Author Topic: Radar Motor  (Read 4066 times)
2772e
  • Simon
  • The Sea Shall Not Have Them
Radar Motor
« on: September 24, 2006, 09:42:01 am »
I need a motor than can run a radar, preferably without a gearbox, not remote and small. 10-15mm high by 10mm wide.
Also not sure of the correct rpm, i think about 30rpm?
I know someone has the answer.
Rubbin is Racin!
Daryl
Re: Radar Motor
« Reply #1 on: September 24, 2006, 09:50:40 am »
Not much help,but I have seen a radar with a motor/ gearbox and a flexable drive to the radar. Or you could have a chat with the folks at Model Power, they might have something or Westbourne Models.
Daryl
Welsh_Druid
Re: Radar Motor
« Reply #2 on: September 24, 2006, 09:51:22 am »
2772e
  • Simon
Re: Radar Motor
« Reply #3 on: September 24, 2006, 10:11:46 am »
Great, thanks, just ordered one.
Love this forum!
 :D ;D
Rubbin is Racin!
chromedome
Re: Radar Motor
« Reply #4 on: September 24, 2006, 04:44:05 pm »
I have just converted a servo to turn 360degrees.This seems to be quite a popular method .It turns about 15rpm.
   chromedome
cbr900
  • Mayhem is the Only Forum!
    • Roys Hompage
Re: Radar Motor
« Reply #5 on: September 24, 2006, 07:48:48 pm »
What is the process for converting a servo to rotate 360 degrees...
Roy
2772e
  • Simon
Re: Radar Motor
« Reply #6 on: September 24, 2006, 07:50:40 pm »
Hey Roy,
If you pop open the gearbox you can remove a small lug on one of the wheels. This will allow the motor to run 360.
Simon
Rubbin is Racin!
Re: Radar Motor
« Reply #7 on: September 24, 2006, 08:29:36 pm »
You remove the lug from the output gear that would otherwise foult the ribs inside the top cover, then you enlarge the "D" shaped hole in the bottom of the gear so that it does not engage the position sensing pot.  Adjusting the pot also gives some measure of speed control if it is running off an RX channel.  Otherwise just remove the electronics board and connect the motor terminals to a battery, voltage of your choice, but I would say a max of 6v.
chromedome
Re: Radar Motor
« Reply #8 on: September 24, 2006, 08:51:16 pm »
1xAA1.5v will run it non stop for days!!
  chromedome
Daryl
Re: Radar Motor
« Reply #9 on: September 24, 2006, 09:35:56 pm »
try putting modifying a servo in google and up pops quitea few pages from the robot enthusiasts.
www.kronosrobots.com
www.firstwiki.org/modifying_a_servo
www.acroname.com/robotics/info/ideas/continious/continious.html
These are only a few ifyou type in the model of the servo the liklyhood of amodpage ia quite good. Different typesofservo require different ways to modify. Some easy some hard.
Good luck
Daryl
2772e
  • Simon
Re: Radar Motor
« Reply #10 on: September 26, 2006, 07:47:34 pm »
Just got the motor from FastComponents.
Perfect, thanks for your help guys!
Rubbin is Racin!
Page created in 0.111 seconds with 22 queries.
