Gentlemen, your opinion is sought....
I have been starting to test-run my little EeZeBilt Terrier
http://modelboats.hobby-site.com/Terrierbuild4.html This is a boat running on several technical limits. It is light - 140gm + 48gm for the batteries, which are 4 AAA NiMH. I don't want to get it much heavier. There is a total space of around 9 cu in for all the works - batteries, motor, receiver, ESC (with a built-in BEC) and servo, so there is not much more room for anything. It is cheap - total cost is around £5 (the biggest single cost is the on-off switch), and I don't want to spend much more.
The motor is specced at 1.5-3v though it can take 6v for short periods. At 4.8v the boat (unsurprisingly) has a sparkling performance, and could do with cooling. Unfortunately, the TurBORIX ESC is specced at 7.2-12v, and has a motor cut-off nominally at 5-6v, so that an aircraft can still retain radio control after the motor dies. I dealt with this by changing the 'arming button' which sets the ESC going to a switch. So, if the power drops below the cut-off point the system is automatically re-armed.
The system runs no-load on the bench fine at 4.8v. On trying it in the water, the motor runs fine up to half-power, but when you go up to full the ESC cuts and resets constantly, producing a very jerky motion. Oddly, if you run it for a while, you can creep up to 3/4 power before the jerks begin. Still fast, and the motor is just too hot to touch after a long run. So the voltage under load is dropping just a little too much for the delicate balance I thought I had....
What do I change? The propeller is an obvious candidate - it costs me nothing but time to have a selection of them -
http://modelboats.hobby-site.com/propmake.html refers. 2-bladed would be a good idea? But what shape and area should the blades be?
And is there any way of feeding more voltage to the ESC but keeping the motor voltage low? I could probably fit another AAA cell in if necessary. Is there a clever little voltage regulator I could fit on the motor line? But ideally I don't want to add weight and complexity....
If I have to give the motor more juice, can I cool it better? Has anyone ever tried watercooling through 1-2mm tubes...? Without adding weight....?
Could the batteries be improved? They are Lidl's best at £2.79 for 4, and only 800mAh. Would some of the more expensive brands keep a bit more power flowing?
Can I do anything about the ESC cut-out? Dropping it to 4.5v would solve everything. I'm unlikely to be able to buy a different better-specced one at a similar price (£1.97!)...
This is a good example of the limit issues you face in R/Cing the original EeZeBilt kits, and a major reason why I went for the slightly bigger 50+ range. But it's also fun to address the problem and find the optimum solution inside the constraints of the original design....
