Is there a particular reason you want this controller?
Or would any forwards/revese 12volt 100Amp controller do?
Model F112R56 - Technical Information
* High power MOS-FETs with aluminium heat-sinks for maximum power transfer and efficient cooling.
* High Speed, Forward and Reverse indicators for optimum adjustment.
* Neutral and High Speed adjustments allowing the use of a variety of R/C systems.
* Fuse protected output providing MOS-FETs protection.
* Thermal overload circuitry.
* ON-OFF switch.
* Includes KYOSHO or TAMIYA battery connector.
* Eliminates the need for a separate throttle control and mechanical speed controller.
* Universal servo connector fits JR, FUTABA and HI_TECH with no modifications
(and will also work with SANWA/AIRTRONICS, KO, MULTIPLEX etc. with different connectors).
Continuous Current 112A
Peak Current 440A
RDS 0.014 Ohms
Operation F (4 pcs.) B/R (2 pcs.)
Main Control VR Adjustment
Frequency 50Hz
Power Supply 5.0V/0.8A
Input Voltage 5~10 Cells (6.0V~12.0V)
Dimensions 32 x 48 x 28mm
Weight 70g
