Author Topic: Fitting new prop shaft to old GRP hull  (Read 12213 times)
Malc Reade
« on: September 27, 2006, 11:14:40 am »
Has anybody got any experience of removing an existing brass prop shaft from an old GRP hull and replacing it?
I bought a lovely example of Caldercraft's Cumbrae Clyde Pilot Cutter at Brighton early this year.  It seems to have a slightly mis-aligned prop shaft and I would like to replace it, and also the whole power train with some nice quality equipment, motor, coupling, shaft and prop etc.
Can anybody offer any suggestions as to how I should go about removing the old one, and also any suggestions for replacement parts, manufacturer's etc?
Regards, Malc
cbr900
  • Mayhem is the Only Forum!
    • Roys Hompage
Re: Fitting new prop shaft to old GRP hull
« Reply #1 on: September 27, 2006, 11:29:33 am »
MALCOM,
Cannot suggest where to get the new replacement but to remove the old one, I have used a dremel with a medium burr bit and cut as close as possible to the hull and then with a smaller burr bit ground away the holding material on the inside and the shaft will come out fairly easily, with no damage to the hull or the shaft......
Roy
« Reply #2 on: September 27, 2006, 12:27:13 pm »
                 Deans Marine do all the bits you want including prop shaft with oiling tube
        Richard ;D
andywright
« Reply #3 on: September 27, 2006, 02:16:26 pm »
Give the shaft a eal sharp tap with a hammer, so long as the hull is sound no harm will come, otherwise its a drill it out job.
riggers24
  • Just full of stupid questions
« Reply #4 on: September 27, 2006, 05:36:38 pm »
Malcom,
I have just removed 2 shafts out of a static model I am converting to RC, small pointed burr mounted in a mini craft drill and gently removed the filler around the outside then on the inside. Took 10 minutes a shaft and no damage to the hull. Just don't go in heavy handed, take your time.
Marc
I will finish the crash tender someday - Still got tooo many toys to play with
justboatonic
« Reply #5 on: September 27, 2006, 07:21:55 pm »
Malcom,
Marc
Wonder what boat that was on Marc?  ;)
riggers24
« Reply #6 on: September 27, 2006, 09:55:59 pm »
I wonder.
Here is a piccy of the hull with one shft removed
« Reply #7 on: September 27, 2006, 10:51:29 pm »
Use some brass tube a tight sliding fit over the old shaft, file teeth in one end and use this to cut out the filler.
« Reply #8 on: September 27, 2006, 11:05:01 pm »
Could you use some kind of dremel and cut the shaft as short as possible in side and outside (if enough room) and then grind the remaining shaft tube down with a burr tool from the inside of the tube out?
Malc Reade
« Reply #9 on: September 28, 2006, 02:20:51 am »
Thanks for the help so far gentlemen.
From the above posts it would seem that chances are that the existing shaft may well be really tight and difficult to remove?
I'm reluctant to start grinding the existing shaft out as the surrounding material will certainly be softer than the brass tube and the chances of me slipping with my Dremel and damaging the hull are significant?
What are the chances of me driving it out with a sharp blow with a blunt instrument? (Given that the surface of the original shaft was probably roughed with Emery paper to ensure good adhesion to the resin)?
Any further input would be much appreciated.
Regards to all, Malc
GOGSAMWE
« Reply #10 on: September 28, 2006, 06:33:53 am »
Malc,
I too would go with this suggestion... using any force with "your blunt instrument" is much more likely to  damage your hull..
As for adjacent damage "limitation" what about covering the area with several layers of thick masking tape.? you could use duck tape or similar...  but it may pull your paint off.
You can easily re-fill any holes...   But repairing  "crash n bash damage" will be much harder  ;)
Steve
« Reply #11 on: September 28, 2006, 08:53:55 am »
I once removed an old shaft by heating the end - VERY carefully - with a soldering iron, (once even a blow torch)  and twisting it with heavy pliers.  I snapped completely clean from the resin & glue and and slid straight out.
I think Prop Shop do a nice range of propshafts.
Martin (Danger man ) Mayhem  :o
Malc Reade
« Reply #12 on: September 28, 2006, 09:24:31 am »
Thanks Martin
That one sounds a possible.
Do you think I might have to re-name the model 'Puff Of Smoke'?
Malc
tonyH
« Reply #13 on: September 28, 2006, 09:34:30 am »
Malcolm,
Do you have to completely remove the old tube?  Could you not cut away as much as poss, protecting the hull as noted. Tidy up outer end and then insert a narrower system through the old one, adding filler between the two?
Tony
Malc Reade
« Reply #14 on: September 28, 2006, 10:51:26 am »
Hi Tony
That's another possibility.  My problem is compounded by the fact that the (planked) deck is securely fixed to the hull, making any attempt to work on it extremely difficult.
Malc
cbr900
    • Roys Hompage
« Reply #15 on: September 28, 2006, 10:55:59 am »
MALCOM go back to the second posting, safest way mate, just take your time...
Roy
chugbug
« Reply #16 on: September 28, 2006, 04:58:27 pm »
 ;D ;D    I heated a mild steel rod with a blow torch and shoved it up the prop tube,waited for a slight pong and it slid out a treat.It works. Good luck.
        Chugbug. ;D ;D
GOGSAMWE
« Reply #17 on: September 28, 2006, 05:17:26 pm »
;D ;D    I heated a mild steel rod with a blow torch and shoved it up the prop tube,waited for a slight pong and it slid out a treat..
He hee ;D
the mind could boggle with that sort of treatment  ;D
Steve
( yes a GOG and a Warped Gog at that !)
 ;D
« Reply #18 on: September 28, 2006, 05:19:50 pm »
No wonder the masthead lights of a Pilot Boat are white over red! (White cap over a red face as we were taught on out RYA lights recognition course)  Mind you, on second thoughts maybe it ought to be a white face... :D
Jonty
« Reply #19 on: September 28, 2006, 10:14:09 pm »
Wasn't that how they polished off Richard II?
I eat my peas with honey,
I've done it all my life;
« Reply #20 on: September 28, 2006, 10:19:19 pm »
That's right, I think. Red hot poker in the bowels. leaves hardly a mark on the body. I need another drink....
tonyH
« Reply #21 on: September 28, 2006, 10:31:31 pm »
Alternatively, getting back to business (how sad!) and if the bent bit is outside the hull, cut off  the bent bit, fit flexi-drive end tube and run flexi up the current pipe after tapping out the top bearing.
Tony
« Reply #22 on: September 28, 2006, 10:47:24 pm »
Remove the whole tube.
I have done several, use whichever suggestion is best for you.
I used the brass tube with teeth, takes a bit of time but leaves a clean hole.
Malc Reade
« Reply #23 on: September 29, 2006, 12:32:50 am »
Thanks guy's
Actually the tube isn't bent, it just leans to starboard when you cast your eye along the length of the model.  The shaft is very sloppy in the tube though and the whole thing makes a helluva noise when I run the motor.
I'm going to have a go at removing it over the weekend, will provide feedback with pics next week.
Malc
Doc
« Reply #24 on: September 29, 2006, 09:35:21 am »
Malc,
If I'm understanding you correctly, the problem isn't with the stuffing tube, but with a wobbly drive shaft and or bad bearings.  I think I'd try just replacing the drive shaft/bearings before tackling the stuffing tube.  Yeah, I certainly understand about it not being 'right' if it's angled off to one side, but that really isn't going to be ~that~ much of a problem.  If you find out that it is that much of a problem later, then you can replace the tube.  Sounds like sort of a sloppy repare job, but why do more than is really required?
 - 'Doc
