Model Boat Mayhem - Forum
Author Topic: Build the Bismarck - a "Hachett" job?  (Read 210472 times)
rem2007
Re: Build the Bismarck - a "Hachett" job?
« Reply #1050 on: December 02, 2008, 09:08:03 PM »
very nice Noel, you should be re-directed shortly :-))nudge , nudge Martin
Mc Fly
« Reply #1051 on: December 09, 2008, 08:32:06 PM »
hi mens,
i find the topic for presentations....
I'm a french ship modeler, i've begining the bismarck few mounth ago :D i've mounted 4 ship kits...
and i have a problem with this resin part :
I don't have the big one !
jock
  • It ain't a hobby if you have to Hurry
« Reply #1052 on: December 11, 2008, 04:24:55 AM »
I've got both parts but they got mixed up so I.m not sure which is the correct one.
Jock
« Reply #1053 on: December 11, 2008, 09:35:20 AM »
Me too!  :embarrassed:
If I remember correctly you're going to need the larger of the two stern resin pieces. The smaller one and the filler wood piece leave the anchor recess in the wrong spot.
Have fun. O0
« Last Edit: December 11, 2008, 09:36:51 AM by Martin - Forum Admin »
"This is my firm opinion, but what do I know?!"   -  http://www.modelboatmayhem.co.uk/
Mc Fly
« Reply #1054 on: December 11, 2008, 11:51:05 AM »
i need the big one :D, the smallest is good, but, not when i glu the second plaking :D %%
Mc Fly
« Reply #1055 on: December 12, 2008, 09:10:52 PM »
with witch book come the big one?
cbr900
  • Mayhem is the Only Forum!
    • Roys Hompage
« Reply #1057 on: December 13, 2008, 11:49:17 AM »
Martin,
You must be about ready for the next installment in your build............. :-)) :-))
Roy
PS It's been a while.....................
« Reply #1058 on: December 13, 2008, 04:08:06 PM »
As soon as my shoulder stops hurting me... bad day today.  <:(
Mc Fly
« Reply #1059 on: December 19, 2008, 06:09:32 AM »
a french team of hachet have send me a mail and say:
Hello,
Ah! The (net).....
The piece of bow supplied with France is everything made correct. She corresponds in thickness to both line.
Good construction.
can you please give me all dimentions of the good part ?
berth44
« Reply #1060 on: January 15, 2009, 12:14:33 AM »
G'day everybody, well back safe and sound from Scotland,( just have to get over the 'jet lag' that I've had for nearly 24 Years!!!) It was a fun trip, but I missed my 'build it'. (nothing much else, I'm afraid to say!)
Now that I'm back I've been slow to get into it, 12 issues were waiting on me..64-75. I'm working my way slowly through them, bit HOT here in Aussieland, not very pleasant working conditions at all, so when there is a 'COOL' spell, I'm in the garage getting on with it!!! I'm finishing off the aft Control station, just generally putting the parts together until I decide to paint them, then I'll start securing the brass parts to the wooden structures. I'm glazing the 'portholes/windows', so all the parts that have these have to be painted before the glazing is fixed in place from behind.
I hope everone has got their little problems solved like mr McFly and his resin parts! The bottom part is the so called second part with the revised anchor pocket, but technically, it's not correct either, well let's put it this way, the way the pocket sits is correct if you were not gluing the part 'under' the aft deck section. The resin part would have to fit directly to the stern with the top forming the deck part, but it would then have to be cut in half, disected through it's middle to fit, way too much bother!!...Dave..(more later)
berth44
« Reply #1061 on: January 15, 2009, 03:45:32 AM »
I'ts later, the aft anchor. If you gets yourself a good photo of the stern you can see that even the new 'pocket' is'nt quite in the correct position. I'ts should be almost at deck level and it's relation to the aft portholes is wrong.
What I did was, as I still had the old resin part, I thought (??) "maybe" if I could 'cut out' the anchor pocket from that, then 'transplant' it to a more 'correct' position on the 'new' bit, "hmmm??" (that part IS fitted by the way, this was an after thought!)
So I got 'cutting' and by accident I found that my soldering iron went through it like butter, much easier! I successfully cut the thing out and filed and sanded it to shape. Once satisfied she was right I placed a small bit of paper over it and did a 'pencil rubbing', this gave me the true shape, that was cut out and I placed it over the the 'in situ' anchor pocket and when the placement was right with the deck and portholes it was marked with a 'fine art pen' and then all that was needed was to cut, gouge, drill out a hole, bung in some filler (I use Tamiya 'grey' plastic putty) and place the 'new new' pocket in it until satisfied the position is correct. Slight pressure was applied and the excess filler oozes out, this is smoothed out and allowed to set.
More filler is used if necessary, then a wee of bit of carefull sanding with fine paper(I dripped a couple of light blobs of superglue round the edge before sanding)  until it was 'as one'. The end result speaks for itself with a more realistically placed anchor, and all it cost was time and effort!
(I'm not very good on computers and have big problems posting photos, so if anybody wants to see the end result go to the Google web page "Titanic Titanic..Build the Bismarck site, page 14, my friend posted them for me!).......Dave
« Reply #1062 on: January 15, 2009, 05:46:26 AM »
Mat_B
« Reply #1063 on: January 15, 2009, 06:24:40 PM »
hi :}
realy want to build this now after seeing everyones pics, but cant get the isues.
has anyone taken photo copys of frames etc that they could e-mail to me?
MAt %%
thank :-))
berth44
« Reply #1065 on: January 19, 2009, 03:16:32 AM »
Hello Martin,thanks for looking!!, that's one lot,(Mark UK's site) the first 24 are of mine in the 'early build it' stages of the hull. The 'other' lot are (gave you a bum steer!!)'Google.... 'build the bismarck' then find the header beginning "Titanic Titanic" (It's usually on the first page) Go into the site and click on page 14, all the gaff under the header 'berth44' (again) is mine, it's not hard to find as it's  mostly me!!!.......Dave.
mark_1984
« Reply #1066 on: January 26, 2009, 05:00:48 PM »
Nice to see that you've finally got the 2nd planking licked - would you like to finish mine for me now ;)
berth44
« Reply #1067 on: January 29, 2009, 11:17:35 PM »
Making slow progress,finally finished off the mast and now working through the brass bits. Only gluing the brass sides that don't have portholes or windows to the woodwork. Ones 'with' will be painted first, then glazed from behind, only then these will then be glued in place.
When fitting one of these brass sides into a 'recess', I found that the part seemed a wee bit big, it would require filing on the bottom (or top) to make it 'flush; with the wood," Hmmm??" I thought of this, if you lightly score/groove the recess along it's length with a blade,( or a sharp pointed tool, say a scriber, maybe even a dart!) where the brass fits into the 'roof' or an 'upper deck', this should 'allow' the brass to slip into 'the groove', therefore you should be able to 'flush fit' the brass without any filing!! It's worked for me on the two parts that I have completed!.
Lastly, a wee tip for the mast when completed, seeing it's 'very fragile', rather than laying it down somewhere or leaving it 'on the job', I made a wee 'stand' for it, small block of wood, 3mm hole, and for the bit that goes into the brass tube a wooden meat skewer did the job!! Took all of 2 minutes to do and now the mast is safe, erect, and out of the way until it is required!....just a couple ot things to ponder on....Dave.
« Reply #1068 on: January 29, 2009, 11:36:35 PM »
Hi Berth44,
"score/groove the recess along it's length"... interesting, do you have any pictures please?
berth44
« Reply #1069 on: January 30, 2009, 02:38:50 AM »
Hello Martin, in a word, no! I really should learn how to get photo's on line, never sort of been a computer person. I've got the digital camera and I did start off pretty keen and take pictures of the build, and I know that a picture can say a thousand words, so I really should learn Martin, but I've been shown before, and HAVE been successful, but, I just forget....I'm a "idiot"!!!
So, in the absence of a photo, try this, take a piece of a wooden fret, and with a steel rule as as a guide, run along it with a Knife/blade for a couple of inches, then take a brass part and work it into the cut/groove, if it does'nt fit, a sharp pointed tool as I've mentioned should do the trick! This should then give you an idea as to what I meant and be self explanitory as to how it translates to the job at hand!.....Dave.
« Reply #1070 on: January 30, 2009, 06:54:55 AM »
If you do have any photos, email them to me and I'll put them on here for you.  :-))
wowan999
« Reply #1071 on: January 30, 2009, 05:25:18 PM »
All greetings from Russia at us have appeared first number Bismarck I have decided to collect I understand you here the master it would be desirable to reach with your help the purpose
« Reply #1072 on: January 30, 2009, 05:38:28 PM »
Wowan999 Здравствуйте, добро пожаловать в Mayhem. Пожалуйста, не стесняйтесь, задавайте вопросы здесь.
Regards, Martin
Hello wowan999, Welcome to Mayhem. Please feel free to ask questions here.
Regards, Martin
Peterm
  • Inactive
« Reply #1073 on: January 30, 2009, 06:18:52 PM »
Is there no limit to this man`s talent?  Pete M
I`m not just old, I`m ancient
« Reply #1074 on: January 30, 2009, 06:59:10 PM »
« Reply #1075 on: January 30, 2009, 07:54:12 PM »
Ah but did you translate it back to english? You can get some interesting results  :-))
Doug
(trying to learn German - badly)
Andre ZS1AZ
« Reply #1076 on: February 01, 2009, 12:26:11 PM »
Hi Martin, I have been following your build with some interest.  In South Africa we are slightly behind magazine wise, but boy o boy, am I far behind building wise.  I think that Berth 44 can attest to that.  Hi to you as well Dave.  Thanks for the long post on 'our site'.  I will pop in here every now and then.  Still busy with the first lot of planking.  Cheers....Andre
« Reply #1077 on: February 02, 2009, 07:30:55 PM »
Via email to Mayhem...
 Hi,   Getting into all sorts of problems using the forum, and attaching a
 photo. As I said this is my 1st attempt at model building, when I saw the
 "Bismarck" I had to have a go, and here it is. Have got this far and have
 decided to insert Radio control, so hope that this will not cause a
 problem.
 Am going along as the instructions say, at times they don't make sense
 perhaps that me at 74 but really enjoying it. Have managed to get info
 from a Bismarck site Subifa but don't know any German, at least I can see what
 is coming next. Great site you have with plenty of reading
 Noel
berth44
« Reply #1078 on: February 02, 2009, 11:45:38 PM »
Hello Noel, model looks great, If I can find all me stuff and successfully put it together, she would look just like yours, without the red paint job!!. I'm not to clever getting the pictures on board either. Martin came up with a solution, so I may do as he says.....happy building Noel!....Dave.
P/S, be aware, be very aware of the  'South African' called 'Andre', bit of a scoundrel he is...."Shssss" don't say his name too loud or he might hear you!!...
PP/S, OK, let the truth be known, he's a great guy and has helped me out heaps by posting some photo's of my build on 'another site' that him and I....."own", well, we are the only two who 'post' stuff on it!!........
TCC
« Reply #1079 on: February 13, 2009, 11:28:44 PM »
I believe that when it was rediscovered they found that the stern had broken off so maybe the spelling is correct... :D
I suppose that if you missed one of the instalments, your model might end up the same way.
Make sure it is all there.
I bought a part works Titanic and the tops of the bulkheads were missing. ::)
I'm just waiting for the inevitable :D
Are they going to do a battlecruiser?  %)
« Reply #1080 on: February 14, 2009, 12:08:55 AM »
Will this one do? Nearly 10 metres long and built from Lego!
berth44
« Reply #1081 on: February 16, 2009, 04:25:54 AM »
Very clever Mr Bishop...how long did it take you to put that together???....Dave.
« Reply #1082 on: February 16, 2009, 11:46:20 AM »
You should see what all those little studs do to the compression ration on a JPEG file! I'd swear the camera got warm..... %)
berth44
« Reply #1083 on: February 19, 2009, 02:35:41 AM »
I'm at the painting stage, now, I'm NOT doing the 'stripey thing', plain 'ole grey, now which one??. I've opted for 'medium grey' and I have 'airbrushed'  all the brass bits  that I have completed so far, but I'm beginning to think that I should have used a 'light sea grey'instead. Can somebody put me right before I reach a point of no return...please???...Dave
LeoS
Coulors
« Reply #1084 on: February 19, 2009, 11:02:17 AM »
Berth
Here you'll find the RAL paint numbers.
http://www.bismarck-class.dk/paint_schemes/introduction.html
Leo
