Technical, Techniques, Hints, and Tips => DC Motors (Brushed) and Speed Controllers => Topic started by: Klunk on March 05, 2017, 09:27:07 am
As above no other letters etc. I assume this does not have a bec. So is this a forward only esc. It has a switcher on top. Speed range pot and neutral pot. And what ampage. .... should I assume 15?
Hi ya Klunk
The Electronize speed controller type 43VR is the one with BEC - it should have an orange and red cable coming out of the size as well as the standard red, black power supply - blue and yellow to the motor and obviously the connection to the Receiver. The switcher on top had me baffled for a min :-) but you are referring to the relay - there also should be a speed range hole and a neutral setting hole for you to set the appropriate ranges.
The Type 43X is exactly the same, only, it doesn't have the BEC - so therefore there should be no orange and red wires coming from the side. Everything else is exactly the same; you are right I presume it is a 15 amp - however, just to be on the safeside - I am going to go through my 'old' electrical documents to check for you - I believe they did do a 10 amp one - but I cant remember.....
Hi John,
I have an electronize speed control unit which doesn't work. I understand they might take them back for repair. Not sure if they charge or not.
Would you know their contact details please.?
ER Ken look at the address on the instuction sheet
Cheers Dave,
Had to magnify the screen, but I deciphered it in the end. I'll give them a ring Monday and see how the land lies.
Cheers mate
Hi ya Ken
It depends upon how old the Electronize speed controller is - if its an old one - with the 'old' ZN409 chip in it - the chances are they may tell you to bin it - BUT DONT - I have a couple of replacement chips and transistors - so if they tell you to bin it - send me a personal message and we will work something out. If its the new type - they will possibly repair it for you for a small fee.
http://electronize.net/model_electronics_frames.htm
Thank you young John. :-))
I'll dig it out of the spares box and have a look. It seems a pity to own it but not being able to use it. There's no rush as I have another project on the go, as you know. %)
cheers
I've just nipped down to the shed and found it's an FR30HX.
The write up on your recommended owners site is rather good so I might pursue it's restoration.
The "switcher" is the relay that allows reverse when it operates. It is a good idea when setting up to make sure that it is in its "not operated" state when going forward. The coil does take relatively a lot of current, and can flatten a receiver battery quite quickly.
