Pages: 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22   Go Down
Author Topic: Wicksteed 3 - May 23, 24 2009  (Read 188728 times)
Re: Wicksteed 3 - May 23, 24 2009
« Reply #300 on: May 13, 2009, 03:48:28 pm »
" gawp "... I can think of another word!    {-)
flashtwo
Re: Wicksteed 2009 - Events?
« Reply #301 on: May 13, 2009, 03:57:22 pm »
That's guaranteed!
Ian.
andyn
« Reply #302 on: May 13, 2009, 04:10:54 pm »
'Marvel in the glory'?
Bill D203
  • not long now!!
« Reply #303 on: May 13, 2009, 04:12:17 pm »
Now Now young Martin Theres no need for that.
Just cause we are a little mad.
chingdevil
« Reply #304 on: May 13, 2009, 06:23:20 pm »
Hang on, Hang on!!!
You did not mention the "little mad" part when I said you could park your boat in my gazeb %% %% %% %% %%
Brian
Bill D203
  • not long now!!
« Reply #305 on: May 13, 2009, 06:34:27 pm »
I think your safe Brian. It's all the rest!!!!
andyn
« Reply #306 on: May 13, 2009, 06:35:13 pm »
Just make sure you park all equipment well away from Stav's tables %%
Bill D203
  • not long now!!
Re: Wicksteed - Boats & Frequency?
« Reply #307 on: May 13, 2009, 06:37:31 pm »
How about "Flash Company"
chingdevil
« Reply #308 on: May 13, 2009, 08:14:59 pm »
Phew
Thats a relief :} :} :} :} :} :}
Brian
andyn
« Reply #309 on: May 13, 2009, 08:22:44 pm »
Just something I would like Martin to confirm for me. An extract from Wicksteed Park's website, model boat club section
Finally the Model Boat Club have the occasional use of part of the main 30 acre lake should we wish to stage large national events that are simply to big for the normal lake.
Do you reckon they would allow us to use it for the IC demo? I'm rather concerned about the size of the model boating lake and the fact it has concrete edges in relation to my multi that cannot turn on anything less than half throttle...
chingdevil
« Reply #310 on: May 13, 2009, 08:26:50 pm »
I doubt that the large lake is also a boating lake, also if I remember last year it had a lot of swans on it.
Brian
andyn
« Reply #311 on: May 13, 2009, 08:27:35 pm »
Have a read of http://www.wicksteedpark.co.uk/content.aspx?cid=148
"Finally the Model Boat Club have the occasional use of part of the main 30 acre lake should we wish to stage large national events that are simply to big for the normal lake. They are always pleased to see visitors at Wicksteed Park as it is the countries first theme park.  It also has a large number of free swings, climbing frames  slides etc. so you can bring the family and have all day sailing in peace.  If you would like to bring your club, we can make special arrangements for you."
« Reply #312 on: May 13, 2009, 08:39:32 pm »
But it's a long walk to the other side of the lake when you boat conks out!
 You can hire a row boat I guess but I hear there's talk of salvage fees!...... ;)
Ghost in the shell
« Reply #313 on: May 13, 2009, 08:51:03 pm »
the large lake, I wander Gemini can ger from one end to tge otger  with the tradio set at the backl nank of the event pool.
Go Nuclear!  you'll love it
andyn
« Reply #314 on: May 13, 2009, 08:56:32 pm »
I'll bring my own kayak then ;)
And I'll have some of what Ghost is currently drinking. Ta.
Ghost in the shell
« Reply #315 on: May 13, 2009, 08:58:16 pm »
im just a lousty tyopist, can't hit the kees straifgr even now after 10 years of having a computer
andyn
« Reply #316 on: May 13, 2009, 09:02:32 pm »
And if you believe that you'll also believe that a swine flu
I'll get me coat...
Bill D203
  • not long now!!
« Reply #317 on: May 13, 2009, 09:05:50 pm »
Here are you trying to take over my place as the worst typer Ghost????????
THE answer Andy Is Simple.
DON'T RUN IT. Save it for Llanberis latter in the year. However If you do get the parky's to allow us to run on the big lake I want to run the Makara. However I don't think they will play ball at all. SO DON'T PEE THEM OFF.
andyn
« Reply #318 on: May 13, 2009, 09:09:04 pm »
Well from what they have written on their site they are happy to let us use it. Never mind the makara, on that lake you could run the hydro.
With Martin's permission it wouldn't hurt to ask nicely, not all parkies are like ours...
Only problem being that what would we do about rescue?
Bill D203
  • not long now!!
« Reply #319 on: May 13, 2009, 09:13:20 pm »
Andy I don't think you will get away with it, So don't spend much time on the rescue boat plan.  Don't get carried away.
Ghost in the shell
« Reply #320 on: May 13, 2009, 09:23:00 pm »
As for the run at llanberis, its a long way tio the bottom of the laje, the large pool isn't probably that deep, also Gemini is small so not meant to be taken FAR off bank.  the Najade is the llanberisd boat
I do plan on bringing diwn the Najade as well, but I need a couple of bits forst of mystang mark, incvluding a neqw prop joint to get her running quieter as the motyor is out of line form the shaft.  m5x45mm pin and a m5x25mm pin as well.
as fpr the malkara, the restriction may because its IC.  not electric.
Bill D203
  • not long now!!
« Reply #321 on: May 13, 2009, 09:29:44 pm »
OMRA boat have buoyancy fitted to them. They have too.  This keeps the boat on the surface till the rescue boat can get to the boat and pull it out. There then follows a drying out of the engine and hopfully the radio box stays waterproof  and then you carry on racing. That's how it works.
Ghost in the shell
« Reply #322 on: May 13, 2009, 09:31:22 pm »
goodf pointy stavros!
Bill, i trued adding bouyanmcy foam to Celestia, I still had to get wet in 5 feet of water after being rammed by a hovercraft.  now I plan to add watrertight compartments
Bill D203
  • not long now!!
« Reply #323 on: May 13, 2009, 09:35:03 pm »
Ghost slow down the finger dept you are typeing rap!!
I find the spell check Very usefull. Give it a go.
Ghost in the shell
« Reply #324 on: May 13, 2009, 09:37:16 pm »
could be a reasion.
the main thing about thw event is to HAVE FUN
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22   Go Up
Page created in 0.033 seconds with 21 queries.
