planking are beech from kevin Rasmussen ( Kevin gave me a loan of his spare Proxon table saw , in the photo , have been using that to cut the ribs and decking strips of beech only) and the 2 transom  sections of Red cedar from Stuart Cribb, cheers.  :-)) ......
Brian  B
steve mahoney
Re: Desco shrimp trawler
« Reply #1 on: January 17, 2025, 09:58:30 am »
Interesting to see the tools you're using. What's the well used bench saw? The blue one?
Mark T
« Reply #2 on: January 17, 2025, 08:53:23 pm »
Ooh I'm gonna enjoy this one - Looking great so far Brian and the little Proxxon table saw is good tool but I have found them noisy.
Looking forward to seeing this progress and all of the carpentry tips I can learn  - good luck with your build mate  :-)) :-)) :-))
B.B
  • B.B
« Reply #3 on: January 22, 2025, 09:44:49 am »
Hi Steve, that saw is a 15 inch planer 'Carba-Tec' made in Taiwan , we bought that early 90's to do a job which never happened ,so it sat in the shed till a few years ago I cleaned it up and respray (different blue) so have only started to use it in the last couple of years...Hi Mark, for the size of them they are noisy ,but found if I am going to cut more than a couple of strips I will hook the vacuum to it ,that solves the noise of it as you can't hear it for the noisy vacuum cleaner  and keeps it cool other wise it cuts out.
With these photo's all the stringers in and garbed planks attached then steaming the ribs and letting them set in the jig, the last shot showing her all ribbed up , and the start of the beamer ( which I will put up) cheers ..
Brian  B
B.B
  • B.B
« Reply #4 on: January 24, 2025, 01:53:45 am »
Hi there , this next section of photo's planking ( 4 mm) her , glued and screwed , after the screws removed on each frame as usual used bamboo dowels, then after filling with Plasti Bond and sanding ,she was given a good coat of wood preserver ,cheers . :-)) .......
Brian  B
Mark T
« Reply #5 on: January 24, 2025, 04:07:35 pm »
4mm planks - now that is very difficult
B.B
  • B.B
« Reply #6 on: January 26, 2025, 08:52:18 am »
Hi Mark , actually with her shape no problems planking her as they are fairly fine towards the bow area and being a full deadwood no hollow heal the planking runs through tho the stern area easy as. With these photo's  took her off the jig, then for the bases for both models put the Camphor cut offs through the thicknesser also a section of Red cedar, which will also be used with the bases , before starting on the shelfing and deck beams ,pre installed the running gear , servo frame and ESC bases ( later 2 not shown), installed the aft knees and the bow knees, also gave her a coat of wood preserver ,then about 4-5 days later she was painted out with X40-Bond Coat....Cheers  :-)) ....
Brian  B
Mark T
« Reply #7 on: January 26, 2025, 03:15:25 pm »
Amazing work Brian - here's a confession; when I saw that you had used different type headed screws for the motor mounting my OCD popped out and went into over drive - sorry mate  :embarrassed: :embarrassed: {-) {-) {-)
KNO3
« Reply #8 on: January 26, 2025, 07:16:05 pm »
Beautiful work, congratulations!
It would make a great hull for a nice steam plant.
« Reply #9 on: January 26, 2025, 11:11:42 pm »
Your techniques and choices of material are amazing B.B. I know this build will be another beauty - following eagerly. :-)
Cheers,
NickelBelter
« Reply #10 on: January 30, 2025, 02:12:22 am »
As much as I love your normal Australian fishing boats, these two new builds are really interesting for being something different!
B.B
  • B.B
« Reply #11 on: February 01, 2025, 01:25:42 am »
Thanks Guys ,,the screws Mark ,was that the 2 different types holding the motor on it's end plate ? they are only temporary :). This section pf photo's deck beams and lift out sections done and dusted , then pre fitted the 1.5 mm deck ply prior to attaching the sponson's ( Tassy Oak), then attached the 2 sections of deck ply before strip decking her, I used a section of Colonial Teak for the centre strip , then the remainder of decking is of 1.2 mm beech with the black cardboard strips in between and the joints. Fitted the front hatch combing and also the w-house combing, before a coat of wood preserver (next the bullwark post) ...Cheers   :-)) .....
Brian  B
B.B
  • B.B
« Reply #12 on: February 25, 2025, 08:13:55 pm »
Hi there, some more of the shrimp vessel build. The main hatch lid , installing the staunchon post & planking the bulwarks , with these vessels they would line the insides of the bulwarks.  For the w-house base placed a deck combing down first then another which will be the base of the w-house & foundation for the side studs.Cheers  :-)) ......
Brian  B
B.B
  • B.B
« Reply #13 on: March 05, 2025, 01:48:28 am »
Hi there, back with some more of the shrimp trawler, with the construction of the w-house used Burmese Teak, Beech ,Colonial Teak & Ply, the last 2 photo's of the tie up cleats made from Colonial Teak. Cheers  :-)) ...
Brian  B
Mark T
« Reply #14 on: March 07, 2025, 06:52:09 pm »
It really doesn't get better than this - A perfect trawler in miniature  :-))
« Reply #15 on: March 07, 2025, 08:44:22 pm »
beautiful workmamship and lovely wood working skills. love it.
B.B
  • B.B
« Reply #16 on: March 09, 2025, 08:17:50 pm »
Hi There, Thanks guy's, some more of the w-house ,construction of the karle raft ( still has to have the ropes attached after painting), showing the pivoting brackets for the base of the trawl arms and the main boom, decided to make it separate then attach it to the lower section of the mast ( easier), I don't know how others solder lugs etc in close quarters to each other without the heat messing it up and profound words slipping out ,with this I could submerge the areas already soldered in water otherwise I wrap wet rags around already soldered ares while soldering close by , well take care ,cheers. :-)) ......
Brian  B
« Reply #17 on: March 09, 2025, 09:05:42 pm »
How many of us would just cut simple square pieces of ply and use these to hold motors etc down in the hold where no one ever sees them, and yet you lavish as much time and effort in your mountings as you do the visible parts of your builds!
You NEVER cease to impress Brian.
B.B
  • B.B
« Reply #18 on: March 16, 2025, 08:55:10 pm »
Morning all, thank you Ballastanksian  :-)) . Next section of the build construction of her trawl booms or I think the yanks call them outriggers ? from Tassy oak and brass, cutting the rungs for the aft ladder which connects at the top of the boom to the top of the bulwarks above the transom. I'm not sure what they call this frame it is solely for tying off ropes etc situated behind the main winch, I find it pays off to spend a little bit of time bracing off something like this before soldering . Cheers  :-)) .......
Brian  B
JimG
« Reply #19 on: March 17, 2025, 11:55:42 am »
Based on the days of sail a name could be a pin rail (as in a rail for belaying pins).
Jim
Dundee Model Boat club
B.B
  • B.B
« Reply #20 on: March 26, 2025, 08:38:41 am »
Hi there,  thanks Jim,,next section constructing the trawl board racks , then the Northill anchor and the anchor bow davit, then the construction of the trawl board (49 parts per board including the chain spiders , not shown there)  cheers.. :-)) ....
Brian  B
B.B
  • B.B
« Reply #21 on: April 05, 2025, 03:17:11 am »
Hi There, next section was the construction of the 'Stroudsburg' winch ,going through some of the gears that a fellow modeller gave a few years back trying to find the the right sizes etc ,the hand operated wire guides ,and the finished product . Cheers .  :-)) ......
Brian  B
PierreP
« Reply #22 on: April 05, 2025, 04:30:23 am »
Very nice work your trawlers are very different from French trawlers :-))
B.B
  • B.B
« Reply #23 on: April 12, 2025, 12:20:47 am »
Hi PierreP, this one also is a bit different to our Australian trawlers, being an American shrimp trawler they have a different rigging set up known as the Texas rigg ,the base of the trawl arms are connected to the lower section of the main mast , and they dump the produce onto the deck and sort off the deck , and stil do to this day ??... Next section, attaching all the foot rungs to the mast and boom, this time I pre rigged her ,used the usual s.s tracer wire and mostly s.s chain (Chinese) the magnet doesn't attach to it so that's a plus  O0 ??. Then the painting, the hull had a coat of wood preserver then 2 undercoats , fun begins with the painting of all the bits n pieces , cheers.. :-)) ....
Brian  B
B.B
  • B.B
« Reply #24 on: April 21, 2025, 10:31:37 pm »
Hi there, will put up 2 post this morning  ,,,showing most of the bits n pieces finished off ,then after spraying her bottom installed her running gear then onto the rigging . cheers  :-)) ....
Brian  B
Page created in 0.081 seconds with 21 queries.
