The Shipyard ( Dry Dock ): Builds & Questions => Yachts and Sail => Topic started by: Scorcher on June 14, 2012, 08:09:01 pm
I acquired a plank on frame hull of a pond yacht about 12 years ago which I am now going to try to reinstate. The name is Hilary Ann, built Worksop Notts. in 1947 and I believe it to be either an A Class or a 10 Rater. The dimensions are:- LOA 5' 5", Waterline 4' 4", Draught 10.5", Beam 12", Mast 5', M'sl area 766 sq", F'sl 374 sq".
I have three questions about this model:- Does anybody out there know anything about it? Which class is it likely to be? Can anyone advise me on a fairly hard primer and topcoat
for it which is not too expensive?
Regards to all,
Scorcher.
Hi Scorcher and welcome to Mayhem.
I have moved your post to the Yachts section where you will meet fellow enthusiasts who may help you.
We could do with a picture to identify the hull.
Paint for the hull
A lot depends really how you want to paint the hull as with everything n life there are various ways to do this
Option 1
Hand paint the whole hull with exterior paint first a primer then topcoat
Option 2
Halfords Aerosols,their primer filler is easy to use and you can get a good finish also,the top coats are designed for a car so will be durable in water
Option 3
B&Q sell a paint called Plasticoat I personally hate this with a vengeance as I don't rate it at all,dries far to slowly for my liking and and can catch the dust very easily,others will rave about it.
Option 4
Get is sprayed professionally at a bodyshop who will use 2 pack car paint,and you will get a finish to die for.
I don't know how competent you are with painting but if you have your own compressor and spray gun you could allways get a ltr of 2 pack primer and top coat,YES i do know that I should not advocate you using it for health reasons BUT there are primers and topcoats available that are isocianate free.
It is a shame you are not closer otherwise I would offer to spray it for you as i am a professional painter.
If you want any info then Pm me and I will help if I can advise is FREE
Thanks to Stavros for response to my paint questions. Re my identification query, an article from 'Model Maker' of the 50's suggests it might be a 6 metre.
Scorcher.
Sounds like a 6 metre to me as well, the 'A'class would have a longer mast about 6 to 7 feet can you put up a picture of the hull.
Thanks to all for replies. I hope I manage to post this picture as requested. I'm about as good with computers as I am at modelling!
(http://s9.postimage.org/i2cb4li4b/Yacht.jpg) (http://postimage.org/image/i2cb4li4b/)
