Thanks for your comments guys.
cos918: As Triumphjon suggests, both ends bolt together. It's a simple arrangement, both bulkheads are flush; with the forward section bulkhead housing three captive bolts. The aft section has three facilitating holes and when both ends are married-up they are secured with rubber washers, backing steel washers and wingnuts. This arrangement has proved 100% watertight in the past but only if the rubber washers are carefully put in place. The only water ingress is sometimes by way of prolonged periods of going astern, where small quantities of water can be pushed back up the propeller tubes. Critical point is when the model is lowered into the water with all of the ballast in situ. There are stresses to both bulkheads and the whole model tends to sag just a little at the join! I may in future lower the model into the water minus the ballast just to relieve the stresses on both model and owner!
Steve, I take your point about weathering on ships. This is something that manifests itself moreso on commercial shipping than warships (although the iconic image of HMS HERMES returning from the South Atlantic in 1982 would tend to belie this statement). There's more bullsh*t on RN ships than commercial ones, after all, in commerce, time is money. Weathering to the modeller is also a preference and some poor attempts at weathering would have been better left alone. Conversely, I have seen some brilliant examples where the weathering has been subtly applied and usage has enhanced the effect. One example is unbuiltnautilus's ORCA. Outstanding. I must go along with Triumphjon's idea for the time being as far as RODNEY is concerned. The salt water content of where we sail, combined with regular usage, may soon provide some natural weathering. If not, I will take lessons from some of the guys and 'slap some rust on' as has been suggested earlier in the thread. And weathering was an important feature during wartime operations, especially amongst the hard worked escorts, Destroyers, Corvettes and Armed trawlers. By comparison, capital ships, such as RODNEY, spent a lot of time alongside the wall. But Steve, I am flattered to think that my refit has been discussed in the local pub!
Next time mate, it's my round! Thank you very much for your kind comment and Seasons Greetings to you and yours.
