Welcome,
Guest
. Please
login
or
register
September 03, 2010, 09:47:51 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Search:
Advanced search
Mayhem at Wicksteed!
The Photos!
243,864
Posts in
15,621
Topics by
4,690
Members
Latest Member:
ROBIN SMITH
Model Boat Mayhem - Forum
Dry Dock: Builds, Rebuilds, Upgrades, Modifications - - - Mayhem Master Classes.
Submarines
HMS Tireless 1/64 Build
« previous
next »
Pages:
1
2
Author
Topic: HMS Tireless 1/64 Build (Read 5785 times)
Mankster
Full Mayhemer
Offline
Wheelerdealer
on:
December 06, 2008, 01:20:16 PM »
I will be posting updates on my current project, HMS Tireless in 1/64, in her 2004 guise. She is based on an old Eden/ Sheerline Trafalgar hull (the current Sheerline Trafalgar has a few updates). I purchased this second hand (this hull has been halfway around the world, to the States, France and now now back home) and some work had already been done, notably to the sail and side flank sonar arrays, which I have continued. The original propulsor shroud was replaced with a more scale like version which will require a little more profiling before its right.
I acquired this hull early in the year and started renovating and accurizing her but neglected to take suitable pictures. I have just started on her again and will be documenting a little more thoroughly this time. The full series of pictures will be on my website, with only the poignant ones here for clarity. I only purchased the hull, so I will be building a watertight module for her on the same vein as the one on my Akula ( which has pr oven very reliable to date) but with a few refinements.
Here are are the some parts of the hull. Bits weren't fitting to my satisfaction, so I have stripped everything back to start again. I have done some work on the planes and ballast tank vents.
There are some extra holes and tubes fitted to the lower hull (the original builder was going to fit a different type of ballast system) which will need to be removed and filled and the tile pattern re-scribed.
There is a gap between the the shroud and propulsor which will need to be filled and profile which is the next task.
Mankster
www.rcmodelsubmarines.co.uk
Subculture
Full Mayhemer
Offline
Re: HMS Tireless 1/64 Build
Reply #1 on:
December 06, 2008, 02:07:09 PM »
Ramesh, What's the inside diameter of the shroud, and the diameter of the propulsor?
I ask because I'm wondering if the Vanguard propulsor might fill out the gap for you. I'm sure Simon would cast you up a separate prop for a reasonable price if you're lucky with the dimensions.
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #2 on:
December 06, 2008, 02:25:47 PM »
Thanks Andy, I have actually made a start filling out the gap with putty and sanding back, and its actally turning out better than I hoped. Its too late to get a measurement of the inside of the shroud now without chiping off the filler. Obviously if it all goes belly up I'll give that a go.
Last Edit: December 06, 2008, 02:28:01 PM by Mankster
Mankster
Sub driver
Full Mayhemer
Offline
Reply #3 on:
December 06, 2008, 05:00:27 PM »
Hi Mankster,
I will watch with interest as always
regards Sub.
colin-stevens
Full Mayhemer
Offline
Reply #4 on:
December 06, 2008, 06:17:01 PM »
Ramesh, stick a link in to youre site please, googling a big fat zero
colin
grumpy old XXX
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #5 on:
December 06, 2008, 06:30:37 PM »
Quote from: colin-stevens on December 06, 2008, 06:17:01 PM
colin
Click on the little globe under my avatar, the link under my signature or from my profile page, take your pick.....
Ok here you go....
(graphic intensive flash based site, those on dial up beware)
Last Edit: December 06, 2008, 06:45:28 PM by Mankster
Mankster
das boot
Guest
Reply #6 on:
December 06, 2008, 06:59:29 PM »
Good luck with it Ramesh, I know it will be perfect...
Turbulent
Full Mayhemer
Offline
Reply #7 on:
December 06, 2008, 08:15:55 PM »
This should put other T's in the shade - glad I'm selling mine!
http://www.norwichmodelboatclub.com/
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #8 on:
December 07, 2008, 07:26:46 PM »
Thanks guys, my aim is to make it as true to scale in appearance and performance as possible.
I filled the gap between the propulsor and shroud with epoxy putty and sanded it smooth and it came out rather well. Given that there is no puplic information on how the real one looks exactly, I can live this
The new profile of the exterior of the reworked shroud is better seen in the second picture.
Mankster
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #9 on:
December 08, 2008, 12:05:21 PM »
The top an bottom hull don’t quite meet at the stern. It will clamp together but I didn’t want to put any tension into to the hull. Small gaps can normally be filled but then the stern wouldn’t taper smoothly to the propulsion cone.
I made a vertical cut with a razor saw, but not all the way so as to separate the top hull into 2.
I then jimmied a 50p coin into the top which opened up a gap enough to push the stern of the top hull down to meet the bottom perfectly.
I used epoxy putty to fill the gap
Mankster
Subculture
Full Mayhemer
Offline
Reply #10 on:
December 08, 2008, 04:33:36 PM »
The propulsor has come out better than I thought it would.
What motor are you going to be using for drive?
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #11 on:
December 08, 2008, 08:01:11 PM »
I haven't figured what motor to use yet. Its probably going outside the dive module so I am flexible. I was thinking along the lines of a Graupner 720 Torque motor (4100rpm no load) on direct drive. I think Sheerline supply a 550 type motor with a 5:1 gearbox. I am not sure if this is a commercial unit or an inhouse item. I wonder if a gearbox will add bulk and noise.
Mankster
Subculture
Full Mayhemer
Offline
Reply #12 on:
December 08, 2008, 09:16:14 PM »
I think a 720BB will work very well . The Trafalgar's I've seen use a planetary gearbox for reduction, which are very compact. But you have a lot of room inside the hull for a larger motor.
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #13 on:
December 12, 2008, 10:18:03 AM »
The hull is moulded thickly with polyester resin and is self supporting, hence the top hull is designed to sit entirely on the bottom and be removed in 1 piece. This makes hooking up the top rudder a little harder. To help with alignment and simply the rudder arrangement, I have gone the more common way & cut the back of the top hull and will bond it to the bottom.
Mankster
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #14 on:
December 14, 2008, 09:52:42 AM »
Some hull detail.
I have taken a break from the hull and moved on to the dive module. Once again I am making the innards out of PVC.
Here are the 10 discs that will go to making the entire module. The outer 2
4 discs will be the endcaps, and the slightly small diameter central 6 will form the module (not shown is the central servo/equipment tray)
Mankster
colin-stevens
Full Mayhemer
Offline
Reply #15 on:
December 14, 2008, 11:24:30 AM »
comin along a treat.
hope you figure out a wat too make the hull stay joined. dont fancy rescuing a top half again.
colin
grumpy old XXX
Subculture
Full Mayhemer
Offline
Reply #16 on:
December 14, 2008, 01:44:17 PM »
I would use that little 'widget' that is sited forward of the conning tower as a fastner. Either attach a machine screw to it's underside, or (better) make a baynet lock pin (think of a light bulb) that attaches underneath. Invisible, and bomb proof.
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #17 on:
December 14, 2008, 02:32:24 PM »
With the Akula, I had to pack quite a bit of foam into to the upper hull to stop her rolling. So it was pretty buoyant and kept wanting to rip itself off when submerged, a more positive locking mechanism would have been the way to go with that boat. The Typhoon had the same system but at the top hull wasnt positively buoyant, and there was no such problem. I'll wait and see how this one turns out
Mankster
colin-stevens
Full Mayhemer
Offline
Reply #18 on:
December 14, 2008, 04:22:25 PM »
on the other hand its so much more fun to watch SOMEONESELSES boat sail in 2 seperate directions
grumpy old XXX
Subculture
Full Mayhemer
Offline
Reply #19 on:
December 14, 2008, 06:01:20 PM »
I'll be passing by the model shop this week. They used to have some Protech 720BB's in stock £16-17 IIRC. Would you like me to pick one up if they still have any?
Turbulent
Full Mayhemer
Offline
Reply #20 on:
December 14, 2008, 07:00:09 PM »
looking well mate, just started on the WTC for my Vanguard this afternoon,I'm makng the end caps in Resin (As I did for my Gato), turned down & fitted with O rings,I used Perspex on the Alpha but it was a struggle on my small lathe.
I'll set up a build post when I get going a bit more.
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #21 on:
December 14, 2008, 07:40:06 PM »
Quote from: Subculture on December 14, 2008, 06:01:20 PM
I'll be fitting the motor/ gearbox from the Sheerline Trafalgar, it seems to work very well on 12v with the propulsor and is pretty compact. I plan to use the WTC is my Alfa hull and that has a pretty heavy prop, so a 720BB would come in handy. So yes please- get me one if they still have some. I should be able to make the morning session of Brockwell Lido Sub run on the 11th of next month, so I'll pick it up there.
Quote from: Turbulent on December 14, 2008, 07:00:09 PM
Ahh good..., Tireless will have a SSBN to accompany, if not at one of the Brockwell runs, at Norwich in the summer.
Mankster
Turbulent
Full Mayhemer
Offline
Reply #22 on:
December 14, 2008, 07:45:32 PM »
Hoping to be on the water by the Feb run, PC & I are going to pay you a visit.
Itching to get started on the V, my lad's away on the real thing at the moment - under the water till March!
Subculture
Full Mayhemer
Offline
Reply #23 on:
December 14, 2008, 09:36:44 PM »
The other alternative would be to look at a brushless motor. Robbe do a nice unit which they're using on the 212 kit.
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #24 on:
December 17, 2008, 09:32:21 AM »
I have finished cutting out and drilling all the pvc pieces that will go to make the innards of the WTC. Just have to cut the rods and tubes that will hold everything together. Total length will be 85cm/33.5" with a diameter of 110cm/ 4.5". The motor will be house in a smaller separate dedicated WTC which will be specific for the boat while the main module can be moved. Batteries will be 2x 12v NiHM packs housed under the WTC, in the wet area of the sub.
Mankster
Subculture
Full Mayhemer
Offline
Reply #25 on:
December 17, 2008, 03:09:47 PM »
More PVC than a bondage convention!
No 720bb's available at 308. Apparently they sold out a while ago, and Protech aren't supplying them anymore.
Might be worth doing a search on here, as I seem to recall someone was knocking out Graupner 720's fairly cheaply.
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #26 on:
December 22, 2008, 11:26:23 PM »
I received the motor I am going to power Tireless from Sheerline Model Submarines. Its the same drive unit they currently supply in their 1/64 Trafalgar kits. Shown next to a 550 motor for size comaprison. The motor itself is a 385 sized unit, which is mated to a smooth turning 5:1 compact planetary gearbox. All Sheerline Trafs I have seen have had more than enough motive power on 12v using this motor-gearbox driving the same multiblade prop as mine, so this should do fine.
Mankster
colin-stevens
Full Mayhemer
Offline
Reply #27 on:
December 23, 2008, 07:57:56 AM »
you dont hang around do you? rready for the first brockwell in 2009 then!!!???
grumpy old XXX
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #28 on:
December 23, 2008, 09:38:02 AM »
Quote from: colin-stevens on December 23, 2008, 07:57:56 AM
Whilst I aim to make it for the morning session of the Jan 11 Pool run, Tireless will never be ready for that. I'll do my best to get her to a sailable condition for the last Brockwell Lido run of the season. Not much time to spend on her over the holidays, still fine tuning the bits that to make the WTC, working out where the electronics will all go. I am planning on fitting 2 ESC's so I can use it with twin motor subs as well but I havent got them yet.
Mankster
Subculture
Full Mayhemer
Offline
Reply #29 on:
December 23, 2008, 04:42:59 PM »
Have you purchased your ESC's yet?
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #30 on:
December 23, 2008, 05:45:42 PM »
Nope!
Mankster
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #31 on:
December 30, 2008, 11:23:57 PM »
The main WTC is nearly done, just electronics to install and wireup, and shorten the tie rods. I couldn't resist puting it all together to see how it looks. Its a rather different construction to Turbulents Vanguard, under construction at the moment, as I will be using piston tanks in this one.
Mankster
Turbulent
Full Mayhemer
Offline
Reply #32 on:
December 31, 2008, 11:30:42 AM »
You like your Piston tanks - only had my P Boat fitted with the Ron perrot type & had nothing but trouble with them. I have to admit that when working the system is very stable.
Engineering Pistons is still a little out of my league as well!
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #33 on:
December 31, 2008, 12:57:15 PM »
I will be using Engel piston tanks in this one but piston tanks are relativily easy to make. If you can turn an end cap you can make a piston. I looked into it for this build before taking the easy wayout, but I will be making my own small piston trim tanks for my next build. The hardest part is finding a source of cheap spur gears and matching pinion (unless you know how to cut your own) and press fitting the ballrace bearing which carries the piston rod on the spur gear. easiest solution seem to be Orings on the actual piston, though Airzet seats are neater but hard to get holf of, in the UK at least
Mankster
Subculture
Full Mayhemer
Offline
Reply #34 on:
December 31, 2008, 02:00:11 PM »
You don't need to worry about press fits these days, we have Loctite.
Turbulent
Full Mayhemer
Offline
Reply #35 on:
December 31, 2008, 04:15:06 PM »
I'm going to have a go at building a Piston one of these days, I've an idea how I want to do it.
I think MFA do Brass gears.
colin-stevens
Full Mayhemer
Offline
Reply #36 on:
December 31, 2008, 04:34:24 PM »
somewhere on this site is a link to a manufacturer of gears. cant remember where, may be in the lifeboat section. when i get more time i'll oink it out and post it here.
off to destoy the last of my brain cells now, so have a good'un, and all the best
colin
grumpy old XXX
Subculture
Full Mayhemer
Offline
Reply #37 on:
December 31, 2008, 07:45:01 PM »
HPC do gears, but aren't cheap.
Muffett are cheaper, as they also sell moulded gears (HPC are machine cut). Metals gears aren't essential, and from a wear point of view, plastic is better, but they will need to be thicker to avoid stripping.
Very cheap options include stripping junked printers (especially laser printers), old electric drills. Also worth looking at spare parts for R/C cars, as the gears for these can often be quite reasonabley priced.
Meccano have brass gears available. There not especially cheap, but they're strong and well made from brass and/or plastic.
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #38 on:
February 04, 2009, 10:02:45 PM »
I had most of last month off building, but I am back at it now. Here I have nearly completed the separate motor housing. I am installing the motor in its own small WTC which can be dedicated to the particular sub with just the main WTC containing the ballast tank moved between hulls. I figured the slow turning geared motor for this multibladed prop may not be suitable for other sub where I usually direct drive the props. Though to be honest, I can only seem my self using the main WTC in 1 other hull, my other hulls will probably have a dedicated dive system.
Here are the bits that go together the ALU motor mount that also holds the Simmering seal is fashioned after the Engel item that is supplied in the Lafayette kit.
Here is dry fitted. I still have to make the oring seals for the endcaps and tidy off the threaded rod. I will be using domed nuts and small orings to waterproof the threaded rod ends. The unit id 60mm dia and 10cm long.
Mankster
Martin - admin.
Administrator
Full Mayhemer
Offline
Reply #39 on:
February 05, 2009, 10:31:42 AM »
What's that purple 'Signal Quality' device?
"This is my firm opinion, but what do I know?!" -
http://www.modelboatmayhem.co.uk/
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #40 on:
February 05, 2009, 12:35:02 PM »
Quote from: Martin - Forum Admin on February 05, 2009, 10:31:42 AM
Its an 8Ch Receiver by Schulze. its an a 40Mhz PPM rx that has onboard signal post processing and can filter out glitches and interferance passing on only clean signals to the servos. Used mainly by the flyboys on 35Mhz but useful for submarines and fast electrics. It has a 'glitch counter to show how many times the RX has had to correct the signal, so helps with rx and aerial placement, range checks and an indiction of how 'electrically dirty' the enviroment your sailing in is.
http://www.schulze-elektronik-gmbh.com/alpha-e.htm
IMHO these are one of the best 40MHZ FM Rx's available, they take Futaba crystals too.
Last Edit: February 05, 2009, 12:42:48 PM by Mankster
Mankster
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #41 on:
February 05, 2009, 12:37:19 PM »
Another good 40MHZ rx is the Hyperion range that also features transmitter recognition, so if someone else switches on, on your frequency, it only accepts signals from yours.
Last Edit: February 05, 2009, 12:42:26 PM by Mankster
Mankster
Turbulent
Full Mayhemer
Offline
Reply #42 on:
February 05, 2009, 01:04:21 PM »
Trying to get hold of a simmering seal - where'd you get yours?
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #43 on:
February 05, 2009, 02:35:49 PM »
Quote from: Turbulent on February 05, 2009, 01:04:21 PM
I've got a stack of these 4mm x 11mm, PM your address and I'll put one in the post gratis.
Mankster
Turbulent
Full Mayhemer
Offline
Reply #44 on:
February 06, 2009, 11:57:25 AM »
PM sent - Cheers mate.
Turbulent
Full Mayhemer
Offline
Reply #45 on:
March 11, 2009, 09:37:04 AM »
All gone quiet down there!
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #46 on:
March 13, 2009, 05:47:51 PM »
Yep, had a big tidy up in the garage, WTC nearly done, just a bit of wiring to sort out. Then its back to sorting out the hull. Pics soon.
Mankster
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #47 on:
April 17, 2009, 11:35:17 PM »
After a couple of months busy with other things, I have finally got around to doing some more work on this project. The WTC is now finished save for save for fitting the push rod seals and other tiny bits. Pitch controller still to be fitted. I hope to have her bath tested in a week. 2x 600ml piston tanks and Engel controller. Battery is 12v 4.6AH and goes under the WTC.
Mankster
Full Mayhemer
Offline
Reply #48 on:
April 18, 2009, 02:53:03 PM »
That's a really well executed lump of engineering Mankster.
Regards Ian.
You might not like what i say, but that doesn't mean I'm wrong.
Mankster
Full Mayhemer
Offline
Wheelerdealer
Reply #49 on:
April 20, 2009, 11:49:15 PM »
Tight, but she fits
Mankster
Pages:
1
2
« previous
next »
Jump to:
Please select a destination:
Mayhem Sponsors
=> Sponsors
Mess Deck: General Section
=> Model Boating
=> Chit-Chat
=> Tugs and Towing
=> Full Scale Ships
=> Model Boat Links
=> Other Hobbies and Interests
=> Humour
=> Build Masterclasses
===> George's TID Tug
===> Welcome to the Mayhem Build Masterclasses
===> DRIFTER/TRAWLER FREDERICK SPASHETT
===> 1915 steam drifter build
===> 63 FOOT RAF AIR SEA RESCUE LAUNCH
===> A PLAN FOR BEGINNERS
===> Ben Ain Build
===> CERVIA Tug Build
===> General Havelock
===> Whitehills Lifeboat
===> Blue Marlin - Heavy lift semi submersible ship
===> Winston S Churchill
=> Warships Navy Military:
=> Working Vessels
=> Power, Race, Leisure & Sports Boats:
=> Submarines
=> Steam
=> Springer Tugs
=> Seaport Tugs
=> Yachts and Sail
=> Any Other Builds
Nautical College: Hints, Tips and Techniques
=> Electrics and all things Black Art
===> Radio Equipment
===> Brushed (DC) Motors Speed Controllers
===> BRUSHLESS Motors & Controllers
===> Batteries & Chargers
===> Miscellaneous (electrical & electronics)
=> Tutorials & "How To’s" ...
=> Technical questions
=> Painting, Finishing and Care.
=> Engineering Techniques and Materials.
=> Detail Work, Rigging, Fittings, Figures Etc.
=> GRP & Epoxy
=> Wood Care:
Research and Design Office
=> Beginners start here...!
=> Working vessels R&D:
=> Warships R&D:
=> Steam R&D:
=> Sports Boats R&D:
=> Yachts and Sail R&D:
=> Submarines R&D:
=> Any Other Information
Shows, Events and Club dates
=> Commercial Events and News
=> Club Events and News
=> Club List
Boat Yard: Marketplace
=> Traders Directory
=> Traders Section
=> Sales
=> Wants & Swaps.
=> Whats in the box?
=> Bargain Basement !
Sponsors 2
=> Sponsors 2
Loading...
