Author Topic: TYNE/FLYING SPINDRIFT  (Read 5596 times)
seahawk 1
« on: August 16, 2009, 11:59:06 pm »
I have taken quite a liking to this kit, so have to ask; what is NOT in the kit?  Have many years building R/C boats and have, more than likely, all the electronics/adhesives/etc, required to complete.  I ask due to being in the US, this 'kit' will set me back about $1300.00. Have requested a shipping quote from Tyne, but no response to date.  What else is needed?  Wood? Plastic?
Thanks,
polobeer
Re: TYNE/FLYING SPINDRIFT
« Reply #1 on: August 17, 2009, 06:17:07 pm »
These kits make very detailed models when finished. I believe they are supplied as semi kits with detailed GRP hull, pre-shaped GRP wheel house/bridge (you need to cut out the windows, port holes, doors, etc), funnel details, etc, plus a number of essential fittings (cast in pewter I think). The purchaser will need to buy other detailing parts and all the RC gear. The person to contact on this forum about these impressive models is Chipchase. I think he's built several Tyne Models kits to a very high standard.
All the best
Simon  %%
chipchase
« Reply #2 on: August 17, 2009, 08:21:02 pm »
Hi Mike
As Simon has said this makes up into a very nice model and I don’t think you will be disappointed. The only thing that’s not in the kit is an instruction book. Everything else is supplied. As you have had some experience of building models I don’t think you will have a problem with any of their kits. Tyne Models have recently started to produce quite a lot of the big fittings in resin, these are up to a very high standard. There are still a lot of the smaller fittings like brake handles and clutches still produced in pewter. I have included two photos in this reply, one is the model that I built and the other is of the contents of the kit that was supplied to me when I purchased it from Tyne Models.
Hope this helps.
Brian
polobeer
« Reply #3 on: August 17, 2009, 09:05:14 pm »
Lovely model Chipchase! How do you achieve such a good paint finish on your models?
Simon  :o
seahawk 1
« Reply #4 on: August 18, 2009, 01:08:16 am »
Thanks for all the input, very nice build! You guys are great.
mike
over_powered84
« Reply #5 on: August 18, 2009, 05:31:49 am »
Nice Spindrift There Chipchase, Do You Have Pics of Your Build?
chipchase
« Reply #6 on: August 18, 2009, 08:14:58 am »
Hi Simon and over powered84
I use acrylic car paint from the local car accessory shop. Some accessory shops will mix paint you need in spray cans. When I built the Spindrift the nearest colours I could get was Ford Baltic blue (semi matt) for the hull and Alabestro (semi matt) for the superstructure. I have use red oxide primer as an under coat on all of the models that I have built.
Unfortunately I only have a few photos of the Spindrift build, if you are going to build her and need any help just pm me.
Brian
over_powered84
« Reply #7 on: August 18, 2009, 11:07:57 pm »
Thanks Brian
The Pics Weren't For Me Bud They Were For A Guy At the Club Who's Building This....Soon :P
chipchase
« Reply #8 on: August 19, 2009, 12:13:46 am »
No problem If he needs any help with the build just pm me and let me know
brian
over_powered84
« Reply #9 on: August 19, 2009, 04:19:47 am »
That's Brill Thanks Brian :-))
