Technical, Techniques, Hints, and Tips => Tutorials & "How To’s" ... => Topic started by: macz_chung on July 05, 2018, 04:19:03 am
Hi everyone,
Nice to meet to you all. I'm going to build a tug from model slipway which is AL KHUBAR. I would like to ask how to cut the freeing port accurate ?
What does the tools as i need ? :-)
Chung
Hi this may help you out :-))
http://www.modelboatmayhem.co.uk/forum/index.php/topic,28028.msg279853.html#msg279853
john
Hi John,
Thanks your reply. That's great idea for mark the line on bulwarks. The next step should be drill the small hole and use flat file knife to make it smooth ?
I did something similar for scuppers, which are smaller. Basically cut the hole too small, and then used a piece of sandpaper glued to a flat stick for the edges, and a round file for corners. Just slowly edging out from the hole. Finally a quick clean with very fine sandpaper. NB I don't use the red oxide colored stuff, it stains.
Hi tiger,
You provide a great method to me for my project.
chung
I have also folded small pieces of sandpaper over a cocktail stick/bamboo toothpick for fine corners.
