Model Boat Mayhem - Forum
Author Topic: Need plan for a steam boiler feed pump  (Read 2331 times)
kno3
« on: March 17, 2010, 05:08:34 PM »
Hello,
I'm looking for a plan to build a steam driven boiler feed pump. Should be something simple and reliable if possible.
Also interested in just the relationship between steam cylinder bore and stroke and pump piston bore and stroke, the rest I can hopefully figure out.
MOG8
Re: Need plan for a steam boiler feed pump
« Reply #1 on: May 12, 2010, 05:29:07 PM »
I have just bought this kit (materials and drawing) . The ram is 6 mm. dia.
I will let you know when it arrives.
Cheers.
MOG8
« Reply #2 on: May 12, 2010, 05:42:05 PM »
This is the pump;
kno3
« Reply #3 on: May 12, 2010, 07:27:35 PM »
Thanks! That's a nice looking pump, but quite big for my engines, I believe. Perhaps i could scale it down to a more suitable size?
oldiron
« Reply #4 on: May 12, 2010, 07:35:10 PM »
Hello,
  On a boiler feed pump, the steam side should have a larger diameter than the water side if you are using the fed boiler to provide steam to the pump.
kno3
« Reply #5 on: May 12, 2010, 07:50:56 PM »
Indeed, but how much bigger exactly?
oldiron
« Reply #6 on: May 12, 2010, 08:03:54 PM »
 10% should do it.
benjaml1
« Reply #7 on: May 12, 2010, 08:19:50 PM »
I would guess that the choice between mechanical & steam driven boiler feedwater pumps would be dependant on the amount of discretionary steam & cash you have....
Bernhard
« Reply #8 on: May 13, 2010, 06:41:24 AM »
hi...maby you can get a ide from This??
With this small we have developed powerful steam-driven feedwater pump steam with a small amount of steam from the boiler can be diverted during the operation of water from a reservoir to be pumped into the boiler.
Specifications:
Length: 70 mm
Width: 0 mm
Height: 20 mm
Weight: 55 g
Power:
30 ml / min at 0.5 bar operating pressure
50 ml / min at 1.5 bar operating pressure
Against boiler pressure to 3 bar
Initial height to 1500 mm at 1.5 bar operating pressure
Horizontal or vertical mounting
Materials Inc., brass, copper, nickel silver
Steam engine
Self start 2 cylinder, double acting
Continuously variable speed, stop
Steam oiler upstream
Piston Ø 7 mm
Hub 7 mm
Pump:
Piston Ø 3 mm
Hub 8 mm
Driven by gears
Ball check valve is required!
Bernhard
« Reply #9 on: May 13, 2010, 07:24:58 AM »
Hi..or a eletric pump from Regner  http://cgi.ebay.de/Regner-20220-RC-Speisepumpe-Neuware-/270523446323?cmd=ViewItem&pt=DE_Modellbau_Modelleisenbahnen&hash=item3efc743433
here is a steam feed pump from Regner,
http://www.youtube.com/watch?v=OxTzQhD6PlQ&feature=related
« Last Edit: May 13, 2010, 07:31:09 AM by Bernhard »
benjaml1
« Reply #10 on: May 13, 2010, 10:44:10 AM »
Pollymodelengineering weir pump .....
