Pages: 1 2 3 4 5 6 7 8 9 [10]   Go Down
Author Topic: Oldiron's Airbrush Tutorial  (Read 202911 times)
tt1
Re: Oldiron's Airbrush Tutorial
« Reply #225 on: March 27, 2013, 01:56:46 pm »
Hello folks, having asked your advice a while back John, I also bought the Badger 200 - the one in the first picture you've posted. I'm well pleased with it O0 :-))
The only thing I can say Oldshrimper is that getting the right paint and viscosity is so important, I've had all the problems you've experienced and more, the difference in using quality paint with very fine pigment for airbrushing is amazing.  A friend put me on to this paint, not cheap but a good size bottle, limited in colour range but I tried it in desperation. A quick shake, into the paint pot & spray - absolutely amazing results!! no clinical settings neede on the brush.  gave me the heart to carry on
http://www.specialistpaints.com/products/inspire-airbrush-base  Regards, Tony.
Captbearuk
« Reply #226 on: March 27, 2013, 02:02:54 pm »
John,
Thanks again for the quick reply.
I initially did my search on Ebay and found these;
Badger 200-3 http://www.ebay.co.uk/itm/BADGER-AIR-BRUSH-PRECISION-SPRAY-SET-MODEL-200-3-/290876047249
Badger 200-5 http://www.ebay.co.uk/itm/BADGER-MODEL-200-5-AIRBRUSH-KIT-BRAND-NEW-IN-BOX-/261181665051
Badger 200-20 http://www.ebay.co.uk/itm/BADGER-MODEL-200-20-DETAIL-SINGLE-ACTION-AIRBRUSH-/380568706856
I then went to the Badger website and found the information you've shown. All appear to be single action pick up airbrushes, but I now think that the 3 and 5 variation may relate to airbrushes supplied in different type of kits with more or less equipment supplied. The 200-20 is as you've stated a 'detail' airbrush. I'm prepared to pay the little extra and go for the 'detail' airbrush 200-20 and practice 'weathering' if, it's suitable for spraying the hull and larger areas of the model.
Glyn
Captbearuk
« Reply #227 on: March 27, 2013, 02:06:49 pm »
Tony,
Took a quick look at Specialist Paints and it's a site I've bookmarked for later. They do have metalflakes paints and for a brief moment I thought of 'Pimping my Tug'........but it was only for a moment. :embarrassed:
Glyn
oldiron
« Reply #228 on: March 27, 2013, 03:08:00 pm »
Tony
 You're quite right about the fine pigment paint these brushes are designed for. Most model paints are of the fine pigment variety. I don't know if you can get them over there, but here are some I use that are specifically designed for model use:
http://www.testors.com/category/135232/Model_Master
http://www.weavermodels.com/page7.html
http://www.testors.com/category/133504/Floquil
tt1
« Reply #229 on: March 27, 2013, 04:29:52 pm »
Hi Glyn, the brush I purchased was the 200-5, gives a good spray diameter for larger assemblies but also sprays amazingly fine, both  lines and into corners. Ideal I think for the newcomer and expert alike.
Captbearuk
« Reply #230 on: March 27, 2013, 07:59:25 pm »
Tony,
Then the 200-5 it shall be. Thanks for writing down your experiences; it all helps us new-guys.
Glyn
tt1
« Reply #231 on: March 28, 2013, 02:32:22 am »
Hi Glyn, John (Oldiron) is the man to thank really, I found his tutorial a boon and gladly I took his recommendation for the brush.
                                     Don't give up! it does take as they say...............practice, practice, and practice.
       Rather than wait till I have something that needs painting,  I'll put time aside to do nothing else than have a play airbrushing. I prime up a few sheets of card with grey and white primer, I stick all sorts of scrap off cuts together any old how to form all manner of shapes, including corner and box type shapes, I prime these up and then just have a play!  different paints, thinners, colours, varying viscosity, air pressure etc. etc. and try to enjoy rather than endure.  I sometimes wish though that my model bits came out as good as the scrap! O0 {-) {-)  Regards, Tony.
old shrimper
« Reply #232 on: March 28, 2013, 04:45:23 am »
well i think i have sorted out my problem
the NIB on my brush was not all the way home ( hard up on the O ring ? and was tight in the thread ) fixed that up and now it sprays like a bought one
probably[size=78%] a good idea to strip the brush and [/size]resemble[size=78%] it before you use it, just watch for the little trigger [/size]rocker[size=78%] [/size]thingy[size=78%] falling out  A %$#@#$% to get back in [/size]
lesson learnt
cheers Bob
50 YEARS OF TOWING NETS
oldiron
« Reply #233 on: March 28, 2013, 10:21:52 am »
probably[size=78%] a good idea to strip the brush and [/size]resemble[size=78%] it before you use it, just watch for the little trigger [/size]rockerthingy[size=78%] falling out  A %$#@#$% to get back in [/size]
lesson learnt
cheers Bob
 Good to hear you got it sorted. let's see some of your paint jobs on here.
old shrimper
« Reply #234 on: March 29, 2013, 08:50:44 pm »
might have to practice a bit more  lol
i tried table salt sprinkled over the wet paint and then wash it off after its dried then a another coat of paint over the top
come up not to bad for the nonskid look
would be more to scale  if it was finer
might try icing sugar next
« Reply #235 on: May 05, 2013, 03:59:53 pm »
Mods.... can this be made sticky?
RAAArtyGunner
« Reply #236 on: May 05, 2013, 09:32:43 pm »
I always thought, paint was sticky enough, without the mods making it worse. O0 O0 {-) {-)
« Reply #237 on: March 02, 2018, 10:53:02 am »
Not sure where to put this.... so lets put it here!
Peter Fitness
« Reply #238 on: March 02, 2018, 09:41:18 pm »
Very interesting Martin :-))
Peter.
RAAArtyGunner
« Reply #239 on: March 03, 2018, 03:24:35 am »
Martin,
Good find O0 O0
As he says simple and cheap, meaning it becomes inexpensive to practice spray painting as you are not wasting expensive thinners.
Captain fizz
« Reply #240 on: March 05, 2018, 03:59:00 pm »
Useful tutorial but i was losing the will to live with all the repetition.
Brian60
« Reply #241 on: March 05, 2018, 06:35:50 pm »
I've used IPA as a diluent in acrylic paint for about 2 years, better than water, cheaper than the paint manufacturers own diluents.
Captain fizz
« Reply #242 on: March 05, 2018, 10:42:01 pm »
Do you just add it neat Brian.
« Reply #243 on: July 16, 2020, 05:04:41 pm »
I've found my old Paasche / Badger external mix airbrush ( 'airbrush', I use that term loosely! ), is there a simple female to female hose adapter anywhere?
( Paasche to 1/8" ) -  I would have thought that was the first adapter available everywhere?
Mark T
« Reply #244 on: July 16, 2020, 07:16:36 pm »
Hi Martin try these people I have always found them to be great  :-))
https://www.everythingairbrush.com/?gclid=EAIaIQobChMIqcT04q_S6gIVW-ztCh2sQAYdEAAYASAAEgJuWfD_BwE
RST
« Reply #245 on: July 16, 2020, 07:40:51 pm »
Hi Martin, probably easier for me to say as I am kind of in the business but if it's 1/8" BSP you should be able to get it from any of your local industrial counters for a quid or so for an s304 one.  Sometimes if it's something very small like that at my local one they just turn their backs and say "see you next time" while you say "thanks" and grab it off the counter if you know what I mean.  Worth a try.
Big Ada
« Reply #246 on: July 18, 2020, 06:12:36 pm »
Great Tips are always welcome. :-))
« Reply #247 on: July 18, 2020, 07:05:55 pm »
NB: I've gone for this type ( external mix ) as:
a. I'm not very good at airbrushing,
b. I'm only priming and top coating, no detail stuff,
c. I found it on the back of a shelf,
d, Mainly the clean up is minimal !
( Minimal ... not  Manimal - that was a idiot TV program from the 80's!  Look it up, it was Terrible  {-)
Mark T
« Reply #248 on: July 18, 2020, 07:10:02 pm »
Thats a good brush for what you need - suction feed that holds loads of paint and if you angle the brush the paint won't spill out either.  The most critical thing will be the viscosity of the paint.  Just thin it until its like milk and you can't go wrong.
« Reply #249 on: November 01, 2020, 09:13:03 pm »
Found this, for further reading:
 Airbrush for Beginners Right Now [Airbrush Buying Guide 2020]
 http://www.airbrushgeek.com/best-airbrush-for-beginners/?fbclid=IwAR0EK359DV4FTNOuwXGu6YFQeL508YkxjRUa-TaeUsvP5duCg567Oiw2FcA
Pages: 1 2 3 4 5 6 7 8 9 [10]   Go Up
Page created in 0.101 seconds with 21 queries.
