You may have seen other posts from me as I try to pick the optimum hardware set for little EeZebilt boats. From 10"-20" long, made of balsa - see
http://modelboats.hobby-site.com.
What I am looking for is a cheap controller for a small motor. I have just trialed a few, and you might be interested in the findings:
ESC - cheap 25A - this one (only £1.90!)
http://www.r2hobbies.com/proddetail.php?prod=rcps51601 . Needs to be started by pushing an arming button.
Motors trialed:
- Small 240 3v (Mabuchi/KaKo toy) - the sort of motor ususually used for these craft
- 480 - decent size smallish motor for 18"-24" displacement hulls -
- Small 12v CD-Rom tray motor (brushed)
4.5v - Servo and receiver work, but all motors cut out shortly after starting
6v - 240 motor runs fast - little response to throttle except over bottom 1/4, where it slows a bit to about 2-3000 rpm.
480 motor - just on the edge. runs at full ok - good speed range, but hard to start with load, and tends to cut out if any load is applied.
12v CD motor - Brilliant! Good speed range, down to a 200rpm tickover with a bit of load, and no hint of any cutting out. Top speed is not brilliant, it's a 12v motor on 6v, and the torque is low because it's a small motor...
7.5v - 240 motor runs fast with little variation over the whole range
480 runs fine, with a fast tickover. But if you stall it it must be manually restarted. That limits the torque you can extract...
12v CD motor - Runs well as before, but with a much faster tickover. Still not much torque
9v - 240 motor taken off quite rapidly, in a hot condition!
480 runs fast, more reliably, and is hard to stall. There is not much speed variation except in last 1/4 of throw, and there is no tickover - just fast and medium
12v CD motor - runs well - still not much torque, but it's very small. Less of a speed variation. No cutout at any point.
One interesting point was that if the transmitter was turned off all motors stopped, and then started again when the transmitter was turned on, without needing the arming button to be pressed. So you could stop a boat on a pond and then restart it. If you weren't worried about leaving a boat with an operating receiver and no transmitter, ready to pick up any interference...
Findings - none of these motors are ideal. The problem is the automatic volt-low cut-out, which means you have to run with high volts or a motor which draws so little that there will be no voltage drop under load. If you run with high volts a small boat will have trouble carrying the batteries, and the motor won't really have a slow speed.
What would be very useful would be one of these ESCs with the low-voltage cut-out disabled. Are there any ESC designers out there who know if this might be a simple mod, like cutting a line, or is it built so deep into the controller circuitry that you might as well buy a more expensive one without the cut-out...?
