Good evening!
Yesterday, the weather was good but suposed to change ( not so fast though) , so I decided to go and sail my old CANELLE before it is too bad!
Let me tell you about this yacht. She was built in 1925 in Munro Shipbuilding Co / Scotland. 27 M long Originally under steam , the new owner switched to diesel in 19?? and witdrawed the furnace. I kept the steam version of the boat.I do not know the full history, but I think she belonged to a Norwegian in first place.
Sailing away.
Let see inside: Saïto, Anton boiler and safety equipement + Regner Gas tank.
I'll pull out the engine as the boiler is too small capacity for it.And I am looking for a 3 to 5 cc max to move her. My Canelle is 1250cm long and weights about 8Kg.
A view of the rear deck. I need Bernhard to find me a nice blond to install in the rocking chair:
Back to the shore to bleed of the pressure. Some drops and dark clouds showing up!
Oops!
1x prop. 55mm and 1x prop. 50mm. But dont worry, I have two 55mm Raboesh on order. They rotate the same direction as I did not have enough gears to do a proper gear box.
Now, comes the rain and heavy: believe me!
Hope you enjoyed!
