Pages: 1 [2] 3 4 5   Go Down
Author Topic: Canadian Corvette K338  (Read 142083 times)
ggeorge
Re: Canadian Corvette K338
« Reply #25 on: February 09, 2012, 08:21:49 pm »
k338
oldflyer2
« Reply #26 on: February 09, 2012, 11:49:30 pm »
Looking Good Gerry!
You have been busy!
Cheers,
Tom
rem2007
« Reply #27 on: February 10, 2012, 03:17:15 am »
those U-boats must be shaking in their tubes now {-)
« Reply #28 on: February 10, 2012, 04:52:03 am »
Hi Gerry - I am following the plating & the posting string with interest...... O0
1.........0.010" styrene sheet plates....what glue did you use to provide a water proof bond to the wooden & semi filled planked hull?
2.........what is the purpose of the thin green tape strip on the hull?
ggeorge
« Reply #29 on: February 10, 2012, 05:22:35 pm »
Hi Derek,
  The hull was covered with fiberglass before I added the styrene. The styrene plate was sanded with 150 grit paper and ca thick was spread over this sanded area and then the styrene plate was placed in the correct location. I have used this method in the past and has worked well for me. I have never had any problem with water with this method. The green tape is just used to scribe a strait line on the location of the plating. I take points off the drawings and mark these points on the hull and then I use the tape to join these points and scribe a pencil line along the tale which now will give me the plating location along the hull.
ggeorge
« Reply #30 on: February 11, 2012, 02:02:15 pm »
Here are a few photos of the anchor windlass. It is a typical steam operated and built by Clark Chapman Ltd.
ggeorge
« Reply #31 on: February 12, 2012, 08:28:07 pm »
 Here are some photos of the finished anchor windlass, all 168 parts . I am now starting on the 4 in. gun. The Landsay had a
4 in. QF Mk XIX in a CP Mk XXIII mounting.
ggeorge
« Reply #32 on: February 12, 2012, 08:29:28 pm »
k338
pugwash
« Reply #33 on: February 12, 2012, 11:36:13 pm »
George, glad to see you back on the shipbuilding trail again its been a long time since the Tid Tug.
Geoff
ggeorge
« Reply #34 on: February 14, 2012, 06:52:35 pm »
 Here are photos of the start of the build of the MK XIX GUN MOUNT.
rem2007
« Reply #35 on: February 14, 2012, 10:21:16 pm »
youve been busy...mind you don t go out on the lake yet :-))
tt1
« Reply #36 on: February 15, 2012, 12:20:57 am »
Beautiful precision engineering, you are without doubt a top notch craftsmen George and am in genuine awe of your skills - your models ain't bad either  {-) {-) {-
                     Kind regards, Tony. :-))
barryfoote
« Reply #37 on: February 15, 2012, 07:07:41 am »
Beautiful work as usual... :-))
Timmer
« Reply #38 on: February 16, 2012, 10:00:18 pm »
looks like its going to be a great build. keep it up :-))
ggeorge
« Reply #39 on: February 18, 2012, 02:47:25 am »
Hi Again,
  Here are a few more photos of the 4in gun as the build progresses and also my helper.
« Reply #40 on: February 18, 2012, 02:56:12 am »
He doesn't seem impressed with something George....
ggeorge
« Reply #41 on: February 18, 2012, 02:57:35 am »
k338
ggeorge
« Reply #42 on: February 18, 2012, 03:02:16 am »
Hi Martin,
 The reason he did not seem impressed is that he wants to clime on the boat and I keep putting him down.
ggeorge
« Reply #43 on: February 22, 2012, 01:21:25 am »
The build plods along.
oldiron
« Reply #44 on: February 22, 2012, 03:04:20 am »
Lookin good. You should show the guys the tool you used to rifle the barrel with.   :-))
John.
pugwash
« Reply #45 on: February 22, 2012, 05:17:19 am »
Looks as if you could ram a shell up the breech and fire it. Very realistic Gerry/george?
Geoff
tt1
« Reply #46 on: February 22, 2012, 11:28:45 am »
Astounding skills, totally amazed at this Gerry.
        Tony.
rem2007
« Reply #47 on: February 22, 2012, 12:43:36 pm »
...do they know that cat is a trained tool and die worker {-), better not let him trip off the Hedgehog, would play havoc with his fur.
tt1
« Reply #48 on: February 22, 2012, 01:19:10 pm »
Hi rem, but what a clever pussy with such creative skills! - there's no way I could decipher or understand the drawings in post No. 30 let alone make the bits! one intellectual moggy with the patience of Job me thinks.
          Tony.  O0  :-))
oldflyer2
« Reply #49 on: February 22, 2012, 01:56:41 pm »
Yup, the secret is out Gerry ... now we know who REALLY does all that work in your shop O0
Cheers,
Tom
Pages: 1 [2] 3 4 5   Go Up
Page created in 0.114 seconds with 21 queries.
