First of all I have to say that I have only really played around with what I call large series motors although I have owned several small series ones and bench run them. I also have more literature on the small than the large but there are big gaps in what I have. I am relatively sure that I am correct about the large series starting with the Marine, I have a copy of Modelmaker add for Veron (Model Aircraft Bornemouth Ltd) which shows Comet and Marine motors and the Marine is listed as "6v 2& 1/2 amps consumption" so I assumed it was 6volt only. Unfortunately it is not dated. All other literature for the large series motors lists the Supermarine, Supermarine Special and Double Special as "6 to 12v Motors". I have never had a motor with blue windings Roy (and I thought it was a small series one you had) so cannot be sure of any differences but Model Maker tests I have test the Star and the Comet series on 4 to 6v and the Torpedo , Meteor, Target and Asteroid on 4 to 12 volts and measured their efficiency. I have a test of the Double Special in Model Maker from Nov 1960 which says " The Taycol Supermarine has been developed extensively from the original 6 volt Marine first reported in these pages in June 1955." The test raves about the torque available on 12v and says that it is capable of shearing couplings. Also suggests running it at 4,000 to 5,000revs loaded as the current draw at maximum torque was 6 amps but rose alarmingly when the motor was loaded to 2,800 rpm. Maximum efficiency was at 6500rpm. In this and other tests and in the makers brochure they actually reccomend lightly oiling the brushes to stop arcing! An earlier add for the Supermarine Special talks about the advantage of the new three terminal connection meaning the motor can easily be reversed by single pole change over switch or a relay. The test talks about separate field coil windings for reverse, wound as pairs with the forward coils but of higher resistance and not meant for continuous running. The original literature also mentions this feature in the smaller series motors and says that the "Meteor and Asteroid have the same power and efficiency as the Torpedo and Target series but the simplified switching arrangement makes them especially suitable for radio control". I do not have the facility to scan these and anyway most are only poor photocopies but if anybody wants copies PM me with an address and I will send them snail mail. Cheers, Ian.
