Yes please go into details.
At 1,5 kg the steam plant is a reasonable weight. Just for comparison, I consider Cheddar plants heavy.
For the next plant I'm assembling my target is to stay under 1,5 kg if possible.
DETAILS.
This boiler is very light because instead of using a 3 mm. copper barrel a nickel silver steel plate (
0,0028" thick) is wrapped around the endplates and silver soldered to the endplates and vertically along the two edges, slightly chamfered, which overlap slightly.
This is the cross section of this boiler. It may not be as efficient as a vertical multi-tubular, but it is very light indeed.
Sketch by Brian Marten.
