Try Action
'TWIN FLICKER' two independant random flickering outputs adjustment of effect/rate P90) - PCB kit with case
This is a microcomputer driven flasher to run two alternate flash operations, either alternate double flash or alternate single flash. This single project will simulate OIL LAMPS,CANDLES, OPEN FIRES, & ARC WELDERS. Ideal for lighting on old steam boats. Each output has the current capability to control any type of bulb or LED up to 200mA provided they are of a suitable voltage for the supply volts you are using (three GOW BULBS) Tiny cased unit with input and output screw connectors. OK for 6 to 12 Volt operation. Screwed case size - 40mm x 27mm x 17mm. Full PCB kit less wire. SCREWDRIVER CONNECTION.
