Hi
I am new to both model boats and to the forum.Hoping someone out there can HELP.
I have a 30amp electronise E.S.C ( not B.E.C) FR30HX---I have wired this in as per the Electronise instructions.
The rest of my equipment is---(i)-R/X Futaba R136F
(2)MFA Torpedo 850 motor
(3)12 Volt gell cell battery
(4)4.8 volt R/X pack
Every time I connect the 12 volt battery the in line 30 amp fuse blows-this happens when I have the T/X and the R/X switched on ( in the right order)
The motor runs ok when connected direct to the battery.
The rudder is working perfectly.
I am fast running out of 30 amp fuses and am in danger of blowing my own built in one as well
Please help before I go up in smoke
Thats what I like! Lots of detail to save the drama and hilarity that was here.
http://www.modelboatmayhem.co.uk/forum/index.php?PHPSESSID=3954eb6cdb272c7e Do any testing with the lowest supply voltage possible.And run through continuity checks beforehand.
Use a suitable value resistor ,say 100 ohm @ 10watt or a 12 volt @ 10 watt headlamp bulb in place of the +ve line fuse as a short will cause voltage to drop across the resistor and not the escOther tests if it passes that one...............
Bulb in the fuse line going on ,with no throttle, is a sure sign its damaged.
You can quite safely repeat that
1 Torpedo 850 on 12v will not stall at 40 amp.It's more than double that.An 850 can blow a 30 amp fuse after a few minutes if prop is big and there is no fault.
2 If you want a resettable fuse it's here
http://uk.farnell.com/jsp/search/productdetail.jsp?SKU=1345958You can put two in parallel to boost rating. Good for scores of operations.
3 Keep the fuse or bulb or resistor in the power line until you've found the problem.
4 You can put another lower power bulb in place of the motor with a high power bulb(lower resistance and volt drop)and power up and test
5 You can diagnose damaged equipment with a meter and a bit of knowhow. Fiirst remove from esc boat and do a continuity test on the red black with a digital multimeter.(These cost £5 and you get them at shows and from Maplin)
A short circuit (0 ohm measurement)means faulty and common where esc's have a 2-pole relay.
Two pole relays show shorting because you can see the opposite poles touching if the relay case is clear
6 On the diode range you can pick up blown transistors.If it is an H-bridge FET type there are four diodes to test.
You do a diode test between red-blue red-yellow blue-black yellow-black.
In each case it should be high impedance one way and ~ 0.6 volt the other.
7 With the motor unconnected does the fuse blow? If so you have a fault.
8 Do any powered up testing with a 12 volt headlamp bulb at the lowest supply voltage possible.The lowest possible fuse or circuit breaker.
9 An external 1 amp BEC is an ideal test accessory as it gives out 5 volt and shows short circuit faults by "shutdown"without causing damage to drive stages.
That's all for now
Barry Park
