This is the briefest of how-tos, offered mainly because I have just discovered (the hard way) how to remove the keyless chuck from battery drills (and probably mains drills as well)
Scene - I had a boxfull of battery drills (12 to 18V) given to me by various people and wanted to salvage the motors and speed controllers for possible use in boats. They are too big and powerful for use as sheeting winches, but all come with 2-stage reduction gearboxes.
Open chuck up as far as possible - as if you were about to fit a 1/2 inch drill - and peer into the chuck
There is a
left-hand thread crosspoint screw which screws into the nose of the gearbox shaft - remove it
The chuck now unscrews in a normal right-handed thread from the nose of the drill
(if it is reluctant do what works with a keyed chuck - fit into the chuck something strong with a rightangled bend - an allen key is ideal - support the drill body and smack the allen key with a hammer in the unscrewing direction)
Remove all the screws holding the drill body together - crosshead - about 8 or 9 of them
Seperate the body halves - the "works" will lift out complete
Pictures can follow if anyone would be helped
The "Works" are:
a motor* - about 650 or 700 size - wound for long life at the drill voltage - with silly internal fan
Speed controller - built into the trigger mechanism - we can operate this with a servo if we are poor or Scottish
The Speed controller has a wander lead with a cast heatsink and a power semiconductor fitted to it (??FET) - I have never felt one get warm at all.
When I get a minute I will eviscerate the mechanism and see what is in there - I would be amazed if there was not a linear pot worked by the trigger, and a small processor which tells the FET what chopping to do.
andrew
I can't pass on without mentioning the "rubbish" fan-cooled motors that were much discussed (and reviled) in Mayhem. I am fairly sure that these were drill motors (with fans) from 4.8 or 6V drills, and would have been good boat motors at 3V or even 2V . (take a bow GG who has published a plan which ran a buggy motor at 2V on a cylon cell). I have no doubt that they are fine motors (sold originally for electric flight on 7.2V) but unfortunately used in the boating fraternity. Fully loaded they are 30Amp+ motors
These drill motors I removed last night run beautifully at 12V, would be happy for warship propulsion at maybe 6V and I would hit them with 24V if I wanted vivid performance - might stick one in the PT boat with 3S Li-ion cells and see what happens
