The Shipyard ( Dry Dock ): Builds & Questions => Pleasure boats, Sports, Race, Power and Leisure Boats: => Topic started by: DJW on November 09, 2021, 09:05:52 pm
Title: 1/5 Riva Aquarama...
Post by: DJW on November 09, 2021, 09:05:52 pm
Hi All
I'm really enjoying the build process of my Amati Riva Aquarama, it's so rewarding to see the classic beauty of the boat emerge from the component parts.  And so starting to consider what comes next, maybe the title of the post gives that away...
I'm learning a lot about the 1/10 scale Aquarama build and quite like the idea of doing it again, improving my implementation in several areas, and taking on the general challenges of scaling up.  I'm thinking that the plans I have can be generally scaled up, with some thought given to materials and hardware.
The 1/10 scale is my first real build for 30 years, so I'd welcome some input as I start to plan out how to approach the project.  I have acquired tools, materials, contacts and techniques that should carry over nicely into the larger version, but would be grateful for comments on some initial planning thoughts.  I have nothing yet in terms of specific materials or hardware, so all up for consideration.
Construction would I think stay quite faithful to the 1/10 build with suitable scaling of materials.
My current build is 860mm loa, and a beam of 270mm at the widest point.  Weight is currently 4.0kg and will end up close to 4.5kg I think.  A doubling of those dimensions would make the new build around 1700mm loa and a beam of 540mm.  First question, how to estimate the target weight...?  It's not a doubling, should I assume around 3x as a guide..? That would make a target weight around 12 - 15kg, is that a reasonable assumption..?
Then the running hardware.  Looking at other builds at this sort of size, a pair of brushless outrunners, say the Overlander / Surpass 5055 model feels about right.  1550w, so around 2hp each, 570kv and can handle up to 24v and have a 65A max rating.  So running them on say 5S lipos would spin them at around 10,000 rpm.  I'm running FrSky and really like the Neuron 40S ESCs on my current build, I'd like to go with the 80S versions on the new build, they handle 80A, 120A burst so seem about right.  An overall 4hp seems a lot to me... But I'd be happy to restrict the top end power or play with the LiPo voltage rather than end up with anything under powered.
I'm thinking 5mm exposed propshafts, I'll make up the tubes and P brackets.  No idea what props these motors would optimally drive...  Any comments gratefully received.  I'd want to use Prop Shop units, so maybe I should ask Simon what he thinks once I've arrived at the correct power and RPM targets.
What do we think...?
David.
Title: Re: 1/5 Riva Aquarama...
Post by: ChrisF on November 09, 2021, 09:54:45 pm
Hi David
My first thoughts were if I'd made such a lovely build already of a Riva I wouldn't want to do another one, but that's just me!
But having thought some more I can see where you're coming from. You've learnt a great deal from your first build and know where you want to do things differently. Having already done it is really the only way to highlight "improvements" though I think most of us would be more than happy with your 1:10 version.
Your reasoning on upsizing all sounds pretty good to me. Have you made a list of things you want to do differently and possible ways of achieving them? One thing I can think of is that reducing weight can be considered at the design stage rather than during the build.
Obviously UKMike will as usual be an excellent source of information and be able to offer constructive advice given his experience of building a bigger Riva.
Again, I will look forward to the build.
Chris
Post by: C-3PO on November 09, 2021, 10:28:03 pm
You may be able to extract some information from this site. I am not certain if they are still active.
http://www.exclusive-shipmodel-shop.de/Riva-Aquarama (http://www.exclusive-shipmodel-shop.de/Riva-Aquarama)
or
http://classicrunabouts.de/ (http://classicrunabouts.de/)
and their FB page https://www.facebook.com/BAE-Schiffsmodellbau-322562321265360/photos/?ref=page_internal (https://www.facebook.com/BAE-Schiffsmodellbau-322562321265360/photos/?ref=page_internal)
and also https://modellboote-mahagoni.de/riva.html (https://modellboote-mahagoni.de/riva.html)
or
https://modellboote-mahagoni.de/riva2.html
They quote 1/6 as being 137 cm x  43 cm - they produced some awesome fittings ($$$)
I have in my fleet one of the models featured in their FB pages "ROCKET" - a beauty
(https://modelboatmayhemimages.co.uk/images/2021/08/07/IMG_0550.jpg)
C-3PO
Post by: ChrisF on November 09, 2021, 10:45:16 pm
Very nice!
Had a look at your first link - you could soon tot up some serious expense!
Chris
Post by: DJW on November 10, 2021, 09:39:07 am
Morning Both
Thanks for the comments, some great information in those links 3PO, I hadn't seen them before...
@Chris, you're right.  I think that building the same boat again allows the benefit of hindsight, how it should have been done in the first place.  As you point out, weight is a major one of those things.  I now know that so much can be taken out of the frames, a lot of the wood is overkill once the planks are on and the hull shape achieved. The bow is a particular issue as its pretty much inaccessible once the first frames are installed. I know that a better engine / shaft arrangement can be arrived at that runs quieter. Most of all I have just run out of room on the 1/10th everything is constrained by the space available. If I want to take out the Rx, almost everything else has to come out first.  I enjoy the electronics side, I know I can improve the sound system.  I'd like to integrate the vapour system in the 1/10th, but have run out of room...
And in terms of cost...  It would be a lengthy project I think, so a spread cost.  And I've probably spent 3x more on tools than the cost of the 1/10 Riva kit, so would be good to give the tools a bit of a workout..!  And thinking about it, I've binned a lot of the kit fittings to make up my own, practice for the next one...  UKMike has indeed led the way with techniques and fabricating Aquarama hardware.
@C-3PO, the links to the German sites are very interesting indeed, some techniques there that I've not seen.  Interesting discussion of materials and running hardware used. I like the method of creating the padding effect on the upholstery, will be looking at that for the 1/10 upholstery.  Interesting motor mounts too.
And love the 'Rocket'..!
Best regards
David.
Post by: C-3PO on November 10, 2021, 10:07:11 am
Hi David,
I will follow your "large scale" Aquarama project with interest.
Somewhere I have plans for a large scale model - I will dig them out and post an update.
My Rocket is currently in dry dock undergoing some upgrades and an installation of a "full on" sound system :)
(https://modelboatmayhemimages.co.uk/images/2021/11/10/IMG_1587.jpg)
C-3PO
Post by: tonyH on November 10, 2021, 10:46:17 am
I'd check on your weight calculation. It's based on the cube of the scale so if the 1/1 Riva weighs 4000kg, then the 1/10 model comes in at 4000/10x10x10 = 4kg BUT at 1/5 it's 4000/5x5x5 = 32kg. ok2
The general dry weight of the real Aquarama Riva is about 3000kg, so it might be worth aiming at 3000/5x5x5 = 24kg
Have fun!Tony
Post by: mrlownotes on November 10, 2021, 12:21:17 pm
If you would rather skip the hull build then MHZ have a 1485mm Riva just waiting for a fitting out and paint job :-
https://www.mhz-powerboats.com/shop/en/hulls/mono-hulls/l-1800-mm/257/riva-modellboat-1485mm-58-46-gfk?c=56
Post by: DJW on November 10, 2021, 07:55:45 pm
Evening All
More very interesting points raised. I didn't realise that was the calculation for scale weight. 24kg sounds pretty heavy to me, but I guess it's important to try not to go over it, then if it needs ballast to get the correct waterline. Well that's fine.
The GRP version of the hull is interesting,  and at 1.4m it's substantial. But I think the Aquarama is all about the woodwork, and finish. I enjoyed the hull taking shape from it's component parts...
Regards to all.
David.
Post by: tonyH on November 11, 2021, 10:19:58 am
At least you're going in the right direction David! It can get a bit scary if you're going the other way so, using the same numbers, 1/20 gives a displacement of 4000 / 20x20x20 = 0.5Kg  {:-{
Post by: Backerther on November 11, 2021, 01:46:55 pm
I think and feel so fundamentally about the way of thinking though I'm not sure... {:-{ ?
4kgx1/2x1/2x1/2=0.5kg...1/20 scale
4kgx2x2x2=32kg.............1/5 scale
If 1/10 model is 4kg....??? {:-{ ?
Post by: tonyH on November 11, 2021, 02:17:45 pm
If the actual boat weighs 4 metric tons i.e. 4000 Kg, then if the scale is 1:10 the target weight for the model should be 4000 divided by 10x10x10 i.e. 4000/1000 = 4KgIf the scale is 1:5 then the target weight should be 4000 Kg divided by 5x5x5 i.e.4000/125 = 32KgIf the scale is 1:20 then the target weight should be 4000Kg divided by 20x20x20 i.e. 4000/8000 = 0.5Kg
If you're changing scales, then I find it's best to work back to the actual weight of the boat because it's less prone to error. You can work back, of course, but it's always going to be working with the cube  so going from 1:20 to 1:10 you're doubling the scale so in this case your target weight is 0.5 x (2x2x2) = 0.5x8 = 4Kg 0r from 1:10 to 1:5 you're doubling again so it's 4 x (2x2x2) = 4x8 = 32Kg
Post by: DJW on December 02, 2021, 02:38:44 pm
Afternoon All
Having realised there's more to scaling than I'd initially appreciated, I've taken on board the comments with respect to weight and done some more digging.  As a sanity check I'd appreciate comments on the following approximations for scale speed and power.
I'm running same calculations for my 1/10 build of the Aquarama as a check that the right numbers come out, which generally they seem to.
Firstly Speed.  I've looked at two approaches, what the scale speed should be, and then what it would take in terms of propeller pitch and shaft RPM to get to that kind of speed.
I saw this scale speed formula in March 2021 Model Boats, so for 1/10 its:
(https://modelboatmayhemimages.co.uk/images/2021/12/02/10th-speed-est2.jpg)
And my current 1/10 build is set up like this:
(https://modelboatmayhemimages.co.uk/images/2021/12/02/10th-speed-est.jpg)
So that's a scale speed of 23.4km/h and a real world that's at best 20.86, but a bit less with some slip.  And that feels about right, I'll get some hard numbers from the GPS on next outing...
For the 1/5 same calculations look like this:
(https://modelboatmayhemimages.co.uk/images/2021/12/02/5th-speed-est2.jpg)
(https://modelboatmayhemimages.co.uk/images/2021/12/02/5th-speed-est.jpg)
So that's a scale speed of 33 km/h, and a combination of shaft speed and pitch that gets close to 33 km/h too, depending on real world slip...
I worked on a ratio of 1.2 for pitch to diameter on the prop which I think is quit conservative in terms of motor loading.
And then on a second related point, what power would one anticipate is needed to get to the scale speed, given scale size and weight, and to turn that size of prop at that shaft speed...
Seems the power calculation is quite straightforward and involves cubes again, so firstly for the 1/10th build.  Its the full size power in HP (700), divided by the scale cubed (10x10x10 or 1000), so that's 0.7hp which is about 520 watts.  My build actually has 2 x 340w (so 680w in total) motors, which on the face of it would appear to be slightly overpowered.  I think they reach max rpm with ease, so basically aren't fully loaded and could take courser pitch props if I felt the need, which I don't.
Same calculation with the 1/5th goes like this. Full size power (700), divided by the scale cubed (5x5x5 or 125), and that's 5.6hp...  Which is just over 4,100 watts.  So that implies 2 x 2,000w ish motors are required to reach scale speed of 33 km/h.
And my feeling right now is A) that's a lot of power, and B) I think a 1/5th scale can be built at a lower weight than the 'scale' 32kg allowance. And that weight saving can be trade off against the predicted power requirement.  So I'm inclined to look at 2 x 1,600 w motors and accept a real world speed a shade lower than true scale.  But still quite perky I think.
Does this all sound realistic..?
Regards to all.
David.
Post by: ChrisF on December 02, 2021, 04:51:07 pm
All looks good to me David. Yes, the power for the 1:5 build does seem a lot but the faster you go the more power you need and I think that your approach to accept a lower top speed using less power is sensible, and I wouldn't be surprised if the top speed isn't far off in reality.
How often are full sized boats run at top speed anyway and 700hp is a lot! I bet that "even" with 500hp it would go well!
And you have the advantage of your passengers weighing a lot less pro rota!
As long as it gets onto the plane easily and is quite brisk it should all be good.
Chris
Post by: DJW on December 02, 2021, 05:19:00 pm
Hi Chris
Thanks, and agreed re top end speed. Its proving interesting to scope out a project like this.  Just trying to get all the main components in the right ballpark in terms of functionality, but then also establishing what the financial outlay may need to be...
Best regards
David.
Post by: DJW on December 07, 2021, 11:49:48 am
Well the DPD guy has just delivered a pair of these bad boys from Overlander...
(https://modelboatmayhemimages.co.uk/images/2021/12/07/20211207_112853-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2021/12/07/20211207_112931-Custom.jpg)
Decided to go with the Overlander brand versions as I had great tech support from them earlier this year when they sent out test ESCs to troubleshoot problems I was having.
Going to need to build a hull to put them in now...
I wanted the motors early so I can start looking at building the motor mounts, so I know what mods to make to the hull frames when the time comes.
Best regards
David.
(Just over 2hp each..! But I think the reference to 16 inch props is a bit optimistic...  %) [size=78%] )[/size]
Post by: 6705russell on December 07, 2021, 11:55:46 am
I think they mean a 16 inch airplane prop  :-))
Post by: DJW on December 07, 2021, 12:04:54 pm
Hey Russell
I think you might be right..!
David.
Post by: ChrisF on December 07, 2021, 02:24:25 pm
Nice David.
I use Overlander in all my builds. The biggest I've gone upto though is a 42 diameter in my Swordsman. Those really are bad boys!
The kv is pretty low, will you be gearing them up to give sufficient revs?
Chris
Post by: tonyH on December 07, 2021, 04:35:42 pm
Will you need the revs? If you end up close to the 60lb weight to get down to the theoretical waterline wouldn't the torque be more important, after all with a pair of coarse 2.5 inch handed props and potentially 7000 revs.........?
Post by: ChrisF on December 07, 2021, 05:33:05 pm
Yeah, I usually reckon on around 10k. rpm for good planing performance but that's with normal sized boats!  :-)
With bigger, coarser props the required performance could well be achieved. Obviously 6S will be required to give 7k. rather than 8S for 10k. without gearing.
What revs were you achieving with the 1:10 David out of interest?
Chris
Post by: DJW on December 07, 2021, 07:31:31 pm
At this stage I'm thinking that I'd rather prop up for the 7k rpm / 6S configuration.  I think a conversation with Simon at the Prop Shop would be in order before making decisions.  I'd rather have the power delivered at lower rpm and use the torque of these motors, I've been looking at 8,000mAh 6S Turnigy graphene lipos. I guess the option would remain to go for 8S if the revs just aren't there... But ideally not.  No gearing planned, but I do want to look at isolating the motors, so will be looking at mounting options.
The 1/10 build motors are spinning at 12k at full speed, and drawing less than 10A when doing that during testing, so not fully loaded. (Say 12v at 10A gives 120w, they are 340w motors.) That current might go up as the final weight goes up and I have set of coarser pitch props to try.  These motors are on 3:2 reduction gearing (belts) so shafts are running at 8k.
Post by: tonyH on December 07, 2021, 08:14:41 pm
Part of the trouble is that, apart from the Lambo powered monsters, the standard and apparently unreliable Riva motors were petrol but they were often replaced with diesels, so the power profiles were totally different. The Yanmar diesels were rated to 3800rpm it seems but what was the gearing? If it was 2:1 then you're spot on. The Riva Crusader 270hp, for example, was allegedly a small-block Chevy, some of which used 1.9:1 gearing which revved to????It's an interesting problem you're facing and I suppose you'll only find out whether it's a gentlemans' runabout or a cads' speedster when you first sail it!
Nice one David :-))
Post by: derekwarner on December 07, 2021, 09:09:33 pm
......"isolating the motors" ...... David, if these T5065/08 were designed primarily for aero applications, it may be worth understanding how or what type of mounting is used in these cases
Do these [non brushed] motors have absolutely equal characteristics with alternate [or opposite] rotation?.....do these motors have an internal thrust load bearing?
To have 2 x 2HP acting as gyros <*< , may need absolute security of mounting and let the aero frame absorb the effects, so you could consider a similar concept %)
The other question is how to harness the near-instantaneous torque of a 1600W motor on a 6.0 diameter shaft, both at the motor, and also the propeller.....[tapered bushes {courtesy of George - ooyah/2} come into mind here, although I have not seen them applied to miniature electric applications ]
Post by: derekwarner on December 08, 2021, 04:19:27 am
David........following and attached is detail from Translock........
Stainless steel M6 bore tapered locking bushes.......if you go back to the Minilock TRMINI6x16 [carbon steel] shows transmission torque values
Two of these back to back as a solid attachment between the motor & propeller shaft, with a 3rd tapered bush in the hub of the propeller  %)
https://www.transdev.co.uk/hardware/bushes/translock-bushes/translock-stainless-steel-bushes/ (https://www.transdev.co.uk/hardware/bushes/translock-bushes/translock-stainless-steel-bushes/)
Post by: DJW on December 08, 2021, 11:00:01 am
Morning All
@Tony, I didn't know that the Aquaramas were sometimes rebuilt with diesels, part of the ownership would be the throbbing V8 sound I'd have thought..! But I think marine gearboxes are always reduction ratios aimed at slowing the shaft. To be honest I've not looked into that for the full sized boat.
@Derek, interesting points raised.  I'm not assuming any thrust bearings in the motors as far as my use is concerned.  Having said that I guess in their aero role the motors do have to take the full lifting force on their shafts so must have some capability...
The standard mount is the 'X' plate:
(https://modelboatmayhemimages.co.uk/images/2021/12/08/20211208_100020-Custom.jpg)
I intend to create a similar 'spreader' solution from aluminium plate, and incorporate water cooling channels.
My current thought is then to use some 7mm walled Aluminium channel (I use this in other work) with the motor mounted via 4 bobbins on one end, and the prop tube rigidly mounted at the other end (black pen in pic below).  And a solid coupling in between, the motors have a 6mm shaft, and I'd use 6mm prop shafts. The base of the channel then becomes the mounting surface to the hull.
The bobbin mounts will have 'cups' of either aluminium or nylon around them to reduce torque induced movement, so they just eliminate solid mounting to the hull, but don't allow the motors to move.  In this kind of arrangement:
(https://modelboatmayhemimages.co.uk/images/2021/12/08/20211208_100147-Custom07c1ba4054bbd571.jpg)
I may look at not having a prop tube top bearing, just a seal...  Using the motor as the top bearing with a solid coupling, so they don't fight each other... (There's a thread on this in R&D section.)
This then gives two options for taking the thrust.
A suitably mounted / integrated P bracket, or the motor mount (left side in pic above) using a more conventional thrust bearing.
In terms of the potentially brutal power of these motors, I agree it could get catastrophic...  I'm planning to use the 80A Neuron ESCs from FrSky, these can be programmed to deliver super smooth acceleration, even if the users stick input is less than smooth. I'm using the 40A versions on my 1/10th and have arrived at very smooth low speed handling and acceleration.
The Translock system looks very elegant, more so than the usual collars with a grub screw, thanks for the link. I'll try to find some and report back.
Thanks for comments, and best regards to all.
David.
Post by: tonyH on December 08, 2021, 03:36:19 pm
Hi David,
I thought that was the case but this is one original.
Riva Aquarama Special #768This beautiful example of Aquarama Special is one of the last manufactured by Cantieri Riva, in 1992. The vessel was commissioned by one of Riva’s customers to be pre-owned as a support on a large yacht in Britain. The peculiarity that makes this model of motor vessel unique is the fact that freshly Riva provisioned it with 380 HP Diesel Hydro Force engines, later replaced with gasoline 350 HP Thermo Electron engines.Interesting fact: the fresh Diesel engines are available with the vessel. (Part of the sales blurb)
It would seem that the petrol ones were almost all direct drive, while with the diesels, the revs were upped by approx 2:1.
Are your engines mounted independently, or are you putting both on a single transverse mount to reduce the torque effect on the hull?
Tony
Post by: DJW on December 09, 2021, 12:13:57 pm
Hi Tony
That is interesting indeed.  I suppose the lower revving diesel, but with higher torque could handle the increased gearing and get back to 'normal' prop and shaft rpm.
I like the idea of making the motor mounts in one piece but it may become a bit difficult to machine in my small lathe / milling machine.  However I do think it would be useful to have an aluminium bridging plate / structure that can be removed.  I can then make up the components as smaller pieces using the bridging support to brace the two mounts together for installation / alignment, and then also to spread the forces from the motors.
Best regards
David.
Post by: tonyH on December 09, 2021, 12:58:02 pm
Hi Dave,
This is the way I fitted the motors in my Jackie S which is only 1/12 coming in at about 6lbs so built relatively lightly. The standard X mounts for the motors are fitted through a piece of 1.2mm roofing rubber straight onto a 1/4 inch ply frame as part of the structure. It's also reinforced with a spare bit of 1x1.  I cut the holes through the ply so I can get access directly onto the screws that hold the motor onto the mount. You've got so much spare displacement available at 1/5 that you could almost make yours out of mild steel!
Tony
Post by: DJW on December 10, 2021, 06:43:19 pm
Hi Tony
I've been thinking more about the single mount for the two motors and I think it can and should be done. Thanks for highlighting it at this stage..!
In other news I'm having some trouble getting the plans taken up from 1/10 to 1/5. I've tried a couple of local copy shops that can print to A0. But even folded once the 1/10 plans are 500mm x 700mm. So taking that up to twice the size exceeds A0.
My plan B is to set up a camera over the 1/10 plans, put a pencil grid say 100mm x 100mm over the plans. Then get the grids to 200mm x 200mm in Photoshop, print tiled output to A3 and tape em together...
But I'd be really happy to hear there's an easier way...
Regards to all.
David.
Post by: DJW on December 11, 2021, 07:13:06 pm
I think I have an alternative way to scale.
I use PhotoShop in the real world, so have tried using the Pen tool to trace an outline from a picture of the 1/10 plans.  The results look OK...
This is the outline of a part:
(https://modelboatmayhemimages.co.uk/images/2021/12/11/PenTool-Custom.jpg)
And this outline can then be pasted onto an A4 sized document:
(https://modelboatmayhemimages.co.uk/images/2021/12/11/PenTool2-Custom.jpg)
And scaled:
(https://modelboatmayhemimages.co.uk/images/2021/12/11/PenTool3-Custom.jpg)
Larger parts would have to go onto A3 and or be tiled on multiple sheets.  I quite like this approach for a couple of reasons:
1. Symmetric parts can just be mirrored, saving tracing time and ensuring symmetry.
2. Some mods will need to be made, around the motor bay for example, and also I like the modified chines on the 1/10 build, so I can edit the frames in PhotoShop.
Bit laborious, but it can work I think.  Anyone tried this approach, if so how did it work out..?
Best regards to all.
David.
Post by: Mark T on December 11, 2021, 07:33:05 pm
Hi David this is one epic build that you are on  :-))
Making plans larger is not an easy task and I think that your approach maybe the best way.  I have tried to upscale and even just copy large plans at the printers and it never seems to come out exactly to scale.  They always seem to stretch a bit going through either the scanner or printer and this has caused me many problems on my current build.
Good luck mate I'm sure its going to be beautiful  O0
Post by: ChrisF on December 12, 2021, 12:26:08 am
Hi David
I use a similar approach to producing my drawings albeit at 1:12. I use Microsoft Visio and trace PDF's of the drawings, either obtained as PDF's or scanned, and then modify them to suit my needs. Once traced I can print out at any scale I like and as you say join A3 prints together. To ensure accuracy  I enclose parts in rectangles so that I can align them. For producing frames/bulkheads I draw half, mirror them and join together. I use Lightroom for my photography but not Photoshop so can't really comment on it's suitability.
CAD would be a better program but it takes some learning. I bought TurboCAD but have only scratched the surface with learning it. Visio isn't the best program for drawing but I used to use it at work so can get good results from it.
Chris
Post by: DJW on December 12, 2021, 09:46:20 am
Morning Both
Thanks for the comments and encouragement. I like the idea of using rectangles on the tiled prints to get good alignment. I've used Photoshop for years. But never the pen tool. That seems to unlock very smooth curves, and given the start and end point of the curve its possible to manipulate the curve to fit what's being traced.
I'm thinking that although it's laborious, it doesn't all need to be done at once. So initially keel and frames, then as required. And then if mods are needed on the way they can be incorporated.
An epic build...  We'll see. Its going to be a challenge for sure. I'm still finishing the 1/10 build and plan / hope to have it ready to run for spring 22, hoping to take it to a few open days and meet up in the real world..!
So now its a case of scoping out how best to approach a 1/5, start to fabricate and acquire some of the core parts that the hull will need to accommodate, I'm thinking the drive train. Then build them so I have them on hand to start the hull.
Best regards
David.
Post by: ChrisF on December 12, 2021, 11:33:07 am
David
That's also the approach I take. Rather than draw everything up at once I draw up enough to start building, as you say keel and frames first and then draw up the other parts as I go along.
Whilst I enjoy the drawing it can get a bit laborious especially if you want to get building! It also has the benefit that you can take actual measurements of what you have built so far, in my case for fitting the superstructure.
Certainly is going to be an epic build!
Chris
Post by: DJW on December 22, 2021, 03:20:08 pm
Afternoon All
Continuing to acquire parts and researching hardware to be used.  I've been very impressed with the TCS Micropumps, very efficient, I have the M200 version in my 1/10 build.  I was looking at a suitable version for the 1/5th and found a brand new still in its box M400S on eBay at £35.00, a bit better than the eye watering £90.00 rrp...  Its a 34g brushless pump that circulates up to 2.6 litres / min through 6mm dia connectors, runs up to 12v, consumes just over 7w and interestingly its speed can be controlled with a PWM signal.  I doubt it'll just hook up to a receiver, but via an arduino it will allow increased circulation based on ESC or motor temps, rpm or whatever.
(https://modelboatmayhemimages.co.uk/images/2021/12/21/20211221_132749-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2021/12/21/20211221_132740-Custom.jpg)
https://micropumps.co.uk/TCSM400range.htm (https://micropumps.co.uk/TCSM400range.htm)
I have some 9mm id brass for the prop tubes and have been looking at this material to create some bearings for the P Brackets and maybe where the prop tubes exits the hull.
https://www.igus.co.uk/product/539?artNr=SFRX-1000 (https://www.igus.co.uk/product/539?artNr=SFRX-1000)
Its machinable, so could create conventional and flanged bearings plus thrust washers at whatever size an length required. This time I'd be on a mission not to use ball race bearings in the drivetrain.
David.
Post by: Mark T on December 22, 2021, 04:25:00 pm
One of the best things about building big - is you can put whatever you want inside it.  That pump looks very well made.
Post by: DJW on January 21, 2022, 05:46:00 pm
Afternoon All
Main focus is trying to get my 1/10 Aquarama build finished, but also giving thought to the 1/5th...
I've found that I can play with 3D printed parts to iterate towards a suitable mount for the motors and shafts. (3D printer, new toy for Christmas...)
So useful to be able to test a part, then improve it, get all the dimensions correct before committing to aluminium, here's the first result, a couple of parts to hold the motor using M6 bobbin mounts:
(https://modelboatmayhemimages.co.uk/images/2022/01/21/20220121_170036-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/01/21/20220121_170023-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/01/21/20220121_170029-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/01/21/20220121_170113-Custom.jpg)
The threads protruding from the bobbin mounts will have another plate attached, the two plates will have channels machined out to make up a water cooled plate once fabricated in aluminium.
And playing with a printed fan blade too...
(https://modelboatmayhemimages.co.uk/images/2022/01/21/20220121_172346-Custom.jpg)
Best regards to all
David.
Post by: Thor on January 21, 2022, 07:22:47 pm
Nice work!
I do the same with 3D printed parts on my Riva build!Dual motor mount prototype:
(https://www.modelboatmayhemimages.co.uk/images/2022/01/19/IMG_5925w.jpg) (https://www.modelboatmayhemimages.co.uk/image/fGP99)
Post by: Mark T on January 21, 2022, 07:27:13 pm
Lads - Wow I think those motors would happily pump a large central heating system let alone a boat. Keep the updates coming  :-))
Post by: DJW on January 23, 2022, 11:36:56 am
@Thor. That's a beautiful mount and gearbox. Really looks the part. Will you run with the printed version or build in aluminium..?  Looks substantial enough to go with the printed version. Those inrunners look pretty fast. Are you gearing down..?  You'll get a really low shaft angle with that design, really nice. I'll be making the 1/5 mount as a single unit too. Really helps with alignment and rigidity I think. Hope you set up a full build log. Looking great from what I see.
@ Mark....  yes... quite a bit of power to deal with and all being well tame...
Post by: DJW on January 28, 2022, 08:38:28 pm
Evening All
Printer has been busy this week with an update to the motor mounts, I think these are getting close to whats required in terms of design.
(https://modelboatmayhemimages.co.uk/images/2022/01/28/20220128_173815_resized-Custom.jpg)
I'm not sure yet whether the two mounts will be fabricated in Aluminium as one unit, or use a temporary or permanent 'bridge' to join the mounts.  Aim is to ensure alignment during installation, then to provide a rigid structure during use, each motor is 2.2hp...  Issue will be machining in a single piece, it will be quite large for my lathe / mill.  Distance between shafts is around 170mm.
(https://modelboatmayhemimages.co.uk/images/2022/01/28/20220128_173831_resized-Custom.jpg)
Plan is to have the left side of the mount (above) take the shaft thrust and transfer it to the motor mount using a couple of thrust bearings.  Double thickness mount plate is size mockup of cooling plate.
The last pic shows the Aluminium channel that I plan to use once the final design is arrived at:
(https://modelboatmayhemimages.co.uk/images/2022/01/28/20220128_174519_resized-Custom.jpg)
In other news, 2 x 80A FrSky ESCs plus an FrSky 8 channel Rx arrive next week.  Props have been ordered from Prop Shop, 2 x 3033 3 blade units (76.2mm diameter x 83.8mm pitch) and 2 x 600mm x 5mm shafts, but I suspect they're a few weeks away.  That prop size is available in a 5 blade config too, so I'm thinking if I need more bite I can move up to the 5 blade units without changing the diameter.
Various other seals and drivetrain parts due in too.  I'm looking at SLEC for the wood, once I have the list together I think a trip to collect will be in order.  Been upgrading my Proxxon bandsaw by fitting a fence, had to make one, why doesn't anyone sell one to fit..?
David.
Post by: DJW on February 09, 2022, 05:40:07 pm
Afternoon All
Bit of a pause on the 1/10 build waiting for some materials, so some 1/5 progress.
Taken delivery of the two FrSky 80A ESCs, the level of control is exceptional, and the telemetry...
(https://modelboatmayhemimages.co.uk/images/2022/02/09/20220201_175718-Custom.jpg)
And have been working on the designs for the motor mounts and thrust bearings, so just in plastic for the time being:
(https://modelboatmayhemimages.co.uk/images/2022/02/09/20220201_175832-Custom.jpg)
And state of play at the moment:
(https://modelboatmayhemimages.co.uk/images/2022/02/09/20220206_120001-Custom.jpg)
Acquiring the materials to translate the mounts to aluminium, also the prop tube in brass.
And started to look at the build slip, it needs to be about 1.7m in length and is made from 40mm extrusion.  3D printed brackets for supporting the keel, and a sweep up of support for the bow, should give a good firm and accurate basis to build from. I'm hoping that using the extrusion will allow supports to be added / moved for the frames as they go in.
(https://modelboatmayhemimages.co.uk/images/2022/02/09/20220209_170652-Custom.jpg)
And for some perspective, the 1/10 build alongside...
(https://modelboatmayhemimages.co.uk/images/2022/02/09/20220209_170730-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/02/09/20220209_170520-Custom.jpg)
Just waiting for the wife to realise what 1/5 scale actually means...
David.
Post by: derekwarner on February 09, 2022, 05:55:36 pm
Evening David....."just in plastic for the time being" ........
Just wondering, with the strength of engineering plastics of today, are there any studies that confirm 'thermally deposited - printed structures' of aluminium are of superior strength to the engineering plastics?
I ask this, as from a design perspective, most if not all areas of critical stress can be eliminated or compensated by the design, so by the printing process irrespective of the medium being printed?
The printed plastic motor mounts you show appear to be extremely robust. >>:-( ...or am I missing something?
Post by: DJW on February 09, 2022, 07:51:17 pm
Hi Derek
An interesting thought. I've not considered the printed parts as the final hardware. Just a way to get the design right. The printed parts could have fillets added to give more rigidity, and the infill increased, these versions are not solid. This could well make them viable as mounts. There is the issue of heat from the motor. Aluminium will conduct that heat away. Plastic will not.
I think for this build with 1600w motors I would not be brave enough to trust the Plastic versions. I do have a rebuild of a robbe fireboat on the to do list, this will be a perfect test for 3d printed parts, including mounts.
I've only been playing with the 3d printer for a month or so. Very impressed so far.
Best regards
David.
Post by: PRG on February 25, 2022, 03:14:04 pm
Hi David,
A question you might be able to answer.  I have just been out with the boat and lost a propeller, high water and clipped it on the jetty!  Partly my fault as originally I fitted 30mm brass props then tried a 35mm in plastic to see if it would fit.  A close shave but yes, anyway having lost the prop this afternoon I need to replace with 35mm brass. Where and what do you recommend?
Thanks for any advice Paul.
Love the 3D printing.
Post by: DJW on February 25, 2022, 04:26:53 pm
Hi Paul
Ouch...  Sorry to hear about the loss of the prop...
I'm using props and shafts from
https://www.prop-shop.co.uk/ (https://www.prop-shop.co.uk/)
These are cast props, nicely balanced.
On my 1/10 I have a set of 'Standard Scale' 1415 bronze props. That's diameter x pitch in inches, so the 1415 props are around 35.6mm diameter.  I have pushed this to 1517 units to get a bit more bite as the motors were not loading up on the 1415s, but I'm running 370w brushless motors.
On the subject of props... It just so happens that the new props and 600mm x 5mm shafts for my 1/5 arrived this morning, and they're beautiful..!
These are new 'Standard Scale' units from Simon at the Prop Shop at 70mm diameter, so around 2.75 inches with a 3 inch pitch.
(https://modelboatmayhemimages.co.uk/images/2022/02/25/20220225_160140-Custom.jpg)
And for scale, a standard servo:
(https://modelboatmayhemimages.co.uk/images/2022/02/25/20220225_160058-Custom.jpg)
Best regards
David.
Post by: PRG on February 25, 2022, 04:44:22 pm
Thankyou for the advice, nice looking new props!
Post by: Mark T on February 26, 2022, 06:38:22 pm
Hi David - any chance you could point me in the right direction for those 40mm aluminium extrusions?  I've been seeing quite a few builders using this stuff and I have an idea regarding a building rig for it.  Cheers Mark
Post by: DJW on February 26, 2022, 07:10:27 pm
Evening Mark
I use HepcoMotion for the extrusions and fittings.
https://www.hepcomotion.com/product/aluminium-profile-construction-system/mcs-aluminium-profiles/ (https://www.hepcomotion.com/product/aluminium-profile-construction-system/mcs-aluminium-profiles/)
I needed their extrusions and bearings for a commercial photography project a couple of years ago and had some spare for modelling. It's precise and rigid. They will cut it to size if required too, otherwise it needs a serious mitre saw to get an accurate cut.
Best regards
David.
Post by: DJW on February 28, 2022, 04:54:47 pm
Afternoon All
My method for this build will be similar to my approach for the 1/10 Aquarama in that I'm getting together the parts and intend to build the subsystems before building the hull.  Aim being to work out the hardware fit of these subsystems before cutting too much wood.
Todays delivery is a couple of PAM8610 stereo amplifiers, each will be controlled by an Arduino playing an Aquarama V8 sound file, one system for each motor. Each can drive 2 x 15w speakers, so I'll be adding a 15w speaker and 15w audio exciter.  Aim is to hear one 'motor' start and stabilise, then a pause for the second to start and stabilise.  Then I'm thinking to add a slight timing mismatch between the two systems and hope is that they will then come into and drop out of resonance when under way, in the same way full sized twin V8s do...
(https://modelboatmayhemimages.co.uk/images/2022/02/28/20220228_092413-Custom.jpg)
On same system, to give an impression of 'cranking' during the start phase, this is a 200rpm 12v motor, I'm going to add an offset mass (brass), secure it firmly to the hull and power it up during the 'startup' sound phase of the sound system...  If I get it right the hull will vibrate as the engine startup sound is active.
(https://modelboatmayhemimages.co.uk/images/2022/02/28/20220228_092129-Custom.jpg)
That's the plan...
David.
Post by: PRG on February 28, 2022, 05:25:29 pm
This looks to be an exciting project, look forward to following your developments.  :-))
Post by: DJW on March 05, 2022, 06:20:43 pm
Evening All
Now have the speakers that I plan to use on the build. Each motor will have a conventional 3 inch speaker, plus an Audio Exciter. Similar to but more powerful than in my 1/10 build.
(https://modelboatmayhemimages.co.uk/images/2022/03/05/PSX_20220305_180641.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/03/05/PSX_20220305_180655.jpg)
Next job is to get a set connected up to Arduino and amplifier to see what kind of sound is generated.
Regards to all
David.
Post by: PRG on March 05, 2022, 06:33:04 pm
Now this looks great.  I was reading about Arduino, looks complex so will follow with interest.  Al the best. Paul
Post by: DJW on May 05, 2022, 05:38:15 pm
Afternoon All
I've started the process of scaling up the plans and getting them ready to transfer to ply.  I've created a 1:1 picture of the 1:10 printed plans, then scaled up x2 and converted sections to PDF.  The PDFs can then be printed tiled on A4 paper with crop marks and put back together with tape...  Some of the frames have been edited in photoshop to change the profile a shade, the same chine mod as on my 1:10 build.
(https://modelboatmayhemimages.co.uk/images/2022/05/05/20220503_154911-Custom.jpg)
For the frames I've just added the chine mods to one side and added a centreline to fold on, to get symmetry.
(https://modelboatmayhemimages.co.uk/images/2022/05/05/20220503_155001-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/05/05/20220503_155706-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/05/05/20220503_160104-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/05/05/20220503_160603-Custom.jpg)
And that's what will be cut out from the ply.
(https://modelboatmayhemimages.co.uk/images/2022/05/05/20220503_160618-Custom.jpg)
And here's the keel plan in the build slip...  With the 1:10 Aquarama for scale...  Going to need a bigger bench.
(https://modelboatmayhemimages.co.uk/images/2022/05/05/20220505_164601-Custom.jpg)
Just had a delivery of 6mm birch ply so will be giving the bandsaw a workout soon...
David.
Post by: DJW on May 11, 2022, 04:00:27 pm
Afternoon All
Some progress to report.  Had to purchase a new toy to assist with the woodworking ahead...
(https://modelboatmayhemimages.co.uk/images/2022/05/11/20220510_095352-Custom.jpg)
Not cheap and not large, but seems pretty smooth and has a dust extraction port that seems to work. It has a clamp built in and doesn't need a permanent mount.
The Proxxon bandsaw is doing well with the 6mm ply, but not ideal for interior cuts in frames, or some of the keel cuts too.  So I looked at a scroll saw, decided I'd already spent too much on the sander, so repurposed the jigsaw, spent £5.00 for some new fine blades...
(https://modelboatmayhemimages.co.uk/images/2022/05/11/20220511_144254-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/05/11/20220511_144316-Custom.jpg)
It's working well, helped me with the keel cuts.  Currently 3D printing a dust extraction adapter to finish it off, it's going to see plenty of action I think.
I have the forward half of the keel cut out and will sort the rear half when the dust extraction is running...  Also have the first frame made up, the 1/5 frame against the 1/10 plan for comparison:
(https://modelboatmayhemimages.co.uk/images/2022/05/11/20220511_130537-Custom.jpg)
And the keel section plus first frame sitting in the build slip, being watched over by the crew of the 1/10, next frames ready to be cut out...
(https://modelboatmayhemimages.co.uk/images/2022/05/11/20220511_151902-Custom.jpg)
I'll get all the frames ready and correctly dry fitted before anything gets glued.  Also a load of holes to be drilled for running wire and pipes, I didn't drill (holesaw) enough at this stage in the 1/10 build and it's almost impossible later, lesson learnt. Weight saving was a big issue with the 1/10 build, I have a feeling it won't be as critical with the 1/5, but I guess the holes will help anyway.  Target weight for this build is 20 / 25 kg, but I'd rather build light and ballast.  There are a few video's of 1/5 builds on YouTube, they seem too ride high to me.
David.
Post by: Capt Podge on May 11, 2022, 04:18:30 pm
You seem to come up with some brilliant ideas for adaptations David - how on earth did you manage to mount your regular jigsaw in that manner?
Like the building slip by the way.
Post by: DJW on May 11, 2022, 04:29:55 pm
Hi Ray
Pleased you like it, my B&D jigsaw has a couple of M6 threads at the front of its base so I used them, I drilled a couple of extra holes at the rear, then bolted them through some 15mm ply, and recessed the heads.  Drilled a hole to the rear of where the blade would be, then used the blade to cut a small path forward, so the ply gives some support to the blade.  The jigsaw can be adjusted for speed, seems to work...  I did find some finer and thinner blades, to help with rounded cuts.
(https://modelboatmayhemimages.co.uk/images/2022/05/11/Capture-Custom.jpg)
Meant to add, it's then all clamped with G Clamps...  Very securely...  I may end up drilling through my bench to make it extra secure.  Coming loose would not end well.
Best regards
David.
Post by: Capt Podge on May 11, 2022, 04:44:05 pm
Ah yes, that all makes sense now.
Don't know if I would attempt that myself but, as you say, securing the rig for safety would be paramount.
Thanks for the clarification David.
Post by: Capt Podge on May 11, 2022, 04:47:32 pm
Just took another look at your jigsaw set up - I thought you had mounted it on the wheels of your chair.  {-)   {-)
DOH!
Post by: DJW on May 15, 2022, 04:43:14 pm
Afternoon All
Getting to grips with scaling up, transferring to ply and cutting out. Bow is coming together.
(https://modelboatmayhemimages.co.uk/images/2022/05/15/PSX_20220515_160837.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/05/15/PSX_20220515_160822.jpg)
Making some mods to the internal layout as i go, the Amati 1/10 version has a full cabin layout, this build will not, so building in the speakers to frame 06. I'm thinking of adding tubes to the speakers to get the bass deeper...
(https://modelboatmayhemimages.co.uk/images/2022/05/15/PSX_20220515_160856.jpg)
06 cut out and dry fit in place.
(https://modelboatmayhemimages.co.uk/images/2022/05/15/PSX_20220515_160954.jpg)
Other holes are for cables.
Frame 07 being cut out on the jigsaw table.
(https://modelboatmayhemimages.co.uk/images/2022/05/15/PSX_20220515_160924.jpg)
And frames 05, 06 and 07 in place dry fit on the forward keel section. Those are the Amati part numbers. They're 1st, 2nd and 3rd frames from the bow.
(https://modelboatmayhemimages.co.uk/images/2022/05/15/PSX_20220515_161024.jpg)
And the 1/10 for scale.
(https://modelboatmayhemimages.co.uk/images/2022/05/15/PSX_20220515_161048.jpg)
It's quite helpful that the keel is in two parts, at this size it's all a bit more manageable for the time being. When it comes time to bring the keel halves together I think I'll need a bench that I can walk around when working on it.
David.
Post by: Mark T on May 15, 2022, 04:54:34 pm
This is seriously first class work - I don't think scratch building gets better or more innovative than this  :-))
Post by: Capt Podge on May 15, 2022, 04:58:19 pm
Glad you put the size comparison photo on - helps us to visualise what you're up against.
Post by: DJW on May 24, 2022, 04:10:04 pm
Afternoon All
Thanks for the comments Mark and Ray..!  Some more progress to report.
I've been a bit deskbound this past week, but that's allowed me to use the 3D printer, so can't complain...  I've made up some tubes with a flanges to use with the speakers.  It's amazing that the tube can deepen the sound, at least it works with a cardboard tube, so hoping these will work too, they'll not be seen once in place.
(https://modelboatmayhemimages.co.uk/images/2022/05/24/20220520_171119-Custom.jpg)
This is where they'll go, up in the bow:
(https://modelboatmayhemimages.co.uk/images/2022/05/24/20220524_153736-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/05/24/20220524_153744-Custom.jpg)
More of the frames are ready to cut out, that's 5 of them on a sheet of 1200 x 600 x 6mm ply, and some of the other parts in top left:
(https://modelboatmayhemimages.co.uk/images/2022/05/24/20220524_153940-Custom.jpg)
The eagle eyed will notice that they're not all symmetrical, at the final cutting stage I'm cutting the modified half first, then folding the template along its centreline to ensure symmetry.  So the 'other' side of the template is just a guide to the approximate shape for the rough initial cut.  The main mods are for the chine, and around the motor / shafts cut outs.
This is the frame 08 template, part the forward section where the hull needs the extra lift and a cleaner water release (in my opinion...) and shows the feint line of the original plan, and the heavier modified line with harder chine.
(https://modelboatmayhemimages.co.uk/images/2022/05/24/20220524_153957-Custom.jpg)
Also have the stern keel section cut out...  Very exciting..!  And when mated up with the forward section, it gives an idea of the overall size of the beast...  1/10th stern is same place as the 1/5th stern:
(https://modelboatmayhemimages.co.uk/images/2022/05/24/20220524_153914-Custom.jpg)
Looking forward to taking the 1/10th Aquarama up to the Mayhem Wicksteed event on Saturday, weather looking decent for Saturday at the moment...
David.
Post by: DJW on June 01, 2022, 05:40:22 pm
Afternoon All
Progress with more of the frames cut out:
(https://modelboatmayhemimages.co.uk/images/2022/06/01/20220601_165955-Custom.jpg)
Two more frames to be cut out plus the transom. The mods to the chine can be seen, I think this makes it a 'reverse chine' or close to it... Nothing glued yet, I'll need to do some sanding and detailing on the frames, and check for symmetry.
Great long weekend to all.
David.
Post by: DJW on June 05, 2022, 09:03:11 pm
Evening All
I now have all the frames ready for trimming, including the transom. 30cm ruler for reference...
(https://modelboatmayhemimages.co.uk/images/2022/06/05/PSX_20220605_205433.jpg)
I've been playing with using the 3D Printer to create the grating in the cabin floor. It's in place in the pic.
Best regards
David.
Post by: DJW on June 23, 2022, 06:02:07 pm
Afternoon All
Made some progress getting the motors / ESCs tested and basic radio configuration, also getting my head around using an SBEC for Rx and general 5V power with a third 4S LiPo for powering everything but the motors.  That 4S will be run through the 8A SBEC for 5V and several 12V regulators for other requirements such as amplifiers, pumps, fans. (In the pics below the motors are running on 3S LiPos, eventually they will be on 6S.)
(https://modelboatmayhemimages.co.uk/images/2022/06/23/20220623_165826-Custom.jpg)
The two motors powered up in the prototype mounts, the foreground mount has cups around the bobbin mounts to prevent too much movement but maintain the isolation of the motors:
(https://modelboatmayhemimages.co.uk/images/2022/06/23/20220623_165633-Custom.jpg)
They're silky smooth all the way up the rev range, very pleased.
The two FrSky Neuron 80 ESCs connect to the LiPos via XT90 anti spark connectors:
(https://modelboatmayhemimages.co.uk/images/2022/06/23/20220623_165701-Custom.jpg)
I'm happy with the use of an aluminium case on my 1/10 build to house the ESCs, it combines fans and water cooling certain areas, it'll be same with this build.  I had to retrofit the cooling on the 1/10, it'll be built in this time around from the start.
Rx is same as the 1/10 build, the FrSky R8 Pro, this has 8 channels built in plus telemetry and can extend out to 24 channels using the SBUS:
(https://modelboatmayhemimages.co.uk/images/2022/06/23/20220623_165708-Custom.jpg)
8A at 5v available from this FrSky SBEC:
(https://modelboatmayhemimages.co.uk/images/2022/06/23/20220623_165713-Custom.jpg)
I'm using a rudder servo for each rudder, not sure if this is overkill but the rudder blades will be substantial and it will allow some tweaking in the programming as they'll be independent, 2 x 25kg metal geared digital servos:
(https://modelboatmayhemimages.co.uk/images/2022/06/23/20220623_165911-Custom.jpg)
And just because its on my desk at the same time...  The sound system under development. The rails and PCB clips are 3D printed, a bit of space under the PCBs to allow wires to be (eventually) routed, and allow ventilation.  Once I have the footprint arrived at I'll make a box to mount the system, this will have one or two fans to maintain an airflow.  This will be mounted to the side of the LiPos, on the opposite side of the hull will be a similar 'box' with Rx and other electronics, switches and so on.  Same arrangement / layout as the 1/10 build.  For reference the rails below are 100mm long.
(https://modelboatmayhemimages.co.uk/images/2022/06/23/20220623_165849-Custom.jpg)
Similar approach to the sound system I made for the 1/10 build...  But there's going to be a separate sound system for each 'engine', so 2 x independent V8 sounds, and they'll start / run 5 seconds apart.  So you hear engine 1 start and run, then engine 2 start and run.  Two Arduino Pro Minis supplying the sounds then two amplifiers that will drive two speakers, and maybe two audio exciters. I've had it running and its working, sounds good to me, a deep rumble...  This stage is getting the parts more integrated, then I'll record the sounds and push it up to YouTube.
I want to get these various systems integrated and boxed ready to install into the hull so I can cut the hull frames for installation before going much further with the hull build.
Best regards to all..!
David.
Post by: Capt Podge on June 23, 2022, 07:28:45 pm
Hiya David, you're certainly approaching these electrical installations with a lot of practical knowledge and experience. I'll need to read this a few times to understand how these things work.
Anyway, it looks like it's gonna be a winner!
Cheers,
Post by: DJW on June 23, 2022, 07:42:18 pm
Hi Ray
Well, I'm taking it slow and doing a lot of background reading / Googling. It's useful to have the 1/10th build experience and am following it as a blueprint.
Nice set of new LiPos on your build..!
Best regards
David.
Post by: derekwarner on June 24, 2022, 12:52:51 am
David
Will the void space [in yellow] behind each speaker be a sealed enclosure, or vented via those '20mm?' diameter pairs of drilling highlighted in the red axis?
I found myself just a little lost with post #53 %)  on the 5th of March, between the 3" coned speaker & the additional Exciters??
Post by: DJW on June 24, 2022, 11:09:59 am
Hi Derek
Here's a clearer view of the current holes...
I envisage the 20mm holes are for routing cables, then there are 30mm holes under the speaker holes. I'd thought that there needs to be some allowance for air to move around behind the speakers, rather than sealed. I think its also a very black art to get it right....  there's a possibility to add an extension pipe to that 30mm hole, the aim being to route the sound from the back of the speaker, and prevent any cancelling of the sound waves by the creation of standing waves. I'll need to test and see what's best as the build progresses.
The exciters will be mounted separately, I need to figure out which flat surface will be suitable.
Aim is for a deep V8 sound...
Very best regards
David.
Post by: DJW on June 28, 2022, 07:30:20 pm
Evening All
First sounds out of the sound system.  Needs a bit of work to finesse but basics are there I think.
https://youtu.be/sct1FfVY3TU (https://youtu.be/sct1FfVY3TU)
Best regards
David.
Post by: CarlC on June 28, 2022, 08:15:34 pm
That is a very cool sound system, sounds are excellent, are they sampled?
Can you change them via SD card or data upload?
Post by: DJW on June 29, 2022, 07:35:21 am
Hi Carl
The system is based on this
https://github.com/TheDIYGuy999/Rc_Engine_Sound (https://github.com/TheDIYGuy999/Rc_Engine_Sound)
And tweaked a little. It uses two sound files converted from WAVs. These are indeed the startup and running sounds from an Aquarama V8. In this instance kindly shared by forum user C-3PO. The Arduinos have very limited memory and processing power. The Arduinos can be interfaced to a PC for code to be tweaked.
I'll post an update when I have it a lite more refined.
Best regards
David.
Post by: DJW on July 30, 2022, 10:32:56 pm
Progress being made in a couple of areas.
I'm using an SBUS adapter to add 8 additional channels. So now have 16 to play with. Just adds options and expansion going forward on the electronic side.
(https://modelboatmayhemimages.co.uk/images/2022/07/30/PSX_20220730_203925.jpg)
Started to build the housing for the two ESCs. I'm going belt and braces this time as the 1/10 build had to be modified a few times before it became reliable. So this time its got forced air cooling with heatsinks on the ESCs and fans. Fans will spool up depending on the temperature of the ESCs. I'll be adding extraction vents to get the air circulation in the hull sorted.
(https://modelboatmayhemimages.co.uk/images/2022/07/30/PSX_20220730_203947.jpg)
And on the base of the housing, the mounting plate will have water passing through to remove additional heat.
(https://modelboatmayhemimages.co.uk/images/2022/07/30/PSX_20220730_204001.jpg)
These ESCs are very good, but not really meant for marine use. Hence the housing and additional cooling.
David.
Post by: DJW on August 03, 2022, 10:19:04 pm
Cooling plate now brazed, and a couple of pinholes tracked down and sealed so it's watertight. 5mm id pipe for in and outlet.
(https://modelboatmayhemimages.co.uk/images/2022/08/03/PSX_20220803_210431.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/08/03/PSX_20220803_210448.jpg)
Best regards to all
David.
Post by: DJW on August 06, 2022, 05:39:02 pm
Another couple of hours today. The case for the ESCs is now ready to test. The two ESCs are equipped with heatsinks that are in contact with the case. The case will be constantly cooled by the water cooled base plate. If more cooling is needed the fans spool up at a set temperature and increase in speed as required. Connections are all in place through the case. I'm mainly using multiplex connections for control and telemetry.  Nice and positive physical connection and carry 6 wires.
(https://modelboatmayhemimages.co.uk/images/2022/08/06/PSX_20220806_171340.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/08/06/PSX_20220806_171354.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/08/06/PSX_20220806_171413.jpg)
And the hull frames and keel will be modified to place the case lower in this kind of position, right behind the motors. White blocks indicate approximate LiPo positions.
(https://modelboatmayhemimages.co.uk/images/2022/08/06/PSX_20220806_171456.jpg)
Again... This is all because I chose to use the aircraft oriented FrSky Neuron ESCs to control the 1600w motors. They would just cook in a sealed boat hull without sufficient cooling.
Very best regards to all.
David.
Post by: Martin (Admin) on August 06, 2022, 06:55:21 pm
   Again ....  :o
Post by: Stuw on August 08, 2022, 08:45:41 am
 %%  Serious heat dissipation being planned! It’ll work a treat I reckon. Wow....
Post by: DJW on August 12, 2022, 10:28:51 am
Morning Stuw
Hope so..!  Moved on to the electronics, I've had the individual systems working on the bench when building and testing, now getting the components mounted for integration with the boat.  In the Aquarama its tricky to use space forward of the motors for equipment that may need access, and not ideal to add weight forward anyway given that the boat builds bow heavy.  So I'm making up two 6mm boards that are 200x120mm and will become boxes that will fit either side of the batteries (seen in the above picture as white blocks).  The hull frames will be adapted to accept the boxes before the frames are bonded in place.  This is the first board (port side) that will be taking the sound system and a couple of related Arduinos and relays.  I'll be adding 40mm 12v fans to keep an air flow across the electronics.  Lower left are the two 15W amplifiers, one for each V8. These are TPA3110 Amps (£5.20 each on Amazon...) as they seem to give a better sound than the original PAM8610 units, I've also switched to conventional relays as the RC switches as I was having problems with the Mosfet type switches leaking current resulting in and on state, and an almost off state... Not ideal as it produced all sorts of whines and strange noises. The relays are larger, but are 100% on, or off...
(https://modelboatmayhemimages.co.uk/images/2022/08/11/PSX_20220811_183755.jpg)
Larger components mounted using stand offs, small components will be added to the grey DIN rails using 3D printed mounts, cable routing on the back of the board.
Power coming in from a 4S liPo using an XT60 connector, though switch, a fuse (5A at the moment) and then a 12v step down for the Amps and fans and so on.
The second board (to be starboard mounted) will accommodate the Receiver, SBEC, water pump relay, fan temp control and bilge water sensor.
David.
Post by: Martin (Admin) on August 12, 2022, 06:25:17 pm
Hi David,
Fantastic build!
Have you done / got a 'block diagram' of the all the electrics... I'd love to see one!   :-)
Post by: DJW on August 13, 2022, 05:04:38 pm
Hi Martyn
Thanks for that..!  And I don't have a diagram at the moment. But I think I could do with drawing one out, it would help with the work in progress.
(https://modelboatmayhemimages.co.uk/images/2022/08/13/PSX_20220813_170250.jpg)
Best regards
David.
Post by: DJW on August 16, 2022, 11:24:10 am
Hi Martyn, and All...
It did help to try putting thoughts re the build hardware on paper, here's my attempt to summarise what's being done, lots more space to play with in this build. This is a guide to the systems and their layout, bow being up...
(https://modelboatmayhemimages.co.uk/images/2022/08/16/1_5-Aquarama-Block-1.jpg)
At the moment I'm building up the 'Port Electronics Package', but have some spare mounting space in it so may move over some of the systems from Stbd side, issue there is I then need to 'bridge' over more connections from stbd side which has the Rx... Not the end of the world...
This is the current state of the 'Port package', sounds systems and Vibration (cranking) motor are working with no blue smoke, yet...
(https://modelboatmayhemimages.co.uk/images/2022/08/16/PSX_20220816_101123.jpg)
And this is a schematic of channel usage:
(https://modelboatmayhemimages.co.uk/images/2022/08/16/1_5-Aquarama-2.jpg)
The 5 / 12V regulators are a mix of types depending on current need.
The sound systems are using Aquarama V8 samples, bow speakers are selected for bass...   The Exciters, I'm thinking of placing them inside port and stbd hull sides.
Exhaust smoke.  After scouring YouTube for options, I'm going to try a glycerine based system using some nichrome wire and fibreglass cord to generate white smoke, then fans to drive it through the exhausts. And an Arduino / Mosfet arrangement to vary the volume of smoke and speed it gets expelled depending on the throttle setting....  But not started that yet.
Some of the channel usage doesn't really need to be on separate channels, I could use Y leads, but as the channels are available it makes everything a little more flexible down the line.
As always, the challenge is getting it all working in the real world...   :-))
David.
Title: Re: 1/5 Riva Aquarama...
Post by: Martin (Admin) on August 16, 2022, 04:47:48 pm
    Astonishing!  :o :o :o
Post by: DJW on August 20, 2022, 07:51:36 pm
Evening All
Some progress with one of the electronics packages. Now have it in a custom case, 3mm ply and 2mm perspex cover and a 40mm fan above the amps. This will be powered up when the amps are active. Some trimming to do and some more ports to cut out for connectors. I've made up two sets of parts for the case, so I have same for the other side, all the RC gear.
(https://modelboatmayhemimages.co.uk/images/2022/08/20/PSX_20220820_193812.jpg)
Not shown well in that pic but the lid is removable, as is the electronics board.
And the smoke generator...  is coming along. 3D printed in the main. Will show it working and the inside layout in a couple of days.
(https://modelboatmayhemimages.co.uk/images/2022/08/20/PSX_20220820_193830.jpg)
This is intended to produce a very modest amount of smoke, just a trace blown out of the exhausts.
David.
Post by: Capt Podge on August 20, 2022, 10:04:33 pm
All cased up like that gives a very real professional looking job - fantastic work David  :-))
Aye,
Post by: DJW on August 23, 2022, 05:32:28 pm
Hi Ray
Thanks for that, it's my attempt to keep the cabling under control.  I'm also using braided cable sleeves to keep wires together as they run through the hull.
(https://modelboatmayhemimages.co.uk/images/2022/08/23/20220823_165409-Custom.jpg)
A bit more progress made.  I've moved the Pump relay over as it needs a 12v supply, and added the ports for the MPX connectors.
(https://modelboatmayhemimages.co.uk/images/2022/08/23/20220823_164231-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/08/23/20220823_164237-Custom.jpg)
First test of the 'smoke generator' is successful, in that it didn't do any damage to anything and did generate smoke.
(https://modelboatmayhemimages.co.uk/images/2022/08/23/20220823_145529-Custom.jpg)
Heavily plagiarised from YouTube examples...  At the moment the output can be varied using a DC motor controller, and that works nicely.  Aim is to have the on/off on an RC channel, then have the output slaved to throttle.  I think the fan can run whenever the sound system is active as the smoke won't be required if the sound system is not 'on', that will maintain an airflow and keep the unit cool. I'd like to 'pulse' the output too, maybe a butterfly arrangement nearer to the exhaust stubs, not sure yet.  Top cover is a tight fit, no smoke coming out where it shouldn't.  When installed M3 screws keep the fan and lid in place.  Unit has a flange to be bulkhead mounted.
This is a low output...
(https://modelboatmayhemimages.co.uk/images/2022/08/23/20220823_145544-Custom.jpg)
And a bit more...
(https://modelboatmayhemimages.co.uk/images/2022/08/23/20220823_145548-Custom.jpg)
I'm thinking that a very low output when pulsed, might just look like a V8...
The insides, a length of 4mm fibreglass cord sitting in vegetable glycerine, the glycerine wicks up the cord to the heating element (nichrome wire).  The two bolts holding the wire are isolated from the case by silicone tube.  Put a voltage across the nichrome an it gets hot enough to vaporise the glycerine producing white smoke.  Fan forces air through the unit picking up the smoke on the way.
(https://modelboatmayhemimages.co.uk/images/2022/08/23/20220823_145805-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/08/23/20220823_145810-Custom.jpg)
This seems a lot more controllable than the ultrasonic disc approach...  I just couldn't make that reliable or controllable and usually ended up with a puddle of water...
This will have an Arduino controlling the unit and its output, as safety measures I could add a temperature sensor, then shut the unit down if it gets too hot, or limit the time the element is 'on'.  Testing it earlier for 5 mins or so on a low setting the case just didn't get hot.  More testing required, anyone tried this approach...?
David.
Post by: DJW on August 30, 2022, 05:03:28 pm
Afternoon All
A few hours here and there on the electronics housings, and the wiring loom.
(https://modelboatmayhemimages.co.uk/images/2022/08/30/20220830_164037-Custom.jpg)
This has a 4S 14.4V input for the various needs, same supply will feed to similar box on the other side of the hull.  'Speaker Grill' is actually a 40mm fan to keep an airflow though the box. There's a grill covered slot to allow the air to vent out, below.
(https://modelboatmayhemimages.co.uk/images/2022/08/30/20220830_164021-Custom.jpg)
And the connectors are now labelled up.  The 'Bridge' connector is to the opposite electronics box that holds the Rx, so it's the on/off signals for the relays.
(https://modelboatmayhemimages.co.uk/images/2022/08/30/20220830_164029-Custom.jpg)
UPS arrived earlier with a shiny new 4,000mAh 4S Turnigy Graphene LiPo.  This will provide the ancillary power for the boat.  The main 6S units are on back order.
(https://modelboatmayhemimages.co.uk/images/2022/08/30/20220830_163713-Custom.jpg)
And it will sit between the main LiPos, somewhere here, but lower once I've taken a saw to the frames...
(https://modelboatmayhemimages.co.uk/images/2022/08/30/20220830_163657-Custom.jpg)
Hoping to take the 1/10th Aquarama for an outing to the Black Park MBC Open Day on Sunday, and hoping the weather remains OK...
David.
Post by: DJW on September 07, 2022, 07:19:54 pm
Work continues on a few bits of hardware.
3D printed a couple of fan ducts. These will act as extractor fans for the interior of the hull. Pipes will connect to the exhaust stubs.
(https://modelboatmayhemimages.co.uk/images/2022/09/07/PSX_20220907_182421.jpg)
Fans will be mounted high to avoid any water coming into the hull.
(https://modelboatmayhemimages.co.uk/images/2022/09/07/PSX_20220907_182455.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/09/07/PSX_20220907_182522.jpg)
Also been working on the port electronics case. The fan is over the SBEC Heatsinks in this case. There is a cutout in the mounting panel and then a vent so the flow is past the SBEC and then out. There will be another vent as some of the components will benefit from small heatsinks and so ideally need an airflow too.
(https://modelboatmayhemimages.co.uk/images/2022/09/07/PSX_20220907_183913.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/09/07/PSX_20220907_183849.jpg)
Will be adding the various components over the coming days.
David.
Post by: DJW on September 09, 2022, 05:58:44 pm
Friday update.  Fedex arrived earlier with 4 x 4,000mAh 6S Turnigy Graphene LiPos for this build, planning to use them as 2 x parallel pairs, so 8,000mAh available to each motor.  I also added a couple of 3,000mAh 3S LiPo spares for the 1/10 build, quite a size and weight difference:
(https://modelboatmayhemimages.co.uk/images/2022/09/09/20220909_101344-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/09/09/20220909_101601-Custom.jpg)
And have been busy building up the port electronics package, it's very much a work in progress...  Currently Rx at top left with expansion board below it. SBEC at lower left. 12V PSU at top right with 2 x RC switches for Dock lights and Nav lights at top centre. Fuse board at lower right an in the middle an arduino and Mosfet that drives the fans in the ESC case based on their temperature. Lower centre is a small step down board that will supply 5V to the (LED) lights.  Just building up the board so I can figure out what connectors need accommodating and where on the case....
(https://modelboatmayhemimages.co.uk/images/2022/09/09/20220909_173532-v2.jpg)
David.
Post by: DJW on September 21, 2022, 01:31:15 pm
Afternoon All
An update on the smoke generator, still a work in progress...
I now have the unit producing smoke and pulsing that smoke, like a V8 on start up, and that pulse rate is linked to the throttle setting on the Tx.
Still needs refining, but the basics are now there.  To get the pulsing action I've placed a rotating disc under the smoke exit pipes, this rotor has cutouts so the exit pipe alternate between open and closed.  This is rotated by a 300rpm 12V motor.  This motor and the fan that drives the smoke out are under proportional control slaved to the throttle.  The 'smoke' is created by vaporising glycerine...  I've realised that's not the best idea as it can create sugar, and then burn it, not good...  So I've a bottle of commercial water based smoke fluid on its way.  Should be similar effect, but lower risks...  A bit more testing then optimising the electronics to fit inside one of the electronics boxes.  Plan is to have the smoke unit on a momentary switch on the transmitter, so it will then run for say 30 seconds, then switch itself off and have to be manually reactivated, primarily a protection against overheating due to a forgetful operator...
Here's a pic, and a link to a video file.
(https://modelboatmayhemimages.co.uk/images/2022/09/21/Smoke-Custom.jpg)
https://vimeo.com/752084275/68d3eeba2b (https://vimeo.com/752084275/68d3eeba2b)
David.
Post by: DJW on September 28, 2022, 05:07:31 pm
Afternoon All
Still busy with the electronics boards, second board is coming along:
(https://modelboatmayhemimages.co.uk/images/2022/09/28/20220928_163608-Custom.jpg)
I had to swap out the 'Tarot' 8 Channel SBUS extender as it was demonstrating some very strange behaviour, mixed up channel outputs, and no output on some channels.  I did see some corrosion on the underside of the board, looked like excess flux to me that had started breaking down the board.  Anyway confidence in it (and the Tarot QA team...) lost, it's in the bin.  Replaced with two FrSky 4 Channel SBUS extenders, I should have just used the FrSky units in the first place...  A bit more work on that board and it should be good to go.
Also been playing with the 3D printer.  Designing and printing an 'exhaust manifold'...  Plan is to use 25mm od brass tube for the exhaust stubs, these will be chromed.  Then I need to feed the coolant water outlet, the airflow outlet from the hulls interior and the 'smoke' output through the 'exhaust', so this manifold is to bring them together.  A couple of mounting flanges, the unit is a push fit into the brass tube, seal improved with the grooves for O rings.
The Tinkercad design:
(https://modelboatmayhemimages.co.uk/images/2022/09/28/Exhaust-Manifold-V2.jpg)
The printed result, needs a little cleaning up, 4 hours to print:
(https://modelboatmayhemimages.co.uk/images/2022/09/28/20220928_163848-Custom.jpg)
The 3D printer approach makes the fabrication of quite a tricky component a lot more straightforward.
(https://modelboatmayhemimages.co.uk/images/2022/09/28/20220928_163924-Custom.jpg)
The main fan will force air through the exhaust from the 'back', the second inlet is for the smoke to be introduced:
(https://modelboatmayhemimages.co.uk/images/2022/09/28/20220928_163506-Custom.jpg)
I'm enjoying the build up of the various bits of hardware, but am looking forward to getting back to the woodwork..!
David.
Post by: Capt Podge on September 28, 2022, 06:54:24 pm
Owing to a scant knowledge of electrical wizardry I'm unable to submit any useful comments on your work David however, still finding it all fascinating  O0 .
Aye,
Post by: Stuw on October 01, 2022, 08:06:38 pm
Wot he said!  :-))
Post by: Mark T on October 02, 2022, 12:20:27 pm
What they both said  {-)   Honestly your work is incredible  :-))
Post by: DJW on October 05, 2022, 06:08:57 pm
Very kind comments, not sure fully deserved...  My approach is 'how difficult can it be..?'  and so I try.  Sometimes it works out, sometimes it takes a few attempts, and sometimes...  Well it just doesn't.
Electronics is a bit of an issue at the moment, parts all worked fine testing individually, but put them all together, and its a different story.  Waiting on a few new components, so thought I'd get back to some metalwork in the meantime.
The rudders, will be shaped from 4mm brass plate on 5mm stainless shafts and custom tubes.  Bearings from an engineering plastic and a good quality seal at the top.  I'll lube them up before use, but they shouldn't really need it.
(https://modelboatmayhemimages.co.uk/images/2022/10/05/20221003_173348-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/10/05/20221005_173741-Custom.jpg)
All still work in progress.  Rudders bolted together to allow some machining and keep them symmetrical.
(https://modelboatmayhemimages.co.uk/images/2022/10/05/20221005_173841-Custom.jpg)
Also working on the P brackets:
(https://modelboatmayhemimages.co.uk/images/2022/10/05/20221003_173420-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/10/05/20221004_152351-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/10/05/20221004_152446-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/10/05/20221004_154943-Custom.jpg)
Making the bearings out of this stuff: [size=78%]https://www.igus.co.uk/product/539?artNr=SFRX-1000 (https://www.igus.co.uk/product/539?artNr=SFRX-1000)[/size]
Bit of a leap of faith, but it machines really well and I can make it any length / design  so above is a flanged bearing that is an interference fit with the P bracket (pushed in once silver soldered), plus a 'thrust washer' of same material.  I spoke to the manufacturer, they seem to think it will work well in this use case.
David.
Post by: DJW on October 13, 2022, 11:07:59 am
An update after a bit of time on the milling machine.
Rudder blades and P bracket skegs bolted together and machined together to ensure they're same size and shape.
(https://modelboatmayhemimages.co.uk/images/2022/10/13/20221013_103916-Custom.jpg)
This is the full size rudder for the Aquarama, so I'm going for a similar shape (also as per the 1/10 build which is working well on that boat).  I'm convinced that keeping the rudder blades not so deep helps stop the Aquarama rolling so much in turns by reducing the amount of lift.  I'm also putting the shaft about 30% from the front of the blade, more conventional for balance I think, the Riva item is unusually far forward...
(https://modelboatmayhemimages.co.uk/images/2022/10/13/AquaramaRudder-Custom.jpg)
And the set of blades / Skegs at the moment:
(https://modelboatmayhemimages.co.uk/images/2022/10/13/20221013_104203-Custom.jpg)
And the blades dry fitted on their shafts / stocks (shafts are an interference fit to the blades, not fully seated yet til I'm ready to solder):
(https://modelboatmayhemimages.co.uk/images/2022/10/13/20221013_104144-Custom.jpg)
I think I'll do some shaping of the blades next before silver soldering to the shafts...  But might be easier to hold if the silver soldering is done first...
We'll see.
Best regards
David.
Post by: Capt Podge on October 13, 2022, 02:10:51 pm
Well they certainly look the business and as for the soldering I'd definitely go with the shafts attached first - less chance of damage to your hands that way!
Aye,
Post by: Mark T on October 14, 2022, 04:19:00 pm
Reading the specs of what you are making the bearings out of it looks like a very good material. I've never heard of it before but its not like models are run for hundreds of hours and they are often over engineered.  Its great to see something new being added to our hobby - having said that I bet others have heard of it before  {-)
As for the rudders - lovely job I reckon people could dig their gardens with them no problem!!  Great job!!!
Post by: DJW on October 15, 2022, 10:55:54 pm
Well I'm certainly putting plenty of faith in that plastic bearing material. We'll see how it performs...
Some progress with the rudders today. Some shaping then some soldering and some more shaping. Still some polishing but pleased with results so far.
(https://modelboatmayhemimages.co.uk/images/2022/10/15/PSX_20221015_194158.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/10/15/PSX_20221015_194216.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/10/15/PSX_20221015_194327.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/10/15/PSX_20221015_194249.jpg)
Once these are polished up it will be on to same work on the P brackets.
Happy weekend to all.
David.
Post by: DJW on October 16, 2022, 06:15:58 pm
Rudders finished.
(https://modelboatmayhemimages.co.uk/images/2022/10/16/PSX_20221016_175626.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/10/16/PSX_20221016_175702.jpg)
Couple of air bubbles in the silver solder. But not bad enough to do it again... just irritating...
(https://modelboatmayhemimages.co.uk/images/2022/10/16/PSX_20221016_175829.jpg)
Meant to shoot the rudders against a ruler. But forgot...  the tube used on the rudder stocks is 10mm OD.
Leading edge profile.
(https://modelboatmayhemimages.co.uk/images/2022/10/16/PSX_20221016_175729.jpg)
And trailing edge.
(https://modelboatmayhemimages.co.uk/images/2022/10/16/PSX_20221016_175758.jpg)
Blades are 60mm in length,  40mm deep and 4mm thick on 5mm shafts.
Regards to all..!
David.
Post by: Capt Podge on October 16, 2022, 07:45:06 pm
Congratulations on a fantastic job, they are real beauties, it's a shame they'll have to go into the wet stuff!
Cheers,
Post by: DJW on October 17, 2022, 09:30:18 am
Haha... They may spend their time on the lake underwater and unseen, but you and I will know they're there and that they're very shiny...!  :-))
Post by: DJW on October 17, 2022, 06:40:42 pm
Couple of hours shaping the P bracket struts today.
(https://modelboatmayhemimages.co.uk/images/2022/10/17/PSX_20221017_181048.jpg)
Some aggressive filing then finer grit sanding discs. Final polish will wait for after the soldering.
(https://modelboatmayhemimages.co.uk/images/2022/10/17/PSX_20221017_181123.jpg)
Shape is now about right I think.
(https://modelboatmayhemimages.co.uk/images/2022/10/17/PSX_20221017_181148.jpg)
Next step is the more tricky silver solder job. Joining the skegs to the bearings.
So this is what it should look like, if I don't melt them...
(https://modelboatmayhemimages.co.uk/images/2022/10/17/PSX_20221017_181216.jpg)
Will post the results...
David.
Post by: DJW on October 18, 2022, 06:06:40 pm
Evening All
P Brackets are ready...!
I was a bit worried about how this would go, but very pleased with the results.
Made up a jig to hold skeg and bearing hub in position:
(https://modelboatmayhemimages.co.uk/images/2022/10/18/20221018_105116-Custom.jpg)
That's a firebrick btw, not MDF...
Managed to keep the silver solder in the joint in the main...
(https://modelboatmayhemimages.co.uk/images/2022/10/18/20221018_120641-Custom.jpg)
And the cleaned up versions:
(https://modelboatmayhemimages.co.uk/images/2022/10/18/20221018_174912-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/10/18/20221018_174924-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/10/18/20221018_175104-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/10/18/20221018_175132-Custom.jpg)
Maybe a tad more buffing up, otherwise good to go.
Props will be drilled and tapped for a grubscrew rather than use a nut on the shaft.  (This was recommended by UKMike and has worked really well. (As in it looks good and I haven't lost a prop on the 1/10th yet...)
Going to start working my way up the shafts now to the motor mounts.  So thrust collars, couplings and so on.
Hope the updates are of interest.
David.
Post by: Capt Podge on October 18, 2022, 07:14:17 pm
David.
Definitely of interest David!
... and quite inspiring as well... Once again, a beautiful result.  :-))
Aye,
Post by: Ralph on October 18, 2022, 10:34:20 pm
Haven't commented before, but I'm really enjoying your build. The electronics are way over my head but the quality of what you are doing is superb.
Ralph
Post by: DJW on October 25, 2022, 09:05:59 pm
Thanks for the feedback and encouraging comments chaps.
Been looking at the top end of the prop shafts and how they're going to connect to the motor mounts. I've got most of it figured out with 3D printed prototype parts, so it's now time for the brass and aluminium components to be created.
(https://modelboatmayhemimages.co.uk/images/2022/10/25/PSX_20221025_183417.jpg)
Prop tubes are 10mm brass, so am making up a brass header that will contain a bearing race plus seal plus oiling tube and be finished with a 35mm diameter flange that will connect to the thrust block.(Still in black plastic in the above picture)
I've been scratching my head re how to get the flanges accurate as I don't really have the tooling to do it. I'm trying with 3D printed dies that hold the flange plates and have guide holes in precise locations required. And it seems to work...
(https://modelboatmayhemimages.co.uk/images/2022/10/25/PSX_20221025_182742.jpg)
And when flipped over
(https://modelboatmayhemimages.co.uk/images/2022/10/25/PSX_20221025_182808.jpg)
Then tapped out for M4
(https://modelboatmayhemimages.co.uk/images/2022/10/25/PSX_20221025_183405.jpg)
That's one of the flanges for top of a shaft. It'll be silver soldered after a bit more machining. Then ready to move on to the thrust block.
Quite pleased with that approach as it should keep all the flanges accurate.
Work in progress..!
David.
Post by: DJW on October 26, 2022, 05:54:18 pm
More progress...
Bit more machining of the top end of the prop shaft ready to take its flange.
(https://modelboatmayhemimages.co.uk/images/2022/10/26/20221026_143602-Custom.jpg)
And some machining of the flange itself so its an interference fit (small hammer required to seat it..)
(https://modelboatmayhemimages.co.uk/images/2022/10/26/20221026_143609-Custom.jpg)
So its ready to silver solder
(https://modelboatmayhemimages.co.uk/images/2022/10/26/20221026_143617-Custom.jpg)
This shows the seat for the 11mm od ball race and 15mm od seal, and shows an apparent gap where the flange joins...  I put a bit of a chamfer on the end so there's somewhere for the silver solder to go, its actually a tight push fit...
(https://modelboatmayhemimages.co.uk/images/2022/10/26/20221026_144030-Custom.jpg)
Here's the ball race inserted
(https://modelboatmayhemimages.co.uk/images/2022/10/26/20221026_144040-Custom.jpg)
And the seal over the bearing (this build method will keep all parts available in future for maintenance / replacement if required)
(https://modelboatmayhemimages.co.uk/images/2022/10/26/20221026_144123-Custom.jpg)
And here's the result after some silver soldering and facing on the lathe
(https://modelboatmayhemimages.co.uk/images/2022/10/26/20221026_161955-Custom.jpg)
Foreground of the pic above shows start of the thrust bearing assembly, thrust will be passed to the solid part of the motor mount, not the motor which will be isolated on bobbin mounts.
And finally for today, I've got the aluminium bar stock in the lathe that will hopefully become the thrust block between the top of the prop shaft and the motor mount.  3D printed version shown alongside, that's what I'm aiming for...
(https://modelboatmayhemimages.co.uk/images/2022/10/26/20221026_161814-Custom.jpg)
We shall see.  Next exciting episode (maybe) tomorrow...
Best regards to all
David.
Post by: Nordlys on October 26, 2022, 06:52:11 pm
You seem to have made a very gallant attempt to drill the flanges accurately! That kind of accuracy usually needs the dividing head as you indicate.
That's where a lot of projects for me go adrift with just a bench pillar drill and centre punch!
N
Post by: DJW on October 27, 2022, 01:29:12 pm
Hi N
Agreed re the problems marking out then centre punch then pillar drill. That's been an issue for me too. This is most ambitious machining attempted by me in a while...  Test with the 3d guides will be to see if they are consistent enough in terms of correct line up when holes are transferred to metal. I plan to print a new guide for each flange to avoid any wear in the holes building up to a problem.
A cnc setup would be nice....  But not sure the wife would agree. 🤔
Best regards
David.
Post by: DJW on October 27, 2022, 07:02:29 pm
Didn't have much time today, but promised an update. Some progress with initial machining of the aluminium bar for the thrust collar.
(https://modelboatmayhemimages.co.uk/images/2022/10/27/PSX_20221027_183844.jpg)
It's then a 10mm drill all the way through, and a boring bar to take out most of the length to 16mm id.  The flange at the left of the pic above will be left at 10mm, this is where the 15mm od thrust bearing will be seated.
Will then cut at the left flange and mill out to expose the shaft and give access to the thrust collar for adjustments and face that left flange. That's the motor mount end.
(https://modelboatmayhemimages.co.uk/images/2022/10/27/PSX_20221027_183805.jpg)
That's now tomorrow's task.  Then we'll see if the flanges line up OK...
Regards to all
David.
Post by: DJW on October 29, 2022, 06:18:00 pm
First thrust collar machined...
This is the thrust bearing that will take reverse thrust.
(https://modelboatmayhemimages.co.uk/images/2022/10/29/PSX_20221029_180046.jpg)
And this is the forward bearing.
(https://modelboatmayhemimages.co.uk/images/2022/10/29/PSX_20221029_180125.jpg)
Milling out the access slot.
(https://modelboatmayhemimages.co.uk/images/2022/10/29/PSX_20221029_180156.jpg)
And comparison with the 3d printed version.
(https://modelboatmayhemimages.co.uk/images/2022/10/29/PSX_20221029_180221.jpg)
And the assembly so far.
(https://modelboatmayhemimages.co.uk/images/2022/10/29/PSX_20221029_180246.jpg)
And this is where the thrust collar will transfer that thrust to the motor mount.
(https://modelboatmayhemimages.co.uk/images/2022/10/29/PSX_20221029_180504.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/10/29/PSX_20221029_180530.jpg)
Coming along...
David.
Post by: Mark T on October 29, 2022, 10:08:42 pm
Thats some pretty amazing engineering going on there.  A great build that just gets better as it evolves  :-)
Post by: DJW on November 05, 2022, 10:12:02 pm
Thanks Mark. I suspect that like you I need to know that I've done my very best with the build, so, I try.
Not much progress this week, just a few hours today. But good news is that the flanges are lining up. This is current state of play...
(https://modelboatmayhemimages.co.uk/images/2022/11/05/PSX_20221105_195539.jpg)
Also now drilled at the motor mount end. And with thrust bearing in place.
(https://modelboatmayhemimages.co.uk/images/2022/11/05/PSX_20221105_195638.jpg)
And the whole assembly.
(https://modelboatmayhemimages.co.uk/images/2022/11/05/PSX_20221105_195602.jpg)
It's pretty rigid and I think fit for the power of the motors.
Now have to make the second one, but should be easier as it will be a copy.
Regards to all.
David.
Post by: Capt Podge on November 05, 2022, 10:52:12 pm
I've just been playing catch-up on your updates David and I must say that I am in absolute awe of your abilities - you're showing just what can be achieved with attention to detail. Really appreciate your updates.  :-))
Post by: T888 on November 06, 2022, 11:14:33 am
Hi David,
Nice bit of engineering,  :-)) like you I enjoy making my own running gear, just a question how do you plan on lubricating the shafts ?
Post by: DJW on November 06, 2022, 05:41:10 pm
Hi Ray and Dave
All I can say is that having set out to build a 1/5 Aquarama I think I have to pull out all the stops to do it justice. And I've made my life just that little more difficult by wanting to suppress unwanted brushless sounds as far as possible. And add a boatload (pun intended..!) of electronic toys. Don't know how long it's all going to take... or cost...
But I am enjoying the build process, that's the main thing..!
@Dave. I've yet to add an oiling tube on the shaft tube. I'm planning to add it on that top brass collar that holds the top bearing and seal. There is an issue with this as I've found on the 1/10 build, there's a large deck assembly immediately above that collar. So maybe still add the tube there but add a feed tube in a more convenient location and link with some pipe. Then I use a syringe to force in a few ml of lube before each outing.
I'm using what I've heard is the Ron Dean mix, vasalene, WD40 and 3 in 1 oil in roughly equal parts on the 1/10 Aquarama. Seems to work very well and that's using the same seals as the current build. I add a drop of same mix to the 'other' side of the shaft seal near the motors every now and then just to stop the seal getting dry.
I was reading on the forum that some are using olive oil. I'd like to do that from an eco point of view, but have also ready mixed reports. Until I'm more convinced I'll stick with the current mixture.
Best regards
David.
Post by: Stuw on November 08, 2022, 09:56:13 am
Wow....I’m assuming that thrust bearings aren’t needed on smaller scale boats? It becomes an issue due to your scaled up version? Without any is my (someday to be finished) Javelin with brushless motor likely to suffer as the forces are transmitted into the motor?
Post by: DJW on November 08, 2022, 10:41:27 am
Morning Stuw
To be honest I don't know what forces the outrunner motors can really take. I do know they're designed to take the pull or push of an aero / drone propeller, but given water is a more 'solid' substance than air, it could create significant loads, instantaneous and sustained...  Maybe there are some folks here who can comment. I'm doing it for a couple of reasons that I can't really quantify, more of a gut feel.
1. I'm using exposed shafts, and I don't want the P brackets to take the force.
2. The motors have the potential to develop around 1,600w / 2.2hp each. I just remember using a 2hp outboard motor and the force it could generate.
3. I'm planning to isolate the motors from the hull by mounting on bobbin mounts, and at the coupling using a suitable three part design.  So this alone means I can't have the thrust from the shaft passed to the motors.  They just have to produce their rotation energy, and not take any forces that would deform the rubber mounts...
In general terms I think the issue of where to take the thrust rises as the motor size and power of that thrust goes up.  On full length prop tubes I think its conventional to use a thrust washer (maybe a teflon washer between a couple of ss washers) at the prop end to help take and transmit the thrust to the prop tube.  So it's not all passed up to the motor.  Then its down to setting up the shaft to not place too much thrust at the coupling end.
As always just my opinion.  A very interesting point and I'd be interested in other folks views.
(Then there's always the fact that I like using the lathe...)
Best regards
David.
Post by: ChrisF on November 08, 2022, 02:20:16 pm
Yes, David, we all know it's because you like to introduce a nice bit of engineering!   :-)
But seriously can't really argue with anything you are saying with the main points being that in this build you are isolating the motors and also that the forces on the P bracket could be considerable. Ok they could be reduced/eliminated by using a collar at the end of the prop tube just outside of the hull with washers as you have said for full length prop tubes but its nowhere as elegant a solution and you have the space.
So no Stuw, it won't be a problem with your Javelin or similar sized craft and the locknut and thrush washer approach at the prop end and a collar at the motor end is a tried and tested solution. Even if some thrust is applied to the motor by not setting up correctly the motor should still last for ages.
Chris
Post by: JimG on November 08, 2022, 07:55:34 pm
There's much less worry about thrust being applied to the motor bearings with a brushless motor. The old brushed motors normally use a plain bearing so any thrust is applied to the face of the bearing and any lack of lubrication will create drag and wear the bearing surface. Brushless motors use ball bearings and they are designed so that the load is on the bearing center which rotates with the shaft so no wear from this. The actual load is on the balls running on the hardened outers and as they are normally a sealed bearing they are well lubricated. As you say these motors are generally sold for aircraft use where the load is on an e-clip on the shaft at the rear of the motor running on the rear bearing. In a boat the load is normally in the opposite direction where it is the rear of the rotating case pushing on the internal bearing. In both cases the bearings can take the load easily without problems.Not too sure why you need to isolate the motors as they should be well balanced and vibration free when running.
Jim
Post by: Stuw on November 09, 2022, 10:11:17 am
Morning Stuw
Best regards
David.
Hi David. That all makes sense to me. I understand now that you want to avoid loading the P brackets and the shear scale of your boat warrants some serious use of the lathe I reckon  :-))
Although it’s not something I’ve done, I also see the need to solve the issue as you’re mounting the motor on bobbins. To be honest I had thought of doing that with mine but couldn’t get my head around avoiding the motor being pushed around! By using the bobbins I take it one of your aims is to eliminate noise being transmitted and magnified through the hull so that you can have a deeper V8 sound generated?
Thanks again for the detailed explanation. I follow with interest and awe...
Post by: DJW on November 09, 2022, 11:56:23 am
Morning Chaps
@Jim. Thanks for the feedback re the bearings, good to know. I agree that these brushless motors are well balanced and precision pieces of engineering, so no mechanically generated 'vibrations' to speak of.  Having said that... I really don't like the high pitched whine that these systems give off, and that's what I'm trying to address...  (The following might be rubbish, but it's what I understand right now...)
I think the whine comes from the pulsing of power into the coils of the pole pairs.  My motors are 14 pole, so seven pairs, each shaft rotation needs 7 'jolts' of volts (and amps..), so to speak, so this is not really totally smooth delivery of power.  Its 7 kicks per shaft rotation.  I'm using FrSky Neuron ESCs that can use sine wave delivery of that power, so smoother than usual...  But the issue then remains if one attaches this 'pulse generator' or as we're calling them 'brushless motors', to a sounding box, or as we're calling them, hulls, we get a very effective speaker resonating at whatever frequency (or harmonic that we can hear) is being generated by the motors...
Maybe the ESCs are adding to the party too as they're busy generating these pulses...   (Just like a mains transformer will hum)
So, I'm isolating and containing the ESCs.  And doing my best to isolate the motors.
@Stuw. I have the same concerns about the bobbins allowing too much movement, that really would not be good.  So, this is the initial test arrangement, standard 20mm bobbins x 4 on the prototype 3D printed mount:
(https://modelboatmayhemimages.co.uk/images/2022/11/09/PSX_20221109_102958.jpg)
It's pretty firm, but could be better, so I've added some cups (below) that are a tight fit around the bobbins.  At the moment just in PLA plastic from a 3D printer.  And they really make the mounts more rigid and resistant to the effects of torque by constraining their movement, while still isolating the motor from the mount and hull with rubber...
(https://modelboatmayhemimages.co.uk/images/2022/11/09/PSX_20221109_103015.jpg)
The idea is that the cups can be made shorter or longer to arrive at a solution that works.
Whether it will all work...  I don't know but it's fun to try.
My 1/10th Aquarama is noticeably quieter than many other similar brushless systems, so I'm planning to use similar techniques, and go further in the quest to have a quiet boat..!
And yes, I'd rather just hear the water coming off the hull, or the V8 sound system..!
Best regards
David.
Post by: DJW on November 09, 2022, 12:44:19 pm
By the way...  I now have two of the thrust blocks ready to go.  That makes the props to the couplings for both shafts reasonably complete.
(https://modelboatmayhemimages.co.uk/images/2022/11/09/PSX_20221109_123704.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/11/09/PSX_20221109_123631.jpg)
Motor mounts next...
David.
Post by: ChrisF on November 09, 2022, 04:10:32 pm
What can one say!   :-))
Post by: SteamboatPhil on November 09, 2022, 06:33:54 pm
Gobsmacked......absolutely brilliant..  :-))
Post by: Stuw on November 09, 2022, 10:09:49 pm
Post by: DJW on November 11, 2022, 05:39:39 pm
Thanks Chaps, just hoping it all works out...
A quick update.  I knew cutting out the aluminium for the motor mounts would be arduous, and it is.
Early days, the channel has been cut and marked up:
(https://modelboatmayhemimages.co.uk/images/2022/11/11/20221110_085936-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/11/11/20221110_092952-Custom.jpg)
Had to remove the usual clamp and just bolt the mount to the mill to accommodate it...  Then started to get the edges square, and then used a small mill bit to start to cut out the interior, want to get good square cuts if I can and rounded corners.
(https://modelboatmayhemimages.co.uk/images/2022/11/11/20221110_174359-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/11/11/20221111_172536-Custom.jpg)
If I can get one mount cut from the channel, drilled and trimmed this weekend I'll be happy.
David.
Post by: DJW on November 14, 2022, 06:22:11 pm
Evening All
Took a bit longer with the first motor mount than I'd anticipated. But it's now its pretty much ready.
(https://modelboatmayhemimages.co.uk/images/2022/11/14/PSX_20221114_180208.jpg)
And here with a motor in place.
(https://modelboatmayhemimages.co.uk/images/2022/11/14/PSX_20221114_180328.jpg)
And with a shaft ready to attach.
(https://modelboatmayhemimages.co.uk/images/2022/11/14/PSX_20221114_180356.jpg)
Next is either make another mount, or carry on and create the water cooling plate, currently a 3d plastic template in the pics above....
It's nice to see the mount coming together in aluminium. Feels like progress.
Regards to all.
David.
Post by: Capt Podge on November 14, 2022, 07:51:54 pm
That's a fine and solid looking bit of work you have done there David - great work with it so far  :-))
Post by: T888 on November 15, 2022, 03:33:31 pm
Nice bit of milling  :-))
Post by: DJW on November 15, 2022, 09:17:58 pm
Thanks Both. A couple of hours today starting to fabricate the motor mount plates. 8mm aluminium plate cut to 80x50mm x 2.
(https://modelboatmayhemimages.co.uk/images/2022/11/15/PSX_20221115_210449.jpg)
Then edges milled to get everything square, nice finish and final sizing.
(https://modelboatmayhemimages.co.uk/images/2022/11/15/PSX_20221115_210612.jpg)
Then a 2mm plate same size, and drilled out using 3d printed template again for the hole positions.
So now at 10mm thick. And tomorrow will be milling out some water cooling channels.
(https://modelboatmayhemimages.co.uk/images/2022/11/15/PSX_20221115_210639.jpg)
David.
Post by: DJW on November 19, 2022, 05:20:23 pm
Afternoon All
Well it's been a bit of a week. On the downside. Felt a bit rough, but Wednesday I didn't have Covid, then another test on Thursday and it seems I do have Covid. No idea how I got it. On the upside... Any going out plans cancelled and did get a few hours of building in today and hopefully more tomorrow...
The mounting plates are coming along nicely. First one is fully machined. This is the water inlet and outlet.
(https://modelboatmayhemimages.co.uk/images/2022/11/19/PSX_20221119_162218.jpg)
And then routed around the plate.
(https://modelboatmayhemimages.co.uk/images/2022/11/19/PSX_20221119_162251.jpg)
Not my finest work. But I think its accurate enough to be functional.
So here's the plate in situ with motor, and main mount.
(https://modelboatmayhemimages.co.uk/images/2022/11/19/PSX_20221119_162409.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/11/19/PSX_20221119_162457.jpg)
I'm pleased that the mounting system is rigid now it's in aluminium.
So next it's complete the second set...
And as the plates are two part, they have to be joined and sealed. My current plan is to use an approach I used back in the day using Araldite Rapid and an oven. I heat the aluminium in the oven to about 50 ish degrees, then apply the mixed epoxy, it's viscosity reduces and it flows really well, I think this helps it bond even better with the aluminium. Anyway its worked for me in the past with aluminium so I'll give it a go. Once cooled, the epoxy is fully flowed and very hard so should fully seal the mount plate.
David.
Post by: Capt Podge on November 19, 2022, 05:43:06 pm
Sorry to hear you've been 'under the weather' David but good to see you're still able to get a bit more done and your explanation of how to achieve the seal sounds very interesting.
Hope it all goes well for you.
Post by: ChrisF on November 19, 2022, 06:04:18 pm
A work of art - as usual!
Chris
Post by: DJW on November 21, 2022, 08:08:46 pm
Managed some time today with the 3D Printer. Tweaked the cups on the bobbins so they come in from both ends of the bobbin rather than one. Looks a bit more balanced. Also slightly thinner walls and bevelled open ends to avoid chafing the bobbins.
Old versions.
(https://modelboatmayhemimages.co.uk/images/2022/11/21/PSX_20221121_193132.jpg)
And the new versions.
(https://modelboatmayhemimages.co.uk/images/2022/11/21/PSX_20221121_193155.jpg)
And as I'm in a covid induced (wife assisted) absence from my workshop... I've started to consider a kali type of coupling customised for my needs and optimised for the mount. Initial designs in PLA then once I've figured out dimensions I think I can make the ends in aluminium and the centre from TPU filament, should be strong but flexible enough to work well transmitting power through the coupling.
(https://modelboatmayhemimages.co.uk/images/2022/11/21/PSX_20221121_193257.jpg)
(https://modelboatmayhemimages.co.uk/images/2022/11/21/PSX_20221121_193332.jpg)
Work in progress...
David.
Post by: Mark T on November 22, 2022, 04:09:04 pm
Lovely work you must have made some serious swarf getting that done!
Post by: DJW on January 01, 2023, 03:32:13 pm
Hey Mark, yes. Did make a bit of a mess, at least with the metal bits it doesn't produce the dust like wood... I have that yet to come...!
Been a bit busy over past month with life in general but finally some progress to report.
I now have the two motor mounts complete in aluminium. Plus the thrust assemblies drilled, threaded and attached to the mounts. Same with the prop tubes.
(https://modelboatmayhemimages.co.uk/images/2023/01/01/PSX_20230101_144759.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/01/01/PSX_20230101_144843.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/01/01/PSX_20230101_144819.jpg)
That last pic also has prototype coupling in view.  3D printed at this stage.
Finally. Added the oiling tubes to the prop tubes.
(https://modelboatmayhemimages.co.uk/images/2023/01/01/PSX_20230101_144927.jpg)
Need to check alignment then start to create the couplings in aluminium.
Best regards to all
David.
Post by: Mark T on January 01, 2023, 08:43:52 pm
Wow I am literally finding the engineering going into this build astounding  - I'm lost for words its that good  :-))   Keep the updates coming please!
Post by: derekwarner on January 02, 2023, 03:00:48 am
Morning David........I have followed this [and the previous] build with great interest, especially with the drive lines
With the current [1/5 scale] build, I see you appear to using a single 3 element ball thrust race in each drive shaft, however I am a little confused as am unsure if this trust race is used in two locations in differing housings within each drive shaft?
Reading about brushless motors [in-runner and out-runner styles], however I found little if any talk about the need for any additional consideration of driveline thrust :-X
May I ask, did you attempt to establish a calculation of distance to limit directional resultant thrust, or just pick a number [say 0.005"] of permissible directional limit thrust element movement?
Post by: DJW on January 02, 2023, 09:47:27 am
Morning Derek, thanks for the feedback, hope all's well with you.
Each drive line will indeed use two thrust races, one for forward thrust and one for reverse.  They will both pass their thrust forces to the motor mount.  Inside what I'm calling the 'thrust assembly' is a collar that can be locked onto the propshaft with one of the thrust bearings between the that collar and the main motor mount. Then as long as there's a little clearance between prop and P Bracket, that bearing should take forward thrust.  The second thrust bearing is going motor side as the propshaft passes through the motor mount, between the motor mount and the coupling, that will take reverse thrust and again apply it to the motor mount.  Hope that makes sense, I'll get some better pictures to illustrate.  The couplings will allow a small longitudinal movement, but it will be minimal once adjusted.
And as to why do it at all...  Well, I think it's all resulting from wanting to isolate the motors from the hull to reduce transmitted sound / whine to the hull.  Once I decided to use rubber mounts, that means the motors can move if sufficient force is applied to them, and as they're rated at 1,600w, that could get messy...  So I felt the only way was to then remove that thrust force from the motors altogether, and this is my solution.  I do agree that the motors should be able to take any longitudinal forces they generate via their shaft bearings, but in my head that force transmitted through the motor itself via ball races (not full on thrust bearings) is not ideal.  Just my view...  So all these motors should have to do is spin, all forces generated by them will be absorbed (or damped) elsewhere, that's the aim.  I also wanted to build the driveline in one assembly rather than rely on the hull itself for alignment.  It's going to be a large wooden hull after all that may flex.
As always, we'll all have to wait to see if all the effort is worthwhile..!
Very best regards and a Happy New Year to all.
David.
Post by: DJW on January 02, 2023, 08:01:12 pm
Hi Derek
Just found these earlier images, I was checking the fit of the thrust bearings in the housing.
This shows the motor end of the thrust assembly at the point it mates with the motor mount.
(https://modelboatmayhemimages.co.uk/images/2023/01/02/PSX_20230102_194528.jpg)
The hole is 7mm, to take the 5mm propshaft.
Then the assembly holds one thrust bearing on each side.
(https://modelboatmayhemimages.co.uk/images/2023/01/02/PSX_20230102_194650.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/01/02/PSX_20230102_194627.jpg)
The collar and the coupling are machined to keep the thrust bearings centralised.
Best regards
David.
Post by: Martin (Admin) on January 02, 2023, 08:36:28 pm
Beats my plastic I found in an old tool box ....  %)
Post by: derekwarner on January 03, 2023, 08:48:25 am
Thanks David
I now understand the concept set for the thrust group for each of your drive lines
Have ordered a dual set of AYX0619 [6mm x 19mm] caged needle roller components
The challenge I have is to contain, or restrict longitudinal movement in a Y2DR steam engine crankshaft
The engine has one spare 20mm space between journals, so hope to fabricate a housing to contain the trust components
regards Derek
Post by: DJW on January 03, 2023, 08:26:08 pm
Hi Derek
I guess this comes down to what fabrication tools you have available, do you have a thread running on the forum here documenting the project..?
I find it a challenge (that I enjoy most of the time...) to create the parts I need with the modest machine tools that I have.  I have to plan well ahead so I don't conceive something that i then can't fabricate. Access to a machine shop and the skills to go with it would make life easier..!!!
David.
Post by: DJW on January 18, 2023, 10:04:25 am
Morning All
Not had very much time to spend on the build recently, very frustrating...
Some modest progress to report on the drivelines.  I've been playing with 3D printed versions of the couplings required with the aim of seeing what dimensions work. Also to make sure it can all be actually assembled when in the boat, so for instance be able to replace the centre of the coupling without a full motor removal.  But now moving to the aluminium fabrication stage.  Motor end first, this (in black plastic) is an idea of what I'm aiming for in terms of machining the lugs, and next to it an aluminium blank.
(https://modelboatmayhemimages.co.uk/images/2023/01/17/20230117_151832-Mayhem.jpg)
And then a couple of jigs to hold the blanks for machining and to act as guides.  (Santa didn't bring a CNC mill...) The guides will be sacrificial for the final stage of machining, so printed one per coupling end.
(https://modelboatmayhemimages.co.uk/images/2023/01/17/20230117_151740-Mayhem.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/01/17/20230117_152629-Mayhem.jpg)
The holes in the jigs at the base are drill guides for the eventual use of grub screws that will lock the coupling to the shaft, and while in the jig will have bolts inserted to keep everything rigid while clamped in the mill.
I've then got the coupling centres printed in (a rather attractive lime green...) TPU, a more flexible filament than the standard PLA printing material.
This shows where the initial slots will be milled out, 3mm...
(https://modelboatmayhemimages.co.uk/images/2023/01/17/20230117_151805-Mayhem.jpg)
I'm working on the coupling blanks for the prop shaft end now (and for a shiny new 3mm mill cutter to arrive), they're a little different as they need to centre the (reverse) thrust bearing.  So the coupling section that has the grub screw will be a little larger in diameter (16mm, same as the thrust bearing) and have a small shoulder on the thrust bearing end to locate the bearing and centre it.
What could possibly go wrong..??!!
David.
Post by: SteamboatPhil on January 18, 2023, 03:19:02 pm
Beautiful engineering such a pity it all gets hidden the boat  :D
Post by: DJW on January 19, 2023, 11:10:17 am
Hi Phil, thanks..!  And assuming this ever materialises into a viable boat, we'll know it's there..!
Best regards
David.
Post by: SteamboatPhil on January 19, 2023, 03:18:10 pm
Post by: T888 on January 19, 2023, 03:58:05 pm
 :-)) :-))  Nice
Post by: DJW on January 21, 2023, 06:56:11 pm
Thanks for that Dave..!
Been busy with the mill. 3mm slots first.
(https://modelboatmayhemimages.co.uk/images/2023/01/21/PSX_20230121_181849.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/01/21/PSX_20230121_181919.jpg)
Then a 10mm mill to take out 3 of the lugs.
(https://modelboatmayhemimages.co.uk/images/2023/01/21/PSX_20230121_181955.jpg)
To end up with this.
(https://modelboatmayhemimages.co.uk/images/2023/01/21/PSX_20230121_182013.jpg)
Then remove the guide jig...
(https://modelboatmayhemimages.co.uk/images/2023/01/21/PSX_20230121_182031.jpg)
Still needs a bit of finishing but quite pleased with the result and the technique seems to work. Need to make the remaining three parts to make up the two couplings now...
Here with a centre inserted.
(https://modelboatmayhemimages.co.uk/images/2023/01/21/PSX_20230121_182048.jpg)
And here with a 3D printed part to show what I'm aiming for.
(https://modelboatmayhemimages.co.uk/images/2023/01/21/PSX_20230121_182119.jpg)
Best regards to all
David.
Post by: DJW on January 24, 2023, 04:32:04 pm
First coupling pretty much ready. A bit more milling on the second to go.
Inserts are flexible but strong enough I think. Not sure how far over the top I'm going... But hoping that the flexible centre damps some of the sound from the motor getting to the hull via the propshaft.
We'll see.
(https://modelboatmayhemimages.co.uk/images/2023/01/24/PSX_20230124_161910.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/01/24/PSX_20230124_161856.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/01/24/PSX_20230124_161836.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/01/24/PSX_20230124_160826.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/01/24/PSX_20230124_160859.jpg)
I do need to trim a couple of mm in the overall length so they fit properly in the mount. Pics to follow.
Best regards to all.
David.
Post by: T888 on January 24, 2023, 04:52:07 pm
Nice bit of engineering on these coupling 😀😀
Post by: DJW on January 26, 2023, 05:48:42 pm
Now have the drive trains pretty much sorted.
Had to remake the thrust collars, first ones didn't have enough diameter to take the grub screws properly.
(https://modelboatmayhemimages.co.uk/images/2023/01/26/PSX_20230126_172806.jpg)
And on the coupling, machined them a little to seat the 'reverse' thrust bearing.
(https://modelboatmayhemimages.co.uk/images/2023/01/26/PSX_20230126_172743.jpg)
Then assembled everything less the motors.  It's important that the motors can be added when the shaft and mounts are installed in one piece like this, so they can be removed without taking out a load of the other hardware too.  So the coupling on the motor end can slide up the motor shaft to be installed, then mated with the other side of the coupling and locked onto the shaft.
(https://modelboatmayhemimages.co.uk/images/2023/01/26/PSX_20230126_172715.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/01/26/PSX_20230126_172832.jpg)
Have to admit, Stbd is silky smooth and aligned well.  Port has a tight spot, will have to investigate that.  Otherwise pleased with the result.  Full isolation of the watercooled motors and thrust taken by the mounts.
This part of the build has taken longer than I'd thought.  But should be moving on to other areas now.  And that means a drive out to get some wood...
David.
Post by: Capt Podge on January 26, 2023, 07:05:13 pm
Great piece of work yet again and it'll be interesting to see how you deal with the Portside tight spot  :-)
Post by: DJW on January 27, 2023, 05:45:29 pm
Hi Ray
Thanks for that.  While the lathe was warmed up I machined a couple of brass discs for the vibration motor and silver soldered them together. This is going to be active while the 'startup' sound is running, hopefully to vibrate the hull as a V8 would while being cranked.  Case is 3D printed, motor is a 300rpm 12v unit, it outputs via a 4mm shaft with a flat on it so I've added a grub screw to secure the rotating offset weight.  I'm hoping the current chunk of 25mm diameter brass will be about right, but i can always add some more brass, or drill some out to adjust. Teflon washer as a spacer.  Motor will only be called on for short 1 second periods, so wear on the bearings should be fine.
(https://modelboatmayhemimages.co.uk/images/2023/01/27/PSX_20230127_173020.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/01/27/PSX_20230127_173042.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/01/27/PSX_20230127_173057.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/01/27/PSX_20230127_173110.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/01/27/PSX_20230127_173123.jpg)
David.
Post by: DJW on January 27, 2023, 07:26:00 pm
I've started thinking about the woodwork. In particular the planking. The 1/10 Amati version uses 1.5mm x 7mm lime followed by 1.5mm x 8mm mahogany planks. I've started to wonder about the thickness of the planks I should use for a larger 1/5 build. I can get 2.4mm or 3.2mm. I'm going to use penetrating (thin) epoxy, so using two layers of 2.4mm would give me a 4.8mm hull, or 2 x 3.2mm would be 6.4mm... Less a bit for sanding. Both pretty strong when epoxied. Could mix the thickness. Maybe thicker lime layer (actually bass on this build) then a thinner skin of mahogany.
I'm hoping for some comments. My concern is getting thicker planks to conform to the curves required. Its a dilemma at the moment. The planks need to be able to bend to the fore / aft curves. But also maintain that curve over several frames, rather than straighten out between frames.
I guess weight becomes an issue too...
I suppose I can order a couple of sample planks to see what works, but would be grateful for any thoughts re how I shoud be thinking about it. Its not the sort of purchase I want to get wrong...
Best regards to all
David.
Post by: DJW on February 07, 2023, 05:15:25 pm
Afternoon All
Made some progress in my head with the woodwork...  But that's about it.  I'm thinking that while I can use the Amati plans as a guideline for scaling up, there will need to be some fundamental changes.  One of these is to use similar thickness planking to the 1/10 build, but add stringers to the hull to reduce distance between support frames, build in rigidity to reduce flexing during the build, and on the water.  So current thinking is to use 2mm bass as the first layer, then 1.5mm mahogany as the second.  But first to get the stringers sorted, the frames modified and so on.  I also plan to add (I don't know the name...) a square section run of bass along the chine, to make the chines and frames in general firmer.
In the meantime, been playing with the 3D printer and working on a set of docklights, and how to fabricate the cabin vents and cleats.
This is the full sized Dock Lights:
(https://modelboatmayhemimages.co.uk/images/2023/02/07/Screenshot_20230129_142647_Adobe-Acrobat-Mayhem.jpg)
And I'm approaching in a similar way, a lamp (for a 5mm LED) in a housing with a flange, then an acetate sheet and a brass frame over the top, to be chromed.
(https://modelboatmayhemimages.co.uk/images/2023/02/07/20230204_123441-Mayhem.jpg)
Printed a couple of guides for cutting and drilling the acetate and brass.  Screwholes are just pilot holes at the moment so look a bit out of scale.
(https://modelboatmayhemimages.co.uk/images/2023/02/07/20230204_123425-Mayhem.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/02/07/20230207_100441-Mayhem.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/02/07/20230207_100504-Mayhem.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/02/07/20230207_100510-Mayhem.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/02/07/20230207_100536-Mayhem.jpg)
I plan to spray the plastic parts with a few coats of white primer, and eventually gloss white.  The lamps are a push fit into the housing so I can build these up with wire tails and add them in when ready.
The deck vents are quite prominent on the forward deck of the Aquarama, at 1/5 they're about 48mm in diameter, I want to machine them from 50mm diameter brass bar as one piece if I can... I've put the vent together as a 3D printed object so I have the dimensions sorted, then designed a jig to hold and wrap around the printed vent for the milling phase, and drilling the screwholes around the flange.
(https://modelboatmayhemimages.co.uk/images/2023/02/07/20230204_123534-Mayhem.jpg)
A work in progress, waiting for the brass bar to arrive.
(https://modelboatmayhemimages.co.uk/images/2023/02/07/20230204_123524-Mayhem.jpg)
And started to look at how the cleats could be fabricated.  Again the large single cleat on the forward deck is a Riva statement piece, so I'd like to fabricate in brass so it can be shaped and eventually added to the parts to be chromed.  at 1/5 its 50mm long, so I'm using same approach of 3D printed jigs to hold the components for machining.  These are the Riva items:
(https://modelboatmayhemimages.co.uk/images/2023/02/07/Screenshot_20230129_142219_Adobe-Acrobat-Mayhem.jpg)
And my starting point...
(https://modelboatmayhemimages.co.uk/images/2023/02/07/20230207_124659-Mayhem.jpg)
I've since cut and drilled the 'plate' shown above with the grey template, that's fine, and the easy bit. And the two grey holders at lower right, the right one has an 8mm hole straight down the middle to hold the rear upright of the cleat for machining on the lathe. The left one has an 8mm hole with a 10 degree angle on it, as the forward upright of the cleat is inclined forward, so this is my attempt to create similar.  Initial machining is to add a 3mm spigot / locating pin on the end of the uprights to locate them in the base plate ready for silver soldering.  The uprights will also be milled to flatten the sides a shade, then an 8mm mill at the top to allow a blend to the top bar of the cleat...  Then silver solder it all together and try to profile it...
We shall see..!
David.
Title: Re: 1/5 Riva Aquarama...
Post by: DJW on February 10, 2023, 07:32:24 pm
Evening All
Well that didn't all go to plan...  Royal Mail delivered me an empty box, no sign of the 50mm brass bar. Someone has a nice paperweight.... So the vents are pushed back til a replacement arrives.
The 3D printed jigs for the cleats were a failure. Couldn't get them to grip the brass. So took a simpler approach, this was as cut, machined and milled.
(https://modelboatmayhemimages.co.uk/images/2023/02/10/PSX_20230210_191433.jpg)
And this is current state. Some profiling, smoothing and polishing to go, but shape is starting to appear.
(https://modelboatmayhemimages.co.uk/images/2023/02/10/PSX_20230210_191507.jpg)
David.
Post by: Stuw on February 16, 2023, 06:18:05 pm
You’re work amazes me.  :-))
Post by: DJW on February 21, 2023, 05:42:16 pm
Hey Stuw, thanks for that..!
Some progress on a few fronts since last post, including finally the creation of some sawdust...!
The dock lights.  I've applied plastic primer, then some white spray gloss to the housings, and purchased some 20mm diameter LED reflector / collimators...  They need some cutting down to fit in the housings, to 17mm, but could be interesting.  They're £3.99 on Amazon for 10. ( [size=78%]https://www.amazon.co.uk/dp/B011HFSIDM (https://www.amazon.co.uk/dp/B011HFSIDM)[/size][size=78%] ) [/size]Seems they have an 8 degree 'viewing angle', which I assume means they pull the LED beam together like a full sized reflector. They've made of solid plastic so I guess act like a lens, I've not seen or used them before...
(https://modelboatmayhemimages.co.uk/images/2023/02/21/20230221_151045-Mayhem.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/02/21/20230221_151040-Mayhem.jpg)
I'm think 5mm high brightness warm white LEDs.  I'll post the results.
Here's the housings at the moment:
(https://modelboatmayhemimages.co.uk/images/2023/02/21/20230221_151135-Mayhem.jpg)
I've been modifying the stern half of the hull.  It's quite useful that the keel is in two parts, makes it a bit more manageable at this stage.
These are the frames pretty much just scaled up from the Amati 1/10 plans:
(https://modelboatmayhemimages.co.uk/images/2023/02/21/20230217_130855-Mayhem.jpg)
And then after some attention with saws and drills of various sizes and shapes...
(https://modelboatmayhemimages.co.uk/images/2023/02/21/20230221_145604-Mayhem.jpg)
Holes are mainly to allow passage of wires and tubes rather than weight saving. So much easier to do at this stage. Everything is dry fit right now.
One of the electronics packages is shown in its correct location, both can now be recessed well into the frames making space in the hull for the LiPos and ESC box.  LiPos will sit low in the hull with the option to stack two to run in parallel.  You can just make out the cut outs that will take longitudinal stringers, these will be cut from 6mm ply, be about 40mm deep and run from the motor mounts to the transom.  They're 10mm apart to accommodate the prop and rudder tubes, and they'll provide a strong mount for the P brackets.  These are not on the 1/10 build, but I'm hoping they'll add serious stiffening to the 1/5 hull.
(https://modelboatmayhemimages.co.uk/images/2023/02/21/20230221_145804-Mayhem.jpg)
Finally for today...  The 50mm brass bar for the vents arrived, but I've not got beyond mounting it in the lathe...  So, this is the starting point.
(https://modelboatmayhemimages.co.uk/images/2023/02/21/20230220_170552-Mayhem.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/02/21/20230220_170605-Mayhem.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/02/21/20230220_170627-Mayhem.jpg)
I'm flitting around various parts of the build...  I think it gives me time to consider what comes next with the various different assemblies. (Also, I get in trouble if I create too much dust...  %) [size=78%] )[/size]
That's about it for now.
David.
Post by: Capt Podge on February 21, 2023, 08:23:31 pm
Hi David, I have to admire the way you manage to plan your way around the build and the accuracy needed.
I guess that flitting about does help to focus the mind.
Cheers,
Post by: Circlip on February 22, 2023, 10:53:10 am
Think i'd be inclined to put a thrust pad and tailstock support on the end of that lump of brass rather than the overhang.
Post by: DJW on February 22, 2023, 11:17:53 am
Hmmm, I did think that was a bit marginal.  I have a tailstock centre and can use that to avoid mishap.  It'll be quite light machining with that length of brass, just to cut the outer edge of the vent down to the flange, then I'm thinking start a cut with the parting cutter and use that as a hacksaw guide to finish the cut.  Then I'll have a 10mm ish disc of brass that I can reverse and put in the chuck to take out the interior, then it goes into the mill to take out the vents.
Thanks for the input..!
David.
Post by: Circlip on February 22, 2023, 11:39:02 am
Not a criticism of your obvious expertise in machining David but SOME observers might try to emulate with a suicide cut. With a thrust pad, you could probably (with a thin parting tool) leave just enough to use a saw to do final release?
  Regard  Ian.
 Used this method to make 6 brake pistons in St Stl 2" (50mm)  dia for Brembo/Guzzi calipers.
Post by: DJW on February 28, 2023, 05:19:26 pm
Afternoon All..!
A little progress to report, not as much as I'd hoped, but isn't that always the way...
@Ian, all feedback gratefully received, I like being on the forum for that very reason. When I just have myself to discuss best approach to whatever I'm doing, I tend to agree with myself... And that's not always a good thing..!
So, here's the 50mm bar with tailstock centre to keep it under control, I don't have a thrust pad...  So did take it slowly.
(https://modelboatmayhemimages.co.uk/images/2023/02/24/20230222_120218-Custom.jpg)
Taken down to 48mm and tested with the guide.
(https://modelboatmayhemimages.co.uk/images/2023/02/24/20230222_120255-Custom.jpg)
Parted off with a parting tool and hacksaw.
(https://modelboatmayhemimages.co.uk/images/2023/02/24/20230223_095756-Custom.jpg)
Then the vent reversed (protected with some masking tape), back in the chuck, faced and marked for boring out.
(https://modelboatmayhemimages.co.uk/images/2023/02/24/20230223_160645-Custom.jpg)
Then drilled to give me a depth to work to, and bored out.
(https://modelboatmayhemimages.co.uk/images/2023/02/28/20230226_095659-Mayhem.jpg)
And the result, extra cut on the flange is 1mm deep to take some acetate sheet.
(https://modelboatmayhemimages.co.uk/images/2023/02/28/20230226_124308-Mayhem.jpg)
Then into the guides to have the flange mounting holes drilled.
(https://modelboatmayhemimages.co.uk/images/2023/02/28/20230228_094308-Mayhem.jpg)
Then countersunk and mounted in the guides with M2 bolts. On the model the bolts will be M1.6.
(https://modelboatmayhemimages.co.uk/images/2023/02/28/20230228_151556-Mayhem.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/02/28/20230228_151551-Mayhem.jpg)
The flats on the underside of the guides are to help mounting in the mill. Then a 6mm end mill to take out the two edge cuts, and a 4mm to start on the centre cuts.
(https://modelboatmayhemimages.co.uk/images/2023/02/28/20230228_151537-Mayhem.jpg)
And that's as far as I've got today...  So, two more cuts on that first vent will give me the 'bars' of the vent, probably a bit of filing to round off the edges.  I'll post an update when they're both milled.
In other news...  I produced a few versions of these 3D printed ESC case mounts before getting it right.  They sit on the keel and bolt through two of the frames so the ESC case has a firm base.  I will be using a thin piece of foam to isolate the case from the mount so no sound vibrations are passed to the hull, or are at least reduced.
(https://modelboatmayhemimages.co.uk/images/2023/02/28/20230226_130144-Mayhem.jpg)
And with M4 threaded inserts.
(https://modelboatmayhemimages.co.uk/images/2023/02/28/20230226_130928-Mayhem.jpg)
And in place, dry fit at the moment.
(https://modelboatmayhemimages.co.uk/images/2023/02/28/20230226_131620-Mayhem.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/02/28/20230226_131615-Mayhem.jpg)
That's about it for today...
Very best regards to all.
David.
Post by: Capt Podge on February 28, 2023, 05:46:57 pm
Hi David, well impressed with yet more of your superb milling and turning skills and, of course, the 3D printed parts and how these things come together.
Looking forward to seeing more of your progress  :-))
Cheers,
Post by: DJW on March 01, 2023, 05:29:14 pm
Afternoon Ray
Thanks for that..!  Finished with one of the vents in the mill today.
(https://modelboatmayhemimages.co.uk/images/2023/03/01/20230301_154707-Custom.jpg)
And out of the guide:
(https://modelboatmayhemimages.co.uk/images/2023/03/01/20230301_170638-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/03/01/20230301_170632-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/03/01/20230301_170652-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/03/01/20230301_170644-Custom.jpg)
Need to get second vent milled, then some finishing for both.
Best regards
David.
Post by: T888 on March 01, 2023, 05:44:00 pm
Coming along nicely David, which milling machine are you using ?
Post by: Circlip on March 02, 2023, 10:27:00 am
Really impressive work for a "Toy" lathe/mill.  O0
Post by: DJW on March 02, 2023, 05:38:30 pm
I have a Clarke CL250M lathe, I've had it for about 10 years, together with the CL251 MH Mill attachment.  Think I paid about £600.00 for both when new from MachineMart. I don't think either are available as Clarke products any more, but also think it's a generic lathe that's badged by a few suppliers.  It's pretty basic, no compound cross slide, and it's pretty small.  But it's served well for modelling work in aluminium and brass, and I use it for machining engineering plastics from time to time too.  It benefits from frequent adjustments to keep the various slides free from play. Then only taking small cuts seems to keep it happy.  On the Mill I use end mills from 10mm down to 3mm.
(https://modelboatmayhemimages.co.uk/images/2023/03/02/20230302_171140-Custom.jpg)
It's pretty heavy (30Kg with Mill), and currently I don't have it bolted down...  Not best practice...  Drive belt snapped after 8 years, so I picked up a couple of spares.  Otherwise keeps going.
For the price it's done and is doing well.
David.
Post by: T888 on March 02, 2023, 07:11:54 pm
Hi David,
I got a Axminster SX1 milling Machine and a C2 lathe. Lath I’ve had for 12 years . The mill I got that a couple of years ago, I thought it would not get much use but it’s be invaluable.
Like you I’ve used 12 - 0.5 mm tools and tend to take small light cuts and to date I’ve not had any issues, in fact I’ve been very please with this tool.
Both my machines are bolted to the work bench.
Post by: Circlip on March 03, 2023, 10:30:22 am
Which goes t show that you don't need "Heavy Metal" to achieve excellent results.
Post by: DJW on March 07, 2023, 05:00:58 pm
Afternoon All
@Dave. I recognise quite a few of the components (but a few design changes) on that Axminster Mill, same components on my Clarke.  Must be a big factory in China with different paint and badges at the end of the production line..!  Like you I do use it a lot as a mill, also use it as a precise pillar drill.
@Ian.  Yes, the smaller hardware makes me as a user more refined and precise I think, in that you really can't brute force anything.  What you'd get away with on a full size (heavy metal) lathe, you just can't on the micro versions.
A modest update this week.  I've produced the second vent, and got them both polished.
(https://modelboatmayhemimages.co.uk/images/2023/03/07/PSX_20230307_162240.jpg)
I think they're going to look good up on the bow once chromed.
David.
Post by: T888 on March 08, 2023, 10:01:18 am
David, still following your build   :-)) :-)) :-))
Post by: Circlip on March 08, 2023, 11:11:23 am
Have you tried HSS turning tools for Brass Dave? Carbides with everything (Bit like Cyano) not always the answer. Not knocking the final result, just an observation.
Post by: DJW on March 14, 2023, 05:03:27 pm
Hi Ian
I do have a set of HSS tools, but I don't have a grinder that I've always thought I needed to sharpen them.  So I must admit that I like the replaceable carbide tip tools as I can just replace the tip when I start something that needs a good sharp tool.  I'll have a go at sharpening the HSS tools, I'm guessing that you mean the shapes of the HSS tools may be more suited to brass / aluminium (rather than the carbide 'points')..?
In other news...  I've got the ESC Case mounts fully sorted.  I used the 3D printer and some flexible TPU filament to create some mount inserts that keep the case 100% isolated from the mounting bolts and the hull mount. Might be overkill and a waste of time, but I'll know that I tried. (To avoid any sounds from the ESCs being passed to the hull...)
(https://modelboatmayhemimages.co.uk/images/2023/03/12/PSX_20230312_185743.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/03/12/PSX_20230312_185831.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/03/12/PSX_20230312_185915.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/03/12/PSX_20230312_190003.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/03/12/PSX_20230312_190054.jpg)
Also some progress on the dock lights to report.  I reduced the diameter of the 'reflectors' a shade in the lathe, bit precarious, but got there in the end.
(https://modelboatmayhemimages.co.uk/images/2023/03/12/PSX_20230312_190144.jpg)
This pic shows the original reflector, then cut down, then in the dock light
(https://modelboatmayhemimages.co.uk/images/2023/03/12/PSX_20230312_190203.jpg)
And the pair installed
(https://modelboatmayhemimages.co.uk/images/2023/03/12/PSX_20230312_190224.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/03/12/PSX_20230312_190240.jpg)
Need to get them powered up to see if I'm on the right track. I call them reflectors, but there's no silvering and they're solid plastic, so by changing the shape I may have altered their characteristics, I'm thinking of silver painting the outer face and seeing what happens.
Very pleased to have made some progress on the actual hull, rather than just fittings..!!  I'm two years into this build, so about time I reckon.
Here's the Stringers ready to shape and install.  Transom / Stern assembly in the background being glued.
(https://modelboatmayhemimages.co.uk/images/2023/03/12/PSX_20230312_190321.jpg)
And that stern assembly in place on the keel, just dry fit.
(https://modelboatmayhemimages.co.uk/images/2023/03/12/PSX_20230312_190300.jpg)
And this stringers cut to fit the frames
(https://modelboatmayhemimages.co.uk/images/2023/03/14/PSX_20230314_161025.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/03/14/PSX_20230314_160949.jpg)
Again still dry fit, but nice and tight, some shaping left to do, and some holes to drill. The 'underside' of the stringers is deliberately protruding beyond the frames so I can plane them flush and plank over them once bonded in. The stringers not part of the Amati design, just my attempt to add some stiffness. They are 10mm apart so they can act as strengthening for the prop tubes, P brackets and rudders.  And provide some good alignment for that hardware.
(https://modelboatmayhemimages.co.uk/images/2023/03/14/PSX_20230314_160815.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/03/14/PSX_20230314_160934.jpg)
P Brackets will need some sort of padded insert, and rudder tubes will need boring out a shade.
(https://modelboatmayhemimages.co.uk/images/2023/03/14/PSX_20230314_160914.jpg)
But finally feeling like a model boat project rather than a model engineering exercise...  Flat sections of the hull are bases for the motor mounts.  And some comparison with my 86cm 1/10 Aquarama...
(https://modelboatmayhemimages.co.uk/images/2023/03/14/PSX_20230314_161054.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/03/14/PSX_20230314_161111.jpg)
Finally.  I have an order in for 100 Mahogany and 80 Lime planks...  Hopefully picking them up next week.  2m lengths.
David.
Post by: Capt Podge on March 14, 2023, 05:50:11 pm
Everything coming together nicely and thanks for the write up, it helps in understanding what you're looking to achieve.
Aye,
Post by: Stuw on March 16, 2023, 11:40:36 am
Agree. Looks like a boat to me. What a project!  :-))
Post by: DJW on March 20, 2023, 05:06:58 pm
Afternoon All
And Hey Stuw, certainly feels like an epic from this side of the build too..!
It was my birthday last week, and so I got a new toy...
(https://modelboatmayhemimages.co.uk/images/2023/03/20/PSX_20230320_163801.jpg)
And once I'd got my head around it, I love it.  Its the smallest Proxxon Scroll Saw, the 230/E. My rookie error was to install the provided blade (pinless) but to not fully seat it in the lower clamp, the result being the 'toothless' part of the blade was above the main plate for part of the cut...  And so I was initially a bit underwhelmed as it was taking an age to cut anything.... Then I added an LED worklight to the area and realised my error...  An adjustment later, and all was well.  Also realised the 'foot' has to be adjusted to the height of the wood being cut. Very impressed to be honest, I know it's modest given the range of scrollsaws out there, but it's now cutting through 6mm birch ply as fast as I need, and very accurately.  Together with the Proxxon bandsaw, which I'm also very happy with, I have no excuses when it comes to cutting model sized wood...
(https://modelboatmayhemimages.co.uk/images/2023/03/20/PSX_20230320_163849.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/03/20/PSX_20230320_163825.jpg)
So I've made a start on a few of the parts that I've recently scaled and printed.
(https://modelboatmayhemimages.co.uk/images/2023/03/20/PSX_20230320_163735.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/03/20/PSX_20230320_164046.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/03/20/PSX_20230320_163922.jpg)
I'm using the sample blades supplied but have ordered some spare straight and spiral cut blades to try.  Need a finer blade too I think, I've noticed the cut is not as clean as the bandsaw, or maybe that can be improved with experience.  Any recommendations for optimal scroll blades for cutting 3 to 6mm ply..?
David.
Post by: DJW on March 29, 2023, 10:56:48 am
Morning All
A little more progress to report, been looking at supporting and securing the electronics cases and batteries.
The electronics cases sit to port and stbd of the batteries, so I've cut some 6mm ply to go around the base of each case, these pieces will be held by a couple of screws so that removal allows the case to be removed too.  I think they'll keep wiring out of view too so make the build look tidier.  Been through 3 sheets of 4 x 2 ft 6mm ply so far, and just ordered some more.  Also cut some bases for the battery compartments.  Pretty much everything in sight is still dry fit at the moment (except the rear hatch frame) so I can modify the frames and keel as I build in the subsections. I'm now way off piste from the Amati plans.  Also using some 3mm birch ply for some non structural parts.
(https://modelboatmayhemimages.co.uk/images/2023/03/29/PSX_20230329_094133.jpg)
Still not sure about how much battery to build in, but I will be able to stack the LiPos and use in parallel if needed.
(https://modelboatmayhemimages.co.uk/images/2023/03/29/PSX_20230329_094150.jpg)
And the ancillary battery will sit in the middle.
(https://modelboatmayhemimages.co.uk/images/2023/03/29/PSX_20230329_094228.jpg)
It just works out that the battery compartments are longer than the batteries, I think I can leave it like that so I can move the batteries for / aft if I need to alter weight distribution later.
I'm also working on the exhausts a little, developing a 3D mount that uses the ply stringers as a fixing point, and thinking through how best to waterproof the exhausts as they pass through the transom, they'll need to be removable.  The original Amati kit uses very short cosmetic exhaust stubs that don't really penetrate the hull.  Pictures on next update.
I've been told by John at Jotika that the planks are now cut and ready to collect, now need to get a date for day trip to pick them up..!
David.
Post by: ChrisF on March 29, 2023, 05:32:43 pm
Hi David
Stirling work as usual and making real progress now.
As far as scroll saw blades go, I use Olson, which is one make recommended on woodwork forums. I did some reading up on the subject and bought various types of blades as I was looking for a fine cut as well. The ones producing the finest cut tend to be the pinless type but I rarely use them as they are fiddly to fit in my Record scroll saw (especially when having to remove and refit for cutting out internal sections) and you can't turn them through 90 degrees to cut longer pieces. For the thicknesses of ply you mention I nearly always use pinned blades now - 15 TPI (Ref. 41101) and 18.5 TPI (Ref. 42401) - these are 5" that I use. The latter used where less splintering is required and tighter turns. Both are pretty good though and as long as you cut a little way from the line and sand to the finished size then you get a good finish. The pinless blades I have are 12 TPI PGT (Ref. 45502).
This is a useful reference:
https://www.olsonsaw.net/wp-content/uploads/2020/01/2020-scroll-chart-WEB.pdf
Chris
Post by: SteamboatPhil on March 29, 2023, 07:23:35 pm
Chris
Much appreciate the info on saw blades, I might just get it right now next time  :-))
Post by: DJW on April 04, 2023, 05:11:09 pm
Afternoon Chris
Very useful PDF re the scrollsaw blades, I'd been guessing at which blades to choose, I'll be taking a good look at that table. The Proxxon uses pinless, I'm finding the current (proxxon) blades are a bit unpredictable in terms of the direction they cut, behaving like they have a twist in them, or maybe I'm applying too much pressure to the cut.  It's all a learning curve... (No pun intended)
Some more progress to report on the build.
Cut the sun deck, it's quite a significant component as it's quite large, has a frame, and then the base of the sundeck has to be removed in a single inside cut.
(https://modelboatmayhemimages.co.uk/images/2023/04/04/PSX_20230404_164803.jpg)
It went OK, had to use a little filler to lose the pilot hole that I had to use to start the cut.
(https://modelboatmayhemimages.co.uk/images/2023/04/04/PSX_20230404_164740.jpg)
And in position.
(https://modelboatmayhemimages.co.uk/images/2023/04/04/PSX_20230404_164833.jpg)
Then I've temporarily aligned the bow with the stern section, and the 1/10th for comparison.
(https://modelboatmayhemimages.co.uk/images/2023/04/04/PSX_20230404_164850.jpg)
And then cutting some pieces that span the bow and stern sections.
(https://modelboatmayhemimages.co.uk/images/2023/04/04/PSX_20230404_164911.jpg)
Had a bit of a busy couple of weeks so plank collection will be after Easter.
David.
Post by: ChrisF on April 04, 2023, 09:28:39 pm
Hi David - you made a good job of cutting that out. Yes, I find sometimes that even though ply has laminates with the grain laid in different directions the piece has to be angled quite a bit on occasions to achieve the cut in the direction required. Sometimes I can cut nice and straight and other times it's all over the place!
Chris
Post by: Stuw on April 05, 2023, 10:30:45 am
More great progress David and excellent job on the one piece cut out. No Pressure!
Also thanks to Chris and others for some very useful tips. I’m thinking of getting a scroll saw one day so interested to see all this info.
Post by: DJW on April 05, 2023, 05:23:13 pm
Thanks Both.
@Chris, well that makes me feel a bit better, in that you also find the blade does it's own thing sometimes.  I can end up holding the piece offset at 10/15° sometimes to get the blade cutting along a line.
@Stuw, the scrollsaw is allowing some work that I can't do with the bandsaw (inside cuts) and with attention gives more precision and consistency that I could achieve with a coping saw or similar.  In fact without a laser CNC I think it was the only way to get that sunbed / hatch out of the frame.  I'm using a quite bright LED work light clamped to fully illuminate the blade and cut, and an extra pair of glasses to make sure I stay on course...!  The scrollsaw has a built in air blower that is really useful to keep the working area clear, and when a vacuum is used on the extraction port it sucks dust from the underside of the wood being cut.  I have noticed that on occasion I've not used the vacuum, and have felt the wood jamming, I suspect from a build up of sawdust on the underside.
Best regards
David.
Post by: DJW on April 11, 2023, 07:45:37 pm
Evening All
Some progress to report.  I've been busy on the PC printing off some more parts that have been enlarged, and cutting them out, but not yet fitted them to the hull, getting ready to dry fit them. I think if I sneeze too close the the sections of hull they'll fall apart.  Still not much glued.  But I am still finding holes that need to be drilled, and cut outs that need power tools, so happy with the approach of not gluing at this stage.
Also been busy with the exhausts, or at least getting ready for the exhausts.  I need to join the brass stubs to the plastic manifolds, I was thinking silicone pipe would do it, then tried 3D printing with TPU as for this application I just need the flexibility, not heat resistance.  And they seem fine, they're an interference fit, so should keep things water tight, but be removable. Also able to build a step into the printed tubes, so the inside diameter is 25mm at one end and 23mm at the other.
(https://modelboatmayhemimages.co.uk/images/2023/04/11/PSX_20230411_172149.jpg)
And readers that have built the Amati version may recognise some extra cut outs on the main transom frame, these are for the exhausts and the stringers.
(https://modelboatmayhemimages.co.uk/images/2023/04/11/PSX_20230411_172109.jpg)
Some progress at the bow, I have started using glue here as I can't see any need to rework this area, it then gives me an anchor point to start shaping some of the other bow woodwork.  Then checking the fit of a few other 6mm ply parts, so far so good.  I need to reprint a couple of the guide clamps that I'm using to maintain alignment up at the bow as the 6mm reinforcement sections either side of the keel are now taking that part of the keel to 18mm.
(https://modelboatmayhemimages.co.uk/images/2023/04/11/PSX_20230411_172128.jpg)
David.
Post by: T888 on April 12, 2023, 02:26:31 pm
Enjoying your modelling David. :-))
Post by: Capt Podge on April 12, 2023, 02:44:59 pm
Hi David, good to see your progress and still enjoying your updates  :-))
Post by: DJW on April 18, 2023, 05:09:06 pm
Afternoon All
Another Tuesday update.  A little more progress around the bow, added the side padding parts to the keel, I think these just give a bit more stiffness and area to attach the planks to once the sanding gives the right profile for planking.  And the revised 18mm clamp in place to keep everything lined up.  Frames are still dry fit.
(https://modelboatmayhemimages.co.uk/images/2023/04/18/PSX_20230418_162811.jpg)
I've been spending time getting the fit of the side ply parts up at the bow right, also reinforcing here and there on the frames to give more surface area to glue to.  Not sure if I need to, but better to build it too strong rather than too weak...
I've brought the two halves together again for a while to work on cutting out a few parts that span both halves.
(https://modelboatmayhemimages.co.uk/images/2023/04/18/PSX_20230418_162623.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/04/18/PSX_20230418_162735.jpg)
I'm getting a but tired of moving the vacuum between power tools for dust extraction duties so am setting up a manifold of sorts with three take offs for bandsaw, scrollsaw and disc sander. The vacuum has a power take off that powers it up when an attached power tool is switched on (Vacmaster Multi 20 PTO).  So I'll use a power strip from the power take off to allow multiple tools to be attached, only using one at a time of course.  I've got the 3D printer busy at the moment printing 'slam gates' to control which tool gets the vacuums attention.  Hoping it works out and makes switching between tools a bit more efficient than it is right now.  I'll update and post pictures next time.
And finally.  On a road trip tomorrow to collect the planks, looking forward to that..!
David.
Post by: Capt Podge on April 18, 2023, 05:58:00 pm
Hi David, it's good to see your progress on the boat and I've also tried to fathom out how to create a vacuum manifold so I'll be looking in on your idea(s) as well  :-) .
Post by: Stuw on April 19, 2023, 11:37:49 am
Wow. Vacuum controlled by power tools. More ideas for the future!
Post by: DJW on April 19, 2023, 03:52:05 pm
Hi Ray, printer is busy with slam gates and manifold parts as I type, will post some pics as soon as I have something ready.  And Stuw, yes, the vacuum with PTO does work well.  Basically on mine I can switch to '1' and its a normal vacuum, or '11' and it only powers up when a connected power tool is switched on.  And as you can see, it's quite a modest vacuum but supports over 1700W.  My power tools are in the 100W range and it works fine.
(https://modelboatmayhemimages.co.uk/images/2023/04/19/PSX_20230419_145631.jpg)
So I'm back from my road trip to Droitwich where the very capable and friendly chaps at Jotika have produced the 2m planks for the Aquarama as a custom order.
(https://modelboatmayhemimages.co.uk/images/2023/04/19/PSX_20230419_145604.jpg)
Plenty of work to be done before I start to use the planks, but good to know I now have them ready.
David.
Post by: Capt Podge on April 19, 2023, 10:48:26 pm
Hiya David and yeah, like you I too have a vacuum with that same switch set up. Mine is from Screwfix and is their Titan wet/dry and blow capable unit. I've had this for about 8-10 years now and it's been faultless so far.  :-))
Post by: DJW on April 26, 2023, 05:13:17 pm
Afternoon All
Minor progress with a few of the hull parts and more templates created, but main effort this week has been to relocate the three bench tools, and hook up the vacuum.
(https://modelboatmayhemimages.co.uk/images/2023/04/26/PSX_20230426_162058.jpg)
Made up 4 slam gates on the 3D printer, made up of a back and a front with the gate in.  I've used a 25mm bore as its based around some spare vacuum hose that I had to hand, should be a bit larger really, but it seems to work.  The bench tools are all pretty small to I hope it'll be OK.  Bench tools are also now screwed down which is better, I was using clamps before and it became painful to keep swapping the tools.  Should have done this a while ago.  This setup also allows the vacuum to be in a separate room (large cupboard really) which keeps the noise down.
(https://modelboatmayhemimages.co.uk/images/2023/04/26/PSX_20230426_161614.jpg)
And bolted together in open position.
(https://modelboatmayhemimages.co.uk/images/2023/04/26/PSX_20230426_161633.jpg)
And closed.
(https://modelboatmayhemimages.co.uk/images/2023/04/26/PSX_20230426_161649.jpg)
Then each gate gets a connector on the back, and these join to make a manifold.  Vacuum hose is coming in at the left, three gates for three machines, and a fourth with just a hose on it for general tidying (and it reaches the lathe which is useful).
(https://modelboatmayhemimages.co.uk/images/2023/04/26/PSX_20230426_161808.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/04/26/PSX_20230426_161835.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/04/26/PSX_20230426_161850.jpg)
No excuse now...  Next update should have a load more wood cut...    :-))
David.
Post by: ChrisF on April 27, 2023, 12:03:41 am
That's a very neat setup you have there David.
Chris
Post by: DJW on May 05, 2023, 02:13:54 pm
Hi Chris, thanks for that.  Have to say it's working really well, I'm at the stage where a lot of wood is getting cut.  So much easier / quicker / efficient having the three tools available as required.
And to underscore that...  More templates being printed, some parts fit on single A4 printouts but some span several sheets so I need to line up the cut marks then tape together. Here's a few more:
(https://modelboatmayhemimages.co.uk/images/2023/05/05/PSX_20230505_135110.jpg)
I had an A3 printer til a couple of years ago, it ended up on a skip as it wasn't getting used... Big mistake.
And some general shots of the current state of the build, still mainly dry fit apart from some of the sub assemblies...
(https://modelboatmayhemimages.co.uk/images/2023/05/05/PSX_20230505_135144.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/05/05/PSX_20230505_135207.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/05/05/PSX_20230505_135316.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/05/05/PSX_20230505_135246.jpg)
Planning to get the 1/10th serviced and maybe out on the water this long weekend, getting ready for a trip to Wicksteed...
David.
Post by: DJW on May 11, 2023, 05:21:21 pm
Afternoon All
Anyone who's built the Amati Riva Aquarama will know it builds bow heavy, and then can dig in at the bow when on the water.  This version will have similar issues I suspect as it's heavily based on the Amati design and layout.  So I've been cutting out the structural wood and have now got to the stage of having the structural parts to the correct basic shape, so have now set about lightening these structural parts, particularly at the bow.
(https://modelboatmayhemimages.co.uk/images/2023/05/11/PSX_20230511_165739.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/05/11/PSX_20230511_165848.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/05/11/PSX_20230511_165900.jpg)
Some of the holes will double as cable routes, also I'm aiming to use a fan to force cooling air through the length of the hull, these holes will help.
Also taken delivery of a nice piece of mahogany, 20mm x 100mm x 600mm.  Plan is to use it for things like the side rubbing strips on on the waterline either side of the Aquarama hull, also there's a 20mm thick piece of shaped mahogany used as part of the transom.  It's 2 parts in the Amati Kit, would be nice to create in one piece.
(https://modelboatmayhemimages.co.uk/images/2023/05/11/PSX_20230511_165755.jpg)
David.
Post by: DJW on June 13, 2023, 05:47:51 pm
Afternoon All
Realised it was a while since last update, so here's some progress.
I've now started to bond the various pieces once they were tweaked and persuaded to fit.  I'm finding that accuracy is very hard to maintain when scaling up, tolerances of transferring plans to wood, cutting that wood, is not the same as telling a laser cutter / CNC to cut another set of frames / parts...  Some parts I'm having to sand to fit, some I'm actually building up a mm or so.
So the bow is now pretty much in one structural piece:
(https://modelboatmayhemimages.co.uk/images/2023/06/13/20230613_170820-Custom.jpg)
The boat itself remains in two parts.
At the stern, the stringers that run either side of the shafts are now bonded to the transom and the two frames near the stern:
(https://modelboatmayhemimages.co.uk/images/2023/06/13/20230610_193709-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/06/13/20230613_170806-Custom.jpg)
The space between the stringers has been made solid between the transom and the last frame, I've then routed out slots to take the P Brackets, also for the two exhaust stubs, and then built up and drilled for the rudder tubes.  This is now a very rigid section and the running hardware should be kept well aligned.
(https://modelboatmayhemimages.co.uk/images/2023/06/13/20230613_170735-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/06/13/20230613_170741-Custom.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/06/13/20230610_193658-Custom.jpg)
Also been busy getting the transom elements to all fit nicely, I'll post once that's all sorted and bonded.
The stringers are deeper than the frames so I can trim them in place to match the line of the hull.
I'm pondering the keel joint at the moment, I think some additional stiffening / strengthening is called for...  On the 1/10 version its just a 3mm ply plate each side of the joint, then it relies on the planking for strength. I can do that and will with 6mm ply plates, but think I need the additional stiffening.  The bow is almost a cage of ply parts, so rigidity is build in, and the stringers have made the stern part of the hull similarly rigid...  I'm thinking a pair of mid hull stringers that lace into the bow and stern sections, we'll see.
That's it for now on the 1/5th.
Have had the 1/10th Aquarama out on the water a few times this year, this was in the sunshine at the excellent MBM Wicksteed event:
(https://modelboatmayhemimages.co.uk/images/2023/06/13/20230527_135713-Custom.jpg)
Huge thanks to everyone involved in organising a great weekend..!
David.
Post by: DJW on June 27, 2023, 05:44:47 pm
Afternoon All
I now have the two halves of the boat joined.  Next to the 1/10th for comparison, LOA 172cm.
(https://modelboatmayhemimages.co.uk/images/2023/06/27/PSX_20230627_114432.jpg)
And starting to look at the motor mounts, the base 6mm ply panels are in and will now be reinforced to the keel and frames.  I need to lift the motor mounts from the panels slightly to accommodate the rubber mounts and to increase the prop shaft angle slightly.  So I'm 3D printing some wedges that will sit between the aluminium mounts and the ply plates.  I hoping the shaft angle will end up around 9 or 10 degrees...  I managed 7 degrees on the 1/10, but that used a gearbox to keep the shafts as low as possible at the motor end.  This process will also give me the mount points for the P Brackets.
(https://modelboatmayhemimages.co.uk/images/2023/06/27/PSX_20230627_171458.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/06/27/PSX_20230627_171512.jpg)
David.
Post by: derekwarner on June 27, 2023, 11:11:28 pm
Following on DavidThats impressively large  :o ......funny how scaling can confuse the mind  >>:-( .....
Without me attempting to confuse myself, could you confirm what the all-up weight of the 1/5 Scale boat
Post by: T888 on June 28, 2023, 07:13:06 am
Hi David,
Your Build is impressive  :-)) :-)) :-))
Post by: DJW on June 28, 2023, 10:56:11 am
Thanks Chaps..!
@Derek.  As I understand it, the scale weight is the full sized boat weight / the cube of the scale factor.  So in this case the full sized Aquarama is about 4,000kg, and the scale factor is 5 (as its a 1/5 model), so its 4000 / (5x5x5) which is 4000 / 125...  Which is 32.  So the 1/5 Aquarama should be around 32kg.
I'm sure there a few 'buts' in there, one of them being the longitudinal centre of gravity, which I think should be a tad aft of the centre of the waterline length.  Get this wrong and the boat won't behave right on the water.  So I'll be aiming to build lighter overall and especially at the bow, I think under 25kg is a reasonable target, then leave some room for ballasting to get fore/after and port/stbd balance about right. There's a related point that's beyond me to understand properly, and that's how buoyancy / displacement will affect things.  I've modified the hull shape a shade as I did on the 1/10 to give a bit more lift at the bow.  But I think this reduces the displacement at the bow, so the 1/10th sits a bit bow down for my taste when at rest, but does lift nicely when under way...
Short answer, I'll be building light so I can adjust when the time comes.
Best regards
David.
Post by: DJW on June 28, 2023, 11:15:09 am
Meant to add.  What you see in the pic above is 5.5kg, everything is mainly 6mm birch ply.  Each motor on its mount with prop tube is 1.0kg.  The LiPos are also just under 1kg each, I'm thinking add 2 or 4 depending on whether they help with ballasting.
Post by: ChrisF on July 03, 2023, 01:10:37 pm
Hi David
The Fairey Huntsman 31 can suffer from a bow down attitude at rest due to the bow being streamlined and its narrow vee shape which doesn't provide much buoyancy. Sterns are a different matter if they are wider and are flat bottomed or a shallower vee than the bow.
My Huntress with stern-drive is heavy at the rear (I haven't checked where the balance point is) and yet sits bang on the waterline, the hull being so bouyant. Away from the bow planing hulls seem to be very toletant of weight distribution so as you say building the bow light is the key as less buoyancy is provided in that area.
Chris
Post by: DJW on November 23, 2023, 02:06:17 pm
Afternoon All
Back on the case with the 1/5 build.
I've started to line up and secure the motor mounts, P brackets and rudders. Still work in progress, cutting shafts to correct length, trimming here and there to get the fit correct.
(https://modelboatmayhemimages.co.uk/images/2023/11/17/PSX_20231117_190223.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/11/17/PSX_20231117_191518.jpg)
The motors have to be able to be taken out and reinstalled installed when the mounts remain attached to the thrust bearings / shafts, so the coupling on the motor end can be slid up the motors drive shaft to give clearance, then secured back in place to mesh with the shaft.  Flats have been ground on the motors and prop shafts wherever you see grub screws on the couplings and thrust collar.  This lets the motors be lifted straight out of the mounts after removing the 4 bolts going into the rubber mounts.
(https://modelboatmayhemimages.co.uk/images/2023/11/17/PSX_20231117_191453.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/11/17/PSX_20231117_191552.jpg)
P brackets are held on two 4mm bolts (then filled with epoxy when lined up), just the rear bolts initially to allow alignment.
(https://modelboatmayhemimages.co.uk/images/2023/11/17/PSX_20231117_191704.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/11/17/PSX_20231117_191608.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/11/17/PSX_20231117_191622.jpg)
Motor mounts are secured to the hull with 4 x M6 SS bolts each.
(https://modelboatmayhemimages.co.uk/images/2023/11/17/PSX_20231117_191642.jpg)
And before I get the epoxy out on the prop tubes / mounts and rudders, I've decided to use some 2mm ply for the aft 50% of the bottom of the hull.  The Aquarama hull is flat enough in that area to get away with it I think, then I'll carry on the forward section with 2mm lime planks.  I'm just wanting to get the cut outs done for the prop tubes, P brackets and rudders. Rough cuts at this stage.  I'm thinking to then install the rudder tubes, then the ply hull panels, then final alignment and fixing of the P brackets, prop tubes and motor mounts.  Plus a bit more reinforcement below the motor mounts before the ply panels go on, they will take the thrust, so ideally they need to be stopped from parting company with the rest of the hull...
David.
Post by: T888 on November 24, 2023, 09:02:43 am
Hi David,
How are you planning on maintenance access to the motors, coupling etc
Post by: DJW on November 25, 2023, 04:56:48 pm
Hi David
Taking the motor out of and installing it back into a mount is quite easy. The coupling on the motor shaft has two grub screws that once loosened allow the coupling to be retracted so it's no longer meshed with the prop shaft end of the coupling. Like this:
Then four bolts taken out of the bobbin mounts and the motor lifts out.
If the mount has to come out for some reason, the flange joining the prop shaft to the thrust housing has to be split, so four allen key bolts removed. Then the flange is on same axis as the bolts that hold down the motor mounts. So the motor mount lifts out while still attached to the thrust bearing housing. Of course that's after the prop shaft has been eased out backwards.
Bit involved,  but workable I think.
Best regards
David.
Post by: DJW on November 25, 2023, 06:21:37 pm
A couple of pictures of the thrust bearings in the thrust housing. This one takes the forward thrust and passes it to the motor mount.
(https://modelboatmayhemimages.co.uk/images/2023/11/24/PSX_20231124_163937.jpg)
And fully in place.
(https://modelboatmayhemimages.co.uk/images/2023/11/24/PSX_20231124_164007.jpg)
Then other side of the mount, the thrust bearing for astern.
(https://modelboatmayhemimages.co.uk/images/2023/11/24/PSX_20231124_164045.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/11/24/PSX_20231124_164110.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/11/24/PSX_20231124_164151.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/11/24/PSX_20231124_164218.jpg)
Also cut the exhaust stubs from 25mm od brass tube. Started to think about marking out and cutting the flanges.
(https://modelboatmayhemimages.co.uk/images/2023/11/24/PSX_20231124_164745.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/11/24/PSX_20231124_164414.jpg)
Good to be making some progress again.
David.
Post by: DJW on December 03, 2023, 07:28:15 pm
Evening All
Decided to carry on developing some if the internal hardware while access is easier.
(https://modelboatmayhemimages.co.uk/images/2023/12/03/PSX_20231202_173228.jpg)
The rudder servos are mounted on a 3D printed carrier that clamps to and through the keel, this version moves the servos further aft. There are now panels in the floor of the battery area and L shaped panels that retain the electronics boxes.
(https://modelboatmayhemimages.co.uk/images/2023/12/03/PSX_20231202_173307.jpg)
I'm thinking to mount the vibration unit on the frame ahead of the rudder servos, in the middle above with the motor sticking out forward. A 3D printed mount coming this week for this unit. . Then the vapour unit will hopefully fit between the vibration unit and the rudder servos. Port electronics box in place in the above pic.
And a better pic of the rudder linkages. 3mm steel rods, threaded into ball joint ends and aluminium servo and rudder arms.
(https://modelboatmayhemimages.co.uk/images/2023/12/03/PSX_20231202_173401.jpg)
I'm hoping that the two servos will allow for some interesting tweaking of rudder response when it comes to FrSky programming.
David.
Post by: ChrisF on January 07, 2024, 09:25:02 pm
Just caught up with your build  David. Absolutely fantastic as usual! You're certainly taking model boat building to a whole new level.
Chris
Post by: DJW on January 08, 2024, 03:39:46 pm
Hi Chris
Happy New Year to you..!
Thanks for that...  Seems like I'm going off at a few tangents at the moment, but hopefully making progress.
The Vibration unit has had some attention:
(https://modelboatmayhemimages.co.uk/images/2023/12/08/PSX_20231208_171636.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/12/08/PSX_20231208_171614.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/12/08/PSX_20231208_171658.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/12/08/PSX_20231208_171723.jpg)
And here it is all together:
(https://modelboatmayhemimages.co.uk/images/2023/12/08/PSX_20231208_171811.jpg)
(https://modelboatmayhemimages.co.uk/images/2023/12/08/PSX_20231208_171748.jpg)
And this is where it mounts:
(https://modelboatmayhemimages.co.uk/images/2023/12/27/PSX_20231227_192212.jpg)
Also working on some of the cabin panels:
(https://modelboatmayhemimages.co.uk/images/2023/12/27/PSX_20231227_192117.jpg)
And have another new Proxxon toy...
(https://modelboatmayhemimages.co.uk/images/2024/01/08/PSX_20240108_150400.jpg)
I think there's a load of sanding heading my way, so I thought I needed a bit of help.
Still playing with the vapour generator...  This is the latest top coming off the printer:
(https://modelboatmayhemimages.co.uk/images/2024/01/08/PSX_20240108_150327.jpg)
Also been using the printer to create some conduits for the cables that will need to go in:
(https://modelboatmayhemimages.co.uk/images/2024/01/08/PSX_20240108_150233.jpg)
And finally for now...  I saw this.
(https://modelboatmayhemimages.co.uk/images/2023/12/27/PSX_20231227_192551.jpg)
And I'm thinking 'boat trolly'.  Apparently it's customised from a Scania Vabis bus from the 60s / 70s...  Maybe I found my next project.  At least for the 1/10th.  I'll need a bigger car if I try for the 1/5th...  Maybe a trailer.
Anyway, that's it for now.
Best regards
David.
Post by: DJW on January 10, 2024, 12:19:21 pm
OK...  This post should see if anyone's awake...   %)
I've been giving thought to the finish of the 1/5th.  It's a shade premature maybe as the hull isn't planked yet.  There are however a couple of side panels in the cabin that need varnishing before they get installed.  So I think it's time to evaluate how to proceed, and do some testing.
On the 1/10th I used a couple of thinned Z-Poxy finishing resin coats to seal, then thinned International Original Yacht Varnish to build up.  With all the sanding in the middle. Then buffing and polishing...  The finish was OK, but not the glass effect I'd been hoping and trying for.
So, Z-Poxy seems elusive to find and it has an amber tint, so I've narrowed down to Hempel 599, 'a two part epoxy with low viscosity and good penetration', its £20 for 750ml so I have some to see how it performs.  In the tin it has the consistency of water.  So plan it to use a brush to apply it, and I'll report back.
Then, the varnish.  I don't think I gave the Le Tonk a fair evaluation last time, so I want to try again, and compare it to Epifanes High Gloss.  Both have a formidable reputation, I'm going to try harder to manage the temperature and humidity, I suspect this was an issue in earlier attempts with the Le Tonk.
And I intend to thin and spray the varnish.  At least test spraying...
This will mean a load of coats to build up thickness, so I can see some sort of spray booth when the time comes for the main hull.
(https://modelboatmayhemimages.co.uk/images/2024/01/10/PSX_20240110_102524.jpg)
Anyway, that's my thoughts.  Any comments on any of the above gratefully received.  :-))
David.
Post by: SailorGreg on January 12, 2024, 11:36:25 am
Not wishing to teach granny to suck eggs, but this is worth a look for anyone wondering how the professionals get that glass-like finish -
How To Apply Epifanes Clear Varnish (https://www.youtube.com/watch?v=K0PiMZGD5LQ)
Greg
Post by: DJW on January 14, 2024, 08:52:51 pm
Hi Greg
Not at all and thanks for sharing that link. That guy Dan Lee certainly know his stuff, its good of him to share his skills, inspiring. I have seen some of his videos on YouTube, he's been building a 1/4 scale of his 'Temptress' design. Very skilled man...
Very best regards
David.
Post by: DJW on January 21, 2024, 09:00:24 pm
Evening All
I've made some progress with the hull. The motor mounts are now fixed as are the rudder tubes.
Also been working on a water inlet fitting, similar to the full set Aquarama fitting. This is the real fitting:
(https://modelboatmayhemimages.co.uk/images/2024/01/21/PSX_20240121_195912.jpg)
I started with creating three brass pieces, the strainer, the plate and the threaded tube. The tube is a drilled out and machined 10mm brass bolt. Bar for the strainer is 20mm stock and plate is 2mm, plate...
(https://modelboatmayhemimages.co.uk/images/2024/01/19/PSX_20240119_123119.jpg)
Milled the bar to give it a taper, then created a cavity:
(https://modelboatmayhemimages.co.uk/images/2024/01/19/PSX_20240119_123149.jpg)
Then a small abrasive disc held in the lathe chuck to cut the slots:
(https://modelboatmayhemimages.co.uk/images/2024/01/19/PSX_20240119_123215.jpg)
Ended up with these parts:
(https://modelboatmayhemimages.co.uk/images/2024/01/19/PSX_20240119_123339.jpg)
Fitting like this:
(https://modelboatmayhemimages.co.uk/images/2024/01/19/PSX_20240119_123450.jpg)
And when silver soldered and shaped:
(https://modelboatmayhemimages.co.uk/images/2024/01/21/PSX_20240121_123757.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/01/21/PSX_20240121_123729.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/01/21/PSX_20240121_123702.jpg)
I don't honestly know whether the full sized Aquarama has an inlet per engine, I suspect it does, but I only need one. This will go to one pump then split into two circuits.
Best regards to all.
David.
Post by: Capt Podge on January 21, 2024, 09:22:38 pm
...been working on a water inlet fitting
David.
That's a good idea and great work in creating the fitting.
Cheers,
Post by: ChrisF on January 21, 2024, 09:56:23 pm
You're on the wrong forum David! Only joking, superb work as always.
Chris
Post by: DJW on January 30, 2024, 07:24:12 pm
Evening All
@Chris, well one of the challenges of building at 1/5th scale is there is very little available off the shelf, so it all has to be fabricated. And as you know, I enjoy that..! I can get away with a few short cuts and interpretation on the more functional fittings as they're pretty much hidden, the challenge will ramp up with the classic Riva fittings...
The Hull is coming along. I've used 2mm ply for the aft section of the planing surface of the hull.
(https://modelboatmayhemimages.co.uk/images/2024/01/29/PSX_20240129_181723.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/01/29/PSX_20240129_181705.jpg)
Also decided to reinforce the chines. I was going to use 10mm Square spruce, but decided to laminate several lime planks to get the shape I need. So the result is 10mm x 6mm shaped to fit. I used titebond 3, and clamped the laminate to the hull before the glue fully grabbed to get the shape. Pleased with the result.
(https://modelboatmayhemimages.co.uk/images/2024/01/29/PSX_20240129_181636.jpg)
Hard to show the compound curves, might be easier once fitted to the boat...
(https://modelboatmayhemimages.co.uk/images/2024/01/30/PSX_20240130_095647.jpg)
Next task is to cut out the frames and inset the chine rail. Nice to see the lines of the Aquarama starting to show themselves...
David.
Post by: ChrisF on January 30, 2024, 08:14:52 pm
Crikey, with it standing on end you can appreciate how big it is! How much do you think it's going to weigh?
Even with the diversions, which you were obviously going to have to do at some point, you're making good progress.
Chris
Post by: DJW on January 30, 2024, 08:33:50 pm
Hi Chris
Calculations say it can weigh 32Kg...  I'd hope for closer to 25. I'll see if I can get all the hardware into the hull and get it on the scales...
Best regards
David.
Post by: DJW on February 11, 2024, 08:00:13 pm
Evening All
Made some progress this weekend on the stern of the Aquarama. I'm using 2mm birch ply for the lower transom area, then 10mm x 2mm bass planks. Some shaping of the frames using the new Proxxon belt sander, then placing a single plank to butt the ply to as the starting point.
(https://modelboatmayhemimages.co.uk/images/2024/02/11/PSX_20240211_193423.jpg)
Using Titebond 3 and brass pins to secure. Clamps where necessary while curing. I use a 0.8mm drill to guide the pins and prevent splitting.
(https://modelboatmayhemimages.co.uk/images/2024/02/11/PSX_20240211_193510.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/02/11/PSX_20240211_193732.jpg)
The ply needs trimming to the hull line once glue has cured. Same with the planks once they're all in place. The planks you see above have gone on without shaping, the remainder will need some shaping to avoid gaps.
Always good to see the Aquarama shapes and curves coming out...!
Best regards to all
David.
Post by: Martin (Admin) on February 11, 2024, 09:20:14 pm
Wonderful !
NB: Any particular reason for using Titebond 3  as opposed to other wood glues? ?
Post by: Circlip on February 12, 2024, 08:36:52 am
Cos Cascomite ain't available any more.
Post by: DJW on February 12, 2024, 10:30:05 am
Haha..!  I do remember using Cascamite on my ever model boat build, a Sea Urchin, way back in the day...
I used Titebond 3 on my earlier Aquarama, its waterproof and I've probably just got used to it's flow, grip, drying time, what it's good at and not so good at.  It also mixes well with sawdust to bulk it as a filler.
Regards to all.
David.
Post by: Martin (Admin) on February 12, 2024, 03:02:17 pm
(https://i.postimg.cc/xqXzBnZW/Casacamite1.jpg) (https://postimg.cc/xqXzBnZW)
Post by: SailorGreg on February 12, 2024, 06:20:31 pm
Say "Cascamite" to any builder of full size wooden boats and just watch the expression on their face!  Let's just say it is not held in the highest regard.
Greg
Post by: DJW on February 13, 2024, 07:11:46 pm
Evening All
Stern is coming along nicely, now planked and sanded. The Proxxon belt sander is really useful...
(https://modelboatmayhemimages.co.uk/images/2024/02/13/PSX_20240213_190249.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/02/13/PSX_20240213_190044.jpg)
Feels like headway being made now with the hull. Over two years into this build...
Regards to all
David.
Post by: T888 on February 15, 2024, 04:40:08 pm
Nice David  :-)) :-)) :-))
Post by: ChrisF on February 17, 2024, 06:40:32 am
Blimey, it doesn't seem like that long ago when you started!
Chris
Post by: DJW on February 20, 2024, 08:04:13 pm
Evening All
Quite a bit of progress made on the framework of the boat. At the stern I've got the rear hatch optimised and nicely flush with the frame that holds it in place. Cockpit area has been worked on, angled steps in front of the seats plus the panels  between cockpit and cabin are added. I've started shaping the bow frames that will define the forward deck shape, a work in progress right now. Adding filler here and there as required.
(https://modelboatmayhemimages.co.uk/images/2024/02/20/PSX_20240220_194138.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/02/20/PSX_20240220_194153.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/02/20/PSX_20240220_194249.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/02/20/PSX_20240220_194214.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/02/20/PSX_20240220_194401.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/02/20/PSX_20240220_194428.jpg)
The Belt sander is getting a workout. Working hard to ensure symmetry. I think the rear sun deck is going to get some attention from a large hole saw. It's quite heavy and doesn't need real strength.
Best regards to all..!
David.
Post by: DJW on February 26, 2024, 08:02:32 pm
Evening All
Had a  it of time to make some more progress with the build. I've got the chine rails attached and have done more sanding and shaping then checking with planks to see how they're going to lay.
(https://modelboatmayhemimages.co.uk/images/2024/02/26/PSX_20240226_182134.jpg)
And as of today
(https://modelboatmayhemimages.co.uk/images/2024/02/26/PSX_20240226_182309.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/02/26/PSX_20240226_182414.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/02/26/PSX_20240226_182452.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/02/26/PSX_20240226_182527.jpg)
Also been fitting the exhaust stubs through the stern, and working out how the flanges are going to be shaped. I'm using the 3D Printer to get the shape right. The Aquarama flanges seem to have 5 holes for  screws, and the flange has to attach to the pipe at around 25 degrees. So I'm printing a guide to get the holes in the right place, and another mount that's going to hold the brass flange in the lathe at the correct angle to bore out the pipes 25mm diameter...  We'll have to see if it works..!
(https://modelboatmayhemimages.co.uk/images/2024/02/26/PSX_20240226_182227.jpg)
Here with a printed flange mock up
(https://modelboatmayhemimages.co.uk/images/2024/02/26/PSX_20240226_182200.jpg)
And the tool designs
(https://modelboatmayhemimages.co.uk/images/2024/02/26/PSX_20240226_181950.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/02/26/PSX_20240226_181929.jpg)
I'll report back...
Best regards to all
David.
Post by: DJW on March 01, 2024, 06:06:04 pm
Evening All
Progress on a couple of fronts.  The exhaust flanges are now created in brass cut from 50mm bar stock on the little lathe:
(https://modelboatmayhemimages.co.uk/images/2024/02/29/PSX_20240229_193519.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/02/29/PSX_20240229_193538.jpg)
And checking fit with the drill guide:
(https://modelboatmayhemimages.co.uk/images/2024/02/29/PSX_20240229_193600.jpg)
And parted off:
(https://modelboatmayhemimages.co.uk/images/2024/02/29/PSX_20240229_193633.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/02/29/PSX_20240229_193659.jpg)
Used the 3D printed drilling guide to get the correct spacing of 2mm holes in the flanges:
(https://modelboatmayhemimages.co.uk/images/2024/03/01/PSX_20240301_174243.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/03/01/PSX_20240301_174257.jpg)
Then used the cutting guide in the lathe to mount one flange at a time allowing boring out for the exhaust stub at a 25° angle, so it fits the sloped transom.
(https://modelboatmayhemimages.co.uk/images/2024/03/01/PSX_20240301_174331.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/03/01/PSX_20240301_174349.jpg)
I need a good fit so the silver solder will flow nicely.
(https://modelboatmayhemimages.co.uk/images/2024/03/01/PSX_20240301_174507.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/03/01/PSX_20240301_174530.jpg)
And when in place on the boat:
(https://modelboatmayhemimages.co.uk/images/2024/03/01/PSX_20240301_174550.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/03/01/PSX_20240301_174615.jpg)
Need a little adjustment to get the flange mounting holes in the right place, but I'm pleased with the fit, next task is to silver solder, challenge there being to maintain the angle needed...  Then I'm thinking to use 2mm brass inserts in the hull, and I'll need some sort of gasket to seal.
In other news I've been using the hole saw to take out some wood where its not really needed, the floor of the seating area, also the aft sundeck:
(https://modelboatmayhemimages.co.uk/images/2024/02/29/PSX_20240229_193720.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/02/29/PSX_20240229_193737.jpg)
That's it for now.
Great weekend to all.
David.
Title: Re: 1/5 Riva Aquarama...
Post by: Martin (Admin) on March 01, 2024, 11:41:31 pm
Looking Good!    :-))
Post by: DJW on March 04, 2024, 07:59:01 pm
Evening All
Thanks for that Martin..!
I've got the exhaust stubs silver soldered. Not plain sailing, the flanges were hard to hold in the correct position, maybe I should have wired them. Anyway  done now. A little more polishing and they'll look the part.
(https://modelboatmayhemimages.co.uk/images/2024/03/04/PSX_20240304_192044.jpg)
This is the port stub:
(https://modelboatmayhemimages.co.uk/images/2024/03/04/PSX_20240304_192213.jpg)
And Stbd:
(https://modelboatmayhemimages.co.uk/images/2024/03/04/PSX_20240304_192407.jpg)
Next task will be to drill through the flanges and insert M2 inserts for the bolts. Also planning to create gaskets from thin foam to ensure a seal.
(https://modelboatmayhemimages.co.uk/images/2024/03/04/PSX_20240304_191841.jpg)
On first attempt I managed to screw up the port stub as the flange holes weren't aligned properly.
(https://modelboatmayhemimages.co.uk/images/2024/03/04/PSX_20240304_192623.jpg)
Got there in the end. !
David.
Post by: DJW on March 06, 2024, 09:45:03 pm
M2 Brass inserts araldited and pushed in, tight fit so needed a small hammer..!
(https://modelboatmayhemimages.co.uk/images/2024/03/06/PSX_20240306_201822.jpg)
And the stubs bolted to the inserts.
(https://modelboatmayhemimages.co.uk/images/2024/03/06/PSX_20240306_195818.jpg)
I need to check whether the flanges use cross head or flat heads. Allen heads are what i had available and just to check the fit.
Also started the forward planking on the hull. 2mm x 10mm bass wood.
(https://modelboatmayhemimages.co.uk/images/2024/03/06/PSX_20240306_195357.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/03/06/PSX_20240306_195602.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/03/06/PSX_20240306_195653.jpg)
David.
Post by: DJW on March 08, 2024, 08:55:24 pm
Evening All
Making progress with the hull planking. Gone about as far as I can for the moment, I want to add some epoxy on the inside to the areas that will become sealed when fully planked. Also need to find a way to build in a fan, but temporarily seal it from all the wood dust that's going to be coming it's way...
(https://modelboatmayhemimages.co.uk/images/2024/03/08/PSX_20240308_191917.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/03/08/PSX_20240308_191957.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/03/08/PSX_20240308_192023.jpg)
I think planking is one of those things where if you ask 10 people how they do it, you get 10 different answers.
My approach for this first layer is to cut the plank appropriately to size, clamp it into place. Mark it up and trim it as required for a good fit, and do this with its pair on the other side. Then drill where the plank crosses a frame using a small hand drill, while making sure the plank is firmly pushed against the previous plank. Drilled same size as the brass pins, and about 3/4 the length of the pins. Aim is to firmly hold the plank and not split it.
Then I glue up the hull to take the plank and hammer the pins home. I use small clamps between frames to make sure the new plank lays alongside the previous packs also larger clamps to apply pressure to keep the planks tight together along the glue line.
(https://modelboatmayhemimages.co.uk/images/2024/03/08/PSX_20240308_192247.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/03/08/PSX_20240308_192356.jpg)
Leave it for about an hour for the Titebond to cure, then repeat...
David.
Post by: DJW on May 07, 2024, 05:21:41 pm
Afternoon All
Haven't posted for a while, but have been making progress.
I paused the planking to install some ducting and also to apply some thinned resin to the interior of the planks while accessible.  This is the ducting installed, it takes air from under the cabin floor slats / grid to the motor bay.  Plan is to then extract the introduced air out of the exhausts to give a positive cooling airflow, and a nod to a real 'exhaust'.
(https://modelboatmayhemimages.co.uk/images/2024/04/29/PSX_20240429_204046.jpg)
This is the fan:
(https://modelboatmayhemimages.co.uk/images/2024/04/29/PSX_20240429_204642.jpg)
And the grid that will cover it:
(https://modelboatmayhemimages.co.uk/images/2024/04/29/PSX_20240429_203936.jpg)
I used a 3D printer to give me the grid layout then glued some mahogany veneer to the top and used the 3D printed grid as a cutting guide.
This is the underside:
(https://modelboatmayhemimages.co.uk/images/2024/04/29/PSX_20240429_203840.jpg)
And this is the layout, you can see the cutout above the keel at lower centre, and the two holes leading aft either side of the keel.  The fan sits in that cutout, and the ducts go off to the motor bay at top in the pic below:
(https://modelboatmayhemimages.co.uk/images/2024/05/06/PSX_20240506_184624.jpg)
Then the planking has progressed:
(https://modelboatmayhemimages.co.uk/images/2024/05/06/PSX_20240506_184035.jpg)
Each plank is 10 x 2mm Lime.  Glued and pinned to the frames.
(https://modelboatmayhemimages.co.uk/images/2024/05/06/PSX_20240506_184116.jpg)
And the result:
(https://modelboatmayhemimages.co.uk/images/2024/05/06/PSX_20240506_184507.jpg)
This sequence shows the modified flatter chine that I think this boat needs as a model to get the spray out and away, and provide lift at the bow:
(https://modelboatmayhemimages.co.uk/images/2024/05/06/PSX_20240506_184455.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/05/06/PSX_20240506_184442.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/05/06/PSX_20240506_184428.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/05/06/PSX_20240506_184410.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/05/06/PSX_20240506_184344.jpg)
And today I've been adding sealing resin to the rest of the planks from the inside, plus some of the other areas that'll be hard to reach in a while.
(https://modelboatmayhemimages.co.uk/images/2024/05/06/PSX_20240506_184606.jpg)
On a related note, I saw that MarkT had made up a neat plank vice to help with planing and shaping when it's needed, and this is my version that I made up for this build:
(https://modelboatmayhemimages.co.uk/images/2024/05/06/PSX_20240506_184519.jpg)
I add spare planks to the bottom of the vice so the plates remain square when gripping at the top edge, useful when working on two planks at a time that need same shape.
(https://modelboatmayhemimages.co.uk/images/2024/05/06/PSX_20240506_184538.jpg)
Final part of todays update, I've been a bit concerned about my LiPos and best way to store them, the 8,000mAh 6S packs for this build are animals...  Saw a chap using Ammo boxes and thought it was a good way to go.  Scouting online seems it's an accepted approach, important mod is that the lids need drilling to allow outgassing if worst happens.  I've also lined them with 5mm 'Aquapanel' basically the thinnest plasterboard I could find, and lined that with woven fibreglass matt, from an old fire blanket.  Hope it's overkill, and hope I never have to find out the hard way.
(https://modelboatmayhemimages.co.uk/images/2024/05/06/PSX_20240506_184211.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/05/07/PSX_20240507_143654.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/05/06/PSX_20240506_184229.jpg)
That's it for now...  Sorry it's a bit of a long post, all up to date now..!
Best regards
David.
Post by: SteamboatPhil on May 07, 2024, 06:03:12 pm
Coming along nicely congratulations  :-))
Post by: DJW on May 16, 2024, 08:01:13 pm
Hi Phil. Thanks for that.
Not had the time I'd have liked to get much done. But isn't that always the way. I've made some progress getting the battery bay sorted out. The motor LiPos will sit on some 5mm neoprene mounted on 3mm panels, about as low as I can get them in the hull. Then I've printed a cover for these LiPos that uses a little more neoprene to hold the LiPos in place, and on the top of that cover is a mount location for the third LiPo that will power everything else on the boat.
(https://modelboatmayhemimages.co.uk/images/2024/05/15/PSX_20240515_165236.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/05/15/PSX_20240515_165201.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/05/15/PSX_20240515_165145.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/05/15/PSX_20240515_165126.jpg)
Also used some more thinned finishing resin to seal the battery compartment.
I've also been reprinting some of the earlier 3D parts that were in PLA as I've a new printer that can handle ABS. And specifically some eSun ABS Max filament that's fire retardant while being more water resistant than PLA.
Looking forward to Wicksteed and will be taking my 1/10th Riva for an outing..!
David.
Post by: T888 on May 17, 2024, 08:26:05 am
Hi David,
She coming long very nicely, I like the planking work  :-)) :-))
The battery holders are you going to have a quick release ?
Post by: DJW on May 17, 2024, 11:12:22 am
Hmm, I like that idea.  At the moment I'd have to fully remove the 4 bolts then relocate them to put the cover back.  I could maybe build in a 'slide' action, so just back off the bolt a turn, then slide the cover to a larger 'bolt hole' that clears the bolt head.  I'll have a go at that, thanks..!
Post by: T888 on May 17, 2024, 11:49:45 am
Hi David,
I await how you solve this  :-)) %)
Post by: Stuw on May 18, 2024, 10:55:06 am
 Still love seeing this build come along. Wow, just wow! Serious battery storage options but good idea as lithium battery fires are not forgiving!
Post by: DJW on May 18, 2024, 07:52:11 pm
Hey Stuw. Good to hear from you, pleased you like the Ammo boxes..!
And @David. Here's the QR version of the LiPo cover.
(https://modelboatmayhemimages.co.uk/images/2024/05/18/PSX_20240518_163848.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/05/18/PSX_20240518_163904.jpg)
I think that will do the job and make access smoother. I'm re printing the cover now in ABS and making some clips that will retain the top, third battery. Initial plan was elastic bands but I think this approach will be a little more elegant and functional. Pictures to follow.
Also been busy today with the lathe, I've made up two solid couplings to make sure the motors and shafts are lined up.
(https://modelboatmayhemimages.co.uk/images/2024/05/18/PSX_20240518_163922.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/05/18/PSX_20240518_163938.jpg)
6mm motor end and 5mm shaft.
Also done some more work to the exhaust manifolds. Mounted the extraction fans and ducted them to the manifolds.
(https://modelboatmayhemimages.co.uk/images/2024/05/18/PSX_20240518_164026.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/05/18/PSX_20240518_164007.jpg)
David.
Post by: T888 on May 18, 2024, 08:54:34 pm
Hi David,
Simple engineering solution  :-))
Nice to see your method /tool for shaft / motor alignment. 👍👍👍 I also use this same method for my motor /shaft alignments.
Post by: DJW on May 21, 2024, 04:34:20 pm
Afternoon All
Think I'm finished with the battery holder / cover now.  Added some neoprene padding here and there to prevent movement of the batteries or chafing.
(https://modelboatmayhemimages.co.uk/images/2024/05/21/PSX_20240521_155526.jpg)
And made up a couple of clips that snap into place to hold that top battery.
(https://modelboatmayhemimages.co.uk/images/2024/05/21/PSX_20240521_155552.jpg)
So the finished article with quick release slots and the clips in place.
(https://modelboatmayhemimages.co.uk/images/2024/05/21/PSX_20240521_155615.jpg)
Have started to look at how to position and mount the little M400 Micropump.  Printed up a mount with cutouts for pipes to make it easier to mount it to the keel as a start point.  It needs to be as low as possible to help with priming, so it's going under the ESC box to the port side with the water inlet in similar position through the hull on the stbd side.
(https://modelboatmayhemimages.co.uk/images/2024/05/21/PSX_20240521_155639.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/05/21/PSX_20240521_155436.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/05/21/PSX_20240521_155501.jpg)
And a while ago the current build weight was mentioned...  Right at the beginning of the build the scale weight was worked out to be somewhere between 24kg and 32kg, depending on whether the full size Aquarama tips the scales at 3,000kg or 4,000kg...  And I think it's closer to 4,000kg...
Well, at the moment this is the situation with the hull probably 2/3 built in terms of the weight of the wood used.  Also with motors and mounts added, ESCs and most of the electronics in their cases, and the batteries all in place...
(https://modelboatmayhemimages.co.uk/images/2024/05/20/PSX_20240520_202030.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/05/20/PSX_20240520_202102.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/05/20/PSX_20240520_202011.jpg)
So about 15kg so far.  I think I have headroom for another 10kg without too much concern regards the waterline and performance.  We shall see.
David.
Post by: DJW on June 18, 2024, 12:32:44 pm
Afternoon All
A progress update...
I've been working to get work done that's easier before planking continues.  Mainly getting holes drilled out for conduits handing cable and water routing.  I'm printing conduit to allow the multiplex connectors to pass through, and to try to keep the eventual cabling neat.  Also thinking that by building in conduit I can pass cables more easily between inaccessible areas of the boat at a later date.  Just finished getting the parts ready, so all dry fit at the moment.
(https://modelboatmayhemimages.co.uk/images/2024/06/18/PSX_20240618_094239.jpg)
The top conduit (at top right above) is for speaker and docking light cabling, and runs all the way up to the bow on either side.
(https://modelboatmayhemimages.co.uk/images/2024/06/18/PSX_20240618_094300.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/06/18/PSX_20240618_094320.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/06/18/PSX_20240618_095241.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/06/18/PSX_20240618_094445.jpg)
In the pic above the lowest conduit takes the power cables to the port motor, the short conduit above that is for coolant tubes in and out of the port motor bay.  Same for starboard.
Also been working to getting the water pump mounted and water pipes routed, so I've drilled through the stringers in a few places:
(https://modelboatmayhemimages.co.uk/images/2024/06/18/PSX_20240618_094405.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/06/18/PSX_20240618_094422.jpg)
This will all be covered up by the ESC box.  Water comes in via the inlet fitting, via the pump then around the ESC box, then into a brass T to split and sent to each motor plate.  Then back to and out of the exhaust stubs.
Also been sealing the planking in a few areas before they become inaccessible:
(https://modelboatmayhemimages.co.uk/images/2024/06/18/PSX_20240618_094556.jpg)
The cabin grating is also ready to seal and finish, I think I need to stain the light wood underneath as the fan cut out is a bit obvious at the moment...
(https://modelboatmayhemimages.co.uk/images/2024/06/18/PSX_20240618_094543.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/06/18/PSX_20240618_094528.jpg)
Finally for todays update, I've been playing with Mahogany infused 3D filament.  I think it could be a useful approach to a few intricate parts, this is the magazine holders that go on the back of the driver and passenger seats:
(https://modelboatmayhemimages.co.uk/images/2024/06/18/PSX_20240618_094611.jpg)
I intend to play around with staining and see what can be done.
Very best regards to all.
David.
Post by: T888 on June 18, 2024, 05:07:32 pm
Hi David,
Nice and tidy work. Question will you be using “T” section conduit fittings for power cable take offs to say lights etc ?
Post by: DJW on June 21, 2024, 04:36:18 pm
Hi David
I could indeed make some T pieces, next on my list is to start getting the wiring sorted out, cut to length and so on as I've realised some of it may be best to be built in.  I'm also busy making templates of each of the frames, I need to check that they're symmetrical before planking up the sides of the hull.  I'm also giving thought as to when to bond in the prop tubes...  I know they usually go in pretty early in a build, I've made the cut outs for them in the first ply skin, but I'm thinking the mahogany planking would be neater if I just run whole planks, then drill / file the holes afterwards.
All just plans at the moment as the Wife has other plans at the moment involving the garden...   O0
Best regards
David.
Post by: DJW on July 12, 2024, 07:59:19 pm
Evening All
Not checked in here for a while, but have been making progress with the build.
Interior has been given a coat or two of thinned z-poxy finishing resin, sealing and I hope adding some strength.  Conduits for cabling are also epoxied in.
I've started on the first layer of planking up the sides of the hull, beginning with a plank on the chine rails as a start point:
(https://modelboatmayhemimages.co.uk/images/2024/07/07/PSX_20240707_155955.jpg)
Then alternating sides and working up the hull:
(https://modelboatmayhemimages.co.uk/images/2024/07/07/PSX_20240707_155859.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/07/11/PSX_20240711_105627.jpg)
And this is the current state:
(https://modelboatmayhemimages.co.uk/images/2024/07/12/PSX_20240712_193151.jpg)
Pleasing to see the shape of the Aquarama coming through..!
I've 3D printed some clips to help with the alignment of the planks between the frames, they're downloaded from Thingiverse and modified to have a 2mm 'grip' face, like this:
(https://modelboatmayhemimages.co.uk/images/2024/07/12/PSX_20240712_193221.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/07/12/PSX_20240712_193312.jpg)
They can be pushed on as much as required, so all the way on where the planks are one above the other, partially on when there is a curve on the hull.
It's a bit laborious as I only get to add a pair of planks a day at the moment....
(https://modelboatmayhemimages.co.uk/images/2024/07/12/PSX_20240712_154917.jpg)
Little notch in the planking at the bow on the chine rail is to accommodate the eventual bow protector strip.
David.
Post by: Martin (Admin) on July 12, 2024, 08:08:27 pm
Nice!    What wood are you using for the Planking?
Post by: DJW on July 13, 2024, 08:38:08 am
Hi Martin
This layer is bass wood, 1.9m lengths of 9mm x 2mm.  And the mahogany layer planks are 1.9m x 8mm x 1.5mm.  80 lengths of the bass and 100 of the mahogany for the build. The hull is just over 1.7m, I asked a couple of companies to quote for 1.8m lengths, I then worked with John at Jotika to supply the wood when he had a suitable length of mahogany to cut the planks from at that length.  On his advice I went for 1.9m lengths to accommodate hull curves and ensure no need for any joints.
Have to say this is one of my favourite if nerve wracking parts of the build.
Best regards
David.
Post by: Mark T on July 13, 2024, 06:27:15 pm
Absolutely astounding David  :-))   WOW
Post by: DJW on July 25, 2024, 05:59:52 pm
Afternoon All
Thanks Mark..!  Putting everything into this one...
More planks on...
(https://modelboatmayhemimages.co.uk/images/2024/07/25/PSX_20240725_174405.jpg)
And from the bow:
(https://modelboatmayhemimages.co.uk/images/2024/07/25/PSX_20240725_174425.jpg)
Short (stealers..?) planks starting to be needed now at the bow to avoid excessive conforming of the full length planks.
And forgot to mention that I've used some 40mm Aluminium extrusion to make a build support for this part of the build.  It used some 3D printed supports with foam rubber to fully support the hull but give reasonable access too.
(https://modelboatmayhemimages.co.uk/images/2024/07/25/PSX_20240725_174451.jpg)
David.
Post by: DJW on August 02, 2024, 04:32:18 pm
Afternoon All
Almost there now with the first layer of side planking.  I've made up some 3D printed clips to help keep the planks aligned between frames, the space available is limited to get normal clamps in.  The clips just are sized to just hold at the point of contact, and a couple of mm either side.  On the Aquarama the top of the hull sides really flares at the bow, the 'side' planking goes from vertical to almost horizontal.
(https://modelboatmayhemimages.co.uk/images/2024/08/01/PSX_20240801_185023.jpg)
(I have shaped the actual planks to butt up, above is just show where the grip is.)
Also a little notch at the top / middle of the clip so it stays aligned with the plank being attached, seems to work..!
(https://modelboatmayhemimages.co.uk/images/2024/08/01/PSX_20240801_184746.jpg)
Planks starting to shape around the transom too:
(https://modelboatmayhemimages.co.uk/images/2024/08/01/PSX_20240801_184825.jpg)
Current profile (with the bow of the 1/10th in the foreground...):
(https://modelboatmayhemimages.co.uk/images/2024/08/01/PSX_20240801_184933.jpg)
And the bow:
(https://modelboatmayhemimages.co.uk/images/2024/08/01/PSX_20240801_184719.jpg)
I've added just one plank each side since these were taken, hope to get the sides complete over the weekend or early next week.
Hope everyone is enjoying the sunshine..!
David.
Post by: DJW on August 08, 2024, 10:34:09 am
Morning All
Work been progressing to plank up the hull sides:
(https://modelboatmayhemimages.co.uk/images/2024/08/06/PSX_20240806_195407.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/08/06/PSX_20240806_195343.jpg)
Pretty much there at the stern:
(https://modelboatmayhemimages.co.uk/images/2024/08/06/PSX_20240806_195453.jpg)
And finally I have the first layer of planks on.  No filling / sanding or sealing yet, but nice to see the Aquarama shape:
(https://modelboatmayhemimages.co.uk/images/2024/08/08/PSX_20240808_095725.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/08/08/PSX_20240808_095650.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/08/08/PSX_20240808_095623.jpg)
I'm leaving plenty of planking proud so I can fill the lip with epoxy, then shape with a sander:
(https://modelboatmayhemimages.co.uk/images/2024/08/08/PSX_20240808_102911.jpg)
So next will be to seal the inside of the new planks, then fill and sand the outside.
David.
Post by: SailorGreg on August 08, 2024, 04:10:47 pm
That's a really neat job you have there before any sanding is done.  Your little clamps obviously did a very good job - as did you!
Greg
Post by: DJW on August 23, 2024, 12:10:30 pm
Afternoon All
@Greg, thanks..!  The clamps did indeed do a good job, having said that, it's been quite tricky to maintain the correct curves...  I realise now why larger hulls may need more frames as they provide a better base to bend the planks over.  Hindsight...   O0
I've now trimmed the planks at the bow, stern and along the deck line:
(https://modelboatmayhemimages.co.uk/images/2024/08/23/PSX_20240823_115327.jpg)
1/10th for comparison.
Also applied thinned finishing resin to all inside hull surfaces and started the hull sanding process.
(https://modelboatmayhemimages.co.uk/images/2024/08/23/PSX_20240823_115253.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/08/23/PSX_20240823_115418.jpg)
David.
Post by: T888 on August 25, 2024, 05:09:30 pm
Planking  :-)) :-)) :-)) :-))  will look fantastic when varnished.
Post by: Stuw on September 20, 2024, 08:56:00 am
Haven’t been on here for a while. Just caught up on your extremely hard work and excellent looking results. It looks amazing!
Post by: DJW on September 20, 2024, 12:51:33 pm
Thanks for the comments..!
More progress on a few fronts.
Still working to get the first plank layer smooth and profiled correctly so it serves as a good and sound base for the mahogany planks.  Mainly using the proxxon belt sander with 80 grit at this stage.
(https://modelboatmayhemimages.co.uk/images/2024/09/20/20240829_181503-EDIT.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/09/20/20240829_181522-EDIT.jpg)
Also been working on some smaller parts of the build.  The front cabin now has mahogany panels cut out for the 'footwell', not varnished yet.  I need access to the grating as there's a fan under it, so using magnets to hold the panels in place.
(https://modelboatmayhemimages.co.uk/images/2024/09/20/PSX_20240919_194407.jpg)
You can also see the start of the cabin cushions.  These are 2mm ply with 3mm neoprene, ready for the cream faux leather at some point.  I've made up some discs on the 3D printer to fit the holes taken out of the 6mm ply panels used for frame construction.  They have a flange on the underside and are generally glued in place (as below), some are bolted where I may need access later.
(https://modelboatmayhemimages.co.uk/images/2024/09/20/PSX_20240919_194455.jpg)
And these are some of the bolted versions, the thickness of the discs is such that when the second magnet and it's smaller disc is in place, the surface is flush.  So I just add a bit of epoxy to the second magnet disc, place the cushion and wait, it then looks like this:
(https://modelboatmayhemimages.co.uk/images/2024/09/20/PSX_20240919_192740.jpg)
And the cushion snaps into place.
I'm using same approach in other areas, so this is the cover for the motors, with the bench seat base on the left:
(https://modelboatmayhemimages.co.uk/images/2024/09/20/PSX_20240919_192652.jpg)
And in place:
(https://modelboatmayhemimages.co.uk/images/2024/09/20/PSX_20240919_192715.jpg)
Discs also in place (bolted just in case...) to retain the cockpit floor:
(https://modelboatmayhemimages.co.uk/images/2024/09/20/PSX_20240919_192627.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/09/20/PSX_20240919_192604.jpg)
Sundeck will use magnets too, but at the moment I've just added some 3D printed clips that are positioned at the front edge for the sundeck, they're shaped to protrude under the sundeck frame, aim being to prevent the sundeck front edge lifting when out on the water.
(https://modelboatmayhemimages.co.uk/images/2024/09/20/PSX_20240919_192529.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/09/20/PSX_20240919_192458.jpg)
Started to look at the seats too, trying to use the 3D printer to get some of the profiles, not there yet, a work in progress.  The print approach makes for rapid prototyping....
(https://modelboatmayhemimages.co.uk/images/2024/09/20/PSX_20240919_192422.jpg)
Using magnets embedded in the prints, they're an interference fit and need pressing in, but I add a drop of cyano to make sure:
(https://modelboatmayhemimages.co.uk/images/2024/09/20/PSX_20240920_123837.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/09/20/PSX_20240920_123804.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/09/20/PSX_20240920_123908.jpg)
Final part of todays update...  I've made up a mount for the steering wheel servo.
(https://modelboatmayhemimages.co.uk/images/2024/09/20/PSX_20240920_124012.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/09/20/PSX_20240920_123945.jpg)
This also uses a collar to directly attach servo to the brass shaft.  I found the basic design on 'Thingiverse', it's splined one end to fit the servo, and takes a securing screw down the centre, then provides an 8mm hole at the other end.  I've made up a reducer out of more flexible TPU to make the brass shaft a push fit.
The mount uses a dovetail plate on the bulkhead so the servo can be added in after the forward deck is in place, and can be removed if needed in future.
So all in all I got a bit carried away playing with the 3D printer and need to get my act together with the sanding...
David.
Post by: DJW on October 18, 2024, 11:56:29 am
Afternoon All
Well I have done some more sanding / filling of the hull, but have to say it's still ongoing...  It's a challenge to get the levels and curves right on this (for me) large hull.  But I think time invested now will pay off, once the varnish goes on it will show up ripple and defects in the hull shape.
(https://modelboatmayhemimages.co.uk/images/2024/10/18/1000015914.jpg)
And I've gone back to the 3D printer for some more pieces and fixings.  I've decided to 3D print the seat plinths, they're a 1/3rd of the weight of the ply versions.  I can also print in some retaining magnets:
(https://modelboatmayhemimages.co.uk/images/2024/10/18/1000015923.jpg)
Also added some side rails to keep the seat aligned on the plinth:
(https://modelboatmayhemimages.co.uk/images/2024/10/18/1000015924.jpg)
The seat is very lightly tacked together with cyano at the moment, just so it stays together, it will come apart again for covering.
(https://modelboatmayhemimages.co.uk/images/2024/10/18/1000015927.jpg)
For the seat edges I've tried to use the 3D printer to give me a head start with the compound curves needed.  I use Tinkercad which doesn't really deal with or allow curved surfaces to be created directly.  So I've taken a 1mm slice of say the seat back to give me a start, then used the 'replicate' function, I realised that it was possible to replicate once, change the dimensions of the replicated piece, say length and or height, move it away from the first slice by say 0.5mm...  Then hit replicate several times and watch the piece build...  I'm not sure whether I'll need to fill and sand to a better shape, or maybe cover in thin foam before the final covering.  But at least this gives me an ability to churn them out easily til I find the right method.
(https://modelboatmayhemimages.co.uk/images/2024/10/18/1000015918.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/10/18/1000015917.jpg)
Still working on the bench seat end pieces...  I've made the bench in 3 sections, centre will have flat material, outers will have the stitch pinstriping.  (And it was too big to print in once piece...)
(https://modelboatmayhemimages.co.uk/images/2024/10/18/1000015916.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/10/18/1000015915.jpg)
David.
Post by: Martin (Admin) on October 18, 2024, 01:24:23 pm
This is such a great build     :-))
Post by: T888 on October 18, 2024, 04:18:44 pm
I’d Second that David  :-)) :-))
Post by: DJW on October 21, 2024, 02:59:25 pm
Thanks for the encouraging comments both..!
Wife says I'm wasting my time and should go straight to a full size version...   O0
Very exciting to be starting to add some mahogany planking to the hull.  I want to get the lower hull planked so I can then get the prop shafts fixed in. So I'm starting with the transom as I like to run the fore / aft planks over the transom plank ends, just feels right that way.
I'm setting a single plank at a known height, then plank down, and eventually up from that initial plank.
I've also been pondering for many months on and off how to not use pins on this mahogany plank layer, anywhere.  I don't want pin heads at all, filled or not.  So I've made up some parts on the 3D printer that I hoped would do the trick, and they seem to be working well, at least on the transom.  The idea is to use large elastic bands that hold these T pieces applying pressure to the plank / hull, and also that they are under tension pulling the new plank against the adjacent plank...
They are also a little concave, so they apply pressure along their length, not just in the middle.  And for pulling the planks together, little teeth:
(https://modelboatmayhemimages.co.uk/images/2024/10/20/1000015971.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/10/20/1000015970.jpg)
And some hooks to anchor the elastic bands:
(https://modelboatmayhemimages.co.uk/images/2024/10/20/1000015973.jpg)
And here's the first plank going on using the T pieces to conform it to the transom curves:
(https://modelboatmayhemimages.co.uk/images/2024/10/20/1000015969.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/10/20/1000015968.jpg)
And working down from the first plank:
(https://modelboatmayhemimages.co.uk/images/2024/10/20/1000015982.jpg)
I'm pleased with the way they're working, tight planks:
(https://modelboatmayhemimages.co.uk/images/2024/10/20/1000015981.jpg)
I've had to cut out and drill the holes for the exhaust stubs before I cover all the screw holes...  They use brass inserts for threads so no winging it later...
(https://modelboatmayhemimages.co.uk/images/2024/10/21/1000015997.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/10/21/1000015995.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/10/21/1000015996.jpg)
And then back at it adding more planks:
(https://modelboatmayhemimages.co.uk/images/2024/10/21/1000015998.jpg)
The T pieces can just be moved up while sliding a new (glued) plank under the elastic bands, then work from the centre (for the transom) by moving the centre T piece down to hold the plank and repeat moving out.
So far it's working well.  And its useful experience with this approach to repeat it on the main hull planks.  No pins, no holes.  And at the moment, it's way quicker than working with pins...
Anyone used a similar approach..?  Did it work..?
That's todays update..!
David.
Post by: SteamboatPhil on October 21, 2024, 07:17:28 pm
This is an incredible build, I have been following from the beginning , and I am learning a lot (you are never too old to learn)
Brilliant  :-))
Post by: derekwarner on October 22, 2024, 12:42:23 am
Those printed T clamps, with the pressure/force created by the rubber-bands is pretty inventive  :-)) ....well done David
Post by: DJW on October 22, 2024, 05:24:10 pm
Thanks both..!  And @Phil, if I can give back to the forum for some of tips and tricks I've picked up on here over the last few years, that's good.
So far so good with the planking, now working my way up the transom, should have it trimmed tomorrow:
(https://modelboatmayhemimages.co.uk/images/2024/10/22/1000016014.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/10/22/1000016016.jpg)
The T pieces are conforming the planks nicely, I'm printing up some modified versions at the moment that will make it easier to attach the elastic bands.  I'm using a small chisel as a scraper to clear any excess glue before adding each plank to keep them tight.
(https://modelboatmayhemimages.co.uk/images/2024/10/22/1000016015.jpg)
David.
Post by: DJW on October 25, 2024, 03:45:44 pm
Transom is now mahogany clad.  And no pins used:
(https://modelboatmayhemimages.co.uk/images/2024/10/25/1000016054.jpg)
And these are now the modified T pieces with little hooks for the elastic bands.  Just makes them easier to use.
(https://modelboatmayhemimages.co.uk/images/2024/10/25/1000016055.jpg)
And roughly trimmed:
(https://modelboatmayhemimages.co.uk/images/2024/10/25/1000016056.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/10/25/1000016057.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/10/25/1000016058.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/10/25/1000016059.jpg)
I'm pleased with the result, I don't think the planks could be any tighter even using pins.  I'll probably leave the transom as is for a while and leave the sanding til nearer varnish time.  I'm thinking to now move onto planking the planing surface of the hull below the chines so I can get on with installing the prop shafts.
If anyone is interested in the 3D print files just drop me a PM, I think they could be resized for any plank size within reason.  I'll be using same method on the main hull planking.
David.
Post by: ChrisF on October 28, 2024, 12:40:20 am
Is it only me as I can't see the photos in this thread on my Android tablet or on my PC?
I can only assume David that you are still doing an excellent job!
Chris
Post by: DJW on October 28, 2024, 01:36:50 pm
Hi Chris..!
Well given you build Fairey Marine boats, I think there are two possible reasons you can't see the pics on this thread.
1. Your devices have marked anything to do with 'Riva' boats as Spam and dutifully removed them...
2. Martin has invoked an AI program on the Forum that filters out anything in your feed not related to 'Fairey Marine'...
To be honest I don't know why that would be, the images are downsized to 800x600px, they're hosted on the MBM Images site and added using the 'Insert Image' button on the toolbar.
Anyone else not seeing pics that I post..?
Very best regards
David.
Post by: JimG on October 28, 2024, 06:41:07 pm
I had problems with images from the Mayhem images site for a short time. My version of AVG virus checker had decided that this site was dodgy and refused to load any images. It initially decided that both MAyhem and images were phishing sites, had to set up the sites as exceptions to get acccess. (AVG on my laptop didn't have a problem)
Jim
Post by: ChrisF on October 30, 2024, 03:21:47 pm
You could be right David but I make an exception with your build!
Thanks Jim. On the PC I'm having that problem as in my case, Norton, displays a message that the site is dangerous. I can ignore it but it won't let me reply. The Norton licence allows me to use on my tablet but I'm not getting the warning message (I do on a car forum) and as you can see I can reply. So as you say looks like an anti-virus problem.
Chris
Post by: DJW on November 02, 2024, 02:49:54 pm
Hi Chris.  Don't know if this will help, but all images for this build are on this URL: https://modelboatmayhemimages.co.uk/album/JJD3 (https://modelboatmayhemimages.co.uk/album/JJD3)
Another build update.  I've started mahogany planking the planing section of the hull.  Spent a while getting the first two planks shaped, then went for the glue and clamps...
(https://modelboatmayhemimages.co.uk/images/2024/10/31/1000016206.jpg)
And then alternating sides adding pairs.  Still using the 3D printed T pieces, they seem to be working fine.  I am using conventional clamps at the bow where there's more pressure required and the clamps fit.  Mahogany planks are 1mm smaller than the Lime/Bass planks to avoid joints over joints.
(https://modelboatmayhemimages.co.uk/images/2024/10/31/1000016205.jpg)
This is latest progress today:
(https://modelboatmayhemimages.co.uk/images/2024/11/02/1000016257.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/11/02/1000016256.jpg)
I've noticed some difference in thickness of the mahogany planks, not ideal but not a lot I can do at this stage.  Just have to do a bit more scraping / sanding once they're on, I suppose I can use filler as these planks as it is the underwater surface that will be painted rather than varnished.  I'll lay them out and see if I can at least get some progression between adjacent planks...  Not sure it really shows on this pic, but its there by feel and when running a straight edge over.
(https://modelboatmayhemimages.co.uk/images/2024/11/02/1000016255.jpg)
David.
Post by: Capt Podge on November 03, 2024, 12:03:22 am
Hi David wow, that's massive progress since last time I looked in on your build - looking really, really good O0
Cheers,
Post by: DJW on November 10, 2024, 08:13:50 pm
Evening All
@Ray, thanks..! It does indeed feel like progress to be working with the mahogany planks.
And some more progress to report, more planks on.  I've planked around the rudder tubes, but over the prop tube and P bracket cut outs.  I've marked where to cut through for the P brackets, and will drill through from the inside for the prop tubes.
(https://modelboatmayhemimages.co.uk/images/2024/11/05/1000016304.jpg)
Then reached the chine rail at the bow:
(https://modelboatmayhemimages.co.uk/images/2024/11/09/1000016350.jpg)
So I added the chine rail plank, and have to admit to using some pins, the curve was just too great to hold any other way...  Not too stressed to be hones, still on the underwater section of the hull, so it'll be painted over.
(https://modelboatmayhemimages.co.uk/images/2024/11/09/1000016351.jpg)
I also had to use some cuts in the chine plank to get it to curve...  The cuts will be hidden / filled.
(https://modelboatmayhemimages.co.uk/images/2024/11/09/1000016353.jpg)
And in place:
(https://modelboatmayhemimages.co.uk/images/2024/11/09/1000016352.jpg)
And the current state of play:
(https://modelboatmayhemimages.co.uk/images/2024/11/10/1000016372.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/11/10/1000016374.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/11/10/1000016370.jpg)
David.
Post by: stuart22 on November 11, 2024, 04:49:19 pm
Hi David, its coming along very nicely, looking forward to seeing that, on the lake next year.
Stuart.
Post by: DJW on November 16, 2024, 07:32:42 pm
Hi Stuart..!  Well I hope she sees the water next year too... Maybe a technical outing.
I've made some progress toward that day, starboard planing surface of the hull is fully planked:
(https://modelboatmayhemimages.co.uk/images/2024/11/15/1000016447.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/11/15/1000016446.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/11/15/1000016445.jpg)
And I've made another mod to the T clamps to make them more stable.
(https://modelboatmayhemimages.co.uk/images/2024/11/16/1000016473.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/11/16/1000016474.jpg)
Very pleased with the hull shape that's coming through. The planks feel like they are conforming well.
David.
Post by: DJW on November 21, 2024, 02:26:46 pm
Afternoon All
A quick update, the planking of the planing surface is now complete:
(https://modelboatmayhemimages.co.uk/images/2024/11/21/1000016541.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/11/21/1000016540.jpg)
Some thickness differences on the planks, but sanding will sort that.  I'm thinking to sand the hull, then look at the cutouts for the P brackets and prop tubes.
Also busy building a proper stand for the hull right now, sled type just like the 1/10th.
Best regards
David.
Post by: SailorGreg on November 21, 2024, 02:29:28 pm
Coming along very nicely David.  I am looking forward to those multiple coats of varnish!
Greg
Post by: T888 on November 21, 2024, 02:55:15 pm
Hi David,
Lovely planking  :-)) :-))  and love the colour of the wood.
Post by: Mark T on November 21, 2024, 05:19:10 pm
Thats sweet planking  :-))
Post by: DJW on December 04, 2024, 04:00:57 pm
Thanks chaps..!  Appreciate the comments and encouragement..!
More to report.  the 1/5th now has a sled / stand that's same design as the 1/10th:
(https://modelboatmayhemimages.co.uk/images/2024/11/25/1000016709.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/11/24/1000016695.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/11/24/1000016693.jpg)
Needs some foam and some paint...
And I decided to go with scrapers as far as possible, they deliver such a uniform surface, and have helped get the high planks down nicely.  I've been on a mission to get my scrapers properly burnished, it's rewarding to see the shavings come off, and not so much sawdust to breath in...
(https://modelboatmayhemimages.co.uk/images/2024/11/29/1000016774.jpg)
And it makes the low spots more visible with the right lighting:
(https://modelboatmayhemimages.co.uk/images/2024/11/29/1000016773.jpg)
Used pencil scribble to gauge where I've been:
(https://modelboatmayhemimages.co.uk/images/2024/11/29/1000016770.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/11/29/1000016771.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/11/29/1000016772.jpg)
Again the scraper makes it a definite yes or no rather than sanding I think...
I used a mix of flat and gooseneck scrapers to deal with the curves, then some filler in places, and some light sanding.
(https://modelboatmayhemimages.co.uk/images/2024/11/29/1000016775.jpg)
I've now added the first plank to the hull sides at the chine as that finishes the planing section, so now ready to work up...
David.
Post by: DJW on December 11, 2024, 02:21:06 pm
Afternoon All
Some progress with the side planking:
(https://modelboatmayhemimages.co.uk/images/2024/12/07/1000016860.jpg)
(https://modelboatmayhemimages.co.uk/images/2024/12/11/1000016933.jpg)
Still not using pins, and nice to see the sharp chine rail.  I've ordered in some 100gsm cloth and epoxy resin from Easy Composites, I have in mind to add a layer of cloth to the planing surface to add strength and seal, it'll be painted over anyway...  And maybe just wrap the chine rail too to give some protection.  Still planning to use Hemple epoxy as a sealer for sides and topsides before the varnish goes on.
Also starting to template the sides of the transom, these will be cut from a 20mm thick Mahogany plank:
(https://modelboatmayhemimages.co.uk/images/2024/12/07/1000016862.jpg)
David.
Post by: DJW on December 18, 2024, 03:16:09 pm
Getting there...  9mm at a time...
Having to add in my stronger clamps now as there's almost a 90° twist needed in this part of the planking as the bow.
(https://modelboatmayhemimages.co.uk/images/2024/12/18/1000017051.jpg)
And at the stern the planks are now starting to roll in to form the rounded section:
(https://modelboatmayhemimages.co.uk/images/2024/12/18/1000017053.jpg)
David.
Post by: DJW on January 07, 2025, 02:54:24 pm
Happy New Year to All..!
Managed to get some work done on the Aquarama build over the Christmas break, feels like a milestone has been reached, the hull is now double planked with it's mahogany layer.
(https://modelboatmayhemimages.co.uk/images/2025/01/05/1000017295.jpg)
And from the top, I've run a bead of slow epoxy where the planks leave the hull, just a bit of reinforcing really, it's an area I'll need to drill into to eventually attach the chrome rubbing strip.
(https://modelboatmayhemimages.co.uk/images/2025/01/05/1000017297.jpg)
And trimmed, but not yet profiled / sanded.
(https://modelboatmayhemimages.co.uk/images/2025/01/05/1000017298.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/01/05/1000017299.jpg)
Some filling needed but not too much. I'm planning to use the scrapers again to flatten off the planks.
Also been a little distracted with a renovation of my old Fireboat (built for my son about 25 years ago), now to be crewed by Fireman Sam and Penny and (I hope) enjoyed by my grandson...
(https://modelboatmayhemimages.co.uk/images/2025/01/05/1000017301.jpg)
And finally, look what Santa brought...
(https://modelboatmayhemimages.co.uk/images/2025/01/05/1000017302.jpg)
Best wishes to all.
David.
Post by: T888 on January 07, 2025, 04:44:43 pm
Hi David,
Looking good, I bet your glad the hull planking is nearly complete  :-))
Post by: DJW on January 09, 2025, 10:25:03 pm
Hi David. Yes it's coming along, slowly...! And yes I'm very pleased to have finally finished the hull planking, it's taken a few weeks. Now working on the solid shoulders that are part of the stern, cutting from a 20mm plank of mahogany. This is second set as I realised I should try to keep the grain horizontal to match the planks.
(https://modelboatmayhemimages.co.uk/images/2025/01/09/1000017351.jpg)
Very best regards
David.
Post by: Martin (Admin) on January 09, 2025, 10:42:41 pm
What glue are you using at this stage?   :-)
Post by: DJW on January 10, 2025, 04:59:28 pm
Afternoon Martin
Still using Titebond 3, seems to perform well and I'm used to it now.  The shaping of the transom 'shoulders' continues, I'm finding it tricky to get the joint with the transom as I'd like it...
(https://modelboatmayhemimages.co.uk/images/2025/01/10/1000017367.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/01/10/1000017366.jpg)
I've also got to remove some thickness from the shoulders before bonding to the hull, not sure whether to try with the bandsaw...  If I leave them as is it'll be a lot to sand...
David.
An update on the above. I did use the bandsaw to take 5mm off each of the shoulders and it worked just fine. Will now attach them and sand to shape.
(https://modelboatmayhemimages.co.uk/images/2025/01/10/1000017371.jpg)
Post by: Mark T on January 10, 2025, 08:54:51 pm
That is beautiful  :-))   It is so difficult and time consuming to get both port and starboard side planking uniform.  You've nailed it there - wow!
Post by: DJW on January 15, 2025, 05:02:41 pm
Hey Mark..!  Thanks for that, and great to see you back at work in your workshop on that beautiful build of yours..!
I have the shoulders in place and roughly shaped, I'll do final shaping when the deck is in place.
(https://modelboatmayhemimages.co.uk/images/2025/01/15/1000017464.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/01/15/1000017463.jpg)
Really pleased to have finally found a mahogany coloured filler that's actually mahogany coloured and not some dodgy shade of purple / red... (Yes Osmo, you know I mean you... )  It's from Ever Build, 'Mahogany' coloured, and cheap as chips on Amazon.  A couple of places on the inner radius of the shoulders it was possible to see a dark glue line, so I ground it out very lightly with a mini tool diamond disc and filled with the Ever Build filler, looks a lot better.  :-))
Rant over, moving on...  Been getting the scrapers out again for the sides of the hull.  Had to order a 0.4mm set of curved scrapers to get into the hull flare at the bow, but they work a treat, take off such thin shavings and really help to level the planks and create the curve.  I think they're easier to see where low spots are and as such less likely to take off too much (compared to sanding).  The scrapers do mean no power tool assistance, so I'm doing it in 15 / 20m stints.
(https://modelboatmayhemimages.co.uk/images/2025/01/15/1000017462.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/01/15/1000017461.jpg)
Plenty more scraping and sanding...
Regards to all.
David.
Post by: SteamboatPhil on January 15, 2025, 06:17:13 pm
Awesome build, and the tip on "REAL" mahogany filler a godsend, thank you for the tip, will help with my up and coming project (thread to follow)
Post by: Mark T on January 15, 2025, 07:44:54 pm
Lovely work  :-))  and I agree with you regarding the scrapers and even better less dust.
I like your recommendation for the filler - I wonder what their oak filler is like for comparison?  I may get some and check it out as I need it for my worktop as I drilled some holes in the wrong place.
Post by: DJW on January 16, 2025, 09:50:42 am
Morning All
@Mark, only other Ever Build I have is the 'Natural - can be stained' offering, I've just been using it as a general filler.  I think they're £3.00 ish for 250ml, so worth a try in Light Oak I'd have thought.
This is the Ever Build filler:
(https://modelboatmayhemimages.co.uk/images/2025/01/16/1000017470.jpg)
And this is the colour compared the the others I've tried:
(https://modelboatmayhemimages.co.uk/images/2025/01/16/1000017473.jpg)
And the curved scrapers:
(https://modelboatmayhemimages.co.uk/images/2025/01/16/1000017477.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/01/16/1000017476.jpg)
@Phil, look forward to seeing new project..! And I'm sure you'll be at Wicksteed in May, I suspect the boat won't be ready for even a technical (lets see if it floats..) test by the time Mayhem 25 comes around, but I'll bring it up anyway even if just to establish how to get it in the car...
Regards to all.
David.
Post by: Mark T on January 16, 2025, 06:01:35 pm
Thanks David - I've ordered some - well let's be honest for £3 you can't go wrong.  You could start a new service with that Riva on a hot day - stand behind it and get cooled down by the blast!!!  Awesome build mate  :-))
Post by: DJW on January 23, 2025, 11:01:56 am
Morning All
I've been working on the stern, specifically the deck and hatch as these all get blended into the 'shoulders' of the transom. Started out with 1.5mm birch ply, this matches the thickness of and mates up with the 1.5mm bass / lime planks on the hull.
(https://modelboatmayhemimages.co.uk/images/2025/01/19/1000017516.jpg)
And that leaves the 1.5mm mahogany planks proud at the edges.
(https://modelboatmayhemimages.co.uk/images/2025/01/19/1000017514.jpg)
After a bit of sanding to get the nice arced deck shape I then applied the mahogany layer, I've actually used 2 x 0.8mm mahogany sheets applied in single layers as they conform to the shape better than a single 1.5mm thickness. (On the 1/10th Amati kit build they supplied mahogany faced ply for this task, but it was so easy to sand through the facing and exposing the lighter coloured core.  So I wanted solid mahogany this time.) So technically this gives 1.6mm rather than 1.5mm but that's easily sanded and blended.
(https://modelboatmayhemimages.co.uk/images/2025/01/19/1000017523.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/01/19/1000017522.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/01/19/1000017524.jpg)
And the result so far:
(https://modelboatmayhemimages.co.uk/images/2025/01/23/1000017563.jpg)
I think I'll keep going with this area of the boat, I'll need to add the 'slipway' (I think that's what Riva call the channel between the port and stbd hatches) and add some inset mahogany just under the slipway to seal the stern, basically cover those two voids at the stern.
I also quite fancy then completing the inlay on the hatches, on this build thats a border of 2x2mm bass/lime with alternating 2x2mm bass/lime and 6x2mm mahogany insets.  It's a lovely feature and gives me a break from the construction aspects of the build.
David.
Post by: DJW on January 27, 2025, 01:01:21 pm
Afternoon All
Next exciting episode...  I've been working on the hatch inlays, started by adding a border of 2x2mm to the hatches, very slightly proud of the frame, then ran them across the disc sander to get the edges in line with the frame, so the hatches still fit basically.
(https://modelboatmayhemimages.co.uk/images/2025/01/27/1000017662.jpg)
I was careful to clear any excess glue from the inside edge as this would stop the inlay laying correctly.
(https://modelboatmayhemimages.co.uk/images/2025/01/27/1000017660.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/01/27/1000017661.jpg)
Then started cutting the inlay strips. My method is to cut the strips a shade long, then sand to an interference fit, including a small chamfer to ease the strip in.  I use the disc sander to ensure I keep the ends at 90 degrees. The strips then hold together without glue at this stage.
(https://modelboatmayhemimages.co.uk/images/2025/01/27/1000017663.jpg)
Then take them out and spread some glue over the hatch so I can add the strips back in one go.
(https://modelboatmayhemimages.co.uk/images/2025/01/27/1000017665.jpg)
And the result with the final little mahogany strip (pic below - top left) ready to be pushed into place.
(https://modelboatmayhemimages.co.uk/images/2025/01/27/1000017664.jpg)
And the hatch in the boat.
(https://modelboatmayhemimages.co.uk/images/2025/01/27/1000017666.jpg)
I've lightly sanded the hatches but will wait for final sanding once the adjoining deck is all in place.
Next task is to add in the 'slipway'.
David.
Post by: DJW on January 31, 2025, 05:06:26 pm
Afternoon All
The aft hatch is pretty much done now, slipway is in place:
(https://modelboatmayhemimages.co.uk/images/2025/01/31/1000017731.jpg)
I used some epoxy with light glass cloth on the underside and the epoxy has seeped through the 2mm mahogany.  It wasn't thinned, so a bit surprised.  I don't think it's going to be an issue as the 'slipway' itself will be covered with cream faux leather and the sides will have some thinned epoxy to seal them anyway so I think the seeping marks will disappear.
Filled in the gap with 0.8mm mahogany...
(https://modelboatmayhemimages.co.uk/images/2025/01/31/1000017728.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/01/31/1000017730.jpg)
I've created a recess between the slipway and the side panels that will take the edges of the faux leather, should give a sharper line I think.
(https://modelboatmayhemimages.co.uk/images/2025/01/31/1000017729.jpg)
I won't be adding the faux leather yet, but this is the look:
(https://modelboatmayhemimages.co.uk/images/2025/01/31/1000017734.jpg)
That's it for now.  A good weekend to all.
Best regards
David.
Post by: SailorGreg on February 01, 2025, 02:03:09 pm
Getting better and better David.  :-)) :-)) :-))
Post by: DJW on February 10, 2025, 05:49:54 pm
Thanks for that Greg, just realised I'm over 3 years into the build...  So much still to do..!
I've added a layer of glass cloth to the planing surface, starting with a thinned mix of epoxy to seal the wood:
(https://modelboatmayhemimages.co.uk/images/2025/02/03/1000017788.jpg)
Then laid on the 100gsm glass cloth while the first layer was just still tacky, just enough to hold the cloth in place, started at the stern and brought it forward as a roll to avoid ripples:
(https://modelboatmayhemimages.co.uk/images/2025/02/03/1000017797.jpg)
I was a bit unsure whether the cloth would be OK on the sharp inside radius of the chines near the bow, but with the tacky hull I was able to really get the cloth into the tight radius and it stayed there.
(https://modelboatmayhemimages.co.uk/images/2025/02/03/1000017798.jpg)
I added a length of glass tape to the sharp bow, it'll be hidden by the cutwater, so just for strength really.
(https://modelboatmayhemimages.co.uk/images/2025/02/03/1000017799.jpg)
I used disposable stippling brushes to apply and 2 inch foam roller to work the resin in and get an even resin load.
I then applied an unthinned layer of resin again with a roller to hide the weave of the cloth, then trimmed up the edges and this is current state:
(https://modelboatmayhemimages.co.uk/images/2025/02/09/1000017896.jpg)
That's also the template for the cutwater, so I can start sourcing the brass to create it.  I'm thinking to make it in 0.8mm brass because its easier to work and solder, then chrome it.  I'd have liked to make it out of stainless steel, but not too familiar working with stainless...
I've been using epoxy from 'Easy Composites', laminating resin matched with their 'slow' curing agent, that gives at least an hour of working time, a bit more when thinned.  I used about 15% of Isopropyl Alcohol by volume and it cured just fine.
(https://modelboatmayhemimages.co.uk/images/2025/02/03/1000017787.jpg)
Two items of other news...
1. What to do with the smallest servo I've ever seen...?  (It's 17.2 x 16.1 x 8.3mm..!  And weighs 11 grams...)
(https://modelboatmayhemimages.co.uk/images/2025/02/03/1000017789.jpg)
Well, I had to order a few more and make up a set of working speedo and tachos...
Here's the 3D printed R&D version, 20mm diameter, and 35mm deep, (which can be accommodated in the dashboard), white LEDs to be embedded, chrome bezels to be added:
(https://modelboatmayhemimages.co.uk/images/2025/02/09/1000017895.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/02/09/1000017894.jpg)
2.  Had a great day out yesterday at the Midhurst Modellers Show with my 1/10th Aquarama polished up joining the impressive fleet and great people on the Portsmouth & District Model Boat Club stand..!  Maybe next year for the 1/5th...
(https://modelboatmayhemimages.co.uk/images/2025/02/09/1000017897.jpg)
Best regards to all.
David.
Post by: ChrisF on February 10, 2025, 06:13:14 pm
I've replaced my tablet and can now view your photos directly in your posts again.
Three years, you're joking, blimey! Fantastic workmanship as usual and love the working dials.
Chris
Post by: DJW on February 24, 2025, 01:48:47 pm
Hi Chris, pleased you can see the pics again..!  And thanks for the comments.
A few updates, and a bit of a close call to report...
1. Water Inlet has been fitted, I cut out the mahogany layer of planking to make the brass plate flush, and lined the cut out with epoxy to seal it. I think I'll use silicone sealant when the inlet is finally fitted to get a watertight seal... I've added a 2mm ply layer on the inside and glassed it in so it should be strong enough in the event the fitting takes any knocks.
(https://modelboatmayhemimages.co.uk/images/2025/02/16/1000017997.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/02/16/1000017998.jpg)
2. Props have been drilled to take 3mm grub screws with conical ends, so they lock the props to the shafts, I'll keep the locknut too to make sure the props don't go anywhere..!  I drilled the props while on the shafts so the drill cut a 'cone' into the shaft threads for the grub screw to locate in.
(https://modelboatmayhemimages.co.uk/images/2025/02/16/1000017999.jpg)
3.  I've fixed the prop tubes and shafts into the hull...  The motors, mounts, thrust bocks and prop tube have been taken apart and put together at optimal alignment, so they become one piece of hardware.  The black shapes are 3d printed wedges that go under the mounts to get correct shaft angle.
(https://modelboatmayhemimages.co.uk/images/2025/02/21/1000018057.jpg)
I then fitted the motors to their mounted positions and enlarged the cut out where the tubes exit the hull, so there was no interference from the hull on the tubes, to keep alignment.  I then fitted the P brackets into their recesses and inserted the shafts.  Happily they all lined up as expected.
(https://modelboatmayhemimages.co.uk/images/2025/02/16/1000017994.jpg)
I poured epoxy with a syringe to fit the P brackets, they're also held by two 4mm SS bolts each.
(https://modelboatmayhemimages.co.uk/images/2025/02/21/1000018066.jpg)
So at this point all was well...  And I masked the tubes passing through the hull before adding epoxy resin and glass tape to seal the tubes in:
(https://modelboatmayhemimages.co.uk/images/2025/02/21/1000018064.jpg)
Maybe some explanation required for the tubes as they pass through the hull.  The main prop tubes are 9mm OD, there's a 40mm end piece of 10mm OD (9mm ID, silver soldered on) that provides a housing for the bearing at the end of the tube.  Then the brass you see in the above pic is 11mm OD (10mm ID), these are cut to provide a more aesthetic pass through of the tubes, also to reinforce the area of the cut out...  So all the brass tubes are an interference fit together and either silver soldered or epoxied together.
And now onto the problem.  I turned the hull over and started to add resin / tape around the tubes and into the slots.
(https://modelboatmayhemimages.co.uk/images/2025/02/23/1000018098.jpg)
The shafts, P brackets and rudders are held in those ply slots / cases (stringers..?) to I wanted resin above and below the tubes to seal and hold them firm, which I did.
And I left the boat overnight.
Next morning resin was well on it's way to being solid.  I'd left the shafts in place to ensure alignment wile the epoxy took hold...  I took one of the shafts out no trouble, but the second was absolutely solid. You know that feeling when you realise you've screwed up...  Resin had dripped onto the shaft past the masking tape, then run down the shaft, into the now firmly attached P bracket.  Not good, not good at all.
I ended up standing the hull on end and soaking the P bracket in acetone to soften the resin, then had to grip the shaft with a mole wrench and gently start to get some movement of the shaft...  Plenty of acetone and coaxing of the shaft later, I have got it out.  The P bracket bearing needs replacing, the shaft needed some attention to get rid of the grip marks.  So disaster avoided, and kicking myself for not masking properly.
I now need to trim up around the pass through area on the outside of the hull and will post some pics.
I've added some threaded inserts inside the hull that allow ply covers to be attached over the prop tubes, will retain the electronics boxes, and hold down the battery covers.
(https://modelboatmayhemimages.co.uk/images/2025/02/24/1000018117.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/02/24/1000018116.jpg)
That's it for now.
David.
Title: Re: 1/5 Riva Aquarama...
Post by: DJW on February 26, 2025, 05:39:19 pm
To follow on, here's the underside of the hull with tubes, shafts, P brackets and rudders in place. Props are 2.75 inch diameter, 3 inch pitch.
(https://modelboatmayhemimages.co.uk/images/2025/02/26/1000018137.jpg)
I do like a shallow shaft angle, tip clearance on the blades is 5mm.
(https://modelboatmayhemimages.co.uk/images/2025/02/26/1000018135.jpg)
Tube passthroughs now faired in, I used Milliput so it's pretty strong.  This section of the hull is going to have some general sanding, filler / primer and several top coats of white, so not too stressed about any current sanding marks.
(https://modelboatmayhemimages.co.uk/images/2025/02/26/1000018136.jpg)
And from the side, all the underwater hardware including the water inlet.
(https://modelboatmayhemimages.co.uk/images/2025/02/26/1000018138.jpg)
And this is one of the bearings, just about visible.  They're about 25mm long made from a low friction engineering plastic designed to be used as bearing material, same as in the P brackets.
(https://modelboatmayhemimages.co.uk/images/2025/02/26/1000018140.jpg)
My thought now is to carry on with fitting out the cabin at the bow so I can get to installing decking.  This means installing speakers and dock lights before they get more tricky to access.  They're already made up so I'm hoping no dramas...   :-))  We have to hope don't we...
Very best regards
David.
Post by: DJW on March 05, 2025, 04:27:44 pm
Afternoon All
Well I thought there was no reason I couldn't get on with the side decks while I get the bow closer to being able to add that deck, so that's what I've done.
(https://modelboatmayhemimages.co.uk/images/2025/03/02/1000018238.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/03/02/1000018236.jpg)
And the birch ply layer in place:
(https://modelboatmayhemimages.co.uk/images/2025/03/05/1000018270.jpg)
Then cut some of the thin birch ply to seal the sundeck, and provide a base for the cushioning:
(https://modelboatmayhemimages.co.uk/images/2025/03/05/1000018271.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/03/05/1000018272.jpg)
So pleased to see the shape of the boat coming through with the recent work...!
Also had the 3D printer busy with some better fitting Speaker tubes:
(https://modelboatmayhemimages.co.uk/images/2025/03/02/1000018235.jpg)
And in place:
(https://modelboatmayhemimages.co.uk/images/2025/03/05/1000018274.jpg)
That's it for now.
David.
Post by: DJW on March 10, 2025, 01:00:21 pm
Afternoon All
Progress made on the deck, now have the second layer of 0.8mm mahogany cut and ready to apply:
(https://modelboatmayhemimages.co.uk/images/2025/03/10/1000018353.jpg)
All of the decking so far has been made up in same way, 1mm birch ply then two layers of 0.8mm mahogany sheet.
(https://modelboatmayhemimages.co.uk/images/2025/03/10/1000018351.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/03/10/1000018352.jpg)
And just wanted to say that the Proxxon 90 degree drill has been so useful, gets me out of trouble when I've forgotten to drill a hole and now have limited access...  Like here:
(https://modelboatmayhemimages.co.uk/images/2025/03/10/1000018354.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/03/10/1000018355.jpg)
I'll post a quick update when the deck is complete.
David.
Post by: DJW on March 17, 2025, 01:27:33 pm
An update as the deck is pretty much in place:
(https://modelboatmayhemimages.co.uk/images/2025/03/13/1000018402.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/03/13/1000018403.jpg)
I gave some thought to getting the deck curves correct around the sunbed and cockpit bench seat.  I ended up 3D printing an 80mm (to match the required radius) sanding drum / cylinder that attaches to my Proxxon polisher, The deck mahogany was then fitted oversized and sanded back to where it should be, and the drum approach has done a nice job:
(https://modelboatmayhemimages.co.uk/images/2025/03/13/1000018400.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/03/13/1000018401.jpg)
I used the polishing machine as it runs a lot slower than the 90 degree drill, I tried that first and it was a bit frantic...
And while that deck was clamped up and drying...  I've been giving thought for a while about transporting the boat, it's getting some weight to it now and while it does just fit in the car, I need a plan for getting it from car to lake.  I decided to see if I could build a trailer out of some spare Aluminium extrusion (40mm or 4040), and while it's a work in progress, here's result so far:
(https://modelboatmayhemimages.co.uk/images/2025/03/16/1000018504.jpg)
I had a couple of spare trolly wheels / hubs.  I've used some spare thick walled 10mm Stainless tube with 3D printed sleeves to connect the wheel hubs to the extrusion.  Then printed some fittings that locate and hold the sled / stand on the trailer frame.  So the idea is that the boat on its stand can be placed on the trailer as is, or the boat can be lifted off the tailer and stand.  I'm thinking to use some straps / Velcro  / or bungies to keep everything in place.
(https://modelboatmayhemimages.co.uk/images/2025/03/16/1000018505.jpg)
I've realised I need a slightly longer handle to avoid me being bent double...  So need to get the mitre saw out again.  I tried 3D printing some 45 / 135 degree brackets, but I'm not sure they're going to be strong enough, so I've ordered a set of stronger aluminium brackets designed for 4040 extrusion from Amazon.  The shole handle will need to be removable I think for transportation.  It should come down to backing off two Allen bolts to allow removal.  Then the trailer will be no longer than the boat.  Each wheel is held by one Allen bolt, so if needed they could come off too.
(https://modelboatmayhemimages.co.uk/images/2025/03/16/1000018508.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/03/16/1000018506.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/03/16/1000018507.jpg)
A useful aspect of the extrusion is that once the boat is complete I can move where the axle is in order to get the balance of the boat correct, so a bit of weight on the 'nose' of the trailer, but keep most over the wheels.
Now I'd like to finish the trailer in its basic form and move on to fitting out the bow cabin.  But we shall see..!
David.
Post by: stuart22 on March 17, 2025, 08:26:33 pm
Hi David, And I thought my Clyde was big, stunning work as usual.  :-)) hopefully we will be able to get too the lake soon. how do you plan to get the boat into the water?
Post by: DJW on March 18, 2025, 12:19:21 pm
Haha..!  Hi Stuart.  Well I reckon I might need a hand getting the boat into and out of the water...  Or a crane.   :-))
Best regards
David.
Post by: rhavrane on May 01, 2025, 10:57:10 am
Bonjour,
For fun, a classic one and a 3D printed one : https://youtu.be/lEBofzMeaYE and https://youtube.com/shorts/7bvPnRJs7G8  :-)) ok2
Post by: DJW on May 13, 2025, 05:05:11 pm
Hi Raphael
Two beautiful Aquarama's there, very nice builds.
I've realised I've not posted an update in a few weeks.  I've been busy with a few other things, but the 1/5th has made some progress.  And it's had it's first road trip...!  Went down to the Popham Model Show at the weekend and the 1/5th saw a lot of interest even though (or maybe because) it's a part build at the moment.  I'm a member of the Portsmouth & District Model Boat Club so the Riva was on the club stand.  At least I know now for sure that I can fit it in the car..!
(https://modelboatmayhemimages.co.uk/images/2025/05/11/1000019674.jpg)
I've been working on a few of the fittings, including the crew...
(https://modelboatmayhemimages.co.uk/images/2025/04/18/1000019165.jpg)
I found male and female 3D printable figures (on Thingiverse), all very articulated so can be made to sit and so on.  Full size they are 18 inches tall, so I've printed at 72% to get to 1/5th scale, they seem just the job.  I like the idea of being able to reprint as required, to optimise for what I need, and giving me plenty of painting practice...  I can also choose which joints will be fixed and which will be articulated.
(https://modelboatmayhemimages.co.uk/images/2025/04/19/1000019219.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/04/19/1000019220.jpg)
And for fun...  Because the limbs can articulate, how about a servo driven throttle control..?
(https://modelboatmayhemimages.co.uk/images/2025/04/29/1000019404.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/04/29/1000019405.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/04/29/1000019406.jpg)
And his right hand will be on the servo driven steering wheel...  And his head, well it's going to turn with the wheel in the direction of the turn.  Well it's all a bit of fun, and part of the reason for going big with the scale was to add some toys..!
Dock Lights are now ready too, some high powered 5mm LEDs into 3D printed lamps and reflectors.
(https://modelboatmayhemimages.co.uk/images/2025/05/11/1000019672.jpg)
And I've resumed sanding the hull.  I'm planning to take the boat to Wicksteed and am hoping to have the hull sanded and sealed at least.
(https://modelboatmayhemimages.co.uk/images/2025/05/13/1000019704.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/05/13/1000019703.jpg)
David.
Post by: rhavrane on May 13, 2025, 06:27:24 pm
Bonjour David,
Glad to hear you enjoyed these boats, so here are some more  :-))
An Ariston: https://youtu.be/zXoaF2_14Ig
Another one with a sound module: https://youtu.be/PjmiYGKUqmU
And a "monster": https://youtu.be/pBMR0g-t8jw Unfortunately, thermal propulsion is banned on most of our waterways now...
Post by: DJW on May 23, 2025, 03:40:33 pm
Well, the week didn't go as planned...
I felt the stern needed a bit more sanding to get everything shaped and flush.  So I sanded, and then I sanded a bit more.  Right up to the point that I went through the mahogany to the birch ply.  The ironic thing is that's exactly what I did with my 1/10th too, same place. What can I say...  :((
So I'm now resigned to taking out the mahogany on both stern quarters, and will replace with 2mm mahogany rather than a laminate approach.
(https://modelboatmayhemimages.co.uk/images/2025/05/23/1000019908.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/05/23/1000019907.jpg)
To be honest I'd not been that happy with the stern quarter panels anyway, they turned out a darker colour than the rest of the deck, so maybe it's the universe telling me just to get it right...   O0
I spoke to 'Hobbies' who'd supplied the Mahogany and asked them to ideally pick some redder tinted panels from their stock, and thats's what they did.  Have to say I was impressed by their delivery too.  Ordered 3.00pm Friday, opened the package 9.30am Saturday...
I have been busy progressing some parts of the cabin, getting some varnish coats on, some upholstery on the bunks.
(https://modelboatmayhemimages.co.uk/images/2025/05/23/1000019918.jpg)
Also been busy starting on the dashboard, I'm 3D printing some dials, thinking to see whether I can smooth the bezels enough to take some chrome paint...  If not I'll have to make them out of brass and get them chromed, we'll see.  Each will have a couple of LEDs installed for backlighting. Tacho's will be servo driven, maybe the speedo...
(https://modelboatmayhemimages.co.uk/images/2025/05/23/1000019910.jpg)
Instruments have an acetate face, then a spacer followed by a dial face, they'll have dayglo orange indicator.
(https://modelboatmayhemimages.co.uk/images/2025/05/23/1000019914.jpg)
And at the back a servo and holes for 3mm LEDs.
(https://modelboatmayhemimages.co.uk/images/2025/05/23/1000019915.jpg)
Planning to be at Wicksteed on Sunday, and will have the 1/5th in the car as a work in progress if anyone wants to see it.
David.
Post by: DJW on June 03, 2025, 05:23:13 pm
Afternoon All
Great to get back to Wicksteed and chat with you friendly folks..!
(https://modelboatmayhemimages.co.uk/images/2025/06/01/1000020143.jpg)
The 1/10th ran well, and the 1/5 got plenty of attention, I wonder whether it'll be a runner by next May...
(https://modelboatmayhemimages.co.uk/images/2025/06/01/1000020144.jpg)
I've set about the repair of the stern quarter deck sections where I'd sanded through, chiselling off the mahogany...
(https://modelboatmayhemimages.co.uk/images/2025/06/01/1000020137.jpg)
That wasn't fun...  And here with all the Mahogany off and sanded back:
(https://modelboatmayhemimages.co.uk/images/2025/06/01/1000020138.jpg)
And the new 1.5mm to bring up to correct height:
(https://modelboatmayhemimages.co.uk/images/2025/06/01/1000020139.jpg)
And the result, I think it's a lot better than the first attempt, so I'm pleased, and relieved...
(https://modelboatmayhemimages.co.uk/images/2025/06/03/1000020169.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/06/03/1000020168.jpg)
And while the glue was drying, I've been busy with elements of the dashboard.  The dials, not 100% faithful to the original Aquarama, but a lot now seem have new instruments and some are white dials.  These are generic dials with the Riva Logo added.  Tachos are 25mm, the rest are 20mm:
(https://modelboatmayhemimages.co.uk/images/2025/06/01/1000020136.jpg)
And some Hi Vis needles...
(https://modelboatmayhemimages.co.uk/images/2025/06/01/1000020140.jpg)
Also cut out a new dashboard, some of the dimensions of the first one were wrong:
(https://modelboatmayhemimages.co.uk/images/2025/06/03/1000020172.jpg)
And the crew just watching and being no help at all...
(https://modelboatmayhemimages.co.uk/images/2025/06/01/1000020141.jpg)
I'm pleased the stern deck fix is behind me now.  Feels I can move the build forward again.
I tried some veneer for the cockpit sides, but not happy with it, I'll just use the veneer as a template to cut some 0.8mm mahogany and see if thats better,  the grain in the veneer just looks wrong. IMHO...
This is the veneer...
(https://modelboatmayhemimages.co.uk/images/2025/06/03/1000020170.jpg)
That's about it for now.
David.
Post by: ChrisF on June 04, 2025, 10:40:23 pm
Looking fantastic as usual, well after your rectification works! I bet your heart fell, but it's great the end result is better than the first. Funny how it works out sometimes.
That veneer does look pretty poor doesn't it. I've even had mahogany where the grain is unacceptable. That's the trouble with having to use scale 1:1 timber for 1:x model builds!
Chris
Post by: ChrisF on June 06, 2025, 08:38:36 pm
Hi David. This is the trouble with reading your posts!   {-)
Post by: DJW on June 09, 2025, 01:14:37 pm
Hi Chris..!  What can I say, I've spent so much more on the tools than the boats themselves. Here's the 90° drill drilling yet another impossible hole..!
(https://modelboatmayhemimages.co.uk/images/2025/06/08/1000020324.jpg)
The issue with sanding through the stern and the fact that the new solid mahogany looks so much better than the laminate I tried has brought me to another realisation.  I need to remove the rest of the laminate from the deck...  I've just received more 1.5mm mahogany and the colour match with the 'new' stern, and the planks is just so much better.  And it's the deck that is the main part of the build that will be seen.  The chisel will be sharpened and busy again.
In other news.  I've installed the dock lights. I need to be able to remove them for varnishing / or future maintenance, so I've printed a back plate with nuts embedded:
(https://modelboatmayhemimages.co.uk/images/2025/06/08/1000020297.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/06/08/1000020298.jpg)
These plates are now epoxied to the inside of the hull, and allow the lights to be bolted in from the outside, bolts are M2.
(https://modelboatmayhemimages.co.uk/images/2025/06/08/1000020300.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/06/08/1000020301.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/06/08/1000020302.jpg)
I've added the wiring too, there are small connectors that allow full removal of the lights.
(https://modelboatmayhemimages.co.uk/images/2025/06/08/1000020325.jpg)
I'm trying to progress the 'cabin' so I can work on the deck, so after the dock lights I thought I'd look at the speakers, and a similar approach, a backing plate with captive nuts.
(https://modelboatmayhemimages.co.uk/images/2025/06/09/1000020338.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/06/09/1000020339.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/06/09/1000020340.jpg)
Mahogany side panels are now also fixed on place:
(https://modelboatmayhemimages.co.uk/images/2025/06/08/1000020326.jpg)
That's current state of play.
David.
Post by: DJW on June 19, 2025, 03:40:40 pm
Afternoon All
Lengthy update today...  Been busy.
The forward speakers have now got their final mounting rings that take nyloc nuts, nuts are an interference fit, and a little cyano to make sure.
(https://modelboatmayhemimages.co.uk/images/2025/06/17/1000020505.jpg)
And they're now mounted:
(https://modelboatmayhemimages.co.uk/images/2025/06/17/1000020506.jpg)
The speakers and tubes are mounted cabin side, but getting them out would not be easy once the deck is on.
And why stop at two speakers...  So there's another small speaker in the cabin:
(https://modelboatmayhemimages.co.uk/images/2025/06/19/1000020574.jpg)
Because an Aquarama needs a few tunes from time to time, so I found a small MP3 player that can be controlled by an Arduino, that can in turn be controlled by radio control.  I'm using the DFPlayer Mini, (£7.49 for 3 from Amazon) with an Arduino Pro Mini.  It's set to power up and random play from a selection of tracks on one channel, and volume on another channel, I'm thinking to assign that to a rotary know on the TX.
It's all working, but a bit messy at the moment:
(https://modelboatmayhemimages.co.uk/images/2025/06/19/1000020573.jpg)
The Futaba is just plugged in to check the volume control.  I now need to put the various modules together ready for installation.
And to finish on the subject of speakers, the two exciters are now mounted and will be fixed in place on the hull sides, I'm hoping they'll give off enough vibration to see on the waters surface, on a good day...
I've attached them to aluminium plates that are epoxied to some 2mm ply, then they'll be epoxied to the side planking:
(https://modelboatmayhemimages.co.uk/images/2025/06/17/1000020511.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/06/17/1000020512.jpg)
Been looking at the dash too, I need more depth behind the dash so some of the support had to go, and a section behind the steering wheel stiffened.
(https://modelboatmayhemimages.co.uk/images/2025/06/17/1000020501.jpg)
(Electronics are in view above as I needed to test the wiring to the forward speakers...)
And as you can see in the pic above, I've started on the planking layer of the cabin.  It's a compound curve fore / aft and port / stbd, so planking is only way I think.  This is 2mm x 10mm bass as used for the main hull.
Also using the same clamps with elastic bands to keep the planks tight together. Plus the small spring clamps to keep the plank edges lined up.
(https://modelboatmayhemimages.co.uk/images/2025/06/17/1000020502.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/06/17/1000020503.jpg)
And state of play as of 30m ago...
(https://modelboatmayhemimages.co.uk/images/2025/06/19/1000020576.jpg)
Laborious as always, but satisfying to see the deck curves materialise.
Very best regards to all.
David.
Post by: T888 on June 19, 2025, 07:46:48 pm
Hi David,
She coming along, very nice work :-)) :-))
Post by: DJW on June 24, 2025, 05:37:19 pm
Hi David
Thanks for that, always appreciated..! Feels like progress is moving fast at the moment.
The forward deck is looking better.
(https://modelboatmayhemimages.co.uk/images/2025/06/22/1000020697.jpg)
I started at the middle and worked outward, numbering each plank.  I'm really pleased and more that a little relieved that the symmetry is perfect, I ended up with 29 planks on each side of centre with same overhang.  As that's the widest section of the beam, that's a beam of 580mm...   :-))
(https://modelboatmayhemimages.co.uk/images/2025/06/22/1000020698.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/06/22/1000020696.jpg)
And here it is finished...
(https://modelboatmayhemimages.co.uk/images/2025/06/24/1000020719.jpg)
Edges trimmed with plane and sanding block, pencil scribble added...
(https://modelboatmayhemimages.co.uk/images/2025/06/24/1000020725.jpg)
And 20 minutes with the Proxxon belt sander later:
(https://modelboatmayhemimages.co.uk/images/2025/06/24/1000020722.jpg)
I'll be sanding a little further with a wide block to make sure any high spots get removed.  Then cutting the mahogany for the deck sides, and I still have to remove the current mahogany on the side decking to replace with matching colour wood... Once that lot's done, it'll be the forward deck inlay, really looking forward to that.
I've tried the sound system and am really pleased with the bass but slightly muffled sound. I've also played with the Frsky programming to mix the two sound systems when using the shafts for differential steering, so using the shafts in opposing directions for manoeuvring at low speed.  The two sound systems do indeed reflect the two 'V8s' running at different speeds.
That's it for now.
David.
Post by: DJW on June 27, 2025, 11:27:02 am
Morning All
I've shaped the forward deck a bit more and am happy with the result:
(https://modelboatmayhemimages.co.uk/images/2025/06/24/1000020724.jpg)
I think the forward deck and its inlay are one of the most visual parts of the Aquarama, so this first planking layer has to be right.
And I've cut the mahogany for the side of the forward deck.  In this pic you can really see how the colour of the centre mahogany is wrong, too red, big mistake.  It's days are now numbered before it meets my set of chisels...  The curved pieces are made up from three 100mm wide mahogany planks, for visual effect I'm trying to keep the grain running fore / aft, and hoping that after some sanding the glued joints will be less apparent.
(https://modelboatmayhemimages.co.uk/images/2025/06/27/1000020800.jpg)
Also made a start on creating the 'music player' that will find it's way to the boat, moving it from the development stage:
(https://modelboatmayhemimages.co.uk/images/2025/06/27/1000020798.jpg)
To a board that can be integrated:
(https://modelboatmayhemimages.co.uk/images/2025/06/27/1000020799.jpg)
That's a 12V down to 5V supply on the left, under it a capacitor to smooth the power supply, then the MP3 board in the middle and Arduino Pro Mini on the right.  Start / stop and volume controlled from the transmitter, track playing order is randomised by the Arduino from about 10 at the moment that are on a micro SD card.
That's all for now.
David.
Post by: DJW on July 02, 2025, 03:58:59 pm
Afternoon All
Well, the mahogany deck V1 is no more...
(https://modelboatmayhemimages.co.uk/images/2025/07/02/1000020958.jpg)
Had to use a couple of chisels, not a nice task...  But that thin mahogany just had to go.  I think it's also giving me the opportunity to blend the forward deck to the side decks a little better.  There's a small step in levels between the birch ply of the side decks and the lime / bass planks of the forward deck:
(https://modelboatmayhemimages.co.uk/images/2025/07/02/1000020959.jpg)
Next task is to cut new side panels and forward deck panels.
Also been playing with the Arduinos again.  :-)
The dashboard is now getting 2g servos behind all the dials not just the tachos as I originally planned. As the build is 1/5th the dash is about 35cm wide, the dials are 25mm and 20mm faces. The tachos will be driven by one Arduino that takes a PWM feed from port and stbd ESC channels, these servos / tachos will then show the power being applied through the motors.  I'm using an Arduino rather than a y lead for a few reasons.
1.  I want the tachos to operate correctly in forward and astern, to show the motors are operating independently when used for manoeuvring on shafts.
2.  I want the tacho dial pointers to do a full sweep on power up, then settle to an idle position and sync this to the sound system.
3.  I want the tacho pointers to display say 600rpm at idle, so when the sound system is active on tick over, but no throttle applied.
4.  I realised that I then need the system to be smart enough to understand when the sound system is powering down, and so to set the pointers to zero rather than just power off.
A second dashboard Arduino will control all the other dials except the speedometer.  I'm thinking that these just need to do a full sweep as they wake up, then rest at a set position (i.e. fuel level and so on), then on power down of the sound system, return to zero like the tachos.
A third Arduino... Will I think be needed for the Speedo as this will be driven by a GPS module, for providing speed across the water (SoG, Speed over Ground).  I'm using a GY-NEO6MV2 NEO-6M GPS Module (£7.59 from Amazon), SoG is then passed to the Arduino which deflects the Speedo dial pointer accordingly.  {-)
So far I have a testbed with couple of servos doing the startup and shutdown routines described above, that code will be needed on the three Arduinos and can be extended to more servos quite easily.  I also have the tacho code servos going to an idle position after startup, and then responding correctly to throttle input going ahead, but not yet astern.  Still a work in progress, but it's coming along.
(https://modelboatmayhemimages.co.uk/images/2025/07/02/1000020960.jpg)
And finally that GPS module, not started with that yet:
(https://modelboatmayhemimages.co.uk/images/2025/07/02/1000020962.jpg)
That's about it for now.  Off to do some sanding and cut some mahogany...
David.
Post by: Mark T on July 04, 2025, 09:38:44 pm
Hi David - I've been looking at your pictures and I thought that the deck looked really spot on.  A very brave decision on your part and sometimes we just have to get things exactly the way we want them - fantastic build.
Post by: DJW on July 07, 2025, 05:24:21 pm
Hey Mark..!
Thanks for your note, and I dithered about removing the decking for weeks, but now pleased that its done.  I think it's now a lot better second time around, so worth doing for sure.
This is the new panels being shaped to fit, and so much better colour and grain match:
(https://modelboatmayhemimages.co.uk/images/2025/07/06/1000021078.jpg)
And have been able to sort the level change between the birch ply and the fore deck planks, here's the before and after:
(https://modelboatmayhemimages.co.uk/images/2025/07/06/1000021076.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/07/06/1000021077.jpg)
This build is getting so much mileage out of the Proxxon belt sander..!
Had to work hard to get the mahogany deck panels held down while glue cured:
(https://modelboatmayhemimages.co.uk/images/2025/07/06/1000021079.jpg)
I've since moved on the the bow inlay, I've been looking forward to this part of the build, so really hope I don't screw it up...
Started with the central section, it's an immediate challenge as the deck planking shape is curved for / aft and port / stbd.  I'm using 1.5mm mahogany so used the 3D printer to create clamps that grip and push down on the edges of the mahogany, and flex enough to conform to the for / aft curve.
(https://modelboatmayhemimages.co.uk/images/2025/07/06/1000021080.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/07/06/1000021081.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/07/06/1000021082.jpg)
And the result:
(https://modelboatmayhemimages.co.uk/images/2025/07/06/1000021083.jpg)
And next the fun part:
(https://modelboatmayhemimages.co.uk/images/2025/07/06/1000021085.jpg)
2 x 2mm lime / bass, and 6 x 2mm mahogany strips.  I'm having to chamfer the inner edges very slightly with the disc sander so the butted up joints are tight as they go over the curved surface.
And some more 3D printed clamps specifically for the 2 x 2mm strips.
(https://modelboatmayhemimages.co.uk/images/2025/07/06/1000021086.jpg)
Same clamps used to pull the 2 x 2 into shape:
(https://modelboatmayhemimages.co.uk/images/2025/07/06/1000021088.jpg)
As an aside, been trying hard to keep the grain all running fore / aft.
(https://modelboatmayhemimages.co.uk/images/2025/07/06/1000021090.jpg)
While I wait for the glue to cure on the endless inlay...  This is the throttle servo getting sized up / prototyped to be recessed into the side of the cockpit:
(https://modelboatmayhemimages.co.uk/images/2025/07/06/1000021089.jpg)
That's going to have a cover, then 'drive' the articulated arm of the skipper. That's the plan anyway.
Also been playing with and testing the GPS for the speedo, I now have the module / Arduino deflecting a servo depending on how fast the GPS is moving, so that's a good start.
That's about it for now, back to add another piece of inlay...   :-))
David.
Post by: DJW on July 10, 2025, 03:54:44 pm
Afternoon All
Making progress...
My method for the inlay...  (and I'm sure if you ask 10 folks, there'd be 10 different methods..!)
I'm using the 'plank' clamps, here they're not clamping, but holding the rubber bands out of the way and ready to use:
(https://modelboatmayhemimages.co.uk/images/2025/07/10/1000021165.jpg)
Then I shape the next strip to be fitted and add that chamfer to keep the join tight:
(https://modelboatmayhemimages.co.uk/images/2025/07/10/1000021166.jpg)
Add a bead of glue, get the strip tightly fitted, and importantly remove excess glue. (Removed left of my thumb, still present at the right...):
(https://modelboatmayhemimages.co.uk/images/2025/07/10/1000021167.jpg)
Bring a clamp over to that first part, and adjust to get tension, forces are down and lateral to press new strip against existing:
(https://modelboatmayhemimages.co.uk/images/2025/07/10/1000021168.jpg)
And work along doing same, fit, remove glue, clamp:
(https://modelboatmayhemimages.co.uk/images/2025/07/10/1000021170.jpg)
Then let it dry for at least 30m before adding another strip.  All being well I end up with no glue residue that could cause an issue with next strip.
I had to order some more wood from CMB (as they originally supplied the wood I'm using as inlay), and mercifully it's same shade as the original...).
Getting closer now with the speedo...
I've added two LEDs that will sit in the dash, a red one for no GPS fix:
(https://modelboatmayhemimages.co.uk/images/2025/07/10/1000021164.jpg)
And a green one for when there are more than say 6 satellites:
(https://modelboatmayhemimages.co.uk/images/2025/07/10/1000021163.jpg)
Just a bit of fun really, they'll make the dash a bit more dynamic.
This shows some output from the GPS module, and some calculated values:
(https://modelboatmayhemimages.co.uk/images/2025/07/10/1000021172.jpg)
The 'GPS Speed Value' is data that comes out of the GPS module, it's in 100ths of a knot...  So the value fluctuates a bit even when the unit is stationary.  The 'Speed in knots' is a calculated field and rounded, so the small fluctuations are lost.  'Servo Deflection' is again a calculated field, in microseconds, sent to the servo.  I need to play with the ranges once I get the unit moving around to see how it behaves.  At the moment I have a speed range of 0 to 20 knots mapped to 1100 to 1900 microseconds, to get the servo to move based on the GPS 'speed in knots'.
That's it for now.
David.
Post by: Tom-C on July 10, 2025, 06:03:06 pm
Beautiful planking David!  You make it look all so easy.  Your clamps are a work of genius, even if they are all held together with rubber bands!
I was amused by the date on you GPS output - you are into time travelling as well, until I realised that our American friends always write their dates backwards!
All the bestTom
Post by: DJW on July 11, 2025, 05:59:35 pm
Afternoon Tom
Thanks for that.  And excellent plan for a time machine, that's just what I need to get this build finished...  :-))
Might need something with more power than an Arduino though.
A few more strips added to the forward deck inlay today:
(https://modelboatmayhemimages.co.uk/images/2025/07/11/1000021192.jpg)
I am pleased with the clamps, they're a bit fiddly at times, and occasionally if I set them up wrong there's a 'ping' and clamp bounces off the wall.  But overall they do the job, still no pins used / holes created and very limited ways to use conventional spring clamps in this situation.
David.
Post by: Mark T on July 11, 2025, 08:20:05 pm
Those inlays - that really is top notch joinery and much more difficult than you make it look.
Post by: DJW on July 15, 2025, 05:18:41 pm
Hey Mark..!
Thanks for that, I do enjoy doing the inlay, and I know it's the area of the boat that'll get a lot of attention when it's varnished and finished, so it has to be right..!  It's a rewarding part of the build for sure, but it takes a while..! I'm getting a few of the strips on each day so this is the current position:
(https://modelboatmayhemimages.co.uk/images/2025/07/15/1000021300.jpg)
Also been working a bit on routing some wiring for the dash, and putting together the controller modules for the various dashboard functions.  The controllers will work together in that they will power up at the same time, power in will be at 12V, one of those step downs is fixed at 5V for the Arduinos, the other will be set to 4V for the micro servos. I'm not sure about best way to power the LEDs at the moment, I think they are 3V, so I could run 4 in series from the 12V supply to cut down on wiring and resistors...
(https://modelboatmayhemimages.co.uk/images/2025/07/15/1000021298.jpg)
They should end up mounted just behind the dashboard and attached to it, the dashboard is mounted on magnets so I'm trying to keep the modules hidden but accessible.  And I need the modules close to the dash as there's going to be quite a bit of wiring with the servos and LEDs, that should then reduce the wiring going back to the aft of the boat:
(https://modelboatmayhemimages.co.uk/images/2025/07/15/1000021303.jpg)
And in situ:
(https://modelboatmayhemimages.co.uk/images/2025/07/15/1000021304.jpg)
Still thinking about the dash I'm not really happy with the 3D printed instrument bezels going forward, they've been fine to work out sizes but my thought was to prime them and see if I could chrome spray them.  I now think that's a bit of a waste of time as the result will be dubious at best.  So I'm using some of the spare brass 25mm OD pipe that was used for the exhaust stubs, machine it a little then silver solder a plate to the front and machine it a bit more to see if I can produce a brass bezel...  That I can then get chromed properly when the various fittings get sent off for chroming.  25mm is right for the tachos, I'll then need some 20mm OD if it works and I go ahead with the approach for the remaining instruments.  Early days, we shall see:
(https://modelboatmayhemimages.co.uk/images/2025/07/15/1000021305.jpg)
That's it for now..!
David.
Post by: JimG on July 15, 2025, 07:26:39 pm
Instead of chrome spray try one of the chrome paint pens. These give a good shiny finish when used on resin castings. They also do refill ink bottles which could be sprayed in needed.
Jim
Post by: DJW on July 17, 2025, 05:38:06 pm
Hi Jim
Thanks for the recommendation, I'll pick one of the pens up and see how it behaves.  I don't have a resin printer, just the filament (FDM..?) type, so I'm thinking to use a primer / filler to get a smooth surface.
The inlay is now complete on the stbd side:
(https://modelboatmayhemimages.co.uk/images/2025/07/17/1000021362.jpg)
I've not glued in the last few strips as I want to make sure the other side matches...  We'll see, then any adjustments can be made.
(https://modelboatmayhemimages.co.uk/images/2025/07/17/1000021363.jpg)
Also a little progress with the dash modules, they're now mounted and ready to get wired up to servos.
(https://modelboatmayhemimages.co.uk/images/2025/07/17/1000021359.jpg)
And in place:
(https://modelboatmayhemimages.co.uk/images/2025/07/17/1000021360.jpg)
I've been printing a case for the GPS too, pics to follow.
David.
Post by: Capt Podge on July 19, 2025, 11:25:33 pm
Totally in awe of what you're achieving with this build but nonetheless fascinating to follow...
Cheers,
Post by: DJW on July 22, 2025, 05:55:20 pm
Afternoon Ray
Thanks for that, and good to hear from you..!
I wanted to get the forward deck inlay done, and it's now complete:
(https://modelboatmayhemimages.co.uk/images/2025/07/21/1000021475.jpg)
I actually used 2mm high inlay, with a 1.5mm surround and centre strip, you can see the height difference here:
(https://modelboatmayhemimages.co.uk/images/2025/07/22/1000021494.jpg)
This gives me a bit more scope for sanding to get the deck curve spot on, I hope...
Great job for the Proxxon belt sander (@ChrisF...  You need one..!), I'm on 240 grit at the moment:
(https://modelboatmayhemimages.co.uk/images/2025/07/22/1000021496.jpg)
Then I've used a flat ply sanding block with some more 240 grit to smooth any high points:
(https://modelboatmayhemimages.co.uk/images/2025/07/22/1000021497.jpg)
And so far so good...
(https://modelboatmayhemimages.co.uk/images/2025/07/22/1000021498.jpg)
The inlay took about 2 weeks to cut and get attached...
(https://modelboatmayhemimages.co.uk/images/2025/07/22/1000021499.jpg)
You can see a low spot to the right of the above pic, I'm not too worried about that area as there's another piece of mahogany to go on top in that area.
(https://modelboatmayhemimages.co.uk/images/2025/07/22/1000021500.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/07/22/1000021507.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/07/22/1000021508.jpg)
You can see the curve on the above pics, also the thickness of the inlay strips, this is after initial sanding so plenty of wood left this time around...   You can also see the symmetry is not bad, it's out by about 2mm over 420mm of inlay, very hard to see any issue by eye, each edge has a 'one and a half' width strip.
So I'm pleased and more than a little relieved that the inlay has gone well, it's such a visual area of the final build and important to get right.
Also been working on the dash instruments, pics to follow.
And this is the GPS module that will provide speed input in it's final form:
(https://modelboatmayhemimages.co.uk/images/2025/07/22/1000021503.jpg)
It's going to sit in this kind of position (well under that part of the deck...), as this gets covered with a faux leather cushion.  So I plan to cut out the mahogany above the antennae so it get a good view of the sky, just the faux leather covering it.
(https://modelboatmayhemimages.co.uk/images/2025/07/22/1000021504.jpg)
That's about all for now.
David.
Post by: ChrisF on July 23, 2025, 12:24:21 pm
David - superb workmanship as usual and all the technical installation etc. is intriguing. This is going to be a fantastic model once finished.
As regards the sander I'm ahead of you there! I bought one and a narrow belt sander sometime ago but they were gathering dust (instead of making it!) until I started on my Fisherman build where it was great for the initial sanding of the hull.
Chris
Post by: DJW on July 23, 2025, 03:01:29 pm
Afternoon Chris
Thanks..!  And pleased to hear you've been getting some use from the belt sander, I don't have the narrow sander.  But I suppose if I've got this far without one, I probably don't need one.  Good to see progress with your fleet, hope we can catch up again at some point to get the boats on the water.
I forgot to mention in yesterdays update that I had put the Riva on the scales, I was a bit concerned and had been putting it off for a while...  To my great surprise it's currently 'only' 12.5kg.  That's most of the major woodwork, two quite heavy speakers in the bow, the motors / shafts / rudders, and the two electronics cases.  To be honest I thought it was going to be a lot closer to 20kg, it feels like it, but maybe thats because it's just a bit awkward to lift.  The 1/5 scale allows for a weight up to 30kg, but I don't want to be anywhere near that.  Anyway I'm quite pleased with 12.5kg at this stage of the build.  There is some more mahogany to be added, plenty of brass fittings, and the batteries of course, another 2kg ish there just for the batteries.  I guess the varnish and other paints will add weight too, I've got a kilo pot of Epifanes ready to go on.
And a couple of pics today, I had to see what the deck vents looked like in place:
(https://modelboatmayhemimages.co.uk/images/2025/07/23/1000021557.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/07/23/1000021558.jpg)
And on the subject of brass fittings, I'm starting to consider how the Musetto up at the bow is going to work and what I'll need...
(https://modelboatmayhemimages.co.uk/images/2025/07/23/1000021560.jpg)
Just ordered some more mahogany for the raised side pieces at the bow, no idea what they're called, this is them on the 1/10th:
(https://modelboatmayhemimages.co.uk/images/2025/07/23/1000021562.jpg)
On the 1/10th build each side is made up from two pieces of mahogany 2mm thick, so 4mm total when laminated. The top surface has to end up horizontal (rather than have the camber that the forward deck has) so it's not possible to just clamp down and glue it without shaping the underside first.  I'm planning to build up another laminate from 2.5mm mahogany, ideally just 3 layers giving me 7.5mm.  I find the thicker mahogany just a bit more of a challenge to make it bend.  On the 1/10th, after the varnish it's impossible to see the two layers at all, it looks like one piece of wood.  Hope I can get same result from this one...
And finally, @JimG - I've just received a 4mm Molotow Chrome pen to do some testing with, I'll report back whether I can get a decent result on suitable parts.
David.
Post by: ChrisF on July 23, 2025, 06:12:06 pm
Interested to see how you get on with the pen. I use Gild Chrome gilding enamel on my plastic window frames and I'm not that satisfied with it as it shows the brush strokes even though it looks as though they should flow out. Also over time it loses the chrome look and looks patchy. I can live with it on my narrow approx. 3mm frames but wouldn't be happy on larger items so hoping the pen gives better results.
Chris
Post by: DJW on August 08, 2025, 05:33:34 pm
Afternoon All
Some updates.
I took the 1/5th to the recent Chantry MBC open day over at Bluewater, also took the 1/10th to have a play on the lake.  Very friendly bunch they are too..!  While there I met up Martin from 'Dockyard Models', very nice and knowledgeable chap, kindly let me get the 1/5th under his Gazebo when a shower or two went through.  He had a range of mainly 3D printed fittings to look at, various scales, beautiful quality, primarily resin prints. We got chatting about the build as you do, and he's now supplied me with some custom resin printed bezels to see how they look on the Dashboard.  Have to say they are way better than I've been getting from my FDM (Filament) printer.  It's these versions that I'll be testing the chrome application from the pen, and also airbrushed.  Martin was also able to supply me with the 0.5mm acetate needed for the gauges, machine cut, perfectly round, just what I needed.  As the build progresses toward detailing I know I'll be getting back to Martin for some assistance..!   https://www.dockyardmodels.co.uk/ (https://www.dockyardmodels.co.uk/)
(https://modelboatmayhemimages.co.uk/images/2025/08/08/1000021852.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/08/08/1000021845.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/08/08/1000021846.jpg)
In other news:
The two rear rubbing strips (?) are now on, glued and bolted, 12 x 12 Mahogany:
(https://modelboatmayhemimages.co.uk/images/2025/08/06/1000021797.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/08/06/1000021798.jpg)
They eventually get a strip of 8mm half round chromes brass to finish them off.
And up at the bow I've cut and am shaping the two forward strips. (Gunwhales..?)
(https://modelboatmayhemimages.co.uk/images/2025/08/06/1000021792.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/08/06/1000021790.jpg)
And you can see up at the bow the start of the 'Musetto', at the moment its the top shape in brass sheet, with some mahogany ready to be shaped under it.  Idea is to get that brass plate butted up to the two gunwhales, and sitting flat.  Then I can remove it again and at some stage start to build the Musetto properly, it's classic Riva.
Also been cutting and attaching the cockpit sides, 0.8mm mahogany over the birch ply.
(https://modelboatmayhemimages.co.uk/images/2025/08/06/1000021794.jpg)
And on the port side I've recessed the throttle servo.
(https://modelboatmayhemimages.co.uk/images/2025/08/07/1000021812.jpg)
And here's the start of a cover for the servo, the cover is 3d printed with text hollowed out so I can add some black plaint.  Thats plan A anyway, we'll see.
(https://modelboatmayhemimages.co.uk/images/2025/08/08/1000021850.jpg)
I'm working on bending some mahogany to go either side of the dashboard, I'm doing it as a laminate of 3 x 0.8mm, but trying to bend it 'with' the grain, so it matches the dash.  This is the current approach, soaking the wood, then apply some force...
(https://modelboatmayhemimages.co.uk/images/2025/08/07/1000021813.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/08/07/1000021814.jpg)
It's getting there.  Once about right I'll add in some glue between the layers, then keep it curved while it sets, then shape it to fit.
I also decided to revisit the creation of exhaust vapour...  And I'm not to happy with the nichome wire approach for two reasons.  One I need mist, not 'smoke', and two, a hot wire is just a risk too far.. So have built a new solution that takes two of the water misting discs, here's (a poor picture of...) the case at the moment, I've had the discs working and it's now a matter of getting the electronics into the case:
(https://modelboatmayhemimages.co.uk/images/2025/08/06/1000021796.jpg)
On the subject of the misting unit, I want to integrate the misting into the startup sound sequence, so everything happens as it should.  The controllers of the misting units tend to have a little button on them that when pushed starts the misting, I was watching a YouTube video about controlling a unit with an Arduino, it showed shorting out two of the terminals on the push button to allow the unit to power up as soon as power is applied, and it works.  Not sure whether this was widely known by everyone (except me...), but it makes the units a lot easier to turn on and off via RC.
That's it for now.
David.
Post by: minimariner on August 08, 2025, 07:37:51 pm
                       David,
                                  I use two wires one each side of the push button then to a RX latching relay switcher.
                                   It then it can be switched on and off via the transmitter.
                                                               Bryan.
Post by: DJW on August 10, 2025, 03:08:17 pm
Good Afternoon Bryan
I did not know that, thanks for the tip.  I've never been quite sure what that switch does, it seems to be responsible for power and mode of operation depending on number of presses, but good to have another option re how to just make the unit power up when required.
And in other news. I had one of those rare moments of joy yesterday.  You know when you've kept something ridiculous thinking that it might be useful one day...  Well, about 25 years ago I kept a TV stand, bought for office use, steel, very strong.  Built for when TVs were as deep as they were wide and weighed as much as a small car.  Yesterday I saw it in the shed, and realised it would make a great build stand for the Riva.
(https://modelboatmayhemimages.co.uk/images/2025/08/10/1000021874.jpg)
I'm going to add some blocks on the top surface so the stand can't move around, but it's pretty non slip anyway.  The stand can be altered in height and gets the boat to a good working position, saving my back... It's on lockable castors so it makes moving the boat around a lot easier.  I just wanted to share that with people that might understand my delight.  Unlike my wife, just saying.  O0
David.
Post by: DJW on August 21, 2025, 06:12:19 pm
Afternoon All
Quite a lot of work around the dashboard.  In the previous post you can see first attempt at the panel that sits above the dashboard, and defines the shape for the windscreen with its curve.  It was cut too early, straight from plans, and is too large, just a shade too wide, so it's in the bin.
So I've worked on the side panels for the dashboard:
(https://modelboatmayhemimages.co.uk/images/2025/08/21/1000022033.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/08/21/1000022034.jpg)
They provide a lead in to the upholstery that will surround the cockpit as same height.
And that top panel, this time I made a laminate for 2 x 1.5mm mahogany, and clamped it into place to get it curved rather than flat.  (Parchment paper underneath.)
(https://modelboatmayhemimages.co.uk/images/2025/08/21/1000022035.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/08/21/1000022036.jpg)
And the result:
(https://modelboatmayhemimages.co.uk/images/2025/08/21/1000022044.jpg)
That's after cutting out from a template:
(https://modelboatmayhemimages.co.uk/images/2025/08/21/1000022040.jpg)
To end up with:
(https://modelboatmayhemimages.co.uk/images/2025/08/21/1000022041.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/08/21/1000022042.jpg)
And finally the result when glued in place and held with some light clamping:
(https://modelboatmayhemimages.co.uk/images/2025/08/21/1000022043.jpg)
There is intentional clearance at the top of the dash as the dashboard has to remain removable.  Now working on the mahogany cap that goes above the dash and provides an overhang / sunshade for the dashboard.  I was thinking of using a sold piece of mahogany, but will try the laminate of two 3mm pieces first, then get them to bend over a former and glue to get the curve...  We'll see how that goes.  Cutting from solid is now plan B.
For the eagle eyed...  In the pic above you'll see the anchor hatch is now also in place...
David.
Post by: DJW on August 28, 2025, 10:26:14 am
Morning All
Made progress with the dashboard cap / sunshade.  It's not faithful to the Amati kit build, but I made this full width type for my version of the 1/10th build and feel it's a better representation of the full size boat.
I made a laminate from some 1.5 and 0.8mm mahogany, 0.8 on the bottom, very approximate shape, but clamped it in place while it cured to get the curved shape:
(https://modelboatmayhemimages.co.uk/images/2025/08/28/20250823_170756.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/08/28/20250823_170811.jpg)
Then added another 1.5mm layer on to as the actual sunscreen:
(https://modelboatmayhemimages.co.uk/images/2025/08/28/20250824_171737.jpg)
Clamped again while curing.  Then some initial shaping and I ended up with this:
(https://modelboatmayhemimages.co.uk/images/2025/08/28/1000022149.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/08/28/1000022150.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/08/28/1000022148.jpg)
And while not fully finished, this is current state of play with the sunshade glued in place:
(https://modelboatmayhemimages.co.uk/images/2025/08/28/20250828_092843.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/08/28/20250828_092855.jpg)
Still a little work to do to get the fit better, and some more sanding to blend it in a little more.  Dashboard remains removable, so I'm happy with the approach so far.
David.
Post by: Martin (Admin) on August 28, 2025, 12:29:43 pm
Re:  dashboard cap / sunshade
Did it need to be  preformed / Curved before fixing down?
Post by: DJW on August 28, 2025, 12:49:55 pm
Hi Martin
Well I felt it was best approach for a couple of reasons.
1. I tried with a piece of mahogany that was 4mm thick, and it wasn't too happy about bending.
2. The shape I needed on the underside to accommodate the raised section of the dashboard where the tachos go was going to be tricky with the thicker 4mm wood, routing out and so on.
So being able to build up the layers of thinner wood, of slightly different shape seemed easier.  I've used the laminate / glue on a curve to end up with a curved result a couple of times.
Very best regards
David.
Post by: Mark T on August 29, 2025, 05:56:41 pm
Such lovely bespoke work - David the boats looking amazing and one of a kind too.
Post by: DJW on September 16, 2025, 03:42:05 pm
Afternoon Mark, thanks for the kind words, trying my best and having to make some parts several times before I'm happy.  Build timescale seems to be extending rather than closing in on a launch date..!
Some progress in the right direction to report.
I've been testing with the Hempel 599 two pack sealer ( https://www.mbfg.co.uk/hempel-epoxy-sealer.html (https://www.mbfg.co.uk/hempel-epoxy-sealer.html) ]
(https://modelboatmayhemimages.co.uk/images/2025/09/16/1000022485.jpg)
It is very thin, and I thinned it a shade (5%) further to improve penetration, and extend curing time, it's now workable for at least an hour, and solid in 24 hours.  Brushes on easily and is all absorbed, ideally so there is no 'shine' to the sealer once applied meaning it's all been absorbed.  I've since used it on the rear hatch, and the cockpit sides, very pleased with the result.  So I've also done a final sanding of the hull and deck ready for a sealing coat in next few days.  It's applied once, no overcoating and I'd like to apply it in one session.  I've already sealed the planing surface of the hull so the boat will sit in it's stand for application.  The epoxy sealer will become the base for varnishing.  (I used thinned Z-Poxy Finishing Resin for the 1/10th Aquarama, the Hempel is a lot thinner, and has a longer working time.)
So here the hatch and slipway is sealed, but not yet the surrounding mahogany.
(https://modelboatmayhemimages.co.uk/images/2025/09/09/1000022400.jpg)
Filled, sanded and rubbed over with isopropyl to degrease:
(https://modelboatmayhemimages.co.uk/images/2025/09/16/1000022489.jpg)
A sealing coat added to the planing surface:
(https://modelboatmayhemimages.co.uk/images/2025/09/16/1000022484.jpg)
Also been busy with the dashboard...  And getting a bit carried away I think.
All the gauges are now functional, as in the dials are correct and the pointers rotate, and there are 2.2g servos behind each, and the LEDs are in place within the dials, but not yet connected up.
(https://modelboatmayhemimages.co.uk/images/2025/09/09/1000022402.jpg)
I've got the code for the various dials working individually, now trying to integrate...
(https://modelboatmayhemimages.co.uk/images/2025/09/16/1000022401.jpg)
And the servos...
(https://modelboatmayhemimages.co.uk/images/2025/09/16/1000022483.jpg)
Tachos feed from the port and stbd ESC throttle position, the gearshifts which are dash mounted either side of the steering wheel as stalks are also functional and use same ESC feeds to know where to move.
Speedo is fed data from an onboard GPS. Fuel gauges, they take the voltage of one cell of their respective (port / stbd) LiPos via the balance lead, then give a servo deflection for a range of (at the moment) 3.5v to 4.2v, a dash light will turn from green to red if voltage reaches 3.6v.  And in the spirit of getting carried away, I may get the temp gauges running and displaying a value representing ESC temps.  That leaves just the Ammeters, I may just fudge those with an arbitrary deflection.  All the gauges do a full sweep on power up, then settle.  Once it's all running I'll put up a video.
This functionality will take 2 or 3 Arduino pro minis.  I think some electronics oriented folks could do it with less or alternative hardware...  I'll just be pleased to see it in action.
On the subject of electronics, I've decided to create two new cases and rework the contents, plans have changed and extended during the build.  I'm moving away from the MPX 6 pin connectors.  The new cases will be 3D printed and use 25 pin D-Sub connectors, more connections available, and more robust the the MPX connectors.
I'll report back when the sealer is all applied.
David.
Post by: DJW on September 17, 2025, 01:01:15 pm
Afternoon All
Well the sealer is now applied to the whole hull. Feels like a build milestone to see the mahogany change colour.
(https://modelboatmayhemimages.co.uk/images/2025/09/17/1000022508.jpg)
It went on well, very easy to apply and 14 hours later (basically this morning after applying yesterday late afternoon) it's touch dry but I'll leave it for a while before doing too much in terms of manhandling the hull.
(https://modelboatmayhemimages.co.uk/images/2025/09/17/1000022509.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/09/17/1000022510.jpg)
I'm in two minds about carrying on with the varnishing, or at least making a start with a couple of coats.  I wanted to get the sealer on to protect the woodwork as a minimum aim. Before this any touching of the bare mahogany leaves traces. I'm aware that varnishing when the temperatures are on the way down is less than ideal.  I'm going to see how stable I can keep the temperature and humidity with heating and dehumidifier.  If that's OK I'll look to get several coats on.  I have some Epifanes Clear High Gloss single pot and will pick up some thinners before I start. I've been watching some of the Danny Lee videos on YouTube, he seems to be the Epifanes guru and gets some truly astounding results.  His approach is to thin first few coats down by 40% ish to fill grain, then use scotch pads between coats for keying, not attempting any sanding / levelling til later coats. So that'll be my approach.
Best regards to all.
David.
Post by: DJW on September 19, 2025, 03:40:24 pm
Afternoon All
I'm not sure whether the Arduino work is of interest on this build log, by all means let me know either way..! I'm no guru myself and it's taking me what seems years to get my head around the basics to get the results I'm after.  I've cracked a few important techniques that open up options for my Aquarama build like how to take an RC (PWM) input and how to control a servo or servos and how to do a bit of manipulation in the middle.  Apart for generating sounds, most of the projects I'm using Arduino's for on the build usually involve reading an RC channel and doing something, usually with a servo.
I spent a few hours yesterday getting code for the 'Fuel' gauges to work properly.  I'll have the voltages of the Lipos available via telemetry, but given the large build scale I quite like the idea of the dashboard delivering the same information it would on full size boats.  The gauges will be large enough to see when the boat is close, as will the LEDs in the dash.
My port and starboard fuel tanks are the two 6S LiPos and as I understand things (googled) a Lipo cell has a normal usage range from about 3.5 to 4.2V, and during discharge a long duration is spent around the 3.7V point. This is handy as the Arduino's Analogue pins can read up to 5V directly without getting too fancy by having to deal with and read in excess of 22V for a 6S. As the voltage goes up you get a reading of 0 for 0V to 1023 for 5V, and all the points in between...  My fuel gauges need to read 3.5V at empty and 4.2V when full and I have 160 degrees of servo movement available to represent that range.  I've hooked up a bench power supply that can provide the 3.5V to 4.2V range to test with and the output from the code currently looks like this:
This screengrab is emulates if the Lipo is almost full, providing 4.18V from the cell being measured via the balance lead:
(https://modelboatmayhemimages.co.uk/images/2025/09/18/4.18v.jpg)
The analogue reading of 855 is from the 0 - 1023 range measured by the Arduino, then the conversion of that reading to 4.18V, last line shows the servo travel of 154 degrees indicated, and shows that a green LED will be illuminated on the dash (1 for on, 0 for off).
Pic below is just above the 3.6V threshold at 3.68V, LED still green, with servo now at a reduced movement of 56 degrees indicated:
(https://modelboatmayhemimages.co.uk/images/2025/09/18/3.68v.jpg)
And finally just below the 3.6V threshold to test the LED change.  This time the voltage is 3.58V so now the green LED is out, and red is illuminated, servo is now at just 34 degrees indicated:
(https://modelboatmayhemimages.co.uk/images/2025/09/18/3.58v.jpg)
I'm happy that the code is fundamentally working as required, I can change the settings a bit if required once it's all hooked up and we see what happens in the real world.
I've thought of another albeit related challenge.  There's the notion of port and starboard running through the code for the gauges.  So now I'm thinking that rather than just 'power up the dash', I can try to power up the port motors gauges as it starts, then the starboard set 5 seconds later.  This is already how the sound system works.  How difficult can it be...   {-)
Epoxy sealer applied a couple of days ago is now fully cured, waiting on the Epifanes thinners before adding some varnish...
David.
Title: Re: 1/5 Riva Aquarama...
Post by: DJW on September 23, 2025, 03:00:56 pm
Afternoon All
Thinners arrived. Varnish time...
(https://modelboatmayhemimages.co.uk/images/2025/09/23/1000022610.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/09/23/1000022611.jpg)
This is first coat of many.  Epifanes High Gloss Clear Varnish, plan is to add 3 coats thinned 30% with Epifanes Brush Thinners before considering sanding. 24 hours between coats.  Then I'll reduce the thinners to 15% ish for subsequent coats.  The Epifanes is Tung Oil based, like Le Tonkinois and has a similar amber hue (even though it's labelled 'clear'), but for me when i tested the Epifanes it gives a harder finish that can be more easily sanded, or maybe it was down to me lacking patience.  The Le Tonkinois gives an exceptional finish like glass in the right hands (see UKMikes epic Aquarama builds...), I'm really hoping the Epifanes will give me a similar finish.
(https://modelboatmayhemimages.co.uk/images/2025/09/23/1000022612.jpg)
At the moment I'm not too stressed about having to door open and an airflow, the fumes are not fun...  I have a filtered spray mask which helps, but not being in same space while it's curing is better.  At least the dog is getting more walks...
Meant to add, I'm using 'Axus Decor Varnish Brushes (Lime Series)' the 25mm version for the early coats.  They're about £2.50 each on Amazon, synthetic and have yet to drop anything, very smooth and lightweight.  I'm applying varnish to the boat in one go as there's no real separation line between hull and deck.
David.
Post by: DJW on September 30, 2025, 02:53:20 pm
Afternoon All
Short update.  Here are a couple of pics of the third coat of thinned epifanes:
(https://modelboatmayhemimages.co.uk/images/2025/09/24/1000022645.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/09/24/1000022644.jpg)
I applied fourth coat yesterday afternoon, still building up some depth with just a rub over with scotchbrite between coats, so far so good.
Also been working on replacing the two electronics boxes.  3D printed this time so I can build in component supports, connection ports, cable routing and using better (more robust) connectors.
Pics to follow.
David.
Post by: T888 on September 30, 2025, 04:11:43 pm
Lovely David  :-)) :-))
Post by: Mark T on September 30, 2025, 05:48:34 pm
I agree - I would have trouble putting that lovely boat in the water
Post by: DJW on October 01, 2025, 01:22:20 pm
Haha..!  Thanks for the comments.  And I can't wait to get it on the water..!  If I can get it running in time for Mayhem at Wicksteed next May I'll be very happy.  It won't be finished for sure, but might be ready to float...
Some pics of the new electronics cases, they sit port and starboard of the LiPos and are powered from a 4S LiPo, then voltage is dropped to 12v and 5v in port case and made available to modules in both cases:
(https://modelboatmayhemimages.co.uk/images/2025/10/01/1000022749.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/10/01/1000022745.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/10/01/1000022746.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/10/01/1000022747.jpg)
And a raised floor to allow the cable routing underneath the modules:
(https://modelboatmayhemimages.co.uk/images/2025/10/01/1000022748.jpg)
Both boxes, and a gratuitous picture of the shiny mahogany after fourth coat...!
(https://modelboatmayhemimages.co.uk/images/2025/10/01/1000022753.jpg)
I have a question too if anyone wants to comment, a sanity check if you like, and to avoid blue smoke.  I plan to use three LiPos, one for each motor and one for ancillary stuff.  I'd like the Rx powered from the 'ancillary' LiPo so it can share ground and signals with other electronics on same battery, so far so good.  Can I just remove the +ve from both ESC becs that plug into the Rx and have the ESCs and motors powered by their main power connectors to the two 'other' LiPos..?
David.
Post by: tsenecal on October 02, 2025, 04:00:13 am
Technically yes, on the three separate lipos, but instead of removing the red wire on the ESCs, take a 3" servo extension and remove the red wire from it, then plug the ESC into that, and the extension into the receiver (x2 for both ESC).  That way, if you ever need to plug an ESC into a programmer or similar to update or change its config, you don't have to repair anything.
Post by: KitS on October 02, 2025, 06:32:13 am
Now that's a BRILL idea.  :-))
How come I never came up with that one myself, after years of using radio control? >:-o
Post by: DJW on October 02, 2025, 09:35:36 am
Agreed, excellent and simple solution. Thanks for that..!
Post by: DJW on October 07, 2025, 02:50:05 pm
Fourth coat went on about 5 days ago, I've been a bit under the weather since so slower progress than I'd hoped.
I took the two boats outside to look at the colours in natural light:
(https://modelboatmayhemimages.co.uk/images/2025/10/07/1000022847.jpg)
And they're pretty similar which is good.  The 1/5th will go darker as the coats are added.
Incidentally this is a similar side by side shot from August 2024, so just over a year ago:
(https://modelboatmayhemimages.co.uk/images/2024/08/23/PSX_20240823_115418.jpg)
Sometimes the pace of progress seems glacial, but good to see a real change to the hull in a year.  In one month the 1/5th will have been in build for four years...
Some more pics from outside:
(https://modelboatmayhemimages.co.uk/images/2025/10/07/1000022848.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/10/07/1000022849.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/10/07/1000022850.jpg)
The Epifanes is covering nicely I think.  The coats are thinned, and thin, I'm mixing up 30ml of varnish with 10ml of thinners, and the resulting 40ml covers the whole boat with some to spare.
Getting close it's plain to see that while the varnish is showing quite good gloss already, it's also still showing grain and is nowhere near smooth.  Not that I'd expect that yet.
(https://modelboatmayhemimages.co.uk/images/2025/10/07/1000022852.jpg)
So as this coat has cured for 5 days I decided to try some smoothing with a cork block and some mirka 'soft' 320 grit (foam backed sandpaper) and its made the high pots more evident and taken them down a shade.
(https://modelboatmayhemimages.co.uk/images/2025/10/07/1000022853.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/10/07/1000022854.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/10/07/1000022855.jpg)
I'm hoping this should improve finish on the next coat, then I'll go back to the scotchbrite between coats for another few coats to build some depth to the varnish before sanding again.
Still making progress with the electronics cases, the 3D printer is so helpful by making mods to the layout and just printing a new version, rather than taking a drill and saw to the old one when I need a new hole...
(https://modelboatmayhemimages.co.uk/images/2025/10/07/1000022856.jpg)
David.
Post by: DJW on October 14, 2025, 03:19:27 pm
Afternoon All
More varnish applied, this is after 7th coat, less thinners used, about 10% now so it's noticeably thicker.  Inclusions and dubious levels still...
(https://modelboatmayhemimages.co.uk/images/2025/10/14/1000022980.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/10/14/1000022979.jpg)
So after that had cured for about 4 days I used 1000 grit sanding pads, together with water and a bit of liquid soap added. The 100 x 70mm pads came from Amazon as a selection and are velcro backed which is useful.  I made up a couple of shaped backing pads to make them easier to use, and to conform the pads to the hull flare near the bow.
(https://modelboatmayhemimages.co.uk/images/2025/10/14/Sanding-Blocks.jpg)
That went well so I used my Proxxon Angle Polisher WP/E with some of the 1000 grit pad cut to fit, and that was even better.  Have to be careful to keep it wet and moving, but very pleased with the surface it's producing. I recall getting to this stage with the 1/10th, once the varnish can be flattened like this, subsequent coats start to level well and all being well the finish starts to look the part.
(https://modelboatmayhemimages.co.uk/images/2025/10/14/1000022984.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/10/14/1000022985.jpg)
I need to spend a little more time doing same to rest of the hull then apply another few coats to build it up again.
Also been working on designing a couple of detailing parts, I quite like the idea of a working compass, flush mounted on the dash, printed in black, something like this:
(https://modelboatmayhemimages.co.uk/images/2025/10/14/Compass.jpg)
I have found a 25mm keyring compass that fits quite nicely.  It would be 125mm sphere at full size, so it's not too far off as the actual units are about 140mm diameter overall.
Also been looking at creating a searchlight... On the Aquarama it mounts to the windscreen, 3D printed first to get the design and dimensions, then create in brass and all being well add to the list to be chromed.
I've found some 3W COB LEDs, they run on 5V and are sooo bright.  They have a 20mm aluminium backplate to dissipate heat which would be helped by the brass case:
(https://modelboatmayhemimages.co.uk/images/2025/10/14/LED.jpg)
And a 27mm 'condenser' glass lens, which apparently 'renders a divergent light beam from a point light source into a parallel or converging beam' (according to Wikipedia), sounds ideal and should be fun to play with if I can get the optics right.
(https://modelboatmayhemimages.co.uk/images/2025/10/14/Lens.jpg)
And the case so far:
(https://modelboatmayhemimages.co.uk/images/2025/10/14/Searchlight.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/10/14/Searchlight2.jpg)
We shall see...  (Pun intended..)
David.
Post by: Dreadnought on October 14, 2025, 07:25:51 pm
Wow that looks amazing  :-)) :-)) :-))
Post by: DJW on October 21, 2025, 03:16:48 pm
Thanks..!  9th coat now, and starting to see a depth to the varnish that just wasn't there, also noticeably flatter after the sanding.
(https://modelboatmayhemimages.co.uk/images/2025/10/21/1000023102.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/10/21/1000023101.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/10/21/1000023103.jpg)
And that's been cut back with scotchbrite again and is now waiting for next coat, hopefully later today.
So now looks like this again:
(https://modelboatmayhemimages.co.uk/images/2025/10/21/1000023104.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/10/21/1000023105.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/10/21/1000023106.jpg)
For the next coat I'm going to try neat varnish without thinners to see if this improves the inclusions appearing.  As I understand it one reason can be solvents (thinners...) trying to escape as the varnish cures, leaving small pits in the finish.  It can be outgassing of the wood too, but I think we're beyond that and it's 100% sealed.  At the end of the day I know I can polish them out so I'm not too stressed at this stage, but I'd rather minimise them in the first place.  It's a bit of trial and error as another reason can be varnish going on too thick, skinning over before solvents have fully escaped...  Also going to switch to a higher quality brush that holds more varnish and avoid too much over brushing.  We'll see.
In other news I went up to the Model Engineer Exhibition in Warwick last week with my good friend John (John.B here on the forum).  John is building an Amati Riva Aquarama at the moment so obviously a man of impeccable taste, just saying...  We've been corresponding about aspects of that build, and now John is helping me by developing some electronics that will really help with the 1/5th build, right now this is a two channel and an eight channel RC switch for use with the various ancillary functions, lights, sounds and so on. Very exciting to get them tested and integrated.
And back to the Engineering Exhibition, lots of stands selling tools from screwdrivers to CNC lathes, bit like a sweet shop really, one of everything please.  And materials, I went with a brass shopping list and managed to get find most of what I need for the 'fittings' stage of the Aquarama build.  I finally found a supplier of half round brass to use as rubbing strip around the hull.  It's hard to find with a few suppliers saying that it's discontinued, I suspect they are all using same source.  Also picked up some tools, well I couldn't help it.  Some boats being displayed, and some very impressive trains and traction engines. Component Shop were there with what looked like the full array of stock, also saw Clevedon Steam with their beautifully engineered steam plants.
That's it for now.
David.
Post by: ChrisF on October 31, 2025, 08:29:10 pm
Hi David - I went along to the exhibition as well and likewise managed to restrain myself as well! Just bought a few more paint brushes - like clamps you can never have too many!
By the way, did you ever try that chrome pen out?
Chris
Post by: DJW on November 04, 2025, 03:27:39 pm
Hi Chris
Nice to hear from you..!  I did try the chrome pen, I used the 'Molotow Liquid Chrome Pump Marker Pen', £8.25 on Amazon with very good reviews.  It looks good when it goes on and covers pretty will, I've only tried it on 3D resin prints so far to be honest.  The issue I'm having is the deterioration over time...  This is freshly applied and just one coat:
(https://modelboatmayhemimages.co.uk/images/2025/11/04/1000023388.jpg)
It's very similar to the real chromed Musetto, so far so good.  And then next to one of the Amati supplied vents that I suspect are nickel plated:
(https://modelboatmayhemimages.co.uk/images/2025/11/04/1000023391.jpg)
So again the pen looks far more like real chrome.  However, over time, the pen loses its mirror effect, quite a lot:
(https://modelboatmayhemimages.co.uk/images/2025/11/04/1000023392.jpg)
And I think at the moment that's a deal breaker.  Which is a bit of a pity, but not wholly unexpected.  I'll still be saving up to get the full chroming done, there's too much chrome on the Riva and it really has to look the part I think.  But then the other complication is that I'll need to fabricate more brass parts rather than get away with 3D printed.
But just my experiences so far.  I've not tried coating the 'chrome' with say gloss clearcoat, that might seal the surface and so retain the shine.  I'll need to try that.  The approach would be so useful if it would work even for just small aesthetic parts.
As far as the main build goes, I've been busy with a couple of more varnish coats, had to pick up another 500ml of the Epifanes. Just building the varnish thickness up really before flattening it back.  I did have an issue with a couple of runs on the sides of the hull, so I had to wait for it to fully harden off before sanding and flattening back.  I'm now on plan B, that involves varnishing the deck and stern, waiting for that to cure, then rotating and putting a coat on one side of the hull, then wait, then the other side...  Bit laborious, but helps get the surfaces flatter.
Also been busy with more of the electronics.  It's all got a bit out of hand really so I'm trying to document how the subsystems are all going to be integrated and what the dependencies are so I can get what needs to be done clear in my head.  I'm using the little Arduinos quite a lot, so getting one to perform a certain task, that's fine, but then some systems are dependent on what other systems are doing...  I'm setting up the Arduinos that are dependents to listen on a given pin, then when they get a signal, they spring into action.  So in a very rudimentary way the different arduinos can network together. The dashboard is an example of this.  I need the dash dials (servos) to be live when the boat is powered up, but then when the boats main 'motors' are started (the sound system starts and the 'motors 'idle') the dials need to do their thing.  But then when the motors are turned off, the dials need to return their pointers to zero and power down gracefully rather than just stop in place as would happen if the power was just removed by a switch.
I'm extending the idea of a Y lead by sending say the port ESC channel from the Rx to a small board with a set of connected pins all carrying the PWM signal for that channel, then the port ESC connects to one of these pins, but so do the port tacho dial, the various fan controllers, the water pump, the port sound system and anything else that needs to know how fast the port motor is running, bit like a Y lead on steroids I suppose.  Same for stbd ESC, also the rudder channels. Common ground throughout the boat, so just the PWM signals shared, seems to be working so far.  Then each device gets it's own +ve supply at whatever voltage it needs (5 or 12V) rather than passing the current via the Rx.  Indeed the Rx just becomes another device to power at 5V.  And the headache begins.  I'm trying to get the boat systems to behave very much like a full sized boat, or as close as I can.
Ever onward...
David.
Post by: ChrisF on November 07, 2025, 04:35:53 pm
Thanks David. It will be a pity if the shine can't be protected.
What you are doing with that model is mind boggling, on many fronts!
Chris
Post by: DJW on November 11, 2025, 02:58:47 pm
Afternoon All
Thanks for the comments Chris.   :-))
A short update as the varnish is coming along:
(https://modelboatmayhemimages.co.uk/images/2025/11/11/1000023528.jpg)
I'm learning more about the Epifanes. Better late than never...  I was plagued by the 'inclusions', or whatever the term is for them.  I had a look under a loupe and they're small bubbles, some googling found that others are having similar issues, as in the varnish seems thicker than a few years ago, and benefits from some thinning on all coats not just the early ones.  So in these pics the varnish is thinned about 5% with epifanes brush thinner, and this does seem to allow the bubbles that do form to dissipate fully, in fact they just don't seem to form as readily at all, but the coating is still thick enough to build depth.
(https://modelboatmayhemimages.co.uk/images/2025/11/11/1000023527.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/11/11/1000023526.jpg)
So I'm happier that this approach seems to be working.
I've only been working on the deck and some removable parts for the last few coats as I don't want to add coats to the hull until I'm able to rotate it, so the hull sides can be brought horizontal ish and so help the varnish level rather than slump. I'm thinking a couple of frames that will bolt / anchor into the hull, this will allow the boat to be inverted for when the time comes to paint the planing surface.  And then to extend the bolted in frames with a couple of L shaped frames that can hold the boat securely on edge to allow varnishing.
We shall see.
David.
Post by: Davo on November 14, 2025, 08:44:20 am
Although logged in, none of the build pictures show up on this topic.  I am in the UK.  Anyway to see the pictures?
David
Post by: DJW on November 14, 2025, 11:34:13 am
Hi David
I've heard this comment before.  I'll see if Martin has any comments re what's happening...  The images are hosted on the MBMImages server, so they should be visible...
Can I ask whether you can see this link, its the Album that goes with this build:
https://modelboatmayhemimages.co.uk/album/JJD3 (https://modelboatmayhemimages.co.uk/album/JJD3)
I have heard in the past that MacAfee can cause issues...
Let me know how you get on.
Best regards
David.
Post by: KitS on November 14, 2025, 02:38:41 pm
I couldn't see the pics y'day, but I can today.
It may be notable that the same problem occurs on another forum that I inhabit and that too uses the Small Machines system.
Post by: Martin (Admin) on November 14, 2025, 03:32:07 pm
Hi David,
I can't see any photos either.... how many / which photos did you post today?
(https://i.postimg.cc/D4fQTzDd/2025-11-14-15-30-58.jpg) (https://postimg.cc/D4fQTzDd)
Post by: SailorGreg on November 14, 2025, 03:46:07 pm
That's weird - I can see them all.
Although none of them have the MBM watermark - has that been dispensed with?
Post by: DJW on November 14, 2025, 04:46:50 pm
Here we go with a test pic....
(https://modelboatmayhemimages.co.uk/images/2025/10/14/1000022981.jpg)
Post by: Capt Podge on November 14, 2025, 10:22:11 pm
That photo is crystal clear David - as are all of your photos (735 of them) throughout this topic - I'm on an ACER ASPIRE 5 laptop, if that helps anyone at all.
Cheers,
...forgot to add - I'm using Windows 11
Post by: DJW on November 18, 2025, 03:29:45 pm
Afternoon All
Thanks for helping troubleshoot the image visibility issues.  Still not sure what happened or why or if it's ongoing.  I see there are big Cloudflare issues again at the moment and know that MBM uses Cloudflare, not sure if the image issues are Cloudflare related.  If anyone cannot see images on this blog please let me know via PM, I can make alternative arrangements with image hosting going forward to see if that helps.
So, back to todays update.  I've been adding varnish again...  Somewhere between 12 and 15 coats of varying thickness.  Interesting to see progress of the layers, this was early coat where grain is still very visible:
And now, a bit more Riva like:
(https://modelboatmayhemimages.co.uk/images/2025/11/18/1000023667.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/11/18/1000023671.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/11/18/1000023670.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/11/18/1000023669.jpg)
Still using 5% thinned varnish, and going well.  I've also been getting prepared for next steps, I've been using the rear hatch to do some tests with the Proxxon WP/E polisher using various grit discs from 600 through 1000, 2000 and 3000.  Then rubbing compound (Farcela G10) to remove any 3000 marks, then finish with wax.  I need to let the varnish cure fully then will be busy with the polisher.
Also been busy with the electronics again.  In the move to the new cases I seem to have caused a new issue with the sound system, it was working fine, now it's not...  And while troubleshooting that I realised I could be setting up future problems by soldering in the Arduinos, it makes them hard to manage in future.  So I'm making them pluggable and just soldering in some sockets.  This will also allow the Arduinos top be taken out of the boat to be updated / reprogrammed, or replaced.  I need to get past this and fix the sounds so I can start integrating new systems...
Very best regards to all.
David.
Post by: DJW on November 25, 2025, 03:41:23 pm
This weeks update.  I've finished with varnish, well I think I have.  If I make a mess of the next stage I may need to retract that...
I've learnt that it's pretty much impossible to get a coat of varnish applied without having some defect or inclusions, dust, small bubbles.  The finish is good, but I know flattening / polishing will improve it.  So, 12 to 15 coats applied over past 8 weeks, and now I need it to fully cure.  I think that could be a week or two.  I heard a good tip, if you can smell the varnish, it's not cured.
I've started the polishing process on some woodwork that was finished a few weeks ago, and this is the result...
(https://modelboatmayhemimages.co.uk/images/2025/11/25/1000023865.jpg)
I'm very pleased with the result.  It's like glass.  If I can get this result on the hull I'll be very happy indeed.
(https://modelboatmayhemimages.co.uk/images/2025/11/25/1000023864.jpg)
It's quite hard to shoot a picture of a reflective surface..!  This is my process:
(https://modelboatmayhemimages.co.uk/images/2025/11/25/1000023860.jpg)
I'm using the Proxxon WP/E polisher with 50mm attachments. I'll be using 25mm attachments for some detail areas. I've a foam backed velcro faced pad on the polisher when using abrasive discs to try to keep even pressure while avoiding digging into the varnish...  I'm starting out with 800 grit and have some 600 discs in case they're needed.  I'm keeping the discs and work piece wet with a spray bottle of water / liquid soap mix, very important to not allow it to dry out and heat up.  Keeping the head flat and moving, then wiping dry to check progress. The water goes milky when varnish is being taken off, like this:
(https://modelboatmayhemimages.co.uk/images/2025/11/25/1000023861.jpg)
The same piece looks like this when dried after initial 800 grit polishing.
(https://modelboatmayhemimages.co.uk/images/2025/11/25/1000023866.jpg)
It's the glossy areas that are low points and so further 800 grit required to remove quite a lot of varnish to get evenly down to the right level.  Once they no longer show it's time to go for a finer grit to remove the 800 grit scratches, so 1000, then 2000 and 3000 aiming to remove scratches from previous grit each time.
(https://modelboatmayhemimages.co.uk/images/2025/11/25/1000023862.jpg)
Then it just looks smooth, no visible scratches, but matt.  Then I use a medium foam head on the polisher with the regular Farcela cutting compound, and then switch to softer foam with fine Farcela compound.  Then I'm using some 'Howard Restor-A-Shine Wood Polish and Cleaner for Glossy Finishes'
And I'm finishing with a Carnuba Wax applied by hand with a soft lint free cloth.
(https://modelboatmayhemimages.co.uk/images/2025/11/25/1000023863.jpg)
That's all for now, polisher has cooled down, time to polish something else..!
David.
Post by: T888 on November 25, 2025, 04:02:19 pm
Hi David,
I bet you can’t wait to this model on the water.
Post by: DJW on November 25, 2025, 05:11:24 pm
Hey David
You're right there.  Hope to have it at Wicksteed in May 26, not finished in terms of fittings and so on, but afloat and under power would be good...
All being well I'll have it on display as 'in build' on the Portsmouth MBC stand at the Midhurst Model Show, 27th January next year.
Best regards
David.
Post by: DJW on December 02, 2025, 02:51:52 pm
Afternoon All
Usual Tuesday update...  Not had as much time on the build as I'd hoped in past week.  I have now got the rear hatch fully sorted, it's been flattened and polished, been tweaked so it fits nicely, and has it's faux leather attached down the centre, I think Riva call it a 'slipway'.  I thought you launched a boat on a slipway, but maybe in Italy it's how you launch yourself into the water.
(https://modelboatmayhemimages.co.uk/images/2025/12/02/1000023995.jpg)
The boat itself is a bit of a mess at the moment, I've working through grades of abrasive discs to flatten off the varnish in areas where the varnish is fully cured, and desperately trying not to go down to bare wood anywhere. I thought this was an interesting pic, it's the stern after the initial 800 grit flattening, the dull areas are high spots, just shows how a surface that looked pretty flat to the eye is anything but flat.  So this was done several times til all the gloss areas had gone, then down through 1000, 2000 and 3000 grit.
(https://modelboatmayhemimages.co.uk/images/2025/12/02/1000023996.jpg)
This is current state of electronics boxes.
This the 8ch Rx with 8 additional PWM channels, and the Arduino sound systems with Amps plus vibration motor drivers.  Looks a bit of a mess, work in progress...  What can I say.  The Arduinos now all sit on pins so can be pulled when needed.
(https://modelboatmayhemimages.co.uk/images/2025/12/02/1000023994.jpg)
And port side.  This has the two power supplies for 12 and 5V, mounts for 4 x Arduinos Pro Minis, and is now sporting 12 PWM driven switches for various onboard functions. These are custom devices designed and built by my fellow Aquarama builder and good friend JohnB.
(https://modelboatmayhemimages.co.uk/images/2025/12/02/1000023993.jpg)
Hope to be able to post some shiny deck pics next time around.
David.
Post by: DJW on December 03, 2025, 03:55:20 pm
OK, as promised some shiny mahogany...
This is the Proxxon WP/E polisher with a 25mm medium sponge applying Farecla G3 Regular Grade cutting compound, so the first stage of polishing after the flattening with discs.  Its a bit hard to see but that's a paste and its further wetted to keep the head cool.
(https://modelboatmayhemimages.co.uk/images/2025/12/03/1000024037.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/12/03/1000024038.jpg)
And wiping it off with a damp cloth
(https://modelboatmayhemimages.co.uk/images/2025/12/03/1000024039.jpg)
(https://modelboatmayhemimages.co.uk/images/2025/12/03/1000024041.jpg)
This one shows the flattened and cut back deck, also the hull side too showing brush marks, that's next to be flattened.
(https://modelboatmayhemimages.co.uk/images/2025/12/03/1000024042.jpg)
And finally the stern showing a better reflection now..!
(https://modelboatmayhemimages.co.uk/images/2025/12/03/1000024044.jpg)
Pleased and a bit relieved to see the gloss coming back after the flattening process.
David.
Post by: ChrisF on December 04, 2025, 01:19:16 pm
I bet you are! That looks great.
Chris
