Author Topic: Sheerline type11D  (Read 5971 times)
petesubman
Sheerline type11D
« on: April 19, 2006, 07:27:09 pm »
As promised pic of the new boat from sheerline, Pete
[Too Large - attachment deleted by admin]
AlanB
Re: Sheerline type11D
« Reply #1 on: April 19, 2006, 09:02:05 pm »
Pete,
Do you have any other details on the kit?
Release date, price, spec (length etc)
petesubman
« Reply #2 on: April 19, 2006, 10:01:46 pm »
Hi Alan, the hull is 66 inches long, beam is 9 inches, the ballast tank is all metal construction, a nicad pack sits in the keel, the scale is 1/27th, price is 950, now that might make you sweat, but if you bought an engels boat and then bought the tools to put it together, ie pillar drill, etc, it bumps the price up, the vast majority of the construction is already done, the manual/cd that chris has put together even shows you how to solder, you could email chris at [email protected], he has also upgraded the trafalgar by reducing the tophull weght and adding a nicad pack, i do have more pics i can send regards Pete
magpie
  • Subs Rock
    • magpieyachts
« Reply #3 on: April 21, 2006, 12:44:25 am »
Hi Pete
I couldn't help noticing the bit "i do have more pics".
Pleeeeeesa post them here for all of us sub lunatics to drool over mate!! That one up top here is great! Very hard to beleive it's not wartime and a real scene.
Jason
"Where's the sub gone?"
http://magpieyachts.com
Turbulent
« Reply #4 on: May 01, 2006, 05:44:51 pm »
So you've got yourself a II then Pete, How's my old P boat then?
petesubman
« Reply #5 on: May 01, 2006, 08:18:29 pm »
Hi Paul, she,s laid up at the moment, gearbox trouble, waiting to fit a replacement, just putting the finishing touches to HMS Conqueror, and Chris,s boat is a really nicely made kit, what are you up to then, hows the u boat, Pete
Turbulent
« Reply #6 on: May 06, 2006, 07:53:57 pm »
Bit quiet on the building front, the VII's finished and came through initial trials well, but needs the aerial extending out side the WTC (Sheerline/Eden),  sails well though.
T Boat up for a refit soon, I'm going to fit her as per your P boat.
sheerline
« Reply #7 on: May 06, 2006, 11:35:40 pm »
Paul, have you tried running the aerial down through the ballast tank and into the motor compartment.. it makes for much better reception. I havn't experienced any range problems using this set-up and do not experience any interference from the motors either.
Best regards.. Chris
Turbulent
« Reply #8 on: May 07, 2006, 07:31:42 pm »
Cheers chris i'll give it a go.
BTW. I've not forgotten about coming to see you, I've just been busy with work. I'm going to retro fit the Traf' as per we discussed, I need the front space for some ordanance!
Page created in 0.013 seconds with 21 queries.
