hi , hey weeds, i got the hack plan from on here somewhere
,all i did was to
pull the top of the servo off
lift off the final drive gear ,and snip off the little lug that stops it against the the other pot,and grind it flush
run a same size drill bit up the inside of the gear just enough to remove the drive dog casting but not go too far to loose the horn attach thread.
now what I'm going to do is plug it all back in,
now when toy move the stick ,you have it .
next though you need to centre the pot so it will stop when the stick is in neutral, by just turning the knob until it stops, its very touchy.
I'm thinking a drop of super glue to stop any chance of it turning whilst in use,
then reassemble the final gear back on and your away.
thanks catengineman,does the slipping happen by the end nut tension.may give that mod to my drum a try.
with the anchor sensing when its home, i have a idea i might try, but originally i was just going to watch it till it was there , which is why i wanted it to go slow, and especially not creep any further.i might try putting the switch in line to isolate it when its home as its only a servo on 5 ish volts
