Mess Deck: General Section => Beginners start here...! => Topic started by: Tralee on July 10, 2013, 05:46:35 pm
Title: ESC PAIRING
Post by: Tralee on July 10, 2013, 05:46:35 pm
I HAVE JUST FITTED A NEW RIPMAX WATER COOLED SEA SPRINT ESC INTO A BOAT I HAVE HAD FOR A FEW YEARS, I AM HAVING DIFFICULTY IN SETTING THIS ESC AND PAIRING IT WITH A 2 CHANNEL FUTABA ATTACK TX, ANY SUGGESTION OR HELP PLEASE
Title: Re: ESC PAIRING
Post by: essex2visuvesi on July 10, 2013, 06:45:39 pm
is it forwards only? in which case it will be looking for throttle at the lowest position (not centred)
Post by: Tralee on July 10, 2013, 06:48:09 pm
No forward and reverse
Post by: essex2visuvesi on July 10, 2013, 06:56:49 pm
OK ignore my last comment  :D
Silly question time
1... have you tested the receiver and confirmed both channels are working?
2... Drive battery (or RX battery pack) is fully charged
Don't have much experience with that particular ESC, but when I did a quick google search I found out that at least one member on here had one and was discussing it on another forum.  So they may be able to help
I have dropped said member a message alerting them to this thread
Post by: Tralee on July 10, 2013, 07:08:07 pm
Thanks for your help I have power into the esc but not from the esc to the motor
Post by: Martin (Admin) on July 10, 2013, 09:38:13 pm
Is this any use?
http://www.tamiyaclub.com/pictureframe.asp?t=n&id=img5880_25042006220022_1.jpg
Post by: red181 on July 10, 2013, 10:51:58 pm
that esc needs a seperate bec, sorry if you already know this, but what that means is it needs a seperate power source to power the rx, and then the esc, so plug it into channel 2 (throttle) and you need 4 x aa batteries (6v is a safe working voltage) into the rx in "batt" slot. Always ensure the voltage is good, dont leave connected, if it drains away whilst in use you could lose the signal and your boat will become uncontrollable %%  a cheap voltabe guage plugged into AUX in the rx will be a visula monitor of rx battery supply condition.
The seasprint also needs 6 cells minimum, I used it a lot some time ago, its a good esc, not water proof though so stick it in a plastic box of some sort for extra protection
Post by: essex2visuvesi on July 10, 2013, 10:57:59 pm
If its a 2Ch receiver you can use a servo Y lead to connect the voltage meter to one of the 2 channels
Post by: malcolmfrary on July 12, 2013, 03:20:57 pm
Plug a servo into the slot intended for the ESC.  If the servo waggles in sympathy with the TX stick, the radio bits are OK and the ESC needs a fettle.  If it doesn't the problem is with the radio part.  Or the power to the control half of the ESC.
ESCs of that era usually had a pair of adjustment pots accessed via holes in the case.  One for centre, one for range.  Adjusting them was a finger and thumb job with a small insulated bit of sharpened plastic* rather than a good run at it with a bayonette.  I have had cause to repair one or two (similar age) ESCs where replacing the mangled bits of ruination was all that was needed to fix the damage done by "a previous owner".
* A use for the toothpick from your Swiss Army knife.
