The Shipyard ( Dry Dock ): Builds & Questions => Lifeboats => Topic started by: montessa315 on September 18, 2011, 08:50:32 pm
Title: 1/12 Mersey Lifeboat fittings kit
Post by: montessa315 on September 18, 2011, 08:50:32 pm
Anyone got any suggestions on wher to buy a fittings kit for the 1/12 Mersey?
Title: Re: 1/12 Mersey Lifeboat fittings kit
Post by: stubbsy on September 18, 2011, 10:12:48 pm
i think model by design do a fitting fit for the mersey and speedline do window kits for most 1/12 lifeboats
hope this helps
stubbsy :-)
Post by: morgsy on September 18, 2011, 10:26:03 pm
Cheers - Will make more enquiries
Post by: Number 6 on September 19, 2011, 12:21:12 am
Macs Mouldings also do a window and door set, he does some fittings too. Model Slipway do some fittings for lifeboats. Waverley models worth contacting too, Dave.  :-))
Post by: tubby on September 19, 2011, 10:01:41 am
Full fitting kit for the 1/12th mersey are available from Dave at Metcalf Mouldings.
Post by: Number 6 on September 19, 2011, 12:12:46 pm
Mustn't forget I got my nameboards, numbers and station name for my Mersey off Barry's Model Lettering. What a guy, Dave.  :-))
http://www.modellettering.com/catDetail.asp?categorycode=09 (http://www.modellettering.com/catDetail.asp?categorycode=09)
http://www.modellettering.com/showProducts.asp?categorycode=03 (http://www.modellettering.com/showProducts.asp?categorycode=03)
Post by: Rottweiler on September 21, 2011, 01:24:21 am
have a look at "Models by Design" website.Quite a comprehensive range there. If you ring Andy,he is always willing to help.
Post by: montessa315 on September 21, 2011, 08:13:34 am
Thanks Guys........ :-))
Post by: gregk9 on September 28, 2011, 09:59:05 pm
Just to "add" a little info, Ive just recieved delivery of a hull kit from models by design, along with a fitting kit, and they actually supply "metcalf mouldings" kits , so save you a bit of a "round the houses", may be worth simply ordering a fitting kit off Dave @ Metcalf.
Postage pirce may be a bit high, as ive just weighed the fittings box and its almost 1kg in weight!
But contains a selection of rail stanchions, base fittings, radar unit,  bollards, anchor and associated bits,  aerial bases,  rail wire adjusters,  steering wheel nav lights,  and quite a fair bit more and thats without opening the seperate packets and actually looking properly. All white metal items and very little "flash" to remove either.
Post by: Dun1227 on September 28, 2011, 10:34:47 pm
Hi all,
Sorry to be negative on my first post but a couple of years back when I bought my Mersey mouldings and fittings from Models by Design I didn't recognise the fittings as being for a Mersey. They looked to me as if they belonged to the Alice Upjohn. I phoned the guy at Models by Design who told me they were made by David Metcalfe. When I phoned David Metcalfe I expected to be told I had been supplied the wrong kit but he told me the kit was the same for both models. Well they didn't match anything that was on the Dungeness boat as far as I could see. Model by Design gave me my money back without any hesitation. Shame because they were nice castings.
Alan C
Post by: gregk9 on September 28, 2011, 11:23:08 pm
http://www.modelboatmayhem.co.uk/forum/index.php?topic=32948.0
See above link, as ive posted pics of the Metcalf fitting kit on my thread for someone else, but may be of interest to you also.
