Model Boat Mayhem - Forum
Author Topic: BoatMadman's - 1915 steam drifter build  (Read 15509 times)
boatmadman
« on: November 14, 2006, 08:56:54 PM »
Any one interested in a build of a 1915 steam drifter? If so, I will be happy to post pics and comments
Ian
boatmadman
Re: BoatMadman's - 1915 steam drifter build
« Reply #1 on: November 15, 2006, 01:44:03 PM »
I started with the idea of a steam drifter Jeannie Mcintosh built in Buckie 1915. Of course, even after lots of searching, no plans were found. So, I used these lines from a book, and intend to get as close as I can with the one b/w photo I have!
boatmadman
« Reply #2 on: November 15, 2006, 01:50:19 PM »
Next, was given a boiler by a retired coppersmith, it failed its first hydrostatic test, but is ok after I repaired it.
The engine, a twin wobbler from stuart turner.
From parts to finished in 6 weeks!
boatmadman
« Reply #3 on: November 15, 2006, 01:56:42 PM »
started on the boat next, took 3 attempts in old ply to get the keel right before cutting from clear pine, fitted the frames and started planking in cedar.
having trouble getting some of the curves, but with perseverence..........
(Thats my 1:1 home build in the background!)
boatmadman
« Reply #4 on: November 16, 2006, 12:26:16 PM »
getting on with the planking now. The hull shape is showing quite nicely!
Note the extensive use of the best clamping system around - masking tape!
I knew there must be a better use for an ironing board! ;D
« Last Edit: November 17, 2006, 04:59:41 PM by boatmadman »
boatmadman
« Reply #5 on: November 19, 2006, 05:42:15 PM »
And now we approach the easy(?) part of the planking, cutting and shaping to fill the holes!
Cant wait for the next part...filling and sanding and filling and sanding.......
« Last Edit: November 22, 2006, 11:39:49 PM by boatmadman »
boatmadman
« Reply #6 on: November 29, 2006, 10:40:59 PM »
Hi all,
Some more progress, I have finished the planking, need to attack with the orbital sander now.
I have also steamed the boiler for the first time tonight, had a few leaks around fittings to start with, but soon sorted those out, got it to 50 psi!
Ian
boatmadman
« Reply #7 on: November 30, 2006, 03:44:28 PM »
Hi All,
Had a good day with the orbital sander and P38 filler.
As you can see, I have also rough cut and fitted the stern blocks from balsa, overseen by my own little gremlin! I dropped a peice of sand paper.... she was off into the garden with it..never did see it again ???
Ian
boatmadman
« Reply #8 on: December 03, 2006, 04:56:08 PM »
Ever had a day when nothing goes right? Its been that day for me  >:( - been trying to make rudder fittings - solder in wrong places - melted brass! I gave up and had a beer, try again tomorrow!
boatmadman
« Reply #9 on: December 06, 2006, 04:45:59 PM »
Given up on the brass fittings for now, got the stern more or less shaped out now. Lots more sanding next!
boatmadman
« Reply #10 on: December 06, 2006, 11:29:47 PM »
hmmm - must remember to shape the bottom of that stem!  :D
boatmadman
« Reply #11 on: December 11, 2006, 07:23:26 PM »
Well, I removed the build shadows, wonder if I have enough room inside!
Found my first mistake though, i only built to the deckline, should have gone right up to the top of the bulwarks.
I will just have to add more planking now. Wont take long - these things happen!
boatmadman
« Reply #12 on: December 11, 2006, 08:34:12 PM »
Thanks for the comments Andy.
This is scaled at about 1:24 and gives a hull length of 48"
Thats the extra planking on! Gonna sit down with coffee and photos now, to try and work out dimensions of wheel house, engine casing etc.
Ian
« Last Edit: December 11, 2006, 08:36:00 PM by boatmadman »
boatmadman
« Reply #13 on: December 13, 2006, 10:28:19 PM »
And here we have tonights limited efforts!
The boiler and engine in the boat to determine positioning and to work out how to mount them.
Also, showing how I mark out a curve on a deck beam to get the correct (?) curvature on the deck.
boatmadman
« Reply #14 on: December 28, 2006, 10:30:05 PM »
Hi All,
Got a bit done today, put the deck lining on for the stern, with rudder tube fitted.
Also started planking in the stern rail, hope this will work out ok!
boatmadman
« Reply #15 on: January 06, 2007, 04:25:25 PM »
Hi all,
Well, got a little done this week, finished off the stern rail and dry fitted deck beams.
Also did more filling and sanding, think the hull is about ready for epoxy now.
Made up some card deck housings to try and get an idea of the size and proportions - dont think I got it right yet!
Ian
« Last Edit: January 06, 2007, 10:13:17 PM by boatmadman »
boatmadman
« Reply #16 on: January 14, 2007, 08:11:27 PM »
Got bored with working on the hull, so did a bit of superstructure for a change!
boatmadman
« Reply #17 on: February 03, 2007, 04:24:49 PM »
Well, I have caught the epoxy pox! I put first coat on the hull and its pooled and rippled like a severe case of cellulite!
Out with the wet and dry!!
Ian
boatmadman
« Reply #18 on: February 20, 2007, 10:14:07 PM »
Here we are again,
I got the poxy epoxy sorted out, lots of sanding down to remove it all, then, I was able to put another coat on while at work on nights. This time it went on just right. The secret is temperature! I had been using it too cool. The boiler room at work was about 25deg and it went on really well.
Next, a quick rub down and red primer sprayed on.
Then marked the waterline and painted the topsides in satin black, but, oops, the waterline sagged midships! Damn!
Rubbed off the waterline with wet/dry, re painted the red primer and drew a new waterline using a laser pointer on a flat surface- -see pic.
next, re paint the topsides, more pics to come when the paint is dry.
Ian
boatmadman
« Reply #19 on: February 21, 2007, 08:42:28 PM »
Got the topsides painted, and the graphics on, just needs a coat of varnish now!
Ian
boatmadman
« Reply #20 on: February 28, 2007, 08:47:09 PM »
Evening all,
Spent a couple of days just trying to sort little things out like the hatch opening, the wheelhouse rear and identifying what I need to order.
Anyway, here we have Jeannie with her deck linings cut and laid loosely in place. I have to wait for some hardware to arrive before glueing these down.
I have made an 'executive decision' on this build.
I have realised that the boat, and the steam plant are best treated as 2 separate projects, hence. I will initially power the boat with an electric motor, and then when its finished - if they ever are - convert to steam when the steam plant is right.
I ran the engine last week, - it leaks !  and so needs more work.
Anyway, here are a couple of pics
ian
boatmadman
« Reply #21 on: March 12, 2007, 01:24:45 PM »
I have a leak on the mating face between one cylinder and the standard. I am hoping it will improve with running in, as when I stripped it down I could see an area where there had been no face/face contact.
Here's hoping anyway!
ian
boatmadman
« Reply #22 on: March 19, 2007, 09:40:44 PM »
Here is the latest. I bought an electronize kit, built it up and woo hoo it works!  ;D
Glued down the deck lining and made up the electrics control board - still to fit some charging sockets yet though. The idea is to be able to charge the battery without having to remove it from the boat.
Ian
PS. Prop by Sitek props, its real nice!
boatmadman
« Reply #23 on: April 09, 2007, 08:30:44 PM »
Have been able to make a start on the deck planking this weekend while all the tourists are spending 4 days in their cars!
 ;D
boatmadman
« Reply #24 on: April 21, 2007, 08:10:47 PM »
Thats the decking done and rubbed down, just needs a seal coat next.
Ian
boatmadman
« Reply #25 on: April 25, 2007, 05:27:09 PM »
Had a good few hours at it, here is what to show for it:
I made a former for the funnel and rolled 1/64 ply onto it, help together with masking tape until it dried, (swimbo thought it was a toilet roll!!)
Took ages to work out how to do the chain steering, but it works great, thanks to bogstandard for his diag of the pulleys.
Made the mast foot from brass sheet, and thats all for now folks!
Ian
« Last Edit: April 25, 2007, 05:30:54 PM by boatmadman »
boatmadman
« Reply #26 on: May 01, 2007, 08:31:28 PM »
And here we have the fruits of today's labour - some panelling on the superstructure, and the frame tops in place.
(timberheads I think they are called?)
Ian
boatmadman
« Reply #27 on: May 03, 2007, 04:48:21 PM »
Thats great Davie thanks.
Just have to work out how to get that grained effect now, bet the better half knows!
Had a quick look at the new pics earlier, some great pics there.
Any help on deck layout would be greatly appreciated.
Ian
« Last Edit: May 03, 2007, 04:50:49 PM by boatmadman »
boatmadman
« Reply #28 on: May 29, 2007, 06:49:15 PM »
Davie,
Thanks for that, I bought a capstan just like that from scoonie a couple months ago - along wih some other bits and bobs.
Ian
boatmadman
« Reply #29 on: May 29, 2007, 08:24:30 PM »
Davie,
Thanks for that. I have got the steering yoke above deck with chains to a servo which will be under the rear accomodation. They will operate the steering. See pic further up this page.
I had a lucky guess there, I have made a steering column and wheel and run the chains vertically down through the deck of the wheelhouse  ;D
I also now have pipes available to fit along the bottom of the superstructure when its painted, i just need to cap off the forward ends where they turn into the wheelhouse.
Ian
boatmadman
« Reply #30 on: June 06, 2007, 04:00:49 PM »
At last got to doing some more on the drifter.
Here we have pics of some of the mast and boom fittings - awaiting paint.
Also, I have been experiimenting on some test peices to work out how to get a wood grained effect - I think its acceptable, Comments anyone?
Ian
DavieTait
    • Trawlerphotos
« Reply #31 on: June 06, 2007, 04:10:50 PM »
The grain effect is spot on Ian just the same as the boats get done now and would have looked 80 years ago !!
Davie Tait,
Scotland
Site Admin www.trawlerphotos.co.uk
boatmadman
« Reply #32 on: June 12, 2007, 09:40:49 PM »
I have been doing some more small stuff tonight, made the nav lights and backing boards.
I have also roughed out hinges for the doors and engine case vents, here they are lined up ready for a dip in citric acid!
Ian
boatmadman
« Reply #33 on: June 27, 2007, 10:51:34 AM »
Ok, back from holiday and now thinking about lighting again.
Not being the star gazing variety of ancient mariner I need help!
I have the port and starboard lights figured out - easy even for me, an all round white at the front and a 180deg astern.
Now, I guess these are running lights, the question is, what standing lights should she carry? I have 2 deck lights on the way, but I dont know about other lighting.
I am hoping to switch standing lights on and off through a switcher linked to throttle.
Ian
boatmadman
« Reply #34 on: June 27, 2007, 09:50:55 PM »
Back again,
Well, I spent the day today making a new mast foot, much better than the first effort I think. Then I started chucking some paint around. I used Tamiya masking tape for the first time today - now that IS the dog's conkers!
Ian
