Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13   Go Down
Author Topic: Bourbon Orca  (Read 149101 times)
boatmadman
Re: Bourbon Orca
« Reply #125 on: March 04, 2010, 09:16:30 pm »
Spent some time today on the main deck and winch deck.
The pics show what I have done. Whilst in the process of doing this, I discovered a mistake in the build. The pic with the arrows shows a space between decks that would suit only vertically challenged people!
So, what to modify? Add a plank above and raise the deck levels? Or remove a plank along the main deck. After measuring all round again, decided that the best (only) option really was to remove a plank along each side of the main deck. This took some time, as I also had to lower all the frames to suit. Anyway, got it done and you can see the difference in the following pic.
Doh! managed to load one pic twice!
boatmadman
Re: Bourbon Orca
« Reply #126 on: March 18, 2010, 08:39:24 pm »
Got back to it today, and realised that the main deck wasnt the correct width, so, out with the saw and cut off some of the frame edges.
The first and second pic show after modification. But, I then realised that the sides above the main deck carry through under the next deck Doh!
So, out came the saw again, you can see in pic 3 the mods I made.
Pics 4 and 5 show the area within the bow, with a couple of platforms in place for batteries and electronics etc.
Code: [Select]
[code][/code]
boatmadman
Re: Bourbon Orca
« Reply #127 on: March 25, 2010, 08:46:24 pm »
Before going any further with the decks, I thought I should make the winches, the thinking being that decks are easier to modify at a later date if required than winches.
Anyway, here are pics of progress so far.
Re: Bourbon Orca
« Reply #128 on: March 25, 2010, 08:53:01 pm »
Very nice Ian
chipchase
Re: Bourbon Orca
« Reply #129 on: March 25, 2010, 09:07:23 pm »
Your making a great job of her Ian those winches really look the business
Umi_Ryuzuki
Re: Bourbon Orca
« Reply #130 on: March 26, 2010, 12:21:48 am »
Code: [Select]
[code][/code]
I didn't think the main deck was too narrow...
I did think that the side passages alone the deck were too wide though...  :P
Looking good Ian...  :-))
boatmadman
Re: Bourbon Orca
« Reply #131 on: May 06, 2010, 09:49:16 pm »
And back to the Orca after steam engine time!
Anyway, I have fitted the 'p' brackets, mounted the motors and put in the rudder tubes - all routine stuff, so I wont put in pics of those.
I have been wondering how to get access to the motors and shafts etc through the main deck, eventually, I came to the idea of using re seal-able food boxes recessed slightly below the deck, and fit a removable deck over the top.
The pics show the progress:
MTrader
Re: Bourbon Orca
« Reply #132 on: May 10, 2010, 08:44:40 pm »
Hello.
After reading your building report I am surprised about your solution to create a watertight deck.
I new another modeller with the same solution.
But I will give you my solution.
I made all decks of plexy glass, perfect to saw,and glue.
In this deck I made a hatch.
This hatch you can tape complete watertight with isolation tape.
Above this plexy deck is the falch deck this is made of 1,8 mm print plate.
At the print I glued the wooden deck.
If there are any troubles under need you only take of the falch deck and you can see trough the plexy deck all what happen under need.
It´s simple to made and very use full.
Please look at the photos.
gr Leen, (model Maersk Master)
Umi_Ryuzuki
Re: Bourbon Orca
« Reply #133 on: May 10, 2010, 10:12:59 pm »
Hi Leen,
What did you build your finish deck on.
It looks very thin, but also very rigid.
Aimee
boatmadman
Re: Bourbon Orca
« Reply #134 on: May 10, 2010, 10:27:20 pm »
Leen,
Nice solution, have to admit I hadnt thought of that.
VIVALDI
Re: Bourbon Orca
« Reply #135 on: May 11, 2010, 06:38:02 pm »
Realy good job!!!! ok2
Nice and clean construction, i like it... :-)) :-))
Kénavo, Philippe!
MTrader
Re: Bourbon Orca
« Reply #136 on: May 11, 2010, 07:32:25 pm »
Hi Aimee
The falsch deck is made of printplate 1,8 mm.
Print plate is very hard en get good shape.
That's importand because the wooden planks are glued at this print plate.
Till now I works perfect.
The plexy deck and hatch construction is copied many times.
It's to simple explane, but it works perfect.
Do You get the time to meed us again in Guterloh?
gr leen
paulolondres
Re: Bourbon Orca
« Reply #137 on: July 18, 2010, 12:04:57 am »
Dont you just hate building model boats?
Paint hardly dry on the last one, and here I go again! %% %%
Ulstein, the builders and Bourbon wouldnt let me have a linesplan, so I designed the hull myself.
Thank you to those who let me have some pics and information - you know who you are.
Anyway, here are the frames pasted onto plywood ready fro cutting out.
Hy  mate i am from brazil, i have the happy hunter plans in cad, and i want the make the ULSTEIN AX104 Bourbon Orca , can you pass me the plan lines?
this is mine one
http://www.rcgroups.com/forums/showthread.php?t=1267660
see ya
paulolondres
Re: Bourbon Orca
« Reply #138 on: July 18, 2010, 12:12:14 am »
offshore
Re: Bourbon Orca
« Reply #139 on: September 09, 2010, 09:09:44 am »
Good morning, dear XBow enthusiasts,
thats an absolutely brilliant work  :-)) :-)). I'm currently working on a scratch built diving support vessel with Ulstein XBow. I wish my model would be looking as good as yours boatmadman <:(.
Like PeterS, who is in the same German XBow community like me
http://forum.modellkapitaene.net/viewforum.php?f=353&sid=d2cab56781b55fe64165cf1cc54b66ef
I made an photo building report, which you can find here:
http://picasaweb.google.de/Skipperiki/DSX144HalmarBeluga?feat=directlink
Greetings form southern Germany.
Matthew
boatmadman
Re: Bourbon Orca
« Reply #140 on: September 10, 2010, 08:45:34 am »
Having completed a little diversionary side project, I am now back on the Orca, nothing to post just yet, but pics and info will start again soon.
Ian  :-))
offshore
Re: Bourbon Orca
« Reply #141 on: September 11, 2010, 09:58:29 pm »
Hello Ian,
these resealable boxes are famouse for not taking any glue. How do you get the hatches watertight if you can't take any glue?
Matthew
boatmadman
Re: Bourbon Orca
« Reply #142 on: September 30, 2010, 03:31:13 pm »
I intend to seal using silicone sealer and then test!
Managed to get some external detailing done:
offshore
Re: Bourbon Orca
« Reply #143 on: October 01, 2010, 09:09:49 am »
Thx. Seems to be the best way for glueing these plastic stuff. Nice work with the gangway.
Matt  ;D
rathikrishna
Re: Bourbon Orca
« Reply #144 on: January 16, 2011, 07:18:15 am »
Hai Friend..i apologize to you once..because i am saving some photographs from you, not for any bussines purpose, but o make one like this.all of your pictures are much inspiring..but i dont want to go this much to make this craft...i will make it from expanded polystyrene..so apologize once again...really i do not have any patience to ask you a permission to save. please..my blood pressure is getting high as i looks in to your craft...its a kind request...Rathikrishna
onofre martins
Re: Bourbon Orca
« Reply #145 on: February 05, 2011, 03:42:38 am »
Dear possible would you send to me the plan of the vessel Bourbon Orca?
 Looked at several sites and so far not succeeded. I hope you send me. Thanks.
boatmadman
Re: Bourbon Orca
« Reply #146 on: February 05, 2011, 09:16:59 am »
I dont have a set of plans in the conventional sense, I designed this hull in Delftship, and then worked on the fittings from photographs taken from the web and  the Bourbon website.
An update on the build, I have now been able to restart this project and have epoxied the inside of the hull, and started construction of the handling crane, pics will follow soon.
Arrow5
Re: Bourbon Orca
« Reply #147 on: February 05, 2011, 09:19:39 am »
Careful Boatmad...that looks like a Chinese full size tug shipyard O0 {-) {-) {-) {-) >>:-( <*<
..well can you land on this?
Roadrunner
Re: Bourbon Orca
« Reply #148 on: February 05, 2011, 09:47:55 am »
I would like to suggest to the admin that this post is worthy of the 'masterclass section' a very diffident model, high in detail very nicely done looking forward to the finished product. :-))
Arrow5
Re: Bourbon Orca
« Reply #149 on: February 05, 2011, 10:31:37 am »
I second that :-))
Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13   Go Up
