Mess Deck: General Section => Model Boating => Topic started by: Tug-Kenny RIP on March 16, 2008, 11:35:03 am
Can anyone recommend a Paddle steamer Kit please.
I fancy having a go on one. I don't mind an empty Hull and I'll scratch build her. I thought something about five foot long.
Cheers...Ken
Metcalf Mouldings do a hull of PS Albion. This was also adapted as the basis of the Glen Rosa series of articles published in Model Boats recently. 51 inches long.
http://business.virgin.net/metcalf.mouldings/catalogue.htm
Hello all, remember there is a wealth of information and advice available onf the dedicated Paddler forum www.paddleducks.co.uk where you are more than welcome to drop-in by.
cheers
Jim
Jim, you beat me to it. Pete M (Oldie)
Hi Ken, with a name like tug kenny this could be the one for you.
Graupner's Glasgow Paddle Tug Kit. O0
http://www.alwayshobbies.com/Store/Model-Boats/Radio-Control-Boats/Graupner's-Glasgow-Paddle-Tug-Kit
Hi there Tug Boat Ken
Have you thought about the paddletug 'Forceful'? You can purchase the plans from Model Boats referenced as MM1292 - for the sum of 14 pounds 95 pence. Plus you can purchase a Vac-formed styrene hull. Not sure of the styrene hull; but, the Model is at 1:48 scale - about 39 1/2 inches long byt about 8 1/2 across the boxes. She was one of the last two (I think) of paddletugs built in the 50s for the Royal Navy, but she is not all grey. She does make a lovely model, you can have working fire monitors, independent controlled paddles (meaning she will just spin on a 2 1/2 pence because there are no sixpences now :) .
Also, I believe Kingston Mouldings do a hull for this, not sure of the prices charged, but I would imagine you may get the hull and plan for the price.
aye
john e
bluebird
Ken I think this is the tug that Bluebird is refering to although I know it as a Director class
BobB
hi ya there Bob - yep that is the one - lovely model :)
Also, I forgot to mention Ken, you can scratchbuild the hull - I have the plans for her. It is a similar build to the Cervia - only difference is where the paddles are located on the sides, you plank in with solid ply, which makes it an easier hull construction.
aye
john
She IS a Director class.
They were built specifically for getting under the flare on carriers.
And to aid maneuverability had dispensations to allow each paddle to be controlled independently.
Diesel Electric drive.
How do I know, I was on the last one. She was shunted over a cat by RMAS Confident so couldn't bring in HMS Invincible for her first entry. This was to be her swansong.
If you build her PLEASE use Humbrol No7 it is exactly the right colour.
I tried the vac-formed hull but gave up on it because of the lack of rigidity. Kingston do a 'Director' hull plus plans for £55.75 and I can vouch for its quality having built on it myself. Just don't be fooled by the paddle boxes that make her look beamy - in fact she is quite narrow with a fair bit of top-hamper. Watch your stability and build weight.
The Model Boats articles on the Class are worth having not least for the info that the photos provide. If you don't already have them, I can let you have copies. Also, she really does have to have feathering paddles to work and look right. I have the Model Maker Plans for these and the gear boxes. Send me a PM if interested.
Both JoTIKa and Waverley Models should be able to supply feathering paddle sets if you don't fancy trying to make them yoursef. Not cheap but do look good.
Pictures below are of the Waverley offering. The template is on computer and can be scaled.
Hi there, I found that the gearboxes were noisy and spoilt the look and sound of my model - so I converted mine to an independent 'tooth belt drive' which made her quieter. I cannot vouch for the 'feathering' paddle blades, I had fixed paddles on mine - and she operated quite well - no complaints.
The only thing I would mention is - sometimes I used to find one side of the model used to dig in and lift one paddle out of the water at the opposite side.
This is a modification, Ive just been informed that both my paddles have never been in the watter {-) {-) {-)
I have yet to finish mine I have the drive train from a Heng-Long panther to put in her she is fitted with Graupner feathering paddle set should get her finished soon but I have a sub to complete first
Is that the same as a few chips short of a butty ? :-\
before we get moderated Dicky, Ive stopped the lift before it goes all the way to the top, cos some body has pinched the chips out me butty - cos the light was on and no body was in....... 8)
anyway, on a more serious note Kenny - I have been looking through the Model Boats' plans book and there is another one which has caught my eye, which I know you could make and easily accomplish from scratch - its a plan numbered MM1273 The Talisman - designed by a guy named A.Thompson - model is 56 inches long; x 7 inches beam and it says it has details for a simple or a feathering type paddle wheel construction. Its star rating is three. That is if you fancy building from a plan - but there may be a hull readily available which you could adapt to this plan; cos to me its a nice looking paddle steamer.
aye
john e
bluebird
Kenny I might Just have what you are looking for a recently completed Waverley Paddle steamer that one of our members just finished before he passed away and his good lady is looking for a Good home for her will pm you this week on a price etc
I have to admit that I didn't fit the gearbox either. Toothed pulleys and geared motors were a much easier bet. I did make the feathering paddles (87 components in each one) and they work fine. If paddles of the right size and scale were available off the shelf at the time, I might have fitted those.
I can't vouch for it but someone who claimed to have seen a Director with fixed paddles competing with a feathering paddle job, said that the latter had a significantly better performance.
The original Directors had feathering paddles.
Eh? - That's why I fitted them!
Just an afterthought to the question of drive systems for paddlers. Before I switched to toothed wheels and rubber belts, I used brass gears and metal chain drives. This system was ditched after I discovered that the metal on metal contact was generating severe radio interference.
Barry M
WOW. Thank you, everyone for your input. I'm overwhelmed.
Yes, I fancy building the 'Waverley'. Special thanks to Stavros for the offer, but I want to build it myself, sorry, but excellent offer. I shall be getting in touch with Mike of Waverley Models and find out some more details.
I was reading my latest Model boat book, Bluebird, and it was the write up on 'Albion' that got my interest. I went back through the editions and came across 'Glen Rosa. It reminded me of my childhood ride on 'Glen Gower' in the Bristol Channel, all those years ago (the 50's).
Thanks for your site info, Red-Hamish. Now I've got something to read for the next week. O0. A truly 'mine of information' there to go through. (must get on with latest boat sometime!!)
Once again, thanks all, and hope to see yours at Wickstead, Youngat 65.
Cheers...Ken
hi ken i am doing up the laura doone for a friend she a big boat. something diffrent.
john
Hi Cos,
I'll soon be starting a model of hms Atherstone which I think was later modified to Lorna doone.
Is there any chance of some more pics or your model, info on the Atherstone id mighty thin on the ground. I'm especialy interested in the paddles which on my drawings seem very small for the size of ship.
Thanks,
Chas
Hi Cos,
Thanks,
Chas
hi chas well she scratch built and is about 50" long. She is at my mums so il go up there this week and take loads of photos for you.
john
That sure is a nice looking Paddler, Cos918. Very tidy. O0
I'm no expert on these craft but I do admire their looks and grace. My Kit hasn't arrived yet but I expect to start mine soon.
Ken
Would you believe this is mine Ken ?
O0
Lovely eh !! You can see why I want one
Have two Ken, I've got lots.... ;D
Thanks a lot cos, I look forward to seeing them.
Chas
Would you believe this is mine ?
No - but if you are quick and bid on Ebay you could have it for £250 {-)
280219029188 - and its a beauty O0
Don B.
I would love it, but shed and wifes salary not big enough. :'(
Heres a link:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280219029188&ru=http%3A%2F%2Fsearch.ebay.co.uk%3A80%2Fsearch%2Fsearch.dll%3Ffrom%3DR40%26_trksid%3Dm37%26satitle%3D280219029188%26fvi%3D1
Is this anything to do with you or Stavros Don ?
Here's a few good photos of the real thing. http://www.river-clyde.org.uk/waverley.html
Thanks for that, Taxi. O0
Ken
Heres a link:
Well yes - in a way. Stavros is selling it on behalf of the widow of one our friends who died suddenly last year. He was a very good builder and its a lovely boat but sadly he was only able to sail it a couple of times before he passed on.
She still comes to the lake every Sunday but she can't bear the thought of seeing it on the lake without her husband so she wants it to go away from here to a good appreciative home (and quite frankly she could do with the money).
Come on you Paddle Boat enthusiats - get bidding :(
Don B.
Wish I could afford it Don, but its definitely worth more than £250.00. What a sad tale.
well here some of thoes photos if you want more PM me and il send you the lot as can only do 250k per post and 10meg on email.
john
a few more
few more
Thanks a lot cos, pictures are a huge help when I'm starting a build. Give me a year and I'll post some ot the Atherstone and we can compare to see the changes.
Chas
Well she has gone now to Ross on Wye for £250 what a bargain
She stole it off you Stavros. Much to cheap.
