Author Topic: Scooter  (Read 9380 times)
woodybob
Scooter
« on: August 25, 2008, 11:38:47 pm »
I started this Springer last year.  It was inspired by a Google search that came up with SLING SHOT.   It’s a wood hull, fiber glassed, then painted.  Some of the deck fittings I got from Wet Goose Marine.(http://www.wetgoose.com/)   Other’s were scratch built be me.  An Astro Flight Ferrite 15 Marine geared motor, (water cooled) Vantec RET 512 ESC, & twelve 4500 Ni-MH batteries power it.  Prop is a Raboesch 176-03.  I get hours of run time with this set up. The rubber bumpers are Rubber Baby Tugboat Bumpers. (http://mysite.verizon.net/res1tf1s/id12.html)  Like all Springer’s, under full power, the decks are awash.  However, it takes on very little water; I think it comes from the prop tube while in reverse.  Here is a Kmot video of Scooter: http://wavelit.com/media/926/A_Springer_Named_Scooter/
Weeds
Re: Scooter
« Reply #1 on: August 25, 2008, 11:46:02 pm »
what materials and painting technique do you use?
ralphhager
  • Ralph1937
Re: Scooter
« Reply #2 on: August 25, 2008, 11:51:30 pm »
Woodybod nice Springer. O0
  Could you show us how you made the rudder....ralph1937 :)
woodybob
Re: Scooter
« Reply #3 on: August 25, 2008, 11:55:59 pm »
The hull is 1/2" ply I had lying about, bottom is 3mm ply, doubled up, the cockpit was formed with 1/64" ply, laminated making it 1/32".  I used Testors Marine paint for the bottom, (anti fouling red) Tamiya flat red for the cockpit. (airbrushed) Flat black & various shades of gray for the deck, which were hardware store enamel aerosols in a can.
woodybob
Re: Scooter
« Reply #4 on: August 26, 2008, 12:02:40 am »
It's made of plywood laminated together.  I used brass rod and drilled holes for the cross members then soldered them to keep the rod from rotating in the wood.  It works great.
Weeds
Re: Scooter
« Reply #5 on: August 26, 2008, 12:22:13 am »
thanks. very detailed info... O0
woodybob
Re: Scooter
« Reply #6 on: August 26, 2008, 05:01:05 am »
This is what the cockpit looks like below the deck.  Hench, SLA's were out of the question.  To high.  A slight oversight, but since I get hours of run time on the Ni-MH, it's all cool.
Arrow5
Re: Scooter
« Reply #7 on: August 26, 2008, 08:31:01 am »
She looks low in the water Woody,what does she weigh ?  The prop-guard must have a bit of Kort effect?
..well can you land on this?
woodybob
Re: Scooter
« Reply #8 on: August 26, 2008, 02:24:07 pm »
She sits right on the waterline arrow, as soon as I hit the throttle she hunkers down, you know, Springer dip.  Scooter weighs it at 8.6 pounds.  (.0038 Metric Tons)
Re: Scooter
« Reply #9 on: August 26, 2008, 03:33:39 pm »
Nice, Very nice!  O0
Arrow5
Re: Scooter
« Reply #10 on: August 26, 2008, 04:06:20 pm »
Thanks Woody. No problem keeping the deck clean then O0
Colin H
Re: Scooter
« Reply #11 on: August 26, 2008, 05:09:18 pm »
Very nice Woody would you mind if I copied your idea.
Colin H.
do every thing today tomorrow may not arrive.
woodybob
Re: Scooter
« Reply #12 on: August 26, 2008, 05:49:51 pm »
Thanks boys.
Copy away Colin.  O0
Colin H
Re: Scooter
« Reply #13 on: August 26, 2008, 10:11:13 pm »
Thanks Woody,
If you have read the thread o my build you will know I am new to scratch building and I thought that nicely curved cockpit might stretch me a little.
Colin H.
Re: Scooter
« Reply #14 on: August 26, 2008, 10:32:44 pm »
Nice springer
Re: Scooter
« Reply #15 on: August 26, 2008, 11:38:54 pm »
Very nice, you have done a nice job, and given me an idea for my next one  O0
woodybob
Re: Scooter
« Reply #16 on: September 17, 2008, 04:58:56 pm »
The cockpit was very challenging.  I hot glued stilts inside the hull to stage the floor in position, then built up from there.  First time for me.
Thanks Woody,
Colin H.
woodybob
Re: Scooter
« Reply #17 on: September 17, 2008, 05:06:24 pm »
Scooter gets tagged.
Mr Andy
Re: Scooter
« Reply #18 on: October 18, 2008, 08:07:55 pm »
Very very nice, a bit of imagination goes a long way.
Andy. :-))
woodybob
Re: Scooter
« Reply #19 on: June 02, 2009, 07:13:59 pm »
 Just got done adding a water cooled heatsink to Scooter's Vantec 713P ESC, also swapped out the Astro Flight metal gear box with an Astro Flight belt reduction set up.  Scooter runs much quieter now, and hopefully cooler.  With no ventilation below the deck it gets pretty warm in there.  O0
Page created in 0.11 seconds with 21 queries.
