Hi all,
I am so intrigued by the Maudsley reversing gear. Both the Cheddar Gemini and MHB engines look very nice indeed. Trying to get to grips with the mechanism. Can see that the gearing ratio is simply 1:1 and how the timing would work in one direction. I am I right in assuming that it is the length of "throw" of the gear train that sets the eccentric shaft to the reverse position. Trying to get by mind round it, and to understand what is the difference in degrees of the eccentric shaft between that of forward and reverse? Can also see that the valves need to be on the side that would lead to squat engine.
Malcolm, you say you built one; Can I ask to what design, are they any drawings?
